AWE Core 8.D.12 Documentation
LinuxApp.c
Examples.
Examples
* Simple AWECore Linux Application
* Description: Sample app to show basic usage of AWECore
* A single instance AWECore integration with simulated real-time audio on Linux.
* Includes an ethernet/TCPIP tuning interface to connect to AWE Server on port 15092
* This is a low latency enabled example, meaning that there can either be 0 or 1 blocks of latency based on certain conditions...
* -If the user loads a layout with a blocksize which does NOT equal the AWEInstance's fundamental BS, there will be 1 block of latency.
* -If the user's layout blocksize matches the AWEInstance's fundamental blocksize, then there will be 0 blocks of latency
* See the Latency section of the docs for more info.
* Copyright: (c) 2024 DSP Concepts, Inc. All rights reserved.
* 3235 Kifer Road
* Santa Clara, CA 95054-1527
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <unistd.h>
#include <sys/types.h>
#include <sys/socket.h>
#include <signal.h>
#include <netinet/in.h>
#include <pthread.h>
#include <math.h>
#include <errno.h>
#include <time.h>
#include <sys/time.h>
#include <semaphore.h>
#include "AWECore.h"
#include "ProxyIDs.h"
#include "AWECoreUtils.h"
#include "TargetInfo.h"
//#define TUNING_DEBUG_PRINTS 1
float coreSpeed;
float profileSpeed;
float sampleRate;
UINT32 fundamentalBlockSize;
UINT32 inChannels;
UINT32 outChannels;
UINT32 profileStatus;
INT32 tuningPort;
} ConfigParameters;
// Config parameters to control from app arguments
// Input/output audio buffers
INT32 *audioInputBuffer = NULL;
INT32 *audioOutputBuffer = NULL;
static BOOL quiet = FALSE;
// Global AWEInstance structure and pins
AWEInstance aweInstance;
// LISTOFCLASSOBJECTS comes from ModuleList.h
LISTOFCLASSOBJECTS
// Global packet buffers
UINT32 awePacketBufferReply[MAX_COMMAND_BUFFER_LEN];
// Global heaps (dynamically allocated based on the size argument
UINT32 *fastHeapA;
UINT32 *fastHeapB;
UINT32 *slowHeap;
UINT32 heapSizeFastA = FASTA_HEAP_SIZE_LINUX;
UINT32 heapSizeFastB = FASTB_HEAP_SIZE_LINUX;
UINT32 heapSizeSlow = SLOW_HEAP_SIZE_LINUX;
pthread_t tuningThreadHandle;
pthread_t processThreadHandle;
pthread_t audioPumpAllThreadHandle;
pthread_mutex_t packetMutex;
sem_t pumpSem;
INT32 audioStarted = 0;
// Tuning parameters
int sockfd, newsockfd;
int exitTuning = 0;
int exitAudioPump = 0;
INT32 pumpActive = 0;
INT32 eventRegisterCnt = 0;
// increase priority levels for AWE threads
// Audio callback functions must be highest priority to avoid
// missing real time requirements. Pump is right after,
// followed by tuning interface where actions can be performed
// in the background.
#define AUDIO_CALLBACK_PRIO 9
#define AUDIO_PUMP_PRIO 8
#define TUNING_THREAD_PRIO 7
printf(
"Usage: %s [args]\n"
" -profStatus:N set profiling status (0 - disable, 1 - enable(default), 2 - enable module level only, 3 - enable top level only)\n"
" -tport:N default 15002, port number for socket interface. User can choose between 15002 - 15098\n"
"This program exercises the AWECore library.\n",
program, FASTA_HEAP_SIZE_LINUX, FASTB_HEAP_SIZE_LINUX, SLOW_HEAP_SIZE_LINUX);
exit(0);
void destroyApp(void)
// Make sure to destroy the layout in case memory needs to be freed
if (aweInstance.pPacketBuffer)
UINT32 destroyCommand = (2 << 16) | PFID_Destroy; // 0x0002000c
UINT32 pos = 0;
INT32 ret = awe_loadAWBfromArray(&aweInstance, &destroyCommand, 1, &pos);
if (ret)
printf("Layout destroy failed, ret = %d\n", ret);
else
printf("Layout destroy success\n");
// Shut down tuning thread and audio pump thread
exitTuning = 1;
exitAudioPump = 1;
close(newsockfd);
shutdown(sockfd, SHUT_RDWR);
close(sockfd);
// Wait until threads ends
sem_post(&pumpSem);
pthread_join(tuningThreadHandle, NULL);
pthread_join(audioPumpAllThreadHandle, NULL);
sem_destroy(&pumpSem);
free(audioInputBuffer);
free(audioOutputBuffer);
free(fastHeapA);
free(fastHeapB);
free(slowHeap);
void error(const char *msg)
perror(msg);
