Examples.
#define _GNU_SOURCE
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <unistd.h>
#include <sys/types.h>
#include <sys/socket.h>
#include <signal.h>
#include <netinet/in.h>
#include <pthread.h>
#include <sched.h>
#include <math.h>
#include <time.h>
#include <semaphore.h>
#include <signal.h>
#include <time.h>
#include "TargetInfo.h"
    float coreSpeed;
    float profileSpeed;
    float sampleRate;
    UINT32 fundamentalBlockSize;
    UINT32 inChannels;
    UINT32 outChannels;
    UINT32 profileStatus;
    INT32 tuningPort;
} ConfigParameters;
const unsigned int loopback_dualcore_startAudio_InitCommands[] = {
    0x0002000c, 0x00060006, 0x473b8000, 0x40040002, 0x00000100, 0x00000000, 0x00060006, 0x473b8000,
    0x40040002, 0x00000100, 0x00000000, 0x00060006, 0x473b8000, 0x40040002, 0x00000100, 0x00000000,
    0x00060106, 0x473b8000, 0x40040002, 0x00000100, 0x00000000, 0x00040007, 0x00000001, 0x00000001,
    0x00040007, 0x00000002, 0x00000002, 0x000b000f, 0xbeef1039, 0x00000001, 0x00000005, 0x00000003,
    0x00000000, 0x00000001, 0x00000000, 0x00000100, 0x00000000, 0x000b010f, 0xbeef1039, 0x00000001,
    0x00000005, 0x00000001, 0x00000000, 0x00000001, 0x00000000, 0x00000100, 0x00000000, 0x0009000f,
    0xbeef0866, 0x00000101, 0x00000002, 0x00000001, 0x00000003, 0x00000001, 0x00000000, 0x0007000f,
    0xbeef086d, 0x00000001, 0x00000001, 0x00000003, 0x00000000, 0x00080065, 0x0000680a, 0x00000000,
    0x00000400, 0x00000002, 0xc0a00000, 0x40a00000, 0x000c010f, 0xbeef103a, 0x00000100, 0x00000006,
    0x00000001, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000100, 0x00000000, 0x0007010f,
    0xbeef086d, 0x00000001, 0x00000001, 0x00000001, 0x00000000, 0x00080165, 0x0000480a, 0x00000000,
    0x00000400, 0x00000002, 0xc0a00000, 0x40a00000, 0x000c000f, 0xbeef103a, 0x00000100, 0x00000006,
    0x00000003, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000100, 0x00000000, 0x0007000f,
    0xbeef086d, 0x00000001, 0x00000001, 0x00000003, 0x00000000, 0x00080065, 0x0000880a, 0x00000000,
    0x00000400, 0x00000002, 0xc0a00000, 0x40a00000, 0x0009000f, 0xbeef0866, 0x00000101, 0x00000002,
    0x00000003, 0x00000002, 0x00000000, 0x00000001, 0x00040010, 0x00000006, 0x00000001, 0x000a002f,
    0x0000000a, 0x00000000, 0x00000005, 0x00000004, 0x00000006, 0x00000007, 0x00000008, 0x00000009,
    0x00040110, 0x00000003, 0x00000001, 0x0007012f, 0x00000005, 0x00000000, 0x00000003, 0x00000002,
    0x00000004, 0x0006013c, 0x00003008, 0x00000000, 0x00000100, 0x00000000, 0x0006003c, 0x00007008,
    0x00000001, 0x00000100, 0x00000000, 0x0002001b, 0x00000000,
const unsigned int loopback_dualcore_startAudio_InitCommands_Len = sizeof(loopback_dualcore_startAudio_InitCommands) / sizeof(int);
#define LOAD_MULTICORE_AWB 1
#define NUM_INSTANCES 4
#ifndef TUNING_MASTER_INSTANCE
    #define TUNING_MASTER_INSTANCE  0
#endif
#ifdef ENABLE_FAKE_FLASH_FILE_SYSTEM
#define FLASH_ERASABLE_BLOCK_SIZE 1024*4
#define FLASH_SIZE_PER_INSTANCE   1024*1024*4
#define FLASH_ERASE_TIME_SEC      5
UINT32 g_AWEEmulatedFFS[1024*1024*NUM_INSTANCES];
#endif
#define MAX_PUMP_COUNT  30
INT32 g_nPumpCount[NUM_INSTANCES];
#endif
    LISTOFCLASSOBJECTS
UINT32 sharedHeap[SHARED_HEAP_SIZE_LINUX];
UINT32 tuningPacketBuffer[MAX_COMMAND_BUFFER_LEN];
#ifdef USE_SAME_BUFFER_PACKET_REPLY
UINT32 *tuningReplyBuffer = tuningPacketBuffer;
#else
UINT32 tuningReplyBuffer[MAX_COMMAND_BUFFER_LEN];
#endif
UINT32 *audioInputBuffer;
UINT32 *audioOutputBuffer;
pthread_t packetProcessHandles[NUM_INSTANCES];
