AWE Core 8.D.12 Documentation
Data Structures | |
| struct | _AWEInstance |
| The AWE instance. More... | |
Typedefs | |
| typedef struct _AWEInstance | AWEInstance |
| typedef struct _AWEInstance AWEInstance |
The AWE instance.
