typedef struct AWEOSAudioRecordNotification | AWEOSAudioRecordNotification_t |
| | Audio recording notification callback argument structure.
typedef void(* | recordNotificationCallbackFunction) (AWEOSAudioRecordNotification_t *) |
| | Audio recording notification callback type.
typedef struct AWEOSThreadPIDs | AWEOSThreadPIDs_t |
| | Internal threading PID structure, meant to be used with aweOS_getThreadPIDs.
typedef struct AWEOSVersionInfo | AWEOSVersionInfo_t |
| | Versioning structure returned by aweOS_getVersion.
| typedef void | AWEOSInstance |
| | The AWE Core OS Instance instance type. More...
| typedef struct AWEOSConfigParameters | AWEOSConfigParameters |
| | AWEOSConfigParameters. More...
| typedef void(* | cbAweOSLogging_t) (AWEOSInstance *pAWEOS, INT32 level, UINT32 type, void *payload, INT32 payloadSizeInBytes) |
| | OPTIONAL This callback is invoked from multiple places in the AWE framework to log any message to the BSP. More...
| typedef INT32(* | cbAweOSEventTrigger_t) (AWEOSInstance *pAWEOS, INT32 eventType, UINT32 moduleObjId, void *payload, INT32 payloadSizeInBytes, void *userHandle) |
| | OPTIONAL These callback are invoked only from the Event Module. More...
| typedef INT32(* | cbAweOSEventRegister_t) (AWEOSInstance *pAWEOS, INT32 eventType, UINT32 moduleObjId, INT32 payloadSizeInBytes, void **userHandle) |
| | The Event Register callback is called by an Event Module when it is constructed. More...
| typedef INT32(* | cbAweOSEventDeregister_t) (AWEOSInstance *pAWEOS, INT32 eventType, UINT32 moduleObjId, void **userHandle) |
| | The Event Deregister callback is called by the Event Module when it is destroyed. More...
| UINT32 | aweOS_getThreadPIDs (AWEOSInstance *pAWEOS, AWEOSThreadPIDs_t *threadPIDs) |
| | Return the PIDs of all internally spawned AWE Core OS threads. More...
| INT32 | aweOS_getParamDefaults (AWEOSConfigParameters *aweParams) |
| | Populates an AWEOSConfigParameters structure with defaults. More...
| INT32 | aweOS_init (AWEOSInstance **pAWEOS, const AWEOSConfigParameters *aweParams, const void *pModuleDescriptorTable, UINT32 moduleDescriptorTableSize) |
| | Initialize the AWEOSInstance with the specified configuration parameters. More...
| INT32 | aweOS_tuningSocketOpen (AWEOSInstance **pAWEOS, INT32 portNo, UINT32 numInstances) |
| | Initialize and open an integrated TCP/IP tuning interface socket. More...
| void | aweOS_tuningSocketClose (AWEOSInstance *pAWEOS) |
| | Close a running integrated TCP tuning socket. More...
| INT32 | aweOS_tuningLoggingEnable (AWEOSInstance *pAWEOS, char *path, char *baseName, UINT32 verbosity) |
| | Enable logging of the tuning packets sent and received by the AWEOSInstance. More...
| INT32 | aweOS_loadAWBFromArray (AWEOSInstance *pAWEOS, const UINT32 *pArray, UINT32 arraySize, UINT32 *pErrorOffset) |
| | Executes packet commands from an in-memory array. More...
| INT32 | aweOS_loadAWBFile (AWEOSInstance *pAWEOS, const char *binaryFile, UINT32 *pErrorOffset) |
| | Executes packet commands from an AWB file on the filesystem. More...
| INT32 | aweOS_appendModules (AWEOSInstance *pAWEOS, size_t length, const void *const *modules) |
| | Append an array of module class pointers to the AWECoreOS instance's dynamic module list. More...
| INT32 | aweOS_layoutGetChannelCount (const AWEOSInstance *pAWEOS, UINT32 *inCount, UINT32 *outCount) |
| | Returns the number of input and output channels in the loaded layout. More...
| INT32 | aweOS_layoutGetBlockSize (const AWEOSInstance *pAWEOS, UINT32 *blockSize) |
| | Returns the block size of the loaded layout. More...
| INT32 | aweOS_layoutGetSampleRate (const AWEOSInstance *pAWEOS, FLOAT32 *sampleRate) |
| | Returns the sample rate of the loaded layout. More...
| INT32 | aweOS_audioPumpAll (AWEOSInstance *pAWEOS) |
| | Pump one fundamental block size of audio through the loaded layout and all of its sublayouts. More...
| INT32 | aweOS_audioImportSamples (AWEOSInstance *pAWEOS, void *inSamples, INT32 inStride, INT32 channel, SampleType inType) |
| | Import samples from an audio buffer to a specific channel of the AWEOSInstance's input pin. More...
| INT32 | aweOS_audioExportSamples (AWEOSInstance *pAWEOS, void *outSamples, INT32 outStride, INT32 channel, SampleType outType) |
| | Export samples to a user buffer from a specific channel of the AWEOSInstance's output pin. More...
| INT32 | aweOS_layoutIsValid (const AWEOSInstance *pAWEOS) |
| | Determines if a layout is loaded and valid. More...