pthread_t audioPumpAllThreadHandles[NUM_INSTANCES];
sem_t pumpSems[NUM_INSTANCES];
INT32 exitAudioCallbackThread;
INT32 audioStarted;
unsigned long long callbackCnt;
unsigned long long pumpCnts[NUM_INSTANCES];
INT32 quiet;
int sockfd, newsockfd;
int exitTuning = 0;
#define DEFAULT_TUNING_PORT             (15092)
#define DEFAULT_BLOCK_SIZE              (256)
#define AUDIO_CALLBACK_PRIO     (99)
#define AUDIO_PUMP_PRIO         (AUDIO_CALLBACK_PRIO - 1)
#define TUNING_THREAD_PRIO      (AUDIO_PUMP_PRIO - NUM_INSTANCES)
void error(const char *msg)
    perror(msg);
    exit(1);
void sig_handler(int signo)
    if (signo == SIGINT)
        exitTuning = 1;
        close(newsockfd);
        shutdown(sockfd, SHUT_RDWR);
        close(sockfd);
            FILE *fPtr = NULL;
            fPtr = fopen("AWE_FFS_Emulated.bin", "wb");
            if (fPtr)
                fwrite(g_AWEEmulatedFFS, 1, sizeof(g_AWEEmulatedFFS), fPtr);
                fclose(fPtr);
#endif
        if (!quiet)
            printf("Exiting LinuxAppMulti\n");
        exit(0);
    printf(
        "Usage: %s [args]\n"
        "       -sr:sampling_rate           value in Hz, default 48KHz\n"
        "       -pf:profile_frequency       value in Hz, default 10MHz\n"
        "       -cf:cpu_frequency           value in Hz, default 1GHz\n"
        "       -profStatus:N               set profiling status (0 - disable, 1 - enable(default), 2 - enable module level only, 3 - enable top level only)\n"
        "       -bsize:N                    default 256, Audio block size for the system\n"
        "       -inchans:N                  default 2, number of input channels\n"
        "       -outchans:N                 default 2, number of output channels\n"
        "       -tport:N                    default 15092, port number for socket interface. User can choose between 15002 - 15098\n"
        "       -quiet                      print only error messages\n"
        "       -h, -help                   show this message\n"
        "This program exercises the AWECore library with 2 AWEInstances.\n",
        program);
        exit(0);
    (void) arg;
    socklen_t clilen;
    INT32 schedPolicy, ret;
    int socketOption;
    schedPolicy = SCHED_RR;
    if (ret != 0)
    char threadNameBuffer[16];
    snprintf(threadNameBuffer, 16, "awe0_packet");
    ret = pthread_setname_np(packetProcessHandles[0], threadNameBuffer);
    if (ret)
        printf("Failed to set thread name to %s\n", threadNameBuffer);
    if (sockfd < 0)
        error("ERROR opening socket");
    socketOption = 1;
              sizeof(serv_addr)) < 0)
        error("ERROR on binding");
    while (!exitTuning)
        listen(sockfd,5);
        if (!quiet)
        clilen = sizeof(cli_addr);
        newsockfd = accept(sockfd,
                     &clilen);
        if (newsockfd < 0)
            error("ERROR on accept");
        if (!quiet)
        struct timespec ts;
        ts.tv_nsec = 5000000;
        ts.tv_sec = 0;
        while(1)
            unsigned int plen;
            ssize_t readBytes, n;
            g_nPumpCount[TUNING_MASTER_INSTANCE] = 0;
                readBytes = read(newsockfd, tuningPacketBuffer, MAX_COMMAND_BUFFER_LEN * sizeof(tuningPacketBuffer[0]));
                if (readBytes == 0)
                    break;
                else if (readBytes < 0)
                    error("ERROR reading from socket");
                while (readBytes < plen)
