AWE Core 8.D.12 Documentation
ControlApp.c
Examples.
Examples
* AWECore Control Example
* Description: AWECore Control Example
* This example shows how to load an .awb from an array, and then
* how to get/set module variables using the corresponding
* controlinterface header file and API's.
* The example will stream an audio file called in_s32_stereo.raw
* and write the processed output to out_s32_stereo.raw.
* This example meets all the conditions to achieve 0 blocks of
* latency in the AWE Core audio path. See the Latency section
* of the docs for more info.
* 3235 Kifer Road
* Santa Clara, CA 95054-1527
#include <float.h>
#include <math.h>
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include "AWECore.h"
#include "Errors.h"
#include "TargetInfo.h"
#include "passthrough_ControlInterface.h"
const char awbFilename[] = "../Designs/passthrough.awb";
const char inFilename[] = "../Audio/in_s32_stereo.raw"; // input audio file: stereo 32-bit fixed-point
const char outFilename[] = "../Audio/out_s32_stereo.raw"; // output audio file: stereo 32-bit fixed-point
// Global AWEInstance structure and pins
AWEInstance aweInstance;
// LISTOFCLASSOBJECTS comes from ModuleList.h
LISTOFCLASSOBJECTS
// Global heaps
UINT32 fastHeapA[FASTA_HEAP_SIZE];
UINT32 fastHeapB[FASTB_HEAP_SIZE];
UINT32 slowHeap[SLOW_HEAP_SIZE];
// Packet buffer
FILE *fin;
FILE *fout;
// Floating-point comparison function used for verification
// Inspired by: http://floating-point-gui.de/errors/comparison/
int awe_isNearlyEqual(float a, float b, float epsilon)
float absA = fabsf(a);
float absB = fabsf(b);
float diff = fabsf(a - b);
if (a == b) { // to handle infinities
return 1;
// a or b is zero or both are extremely close to it
// relative error is less meaningful here
} else { // use relative error
if ((absA + absB) < FLT_MAX)
else
void destroyExample()
fclose(fin);
fclose(fout);
free(inputBuffer);
free(outputBuffer);
inputBuffer = NULL;
outputBuffer = NULL;
void InitializeAWEInstance()
int ret;
//set memory for awe instance and initialize to 0's
memset(&aweInstance, 0, sizeof(AWEInstance));
aweInstance.pInputPin = &aweInputPin;
aweInstance.pOutputPin = &aweOutputPin;
// No tuning interface in this example
aweInstance.pPacketBuffer = awePacketBuffer;
aweInstance.pReplyBuffer = awePacketBuffer;
aweInstance.packetBufferSize = MAX_COMMAND_BUFFER_LEN;
aweInstance.pModuleDescriptorTable = module_descriptor_table;
aweInstance.numModules = module_descriptor_table_size;
aweInstance.numThreads = 1;
aweInstance.sampleRate = SAMPLE_RATE;
aweInstance.fundamentalBlockSize = BASE_BLOCK_SIZE;
aweInstance.pFlashFileSystem = HAS_FLASHFILESYSTEM;
aweInstance.fastHeapASize = FASTA_HEAP_SIZE;
aweInstance.fastHeapBSize = FASTB_HEAP_SIZE;
aweInstance.slowHeapSize = SLOW_HEAP_SIZE;
aweInstance.pFastHeapA = fastHeapA;
aweInstance.pFastHeapB = fastHeapB;
aweInstance.pSlowHeap = slowHeap;
aweInstance.cbAudioStart = NULL;
aweInstance.cbAudioStop = NULL;
aweInstance.coreSpeed = CORE_SPEED;
aweInstance.profileSpeed = PROFILE_SPEED;
aweInstance.pName = NULL;
ret = awe_initPin(&aweInputPin, NUM_INPUT_CHANNELS, NULL);
if (ret != 0)
ret = awe_initPin(&aweOutputPin, NUM_OUTPUT_CHANNELS, NULL);
if (ret != 0)
ret = awe_init(&aweInstance);
if (ret != 0)
printf("awe_init failed\n");
// Enable profiling (by default this is the case, but just called here to demonstrate usage)
ret = awe_setProfilingStatus(&aweInstance, 1);
if (ret != 0)
printf("awe_setProfilingStatus failed\n");
int main() {
INT32 ret = 0;
UINT32 position;
UINT32 inSize, outSize;
InitializeAWEInstance();
// Load the .awb from C array
ret = awe_loadAWBfromArray(&aweInstance, Core0_InitCommands, Core0_InitCommands_Len, &position);
if (ret != E_SUCCESS)
printf("Error loading AWB from array: error = %d, at offset %u\n", ret, position);
exit(1);
ret = awe_layoutIsValid(&aweInstance);
if (ret != 1)
exit(1);
ret = awe_audioIsStarted(&aweInstance);
if (ret != 1)
exit(1);
// Get the layout I/O configuration
// Input and output blocksizes must be the same
//NOTE: Because there can only be one input pin and one output pin, all API's that take the argument "pinIdx" will always pass in 0. This is demonstrated in the function calls below.