exit(1);
void sig_handler(int signo)
// Cought termination signal
destroyApp();
printf("Exiting LinuxApp\n");
exit(0);
void usrLogging(AWEInstance* pAWE, INT32 level, UINT32 type, void* payload, INT32 payloadSizeInBytes)
struct timeval ts;
char timeCh[25];
// Get current time for log
gettimeofday(&ts, NULL);
if (payloadSizeInBytes > 0)
INT32 usrEventRegister(AWEInstance* pAWE, INT32 eventType, UINT32 moduleObjId, INT32 payloadSizeInBytes, void** userHandle)
// This function does nothing, but it could use the eventHandle->userHandle struct
// to open a file to write events, or whatever else is needed
// Allcoate some dummy stuff to the userHandle(TODO)
return E_SUCCESS;
INT32 usrEventDeregister(AWEInstance* pAWE, INT32 eventType, UINT32 moduleObjId, void** userHandle)
// This function would normally free any memory allocated by the register function
// (TODO) free dummy stuff
return E_SUCCESS;
INT32 usrEventTrigger(AWEInstance* pAWE, INT32 eventType, UINT32 moduleObjId, void* payload, INT32 payloadSizeInBytes, void* userHandle)
// This function gets called when an event is triggered by an Event Module in the layout.
// Normally the BSP would react to specific eventTypes and objectIds in specific
// ways (e.g. pass wakeword detection on to another system),
// but here we are just printing the details of the event, assuming the payload is ASCII characters
// if eventType is 10. Also one specific objectId case is handled
struct timeval ts;
char timeCh[25];
if (eventType == 10)
// Just an example of handling for a specific objectId event (RMS overflow)
else
return E_SUCCESS;
void resetTuningSocket()
socklen_t clilen;
struct sockaddr_in cli_addr;
close(newsockfd);
listen(sockfd, 5);
#ifdef TUNING_DEBUG_PRINTS
printf("Listening again for connection on port %d\n", configParams.tuningPort);
#endif
clilen = sizeof(cli_addr);
newsockfd = accept(sockfd,
&clilen);
if (newsockfd < 0)
exitTuning = 1;
printf("ERROR on accept, %d\n", newsockfd);
return;
printf( "Found connection again!\n");
#endif
Tuning packets can be recieved and processed here. Another implementation
may choose to process the packet in another thread.
(void) arg;
socklen_t clilen;
INT32 schedPolicy, ret;
int socketOption;
schedPolicy = SCHED_FIFO;
if (ret != 0)
if (sockfd < 0)
printf("ERROR opening socket, %d\n", sockfd);
return NULL;
// Set the socket connection option to immediately allow reuse of port upon losing connection
socketOption = 1;
sizeof(serv_addr)) < 0)
printf("ERROR on binding\n");
return NULL;
listen(sockfd, 5);
&clilen);
if (newsockfd < 0)
return NULL;
/* Enter a tuning loop. This will be in a separate thread from audio processing */
while (!exitTuning)
while(1)
UINT32 plen;
INT32 readBytes, n;
readBytes = recv(newsockfd, aweInstance.pPacketBuffer, MAX_COMMAND_BUFFER_LEN * sizeof(aweInstance.pPacketBuffer[0]), 0);
if (readBytes <= 0)
if (readBytes == 0)
printf("ERROR: socket read 0 length packet, attempt to reconnect\n");
else
printf("ERROR: socket read error, attempt to reconnect -- ret = %d, errno = %d\n", readBytes, errno);
#endif
resetTuningSocket();
break;
// May not have received the whole message. Read again if not
plen = PACKET_LENGTH_BYTES(aweInstance.pPacketBuffer);
while (readBytes < plen)
printf("Didn't read the entire packet! readBytes = %d, totalPacketLength = %u\nReading again\n", readBytes, plen);
#endif
readBytes += recv(newsockfd, &((char*)aweInstance.pPacketBuffer)[readBytes], MAX_COMMAND_BUFFER_LEN * sizeof(aweInstance.pPacketBuffer[0]), 0);
if (readBytes > plen)
printf("ERROR: read %d bytes, expected maximum is %u. Exiting.\n", readBytes, plen);
#endif
break;
// Don't process the packet if audio is pumping
pthread_mutex_lock(&packetMutex);
awe_packetProcess(&aweInstance);
pthread_mutex_unlock(&packetMutex);
plen = PACKET_LENGTH_WORDS(aweInstance.pReplyBuffer);
n = write(newsockfd, aweInstance.pReplyBuffer, plen * sizeof(aweInstance.pReplyBuffer[0]));
if (n < plen)