                    n = read(newsockfd,&((char*)tuningPacketBuffer)[readBytes], MAX_COMMAND_BUFFER_LEN * sizeof(tuningPacketBuffer[0]));
                    if (n == 0)
                        break;
                    else if (n < 0)
                    else
                        readBytes += n;
                n = write(newsockfd, tuningReplyBuffer, plen * sizeof(tuningReplyBuffer[0]));
                if (n < plen)
                    error("ERROR writing to socket");
            else
    return NULL;
void* packetProcessThread(void * args)
    struct timespec ts;
    schedParam.sched_priority = TUNING_THREAD_PRIO - instanceId;
    if (ret != 0)
        printf("Failed to increase priority of tuning thread %d with error: %s \nTry running with sudo\n", instanceId, strerror(ret));
    snprintf(threadNameBuffer, 16, "awe%d_packet", instanceId);
    pthread_setname_np(packetProcessHandles[instanceId], threadNameBuffer);
    if (ret)
    if (!quiet)
        printf("Starting instance %d packet process thread\n", instanceId);
    ts.tv_sec = 0;
    while(1)
        g_nPumpCount[instanceId] = 0;
    return NULL;
void* aweuser_pumpAudio(void * args)
    INT32 pumpMask;
    INT32 schedPolicy, ret, targetPriority;
    targetPriority = AUDIO_PUMP_PRIO - instanceId;
    schedParam.sched_priority = targetPriority;
    schedPolicy = SCHED_FIFO;
    int policy;
    pthread_getschedparam(currentHandle, &policy, &schedParam);
    if ((SCHED_FIFO != policy) || (schedParam.sched_priority != targetPriority))
        printf("Warning: Failed to increase priority of audio simulation thread to %d\nTry running as root\n", targetPriority);
    snprintf(threadNameBuffer, 16, "awe%d_pump", instanceId);
    ret = pthread_setname_np(audioPumpAllThreadHandles[instanceId], threadNameBuffer);
    if (!quiet)
        printf("Starting pump thread for instance %d\n", instanceId);
    while (1)
        sem_wait(&pumpSems[instanceId]);
            if (instanceId == 0)
                for (int i = 0; i < configParams.inChannels ; i++)
                    if (ret)
                        printf("Error: awe_audioImportSamples() failed, channel = %d, error = %d\n", i, ret);
                for (int ix = 1; ix < NUM_INSTANCES; ix++)
                        sem_post(&pumpSems[ix]);
            if (g_nPumpCount[instanceId] < MAX_PUMP_COUNT)
                for (int j = 0; j < NUM_THREADS; j++)
                    if (pumpMask & (1U << j))
                if (ret > 0)
                g_nPumpCount[instanceId]++;
                for (int i = 0; i < configParams.outChannels ; i++)
                    if (ret)
                        printf("Error: awe_audioExportSamples() failed, channel = %d, error = %d\n", i, ret);
            pumpCnts[instanceId]++;
    return NULL;
    struct timespec ts;
    struct timespec ts_tmp;
    long time_nsec;
    long long accumulated_time1;
    long long accumulated_time2;
    long long overshoot = 0.0;
    (void) args;
    ts.tv_sec = 0;
    ts_tmp.tv_sec = 0;
    ts_tmp.tv_nsec = 0;
    int policy;
    if ((SCHED_FIFO != policy) || (schedParam.sched_priority != AUDIO_CALLBACK_PRIO))
        printf("Warning: Failed to increase priority of audio simulation thread to %d\nTry running as root\n", AUDIO_CALLBACK_PRIO);
    char threadNameBuffer[32];
    snprintf(threadNameBuffer, 32, "awe_callback");
    ret = pthread_setname_np(audioCallbackThreadHandle, threadNameBuffer);
    if (ret)
        callbackCnt++;
        sem_post(&pumpSems[0]);
        ts.tv_nsec = time_nsec - overshoot;
