AWE Core 8.D.11 Documentation
Macros | Functions
AWECoreUtils.h File Reference
The AWECore Helper Functions File. More...
#include "ProxyIDs.h"
#include "Errors.h"
#include "TargetProcessor.h"
Macros
#define MAX_PROCESSING_INSTANCES   (256)
#define PACKET_LENGTH_WORDS(x)   (x[0]>>16)
#define PACKET_LENGTH_BYTES(x)   ((x[0]>>16) * sizeof(x[0]))
#define PACKET_INSTANCEID(x)   (x[0] >> 8) & 0xff
 This will get the instance ID of a packet. More...
#define PACKET_OPCODE(x)   ((INT32)x[0] & 0xffU)
 Get the OPCODE of the packet. More...
#define AWB_DONE   1
 return value that indicates that the end of the AWB has been reached
#define AWB_NOT_DONE   0
 return value that indicates that the end of the AWB has been reached and another command should be processed
#define INCOMPLETE_PACKET   0
#define COMPLETE_NEW_PACKET   1
#define COMPLETE_REPEATED_PACKET   2
#define FLOAT_TO_FRACT32_DEFINED
 Convert audio data from floating point to Fract32 sample by sample. More...
#define FRACT32_TO_FLOAT_DEFINED
 Convert audio data from fract32 to float sample by sample. More...
Functions
void GenerateInstanceTableReply (UINT32 *pPacketBuffer, UINT32 numInstances, UINT32 *pInstanceTable)
 Generate an instance table reply for Server based on the arguments. More...
INT32 float_to_fract32 (FLOAT32 x)
FLOAT32 fract32_to_float (INT32 x)
INT32 awe_getNextAWBCmd (const UINT32 *pArray, UINT32 arraySize, UINT32 *pErrorOffset, UINT32 *pPacketBuffer)
 Get the next command from an array of AWB commands and write it into a packetBuffer to be processed. More...
Detailed Description
Macro Definition Documentation
◆ PACKET_INSTANCEID
#define PACKET_INSTANCEID (   x)    (x[0] >> 8) & 0xff
Examples
singleinstance_simple.c.
◆ PACKET_OPCODE
#define PACKET_OPCODE (   x)    ((INT32)x[0] & 0xffU)
Examples
◆ FLOAT_TO_FRACT32_DEFINED
Parameters
[in]xThe floating point value that you wish to convert
Returns
The converted value in fract32 format
◆ FRACT32_TO_FLOAT_DEFINED
Parameters
[in]xThe fract32 point value that you wish to convert
Returns
The converted value as a float
Function Documentation
◆ GenerateInstanceTableReply()
void GenerateInstanceTableReply ( UINT32 *  pPacketBuffer,
UINT32 *  pInstanceTable
Parameters
[out]pPacketBufferpointer to your instance's packet buffer
[in]numInstancesnumber of instances on your system
[in]pInstanceTablepointer to your instanceID's table
◆ awe_getNextAWBCmd()
INT32 awe_getNextAWBCmd ( const UINT32 *  pArray,
UINT32  arraySize,
UINT32 *  pErrorOffset,
Parameters
[in]*pArrayThe AWB array
[in]arraySizeThe size of the AWB array
[out]*pErrorOffsetcurrent position in the array (index of command)
[in]*pPacketBufferThe packetBuffer to write the next command into.
Returns
AWB_NOT_DONE if processing of array is not complete
