AWE Core 8.D.12 Documentation
bare_metal_example.c
A bare-metal single instance integration that uses interrupts.
A bare-metal single instance integration that uses interrupts.This example can achieve 1 block of latency in the audio path if the loaded layout matches the AWEInstance's fundamental blocksize If the blocksizes are not equal, there will be 2 blocks of latency. This is due to the fact that this example uses signalling for the pumps, and awe_audioPump is NOT called inline with the audio callback. Examples
// Version Information
#define USER_VER 20190801
#define NUM_CORES 1
#define CORE_ID 0
#define CORE_SPEED 216e6f
#define SAMPLE_SPEED 216e6f
#define HAS_FLOAT_SUPPORT 1
#define HAS_FLASH_FILESYSTEM 1
#define HAS_GPIO 1
#define NO_INPUT_PINS 1
#define NO_OUTPUT_PINS 1
#define IS_SMP 0
#define NUM_AUDIO_THREADS 2
#define AUDIO_SAMPLE_RATE 48000.0f
#define AUDIO_BLOCK_SIZE 32
#define IS_COMPLEX 0
#define SAMPLE_SIZE_IN_BYTES 4
** Specify the size of each of the heaps on this target
#define MASTER_HEAP_SIZE (1024*31)
#define FASTB_HEAP_SIZE (1024*80)
#define SLOW_HEAP_SIZE (1024*2048)
** Specify communication buffer size
#define MAX_COMMAND_BUFFER_LEN 264
** Specify which modules to include on this target
#include "ModuleList.h"
AWEInstance g_AWEInstance;
static IOPinDescriptor s_InputPin = { 0 };
static IOPinDescriptor s_OutputPin = { 0 };
UINT32 g_MasterHeap[MASTER_HEAP_SIZE] @ ".DTCMRAM_Section";
UINT32 g_FastbHeap[FASTB_HEAP_SIZE];
__no_init UINT32 g_SlowHeap[SLOW_HEAP_SIZE] @ ".SDRAM_Section";
** Module table
const void * g_module_descriptor_table[] =
// List of modules from ModuleList.h
(void *)LISTOFCLASSOBJECTS
UINT32 g_module_descriptor_table_size = sizeof(g_module_descriptor_table) / sizeof(g_module_descriptor_table[0]);
// METHOD: AWEInstanceInit
// PURPOSE: Initialize AWE Instance with target details
void AWEInstanceInit()
memset(&g_AWEInstance, 0, sizeof(AWEInstance) );
g_AWEInstance.pInputPin = &s_InputPin;
g_AWEInstance.pOutputPin = &s_OutputPin;
awe_initPin(&s_InputPin, INPUT_CHANNEL_COUNT, NULL);
awe_initPin(&s_OutputPin, OUTPUT_CHANNEL_COUNT, NULL);
// User version word
g_AWEInstance.userVersion = USER_VER;
g_AWEInstance.instanceId = CORE_ID;
g_AWEInstance.coreSpeed = CORE_SPEED;
g_AWEInstance.profileSpeed = CORE_SPEED;
g_AWEInstance.pName = "ST32F769";
g_AWEInstance.numThreads = NUM_AUDIO_THREADS;
g_AWEInstance.pModuleDescriptorTable = g_module_descriptor_table;
g_AWEInstance.numModules = g_module_descriptor_table_size;
g_AWEInstance.sampleRate = AUDIO_SAMPLE_RATE;
g_AWEInstance.fundamentalBlockSize = AUDIO_BLOCK_SIZE;
// Define the heap sizes
g_AWEInstance.fastHeapASize = MASTER_HEAP_SIZE;
g_AWEInstance.fastHeapBSize = FASTB_HEAP_SIZE;
g_AWEInstance.slowHeapSize = SLOW_HEAP_SIZE;
// Point to the heaps on this target
g_AWEInstance.pFastHeapA = g_MasterHeap;
g_AWEInstance.pFastHeapB = g_FastbHeap;
g_AWEInstance.pSlowHeap = g_SlowHeap;
g_AWEInstance.pPacketBuffer = g_packet_buffer;
g_AWEInstance.pReplyBuffer = g_packet_buffer;
g_AWEInstance.packetBufferSize = MAX_COMMAND_BUFFER_LEN;
// Initialize AWE signal processing instance
awe_init(&g_AWEInstance);
} // End AWEInstanceInit
// METHOD: BSP_AUDIO_IN_DMA_Handler
// PURPOSE: Interrupt handler - called each time a frame of audio received
void BSP_AUDIO_IN_DMA_Handler(void)
int nSamplesAvail;