printf("ERROR: Packet reply transmit failed -- ret = %d\n", n);
#endif
break;
return NULL;
void* aweuser_pumpAllAudio(void * args)
// Represents the callback function from the audio framework
(void) args;
INT32 pumpMask;
INT32 ix;
INT32 i;
schedParam.sched_priority = AUDIO_PUMP_PRIO;
if (ret != 0)
printf("Failed to increase priority of audio pump thread to real time with error: %s \nTry running with sudo\n", strerror(ret));
printf("Starting pump all thread\n");
while (!exitAudioPump)
sem_wait(&pumpSem);
// Set the pumpActive global flag
pumpActive = 1;
if (awe_layoutIsValid(&aweInstance) && awe_audioIsStarted(&aweInstance))
// Import new samples
awe_audioImportSamples(&aweInstance, &audioInputBuffer[i], configParams.inChannels, i, Sample32bit);
// Pump any required sublayouts
pumpMask = awe_audioGetPumpMask(&aweInstance);
// Lock the instance so packet processing doesn't occur simultaneously
for (ix = 0; ix < aweInstance.numThreads; ix++)
if (pumpMask & (1U << ix))
// Pump the sublayout. Each pump may be in its own thread depending on the application
ret |= awe_audioPump(&aweInstance, ix);
// Do deferred processing if needed
if (ret > 0)
// This could be done in a loop until ret == 0, but doing one per fundamental period
// is more conservative at the cost of potentially taking longer to update a module parameter
ret = awe_deferredSetCall(&aweInstance);
// Export samples
awe_audioExportSamples(&aweInstance, &audioOutputBuffer[i], configParams.outChannels, i, Sample32bit);
// Clear the pumpActive global flag
pumpActive = 0;
return NULL;
struct timespec ts;
struct timespec ts_tmp;
long time_nsec;
long long accumulated_time;
long long target_time;
long long overshoot = 0.0;
(void) args;
// Setup sleep time for fundamental blocksize
ts.tv_sec = 0;
ts.tv_sec = 0;
ts_tmp.tv_sec = 0;
ts_tmp.tv_nsec = 0;
if (ret != 0)
printf("Failed to increase priority of audio callback thread with error: %s \nTry running with sudo\n", strerror(ret));
// Check if the previous pump is active (overflow detection)
// Workaround for the AWECore overflow detection failure
if (!pumpActive)
// Kick off the audio thread
sem_post(&pumpSem);
// Might need to post more than once due to clock resolution
while (overshoot > time_nsec)
overshoot -= time_nsec;
sem_post(&pumpSem);
else
overshoot = 0.0;
ts.tv_nsec = time_nsec;
target_time = ((long long)ts_tmp.tv_sec*1000000000) + ts_tmp.tv_nsec + time_nsec;
while(1)
accumulated_time = ((long long)ts_tmp.tv_sec*1000000000) + ts_tmp.tv_nsec;
if (accumulated_time >= target_time)
overshoot += (accumulated_time - target_time);
break;
else
ts.tv_nsec = (long)(target_time - accumulated_time);
return NULL;
INT32 aweuser_audioStart(AWEInstance *pAWE)
(void) pAWE;
// Kick off real-time audio simulation thread
pthread_create(&audioCallbackThreadHandle, NULL, audioCallbackSimulator, NULL);
audioStarted = 1;
printf("Audio Started\n");
return 0;
INT32 aweuser_audioStop(AWEInstance *pAWE)
(void) pAWE;
if(audioCallbackThreadHandle)
exitAudioCallbackThread = 1;
pthread_join(audioCallbackThreadHandle, NULL);
if (audioStarted)
printf("Audio Stopped\n");
audioStarted = 0;
return 0;
void InitializeAWEInstance()
int ret = 0;
int i, j;
//set memory for awe instance and initialize to 0's
memset(&aweInstance, 0, sizeof(AWEInstance));
aweInstance.pInputPin = &aweInputPin;
aweInstance.pOutputPin = &aweOutputPin;
// Set pointers to the separate packet buffers in this example
// Could set both pointer to same buffer if desired
aweInstance.pPacketBuffer = awePacketBuffer;
aweInstance.pReplyBuffer = awePacketBufferReply;
aweInstance.packetBufferSize = MAX_COMMAND_BUFFER_LEN;
aweInstance.pModuleDescriptorTable = module_descriptor_table;
aweInstance.numModules = module_descriptor_table_size;
aweInstance.numThreads = NUM_THREADS;
aweInstance.sampleRate = configParams.sampleRate;
aweInstance.fundamentalBlockSize = configParams.fundamentalBlockSize;
aweInstance.pFlashFileSystem = HAS_FLASHFILESYSTEM;