awe_layoutGetChannelCount(&aweInstance, 0, &layoutInChannels, &layoutOutChannels);
ret = awe_layoutGetInputBlockSize(&aweInstance, 0, &layoutBlockSize);
printf("Error: GetBlockSize failed: error = %d\n", ret);
exit(1);
printf("Layout loaded with inputChannels=%u, outputChannels=%u, blockSize=%u\n", layoutInChannels, layoutOutChannels, layoutBlockSize);
// Prepare the stereo input and output buffers, and open files
if (fin == NULL)
printf("Error opening file %s\n", inFilename);
exit(1);
if (fout == NULL)
printf("Error opening file %s\n", outFilename);
exit(1);
// Set Scaler1 gain attributes
float scaler1Gain;
float scaler1TargetGain;
long count = 0;
int numSamplesRead = 0;
UINT32 classId;
//NOTE: All handles, IDs, and sizes that are passed into the ctrl interface API functions are found in the example ControlInterface header file "passthrough_ControlInterface.h"
// Check that the layout has the correct control modules in it
int moduleFound = 0;
if (awe_ctrlGetModuleClass(&aweInstance, AWE_Scaler1_gain_HANDLE, &classId) == E_SUCCESS)
// Check that module assigned this object ID is of module class SinkInt
if (classId == AWE_Scaler1_classID)
moduleFound = 1;
if (!moduleFound)
printf("Error: Scaler1 module not found in layout\n");
if (awe_ctrlGetModuleClass(&aweInstance, AWE_Meter1_value_HANDLE, &classId) == E_SUCCESS)
if (classId == AWE_Meter1_classID)
moduleFound = 1;
if (!moduleFound)
printf("Error: Meter1 module not found in layout\n");
printf("\n");
// Set the gain to -10 dB
scaler1Gain = -10.0;
ret = awe_ctrlSetValue(&aweInstance, AWE_Scaler1_gain_HANDLE, (const void *)&scaler1Gain, 0, AWE_Scaler1_gain_SIZE);
ret = awe_ctrlGetValue(&aweInstance, AWE_Scaler1_gain_HANDLE, &scaler1Gain, 0, AWE_Scaler1_gain_SIZE);
ret = awe_ctrlGetValue(&aweInstance, AWE_Scaler1_targetGain_HANDLE, &scaler1TargetGain, 0, AWE_Scaler1_targetGain_SIZE);
// Process the input data
INT32 i, j;
INT32 numOutFrames;
UINT32 pumpMask;
// Import and export samples for each channel in I/O files
ret = awe_audioImportSamples(&aweInstance, inputBuffer + i, inputChannels, i, Sample32bit);
printf("Error: audio import failed: error = %d\n", ret);
// Only one layout in this example, so only bother checking for that field of the pump mask
pumpMask = awe_audioGetPumpMask(&aweInstance);
if (pumpMask & 1U)
// Pump the layout if ready
ret = awe_audioPump(&aweInstance, 0);
printf("Error: audio pump failed: layout=%d, error=%d\n", 0, ret);
ret = awe_audioExportSamples(&aweInstance, outputBuffer + i, outputChannels, i, Sample32bit);
printf("Error: audio export failed: error = %d\n", ret);
count++;
// Print the Meter1 value every 1024 pump cycles
if ((count % 1024) == 0)
ret = awe_ctrlGetValue(&aweInstance, AWE_Meter1_value_HANDLE, &meter1Values, 0, AWE_Meter1_value_SIZE);
// Perform inline verification
// Channel 1 is expected to be attenuated by -10 dB
// Channel 2 is expected to be passed through without modification
#define EPSILON 0.1f
for (j = 0; j < numOutFrames; j++) {
if (awe_isNearlyEqual(expectedValueChannel1, (float)outputBuffer[outputChannels * j], EPSILON) == 0) {
destroyExample();
exit(1);
if (awe_isNearlyEqual(expectedValueChannel2, (float)outputBuffer[outputChannels * j + 1], EPSILON) == 0) {
destroyExample();
exit(1);
// There is no latency through the audio pump
printf("\n");
// Clean up
destroyExample();
return 0;
The AWECore API Header File.
Audio pump function.
void awe_layoutGetChannelCount(const AWEInstance *pAWE, UINT32 pinIdx, UINT32 *inCount, UINT32 *outCount)
Returns the number of channels in the Layout's input and output pins.
Test if AWE is ready to run.
Initialize the instance.
INT32 awe_layoutGetInputBlockSize(const AWEInstance *pAWE, UINT32 pinIdx, UINT32 *blockSize)
Returns the block size of a pin.
#define E_SUCCESS
OK result.
Definition: Errors.h:31
@ Sample32bit
Data is 32 bit PCM .
The AWE instance.
Definition: AWEInstance.h:109
IOPinDescriptor * pInputPin
Definition: AWEInstance.h:181
const char * pName
Definition: AWEInstance.h:253
float profileSpeed
Profiling clock speed in Hz.
Definition: AWEInstance.h:245
UINT32 * pReplyBuffer
Reply buffer pointer.
Definition: AWEInstance.h:227
UINT32 * pFastHeapB
The second fast heap, B .
Definition: AWEInstance.h:121
UINT32 numThreads
Definition: AWEInstance.h:257
IOPinDescriptor * pOutputPin
Definition: AWEInstance.h:187
UINT32 * pPacketBuffer
The Packet buffer pointer.
Definition: AWEInstance.h:218
Definition: AWEInstance.h:143
OPTIONAL.
Definition: AWEInstance.h:149
UINT32 slowHeapSize
The slow heap size.
Definition: AWEInstance.h:135
UINT32 fundamentalBlockSize
Definition: AWEInstance.h:264
UINT32 * pSlowHeap
The slow heap.
Definition: AWEInstance.h:124
float sampleRate
Definition: AWEInstance.h:260
UINT32 packetBufferSize
Packet buffer size.
Definition: AWEInstance.h:234
UINT32 fastHeapBSize
The fast heap B size.
Definition: AWEInstance.h:132
Definition: AWEInstance.h:269
float coreSpeed
Definition: AWEInstance.h:242
UINT32 numModules
Definition: AWEInstance.h:197
Pointer to module table.
Definition: AWEInstance.h:205
UINT32 fastHeapASize
Definition: AWEInstance.h:129
UINT32 * pFastHeapA
Fast heap A.
Definition: AWEInstance.h:118
