Examples.
#define _GNU_SOURCE
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <unistd.h>
#include <sys/types.h>
#include <sys/socket.h>
#include <errno.h>
#include <signal.h>
#include <netinet/in.h>
#include <pthread.h>
#include <sched.h>
#include <math.h>
#include <time.h>
#include <semaphore.h>
#include <signal.h>
#include <time.h>
#include <sys/time.h>
#include "TargetInfo.h"
float coreSpeed;
float profileSpeed;
float sampleRate;
UINT32 fundamentalBlockSize;
UINT32 inChannels;
UINT32 outChannels;
UINT32 profileStatus;
UINT32 profileOptions;
INT32 tuningPort;
} ConfigParameters;
const unsigned int loopback_dualcore_startAudio_InitCommands[] = {
0x0002000c, 0x00060006, 0x473b8000, 0x40040002, 0x00000100, 0x00000000, 0x00060006, 0x473b8000,
0x40040002, 0x00000100, 0x00000000, 0x00060006, 0x473b8000, 0x40040002, 0x00000100, 0x00000000,
0x00060106, 0x473b8000, 0x40040002, 0x00000100, 0x00000000, 0x00040007, 0x00000001, 0x00000001,
0x00040007, 0x00000002, 0x00000002, 0x000b000f, 0xbeef1039, 0x00000001, 0x00000005, 0x00000003,
0x00000000, 0x00000001, 0x00000000, 0x00000100, 0x00000000, 0x000b010f, 0xbeef1039, 0x00000001,
0x00000005, 0x00000001, 0x00000000, 0x00000001, 0x00000000, 0x00000100, 0x00000000, 0x0009000f,
0xbeef0866, 0x00000101, 0x00000002, 0x00000001, 0x00000003, 0x00000001, 0x00000000, 0x0007000f,
0xbeef086d, 0x00000001, 0x00000001, 0x00000003, 0x00000000, 0x00080065, 0x0000680a, 0x00000000,
0x00000400, 0x00000002, 0xc0a00000, 0x40a00000, 0x000c010f, 0xbeef103a, 0x00000100, 0x00000006,
0x00000001, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000100, 0x00000000, 0x0007010f,
0xbeef086d, 0x00000001, 0x00000001, 0x00000001, 0x00000000, 0x00080165, 0x0000480a, 0x00000000,
0x00000400, 0x00000002, 0xc0a00000, 0x40a00000, 0x000c000f, 0xbeef103a, 0x00000100, 0x00000006,
0x00000003, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000100, 0x00000000, 0x0007000f,
0xbeef086d, 0x00000001, 0x00000001, 0x00000003, 0x00000000, 0x00080065, 0x0000880a, 0x00000000,
0x00000400, 0x00000002, 0xc0a00000, 0x40a00000, 0x0009000f, 0xbeef0866, 0x00000101, 0x00000002,
0x00000003, 0x00000002, 0x00000000, 0x00000001, 0x00040010, 0x00000006, 0x00000001, 0x000a002f,
0x0000000a, 0x00000000, 0x00000005, 0x00000004, 0x00000006, 0x00000007, 0x00000008, 0x00000009,
0x00040110, 0x00000003, 0x00000001, 0x0007012f, 0x00000005, 0x00000000, 0x00000003, 0x00000002,
0x00000004, 0x0006013c, 0x00003008, 0x00000000, 0x00000100, 0x00000000, 0x0006003c, 0x00007008,
0x00000001, 0x00000100, 0x00000000, 0x0002001b, 0x00000000,
const unsigned int loopback_dualcore_startAudio_InitCommands_Len = sizeof(loopback_dualcore_startAudio_InitCommands) / sizeof(int);
#define LOAD_MULTICORE_AWB 1
#define NUM_INSTANCES 4
#ifndef TUNING_MASTER_INSTANCE
#define TUNING_MASTER_INSTANCE 0
#endif
#ifdef ENABLE_FAKE_FLASH_FILE_SYSTEM
#define FLASH_ERASABLE_BLOCK_SIZE 1024*4
#define FLASH_SIZE_PER_INSTANCE 1024*1024*4
#define FLASH_ERASE_TIME_SEC 5
UINT32 g_AWEEmulatedFFS[1024*1024*NUM_INSTANCES];