aweInstance.fastHeapASize = heapSizeFastA;
aweInstance.fastHeapBSize = heapSizeFastB;
aweInstance.slowHeapSize = heapSizeSlow;
aweInstance.pFastHeapA = fastHeapA;
aweInstance.pFastHeapB = fastHeapB;
aweInstance.pSlowHeap = slowHeap;
aweInstance.cbAudioStart = aweuser_audioStart;
aweInstance.cbAudioStop = aweuser_audioStop;
aweInstance.coreSpeed = configParams.coreSpeed;
aweInstance.profileSpeed = configParams.profileSpeed;
aweInstance.pName = TARGET_NAME;
ret = awe_initPin(&aweInputPin, configParams.inChannels, NULL);
if (ret != 0)
ret = awe_initPin(&aweOutputPin, configParams.outChannels, NULL);
if (ret != 0)
ret = awe_init(&aweInstance);
if (ret != 0)
// Enable profiling (by default this is the case, but just called here to demonstrate usage)
ret = awe_setProfilingStatus(&aweInstance, configParams.profileStatus);
if (ret != 0)
printf("awe_setProfilingStatus failed with error code: %d\n", ret);
// Register logging callback for all framework log messages
ret = awe_registerLoggingCallback(&aweInstance, usrLogging, AWE_LOG_LEVEL_DEBUG, AWE_LOG_ALL_TYPE_MASK);
if (ret != 0)
printf("awe_registerLoggingCallback failed with error code: %d\n", ret);
// Register event callbacks that can be triggered by Event Modules in the layout
ret = awe_registerEventCallbacks(&aweInstance, usrEventTrigger, usrEventRegister, usrEventDeregister);
if (ret != 0)
printf("awe_registerEventCallbacks failed with error code: %d\n", ret);
#ifndef PI
#define PI 3.141592653589793
#endif
// Fill audio input buffers with full scale sin waves
audioInputBuffer[i * configParams.inChannels + j] = float_to_fract32(sinf(2.f*PI*(j+1)*((float)configParams.sampleRate/configParams.fundamentalBlockSize) * (i / (float)configParams.sampleRate)));
INT32 i;
UINT32 inSize, outSize;
const char *awbpath = NULL;
INT32 ret;
// Init default configurations
configParams.fundamentalBlockSize = BASE_BLOCK_SIZE;
configParams.tuningPort = 15002;
// Check if the argc == 1, meaing that there are not input parameters supplied with the program.
// Print the usage information, to help the user.
for (i = 1; i < argc; i++)
const char *arg = argv[i];
printf("profStatus:%u\n",configParams.profileStatus);
printf("-bsize: %u\n",configParams.fundamentalBlockSize);
printf("-inchans: %u\n",configParams.inChannels);
printf("-outchans: %u\n",configParams.outChannels);
printf("-tport: %d\n",configParams.tuningPort);
quiet = TRUE;
printf("-quiet: %d\n",quiet);
awbpath = arg + 6;
else
usage(argv[0]);
if (!quiet)
ret = awe_getBuildVersionInfo(&aweVersion);
if (aweVersion.hotFixVer)
// If hot fix version is not empty
printf("\nAWECore version %u.%c.%u.%u.%c (build %u) initialized with the following parameters\n\n",
aweVersion.tuningVer, aweVersion.majorVer, aweVersion.minorVer, aweVersion.procVer,
aweVersion.hotFixVer, aweVersion.buildNumber);
else
printf("\nAWECore version %u.%c.%u.%u (build %u) initialized with the following parameters\n\n",
if (configParams.profileStatus)
else
// Setup signal handler to kill sockets
//Allocate the input and output buffers
audioInputBuffer = malloc(inSize * sizeof(INT32));
audioOutputBuffer = malloc(outSize * sizeof(INT32));
// Allocate heaps
// Initialize the AWEInstance
InitializeAWEInstance();
if ( NULL != awbpath )
FILE *fin;
UINT32 position;
fin = fopen(awbpath, "rb");
if (NULL == fin )
printf("Please check the path\n");
exit(1);
//Load the AWB from the file
ret = awe_loadAWBfromFile(&aweInstance, awbpath, &position);
if (E_SUCCESS == ret)
printf("The layout %s loaded successfully\n", awbpath);
else
exit(1);
// Initialize mutex and condition variable objects
pthread_mutex_init(&packetMutex, NULL);
sem_init(&pumpSem, 0, 0);
// Start tuning thread
pthread_create(&tuningThreadHandle, NULL, tuningPacketThread, NULL);
// Start audio pump all thread
pthread_create(&audioPumpAllThreadHandle, NULL, aweuser_pumpAllAudio, NULL);
// Block forever until threads close
return 0;
The AWECore API Header File.
