Method table to provide overrides to awe_PluginLoader_initWithMethods.
More...
#include <AWEPluginLoader.h>
void *(* | malloc )(size_t size) |
| | Allocate memory.
void *(* | realloc )(void *ptr, size_t size) |
| | Reallocate memory.
void(* | free )(void *ptr) |
| | Free memory.
void *(* | open )(const char *file) |
| | Open a shared library, returning a handle.
void(* | close )(void *handle) |
| | Close a shared library.
void *(* | sym )(void *handle, const char *name) |
| | Look up a symbol in a shared library.
void(* | vlog )(int32_t level, uint32_t type, const char *fmt, va_list args) |
| | Handle a log message.
This struct defines a set of function pointers which are used by awe_PluginLoader to perform memory allocation, dynamic library loading, and symbol resolution. It should be passed to awe_PluginLoader_initWithMethods. To avoid overriding a default value, leave it null.