#endif
#endif
const void* module_descriptor_table_1[] =
LISTOFCLASSOBJECTS
#ifndef LISTOFCLASSOBJECTS2
#define LISTOFCLASSOBJECTS2 LISTOFCLASSOBJECTS
#endif
const void* module_descriptor_table_2[] =
LISTOFCLASSOBJECTS2
UINT32 sharedHeap[SHARED_HEAP_SIZE_LINUX];
UINT32 tuningPacketBuffer[MAX_COMMAND_BUFFER_LEN];
#ifdef USE_SAME_BUFFER_PACKET_REPLY
UINT32 *tuningReplyBuffer = tuningPacketBuffer;
#else
UINT32 tuningReplyBuffer[MAX_COMMAND_BUFFER_LEN];
#endif
UINT32 *audioInputBuffer;
UINT32 *audioOutputBuffer;
pthread_t packetProcessHandles[NUM_INSTANCES];
pthread_t audioPumpAllThreadHandles[NUM_INSTANCES];
sem_t pumpSems[NUM_INSTANCES];
sem_t packetProcessSems[NUM_INSTANCES];
INT32 exitAudioCallbackThread;
INT32 audioStarted;
unsigned long long callbackCnt;
unsigned long long pumpCnts[NUM_INSTANCES];
INT32 quiet;
int sockfd, newsockfd;
int exitPrimaryTuningThread = 0;
int exitSecondaryTuningThreads = 0;
int exitAudioPumpThread = 0;
#define DEFAULT_TUNING_PORT (15092)
#define DEFAULT_BLOCK_SIZE (256)
#define AUDIO_CALLBACK_PRIO (99)
#define AUDIO_PUMP_PRIO (AUDIO_CALLBACK_PRIO - 1)
#define TUNING_THREAD_PRIO (AUDIO_PUMP_PRIO - NUM_INSTANCES)
void error(const char *msg)
perror(msg);
exit(1);
void sig_handler(int signo)
int i;
exitPrimaryTuningThread = 1;
exitAudioPumpThread = 1;
close(newsockfd);
shutdown(sockfd, SHUT_RDWR);
close(sockfd);
pthread_join(packetProcessHandles[TUNING_MASTER_INSTANCE], NULL);
if (pInstances[TUNING_MASTER_INSTANCE]->pPacketBuffer)
UINT32 destroyCommand = (2 << 16) | (TUNING_MASTER_INSTANCE << 8) |
PFID_Destroy;
UINT32 pos = 0;
if (!quiet)
if (ret)
printf("Layout destroy failed, ret = %d\n", ret);
else
printf("Layout destroy success\n");
exitSecondaryTuningThreads = 1;
for (i = 0; i < NUM_INSTANCES; i++)
sem_post(&pumpSems[i]);
sem_post(&packetProcessSems[i]);
pthread_join(packetProcessHandles[i], NULL);
pthread_join(audioPumpAllThreadHandles[i], NULL);
free(audioInputBuffer);
free(audioOutputBuffer);
sem_destroy(&pumpSems[i]);
sem_destroy(&packetProcessSems[i]);
free(pInstances[i]->pFastHeapA);
free(pInstances[i]->pFastHeapB);
free(pInstances[i]->pSlowHeap);
free((void*)pInstances[i]->pName);
free(pInstances[i]);
free(pFlashFSInstances[i]);
#endif
FILE *fPtr = NULL;
fPtr = fopen("AWE_FFS_Emulated.bin", "wb");
if (fPtr)
fwrite(g_AWEEmulatedFFS, 1, sizeof(g_AWEEmulatedFFS), fPtr);
fclose(fPtr);
#endif
if (!quiet)
printf("Exiting LinuxAppMulti\n");
exit(0);
printf(
"Usage: %s [args]\n"
" -profStatus:N set profiling status (0 - disable, 1 - enable(default), 2 - enable module level only, 3 - enable top level only)\n"
" -profOptions:N set accurate profiling option (0 - enable, 1 - disable(default))\n"
" -bsize:N default 256, Audio block size for the system\n"
" -tport:N default 15092, port number for socket interface. User can choose between 15002 - 15098\n"
" -quiet print only error messages\n"
" -h, -help show this message\n"
"This program exercises the AWECore library with 2 AWEInstances.\n",
program);
exit(0);