Definition: AWECoreUtils.h:40
Definition: AWECoreUtils.h:43
INT32 awe_registerEventCallbacks(AWEInstance *pAWE, cbAweEventTrigger_t cbAweEventTrigger, cbAweEventRegister_t cbAweEventRegister, cbAweEventDeregister_t cbAweEventDeregister)
INT32 awe_getBuildVersionInfo(AWEBuildVersionInfo_t *pBuildVersionInfo)
Get the AWECore build number and version information.
Audio pump function.
INT32 awe_registerLoggingCallback(AWEInstance *pAWE, cbAweLogging_t cbAweLogging, INT32 logLevel, UINT32 logTypeMask)
Test if AWE is ready to run.
INT32 awe_loadAWBfromFile(AWEInstance *pAWE, const char *binaryFile, UINT32 *pPos)
Load an AWB file from stdio.
Initialize the instance.
#define E_SUCCESS
OK result.
Definition: Errors.h:31
@ PFID_Destroy
Function ID for awe_fwDestroy().
Definition: ProxyIDs.h:68
@ Sample32bit
Data is 32 bit PCM .
The AWE instance.
Definition: AWEInstance.h:109
IOPinDescriptor * pInputPin
Definition: AWEInstance.h:181
const char * pName
Definition: AWEInstance.h:253
float profileSpeed
Profiling clock speed in Hz.
Definition: AWEInstance.h:245
UINT32 * pReplyBuffer
Reply buffer pointer.
Definition: AWEInstance.h:227
UINT32 * pFastHeapB
The second fast heap, B .
Definition: AWEInstance.h:121
UINT32 numThreads
Definition: AWEInstance.h:257
IOPinDescriptor * pOutputPin
Definition: AWEInstance.h:187
UINT32 * pPacketBuffer
The Packet buffer pointer.
Definition: AWEInstance.h:218
Definition: AWEInstance.h:143
OPTIONAL.
Definition: AWEInstance.h:149
UINT32 slowHeapSize
The slow heap size.
Definition: AWEInstance.h:135
Definition: AWEInstance.h:264
UINT32 * pSlowHeap
The slow heap.
Definition: AWEInstance.h:124
float sampleRate
Definition: AWEInstance.h:260
UINT32 packetBufferSize
Packet buffer size.
Definition: AWEInstance.h:234
UINT32 fastHeapBSize
The fast heap B size.
Definition: AWEInstance.h:132
Definition: AWEInstance.h:269
float coreSpeed
Definition: AWEInstance.h:242
UINT32 numModules
Definition: AWEInstance.h:197
Pointer to module table.
Definition: AWEInstance.h:205
UINT32 fastHeapASize
Definition: AWEInstance.h:129
UINT32 * pFastHeapA
Fast heap A.
Definition: AWEInstance.h:118
Build versioning structure returned by awe_getBuildVersionInfo.
Definition: AWEInstance.h:298
UINT32 buildNumber
Library build number.
Definition: AWEInstance.h:304
UINT32 minorVer
Minor API version.
Definition: AWEInstance.h:301
char hotFixVer
Hot fix version, if the build is a hot fix release.
Definition: AWEInstance.h:303
char majorVer
Major API version (single letter)
Definition: AWEInstance.h:300
UINT32 procVer
Processor specific version.
Definition: AWEInstance.h:302
UINT32 tuningVer
Tuning version.
Definition: AWEInstance.h:299