INT16 * pUSBSamples;
INT32 layoutMask;
INT32 bAudioIsStarted;
INT32 bLayoutValid;
// Collected USB playback samples from an ASRC component
pUSBSamples = USB_Playback_ASRCSamples;
bAudioIsStarted = awe_audioIsStarted(&g_AWEInstance);
bLayoutValid = awe_layoutIsValid(&g_AWEInstance);
// If no audio processing running
if (!bAudioIsStarted)
// Output zeros (silence)
memset(AudioBufferOut, 0, sizeof(AudioBufferOut) );
else
// Audio playing but no AWD layout loaded
if (!bLayoutValid)
// Copy the CODEC stereo input to the CODEC stereo output
memcpy(&AudioBufferOut[nOutWriteNdx], &AudioBufferIn[nInReadNdx], STEREO_BLOCK_SIZE_IN_SAMPLES * PCM_SIZE_IN_BYTES);
else
// Insert the received USB samples into the AudioWeaver buffer
awe_audioImportSamples(&g_AWEInstance, pUSBSamples, STRIDE2, CHANNEL1, Sample16bit);
awe_audioImportSamples(&g_AWEInstance, &pUSBSamples[1], STRIDE2, CHANNEL2, Sample16bit);
// Insert the received CODEC samples into the AudioWeaver buffer
awe_audioImportSamples(&g_AWEInstance, &AudioBufferIn[nInReadNdx], STRIDE2, CHANNEL3, Sample16bit);
awe_audioImportSamples(&g_AWEInstance, &AudioBufferIn[nInReadNdx + 1], STRIDE2, CHANNEL4, Sample16bit);
// Insert the received Mic samples into the AudioWeaver buffer
awe_audioImportSamples(&g_AWEInstance, &MicBufferIn[nMicReadBufferNdx], STRIDE1, CHANNEL5, Sample16bit);
awe_audioImportSamples(&g_AWEInstance, &MicBufferIn[nMicReadBufferNdx + AUDIO_BLOCK_SIZE], STRIDE1, CHANNEL6, Sample16bit);
awe_audioImportSamples(&g_AWEInstance, &MicBufferIn[nMicReadBufferNdx + (AUDIO_BLOCK_SIZE * 2)], STRIDE1, CHANNEL7, Sample16bit);
awe_audioImportSamples(&g_AWEInstance, &MicBufferIn[nMicReadBufferNdx + (AUDIO_BLOCK_SIZE * 3)], STRIDE1, CHANNEL8, Sample16bit);
layoutMask = awe_audioGetPumpMask(&g_AWEInstance);
if (layoutMask > 0)
// If higher priority level processing ready pend an interrupt for it
if (layoutMask & 1)
if (!g_bAudioPump1Active)
NVIC_SetPendingIRQ(AudioWeaverPump_IRQ1);
// If lower priority level processing ready pend an interrupt for it
if (layoutMask & 2)
if (!g_bAudioPump2Active)
NVIC_SetPendingIRQ(AudioWeaverPump_IRQ2);
// Insert the processed Audio Weaver samples into the CODEC output buffer
awe_audioExportSamples(&g_AWEInstance, &AudioBufferOut[nOutWriteNdx], STRIDE2, CHANNEL1, Sample16bit);
awe_audioExportSamples(&g_AWEInstance, &AudioBufferOut[nOutWriteNdx + 1], STRIDE2, CHANNEL2, Sample16bit);
// Insert the processed Audio Weaver samples into the USB output buffer
awe_audioExportSamples(&g_AWEInstance, USB_Record_ASRCSamples, STRIDE2, CHANNEL3, Sample16bit);
awe_audioExportSamples(&g_AWEInstance, &USB_Record_ASRCSamples[1], STRIDE2, CHANNEL4, Sample16bit);
// Switch double buffers
nInReadNdx = (nInReadNdx + STEREO_BLOCK_SIZE_IN_SAMPLES) % INPUT_AUDIO_BUFFER_SIZE;
nMicReadBufferNdx = (nMicReadBufferNdx + NEW_MIC_BUFFER_SAMPLES) % MIC_BUFF_SIZE;
nOutWriteNdx = (nOutWriteNdx + STEREO_BLOCK_SIZE_IN_SAMPLES) % OUTPUT_AUDIO_BUFFER_SIZE;
} // End BSP_AUDIO_IN_DMA_Handler
// METHOD: AudioWeaver Pump Interrupt Handler
// PURPOSE: Perform AudioWeaver Processing
void AudioWeaverPump_IRQHandler1(void)
g_bAudioPump1Active = TRUE;
NVIC_ClearPendingIRQ(AudioWeaverPump_IRQ1);
g_bDeferredProcessingRequired |= awe_audioPump(&g_AWEInstance, 0);
g_bAudioPump1Active = FALSE;
} // End AudioWeaverPump_IRQHandler
