AWE Core 8.D.12 Documentation
Data Fields
_AWEPlugin Struct Reference
A struct encapsulating the functionality which can be provided by a plugin library. More...
#include <AWEPluginTypes.h>
Data Fields
const char * apiVersion
 API version that this plugin was built with. More...
const char * pluginVersion
 Optional plugin version. More...
const char * name
 Optional plugin name. More...
AWEPluginModuleArray modules
 List of module classes provided by the plugin.
void(* cleanup )(const struct _AWEPlugin *)
 Optional destructor. More...
Detailed Description
This struct is to be returned by the plugin's AWEPlugin_initialize entrypoint. Optional fields can be set to NULL.
Field Documentation
◆ apiVersion
const char* _AWEPlugin::apiVersion
Should always be set to AWE_PLUGIN_API_VERSION
◆ pluginVersion
const char* _AWEPlugin::pluginVersion
If the plugin has its own versioning scheme, use this to present that information to the loader. This is currently unused.
◆ name
const char* _AWEPlugin::name
Currently unused, but should be globally unique.
◆ cleanup
void(* _AWEPlugin::cleanup) (const struct _AWEPlugin *)
If set, the loader will call this function before it is freed. Use it to deallocate dynamic memory or any other cleanup task required by the plugin.