        accumulated_time1 = ((long long)ts_tmp.tv_sec*1000000000) + ts_tmp.tv_nsec + time_nsec - overshoot;
        while(1)
                overshoot = (accumulated_time2 - accumulated_time1);
                break;
            else
    return NULL;
        exitAudioCallbackThread = 0;
        callbackCnt = 0;
        memset(pumpCnts, 0, sizeof(pumpCnts));
        INT32 ret = pthread_create(&audioCallbackThreadHandle, NULL, audioCallbackSimulator, NULL);
        if (ret)
            return 0;
        audioStarted = 1;
        if (!quiet)
            printf("Audio Started\n");
    return 0;
    if (audioStarted)
        INT32 ret;
        exitAudioCallbackThread = 1;
        if (ret != 0)
        if (!quiet)
            UINT32 avgCycles;
            const FLOAT32 clockRatios = configParams.coreSpeed / configParams.profileSpeed;
            printf("\nAudio Stopped\n");
            for (int i = 0; i < NUM_INSTANCES; i++)
                    avgCycles = 0;
                printf("-- Pumped instance %d %llu times, average cycles per pump: %f\n", i, pumpCnts[i],
                    (avgCycles >> 8) * clockRatios);
        audioStarted = 0;
    return 0;
BOOL usrInitFlashFileSystem(void)
    return SUCCESS;
BOOL usrReadFlashMemory(UINT32 nAddress, UINT32 * pBuffer, UINT32 nDWordsToRead)
    BOOL bSuccess = 0;
    if(nDWordsToRead == 0)
        return SUCCESS;
    memcpy(pBuffer, &g_AWEEmulatedFFS[nAddress >> 2], nDWordsToRead*sizeof(UINT32));
    return SUCCESS;
BOOL usrWriteFlashMemory(UINT32 nAddress, UINT32 * pBuffer, UINT32 nDWordsToWrite)
    BOOL bSuccess = 0;
    if(nDWordsToWrite == 0)
        return SUCCESS;
    memcpy(&g_AWEEmulatedFFS[nAddress >> 2], pBuffer, nDWordsToWrite*sizeof(UINT32));
    return SUCCESS;
BOOL usrEraseFlashMemorySector(UINT32 nStartingAddress, UINT32 nNumberOfSectors)
    memset(&g_AWEEmulatedFFS[nStartingAddress >> 2], 0xffu, nNumberOfSectors * FLASH_ERASABLE_BLOCK_SIZE);
#endif
void InitializeAWEInstance(
AWEInstance * awePtr, INT32 instanceId)
    int ret = 0;
    UINT32 module_descriptor_table_size = sizeof(module_descriptor_table) / sizeof(module_descriptor_table[0]);
#endif
    pAweFFSPtr->
cbInit = &usrInitFlashFileSystem;
#endif
    awePtr->
    awePtr->
slowHeapSize = SLOW_HEAP_SIZE_LINUX / NUM_INSTANCES;
    awePtr->
pName = malloc(
sizeof(
char) * 8);
    sprintf((
char*)awePtr->
pName,
"awe#%d", instanceId);
        int i, j;
        ret =
awe_initPin(&aweInputPin, configParams.inChannels, NULL);
        if (ret != 0)
            printf("awe_initPin inputPin failed on AWEInstance 0\n");
        ret =
awe_initPin(&aweOutputPin, configParams.outChannels, NULL);
        if (ret != 0)
            printf("awe_initPin outputPin failed on AWEInstance 0\n");
#ifndef PI
#define PI 3.141592653589793
#endif
        float blockRate = configParams.sampleRate / configParams.fundamentalBlockSize;
                audioInputBuffer[i * configParams.inChannels + j] =
float_to_fract32(sinf(2.f * PI *
                    (j + 1) * blockRate * (i / configParams.sampleRate)));
    if (ret != 0)
        printf("awe_init on instance %d failed with %d\n", instanceId, ret);
    else
        if (!quiet)
            printf("Initialized instance %d\n", instanceId);
    int i;
    if ((TUNING_MASTER_INSTANCE < 0) || (TUNING_MASTER_INSTANCE >= NUM_INSTANCES))
        printf("Provided TUNING_MASTER_INSTANCE of %d is out of range. Value should be [0 %d]\n",TUNING_MASTER_INSTANCE, NUM_INSTANCES-1);
        return 0;