void AudioWeaverPump_IRQHandler2(void)
g_bAudioPump2Active = TRUE;
NVIC_ClearPendingIRQ(AudioWeaverPump_IRQ2);
g_bDeferredProcessingRequired |= awe_audioPump(&g_AWEInstance, 1);
g_bAudioPump2Active = FALSE;
// METHOD: AWEIdleLoop
// PURPOSE: AWE Idle loop processing
void AWEIdleLoop(void)
BOOL bMoreProcessingRequired = FALSE;
while(TRUE)
// Set if a packet is received over USB HID
if (g_bPacketReceived)
g_bPacketReceived = FALSE;
// Process the received packet
awe_packetProcess(&g_AWEInstance);
// Send the reply over USB HID
USBSendReply(&g_AWEInstance);
// Process any local controls
if (awe_audioIsStarted(&g_AWEInstance) )
UINT32 classID;
INT32 nValue;
// Perform any needed deferred processing
if (g_bDeferredProcessingRequired || bMoreProcessingRequired)
g_bDeferredProcessingRequired = FALSE;
bMoreProcessingRequired = awe_deferredSetCall(&g_AWEInstance);
// Does the current AWE model have a SinkInt module with this control object ID?
if (awe_ctrlGetModuleClass(&g_AWEInstance, AWE_SinkInt1_value_HANDLE, &classID) == OBJECT_FOUND)
// Check that module assigned this object ID is of module class SinkInt
if (classID == AWE_SinkInt1_classID)
// SinkInt module (gets nValue from the running layout)
awe_ctrlGetValue(&g_AWEInstance, AWE_SinkInt1_value_HANDLE, &nValue, 0, 1);
// Does the current AWE model have a DCSourceInt module with this control object ID?
if (awe_ctrlGetModuleClass(&g_AWEInstance, AWE_DC1_value_HANDLE, &classID) == OBJECT_FOUND)
// Check that module assigned this object ID is of module class DCSourceInt
if (classID == AWE_DC1_classID)
// DCSourceInt module (returns nValue to the running layout)
awe_ctrlSetValue(&g_AWEInstance, AWE_DC1_value_HANDLE, &nValue, 0, 1);
} // End while
} // End AWEIdleLoop
int main(void)
// Initialize AWE platform
targetInit();
// Awe Idle loop
AWEIdleLoop();
} // End main
Audio pump function.
Test if AWE is ready to run.
Initialize the instance.
@ Sample16bit
Data is 16 bit PCM.
Definition: StandardDefs.h:222
The AWE instance.
Definition: AWEInstance.h:109
IOPinDescriptor * pInputPin
Definition: AWEInstance.h:181
const char * pName
Definition: AWEInstance.h:253
float profileSpeed
Profiling clock speed in Hz.
Definition: AWEInstance.h:245
UINT32 * pReplyBuffer
Reply buffer pointer.
Definition: AWEInstance.h:227
UINT32 * pFastHeapB
The second fast heap, B .
Definition: AWEInstance.h:121
UINT32 numThreads
Definition: AWEInstance.h:257
IOPinDescriptor * pOutputPin
Definition: AWEInstance.h:187
UINT32 * pPacketBuffer
The Packet buffer pointer.
Definition: AWEInstance.h:218
UINT32 slowHeapSize
The slow heap size.
Definition: AWEInstance.h:135
UINT32 fundamentalBlockSize
Definition: AWEInstance.h:264
UINT32 * pSlowHeap
The slow heap.
Definition: AWEInstance.h:124
UINT32 userVersion
User Version word.
Definition: AWEInstance.h:239
float sampleRate
Definition: AWEInstance.h:260
UINT32 packetBufferSize
Packet buffer size.
Definition: AWEInstance.h:234
UINT32 fastHeapBSize
The fast heap B size.
Definition: AWEInstance.h:132
float coreSpeed
Definition: AWEInstance.h:242
UINT32 instanceId
The ID of this instance.
Definition: AWEInstance.h:114
UINT32 numModules
Definition: AWEInstance.h:197
Pointer to module table.
Definition: AWEInstance.h:205
UINT32 fastHeapASize
Definition: AWEInstance.h:129
UINT32 * pFastHeapA
Fast heap A.
Definition: AWEInstance.h:118