| INT32 | aweOS_audioIsStarted (const AWEOSInstance *pAWEOS) |
| | Check if this instance has received an Audio Start command. More...
| const char * | aweOS_errorToString (INT32 errorCode) |
| | Convert an error code (INT32) to its corresponding error string. More...
| INT32 | aweOS_tuningPacketProcess (AWEOSInstance *pAWEOS) |
| | Process the packet buffer in the AWEOSInstance. More...
| INT32 | aweOS_ctrlSetValue (const AWEOSInstance *pAWEOS, UINT32 handle, void *value, INT32 arrayOffset, UINT32 length) |
| | Set a scalar or array value(s) of a module parameter by handle. More...
| INT32 | aweOS_ctrlGetValue (const AWEOSInstance *pAWEOS, UINT32 handle, void *value, INT32 arrayOffset, UINT32 length) |
| | Get a scalar or array value(s) of a module parameter by handle. More...
| INT32 | aweOS_ctrlSetStatus (const AWEOSInstance *pAWEOS, UINT32 handle, UINT32 *status) |
| | Set the status of a module. More...
| INT32 | aweOS_ctrlGetStatus (const AWEOSInstance *pAWEOS, UINT32 handle, UINT32 *status) |
| | Get the status of a module. More...
| INT32 | aweOS_ctrlSetValueMask (const AWEOSInstance *pAWEOS, UINT32 handle, void *value, INT32 arrayOffset, UINT32 length, UINT32 mask) |
| | Set a scalar or array value(s) of a module variable by handle with mask. More...
| INT32 | aweOS_ctrlGetValueMask (const AWEOSInstance *pAWEOS, UINT32 handle, void *value, INT32 arrayOffset, UINT32 length, UINT32 mask) |
| | Get a scalar or array value(s) of a module variable by handle with mask. More...
| INT32 | aweOS_ctrlGetModuleClass (const AWEOSInstance *pAWEOS, UINT32 handle, UINT32 *pClassID) |
| | Get a module's object class from its handle. More...
| INT32 | aweOS_destroy (AWEOSInstance **pAWEOS) |
| | Destroys the AWEOSInstance and closes all associated threads. More...
| INT32 | aweOS_setProfilingStatus (AWEOSInstance *pAWEOS, UINT32 status) |
| | Enable or disable the profiling ability of the AWE Core OS Instance. More...
| INT32 | aweOS_getAverageLayoutCycles (AWEOSInstance *pAWEOS, UINT32 idx, UINT32 *averageCycles) |
| | Get the average cycles of a running layout, in units of cycles at profileSpeed. More...
| void | aweOS_getVersion (AWEOSVersionInfo_t *versionInfo) |
| | Get the version information of the AWE Core OS library. More...
| INT32 | aweOS_audioRecordingEnable (AWEOSInstance *pAWEOS, char *path, char *baseName, UINT32 bufferLength, SampleType sampleType) |
| | Enables recording of all input and output audio of AWEOSInstance. More...
| INT32 | aweOS_audioRecordingRegisterNotificationCallback (AWEOSInstance *pAWEOS, recordNotificationCallbackFunction recordNotificationCallback, UINT32 recordNotificationMask) |
| | Register a callback function for audio recording event notificiations. More...
| INT32 | aweOS_audioRecordingDisable (AWEOSInstance *pAWEOS) |
| | Disable recording of input and output audio of AWEOSInstance. More...
| INT32 | aweOS_wavFileOpen (const char *file, FLOAT32 *sampleRate, UINT32 *numChannels, UINT32 *sampleSize, UINT32 *numSamples, FILE **fp) |
| | Open a .wav file and populate the user arguments with the header information in the file. More...
| INT32 | aweOS_wavFileCreate (const char *file, FLOAT32 sampleRate, UINT32 numChannels, UINT32 sampleSize, FILE **fp) |
| | Create a .wav file and populate the header with the passed in arguments. More...
| INT32 | aweOS_wavFileWrite (FILE *fp, void *samples, UINT32 numSamples, UINT32 sampleSize) |
| | Write audio data to .wav file created using aweOS_wavFileCreate. More...
| INT32 | aweOS_wavFileRead (FILE *fp, void *samples, UINT32 numSamples, UINT32 sampleSize) |
| | Read audio data from .wav file opened using aweOS_wavFileOpen. More...
| INT32 | aweOS_wavFileClose (FILE *fp) |
| | Close the.wav file opened using aweOS_wavFileOpen or aweOS_wavFileCreate. More...
| INT32 | aweOS_setInstancesInfo (AWEOSInstance **pInstances, INT32 numInstances) |
| | Profiling related setup function only intended for systems with multiple AWEOS Instances in a single application. More...
| INT32 | aweOS_registerLoggingCallback (AWEOSInstance *pAWEOS, cbAweOSLogging_t cbAweOSLogging, INT32 logLevel, UINT32 logTypeMask) |
| | Register the logging callback with required logging level and logging type mask. More...
| INT32 | aweOS_registerEventCallbacks (AWEOSInstance *pAWEOS, cbAweOSEventTrigger_t cbAweOSEventTrigger, cbAweOSEventRegister_t cbAweOSEventRegister, cbAweOSEventDeregister_t cbAweOSEventDeregister) |
| | Register the event callbacks used by the Event Module. More...