    configParams.fundamentalBlockSize = DEFAULT_BLOCK_SIZE;
    configParams.tuningPort = DEFAULT_TUNING_PORT;
    quiet = 0;
    for (i = 1; i < argc; i++)
        const char *arg = argv[i];
            quiet = 1;
        else if ((0 == strncmp(arg, "-help", 5)) || (0 == strncmp(arg, "-h", 2)))
            usage(argv[0]);
    if (!quiet)
        printf("\nAWECore initialised with the following parameters\n");
        printf("-cf:            %f Hz\n", configParams.coreSpeed);
        printf("-pf:            %f Hz\n", configParams.profileSpeed);
        printf("-sr:            %f Hz\n", configParams.sampleRate);
        printf("-bsize:         %u\n", configParams.fundamentalBlockSize);
        printf("-inchans:       %u\n", configParams.inChannels);
        printf("-outchans:      %u\n", configParams.outChannels);
        printf("-tport:         %d\n", configParams.tuningPort);
        printf("-profStatus:    %u\n", configParams.profileStatus);
        printf("TUNING_MASTER_INSTANCE: %d\n", TUNING_MASTER_INSTANCE);
        printf("Running with same buffer for packet and reply.\n");
        #endif
        FILE *fPtr = NULL;
        memset(g_AWEEmulatedFFS, 0xffu, sizeof(g_AWEEmulatedFFS));
        fPtr = fopen("AWE_FFS_Emulated.bin", "rb");
        if (fPtr)
            INT32 ret;
            ret = fread(g_AWEEmulatedFFS, 1, sizeof(g_AWEEmulatedFFS), fPtr);
            if (ret <= 0)
                printf("Failed to read emulated AWE FFS from the file.");
            fclose(fPtr);
#endif
    audioInputBuffer  = malloc(configParams.inChannels  * configParams.fundamentalBlockSize * sizeof(UINT32));
    audioOutputBuffer = malloc(configParams.outChannels * configParams.fundamentalBlockSize * sizeof(UINT32));
    for (i = 0; i < NUM_INSTANCES; i++)
        g_nPumpCount[i] = 0;
#endif
        InitializeAWEInstance(pInstances[i], i);
    pthread_create(&packetProcessHandles[TUNING_MASTER_INSTANCE], NULL, tuningPacketThread, pInstances[TUNING_MASTER_INSTANCE]);
        if (i != TUNING_MASTER_INSTANCE)
            pthread_create(&packetProcessHandles[i], NULL, packetProcessThread, pInstances[i]);
        sem_init(&pumpSems[i], 0, 0);
        pthread_create(&audioPumpAllThreadHandles[i], NULL, aweuser_pumpAudio, pInstances[i]);
    if (LOAD_MULTICORE_AWB)
        UINT32 position;
        INT32 ret =
awe_loadAWBfromArray(pInstances[TUNING_MASTER_INSTANCE], loopback_dualcore_startAudio_InitCommands, loopback_dualcore_startAudio_InitCommands_Len, &position);
            printf("Error loading awb: error = %d, at offset %u\n", ret, position);
        else
            printf("Loaded multi-instance awb\n");
        pthread_join(packetProcessHandles[i], NULL);
        pthread_join(audioPumpAllThreadHandles[i], NULL);
    free(audioInputBuffer);
    free(audioOutputBuffer);
        free(pInstances[i]->pFastHeapA);
        free(pInstances[i]->pFastHeapB);
        free(pInstances[i]->pSlowHeap);
        free((void*)pInstances[i]->pName);
        free(pInstances[i]);
        free(pFlashFSInstances[i]);
#endif
    return 0;
The AWECore API Header File.
INT32 float_to_fract32(FLOAT32 x)
Definition: AWECoreUtils.h:40
Definition: AWECoreUtils.h:43
INT32 awe_packetProcessMulti(AWEInstance *pAWE, BOOL isTuningInstance)
Multi-instance Wrapper for tuning packet processing.
Audio pump function.
void awe_setInstancesInfo(AWEInstance **pInstances, INT32 numAweInstancesOnCore)
Setup function only intended for systems with multiple AWE Instances in a single core.
