AWE Core 8.D.10 Documentation
Macros | Typedefs | Enumerations
StandardDefs.h File Reference
Macros
#define UINT32_DEFINED
#define INT32_DEFINED
#define BOOL   INT32
#define MAXINT32   ((INT32)0x7fffffffUL)
#define MININT32   ((INT32)~MAXINT32)
#define UINT64_DEFINED
#define INT64_DEFINED
#define MAXINT64   ((INT64)0x7ffffffffffffffffULL)
#define MININT64   ((INT64)~MAXINT64)
#define FLOAT32_DEFINED
#define FLOAT64_DEFINED
#define INT16_DEFINED
#define UINT16_DEFINED
#define INT8_DEFINED
#define UINT8_DEFINED
#define INT_DEFINED
#define UINT   unsigned int
#define BYTE_DEFINED
#define PBYTE   unsigned char *
#define TRUE   1
#define FALSE   0
#define WORD   unsigned short
#define PWORD   unsigned short *
#define DWORD   unsigned long
#define PDWORD   unsigned long *
#define NUMOF(x)   (sizeof(x) / sizeof(*x))
#define NULL   0
#define SUCCESS   1
#define FAILURE   0
#define PASTE(x, y)   x ## y
#define EVAL(x, y)   PASTE(x, y)
#define FIXNAME(x)   EVAL(MODULE_PREFIX, x)
#define AWE_UNUSED_VARIABLE(x)   ((void)(x))
#define SAMPLETYPE_DEFINED
#define DLLSYMBOL
#define CXX_NOWARN_DLLCLASSIF
#define CXX_RESTORE_DLLCLASSIF
Typedefs
typedef unsigned int UINT32
typedef int INT32
typedef unsigned long long UINT64
typedef long long INT64
typedef float FLOAT32
typedef double FLOAT64
typedef short INT16
typedef unsigned short UINT16
typedef signed char INT8
typedef unsigned char UINT8
typedef int INT
typedef unsigned char BYTE
typedef enum _SampleType SampleType
 Type of data for I/O.
Enumerations
enum  _SampleType { Sample16bit , Sample24bit_low , Sample24bit_high , Sample32bit }
 Type of data for I/O. More...
Enumeration Type Documentation
◆ _SampleType
Enumerator
Sample16bit
Data is 16 bit PCM.
Sample24bit_low
Data is 24 bit PCM aligned to the low bit in 32 bit buffers.
Sample24bit_high
Data is 24 bit PCM aligned to the high bit in 32 bit buffers.
Sample32bit
Data is 32 bit PCM .