INT32 awe_getAverageLayoutCycles(AWEInstance *pAWE, UINT32 layoutIdx, UINT32 *averageCycles)
void awe_initFlashFS(AWEInstance *pAWE, AWEFlashFSInstance *pAWEFlashFSInstance)
Initialize the file system.
Test if AWE is ready to run.
INT32 awe_audioIsReadyToPumpMulti(AWEInstance *pAWE, UINT32 instanceID)
Test if AWE is ready to run on secondary instances (ID > 0).
Initialize the instance.
#define E_MULTI_PACKET_WAITING
Multi-instance packet has been forwarded but has not yet been serviced.
Definition: Errors.h:384
#define E_SUCCESS
OK result.
Definition: Errors.h:31
@ Sample32bit
Data is 32 bit PCM .
The AWE instance.
Definition: AWEInstance.h:82
IOPinDescriptor * pInputPin
Definition: AWEInstance.h:146
const char * pName
Definition: AWEInstance.h:215
float profileSpeed
Profiling clock speed in Hz.
Definition: AWEInstance.h:207
UINT32 * pReplyBuffer
Reply buffer pointer.
Definition: AWEInstance.h:189
UINT32 * pFastHeapB
The second fast heap, B .
Definition: AWEInstance.h:94
UINT32 numThreads
Definition: AWEInstance.h:219
IOPinDescriptor * pOutputPin
Definition: AWEInstance.h:152
UINT32 * pPacketBuffer
The Packet buffer pointer.
Definition: AWEInstance.h:180
Definition: AWEInstance.h:116
OPTIONAL.
Definition: AWEInstance.h:122
UINT32 slowHeapSize
The slow heap size.
Definition: AWEInstance.h:108
Definition: AWEInstance.h:226
UINT32 * pSlowHeap
The slow heap.
Definition: AWEInstance.h:97
float sampleRate
Definition: AWEInstance.h:222
UINT32 packetBufferSize
Packet buffer size.
Definition: AWEInstance.h:196
volatile UINT32 * pSharedHeap
AWE Core shared memory definitions.
Definition: AWEInstance.h:237
UINT32 fastHeapBSize
The fast heap B size.
Definition: AWEInstance.h:105
UINT32 numProcessingInstances
The number of audio processing instances of AWE Core configured on a single target.
Definition: AWEInstance.h:243
UINT32 sharedHeapSize
The shared heap size, in 32-bit words.
Definition: AWEInstance.h:240
Definition: AWEInstance.h:231
float coreSpeed
Definition: AWEInstance.h:204
UINT32 instanceId
The ID of this instance.
Definition: AWEInstance.h:87
UINT32 numModules
Definition: AWEInstance.h:162
Pointer to module table.
Definition: AWEInstance.h:170
UINT32 fastHeapASize
Definition: AWEInstance.h:102
UINT32 * pFastHeapA
Fast heap A.
Definition: AWEInstance.h:91
The DSPC Flash File System Instance.
Definition: FlashFSInstance.h:40
UINT32 flashEraseTimeInMs
Flash erase time in milliseconds.
Definition: FlashFSInstance.h:51
BOOL(* cbFlashRead)(UINT32 nFlashAddress, UINT32 *pBuffer, UINT32 nDWordsToRead)
User function to read from flash.
Definition: FlashFSInstance.h:63
BOOL(* cbFlashWrite)(UINT32 nFlashAddress, UINT32 *pBuffer, UINT32 nDWordsToWrite)
User callback function to write to flash.
Definition: FlashFSInstance.h:60
UINT32 flashStartOffsetInBytes
Offset into start of flash used for file system.
Definition: FlashFSInstance.h:48
UINT32 flashSizeInBytes
Size of flash memory - if non-zero, next two values must also be non-zero.
Definition: FlashFSInstance.h:42
BOOL(* cbEraseSector)(UINT32 nStartingAddress, UINT32 nNumberOfSectors)
User callback function to erase one or more sectors.
Definition: FlashFSInstance.h:57
UINT32 flashErasableBlockSizeInBytes
Size of flash erase block.
Definition: FlashFSInstance.h:45
BOOL(* cbInit)(void)
User function to initialize flash file system.
Definition: FlashFSInstance.h:54