void usrLogging(
AWEInstance* pAWE, INT32 level, UINT32 type,
void* payload, INT32 payloadSizeInBytes)
struct timeval ts;
char timeCh[25];
char instCh[11];
gettimeofday(&ts, NULL);
snprintf(instCh, 11,
"inst %d - ", (INT32)pAWE->
instanceId);
if (payloadSizeInBytes > 0)
printf("%s%s%s\n", timeCh, instCh, (char *)payload);
INT32 aweuser_forwardPacketCallback(
AWEInstance *pAWE, INT32 instanceID)
(void)pAWE;
if (instanceID < NUM_INSTANCES)
sem_post(&packetProcessSems[instanceID]);
return 0;
void resetTuningSocket()
socklen_t clilen;
struct sockaddr_in cli_addr;
close(newsockfd);
listen(sockfd, 5);
#ifdef TUNING_DEBUG_PRINTS
if (!quiet)
printf("Listening again for connection on port %d\n", configParams.tuningPort);
#endif
clilen = sizeof(cli_addr);
newsockfd = accept(sockfd,
&clilen);
if (newsockfd < 0)
printf("ERROR on accept, %d\n", newsockfd);
return;
if (!quiet)
printf( "Found connection again!\n");
#endif
(void) arg;
socklen_t clilen;
INT32 schedPolicy, ret;
int socketOption;
AWEInstance * pAWE = pInstances[TUNING_MASTER_INSTANCE];
schedPolicy = SCHED_RR;
if (ret != 0)
char threadNameBuffer[16];
snprintf(threadNameBuffer, 16, "awe%d_packet", TUNING_MASTER_INSTANCE);
ret = pthread_setname_np(packetProcessHandles[TUNING_MASTER_INSTANCE], threadNameBuffer);
if (ret)
printf("Failed to set thread name to %s\n", threadNameBuffer);
if (sockfd < 0)
printf("ERROR opening socket, %d\n", sockfd);
return NULL;
socketOption = 1;
sizeof(serv_addr)) < 0)
printf("ERROR on binding\n");
return NULL;
listen(sockfd, 5);
if (!quiet)
&clilen);
if (newsockfd < 0)
return NULL;
if (!quiet)
while (!exitPrimaryTuningThread)
struct timespec ts;
ts.tv_nsec = 500000;
ts.tv_sec = 0;
while(1)
UINT32 plen;
INT32 readBytes, n;
if (readBytes <= 0)
if (readBytes == 0)
printf("ERROR: socket read 0 length packet, attempt to reconnect\n");
else
printf("ERROR: socket read error, attempt to reconnect -- ret = %d, errno = %d\n", readBytes, errno);
#endif
resetTuningSocket();
break;
while (readBytes < plen)
printf("Didn't read the entire packet! readBytes = %d, totalPacketLength = %u\nReading again\n", readBytes, plen);
#endif
readBytes += recv(newsockfd, &((
char*)pAWE->
pPacketBuffer)[readBytes], MAX_COMMAND_BUFFER_LEN *
sizeof(pAWE->
pPacketBuffer[0]), 0);
if (plen <= 0)
printf("Got bad plen = %u\n", plen);
if (n < plen)
printf("ERROR: Packet reply transmit failed -- ret = %d\n", n);
#endif
break;
else
return NULL;
void* packetProcessThread(void * args)
schedParam.sched_priority = TUNING_THREAD_PRIO - instanceId;
if (ret != 0)
printf("Failed to increase priority of tuning thread %d with error: %s \nTry running with sudo\n", instanceId, strerror(ret));
snprintf(threadNameBuffer, 16, "awe%d_packet", instanceId);
pthread_setname_np(packetProcessHandles[instanceId], threadNameBuffer);
if (ret)
if (!quiet)
printf("Starting instance %d packet process thread\n", instanceId);
while (!exitSecondaryTuningThreads)
sem_wait(&packetProcessSems[instanceId]);
return NULL;
void* aweuser_pumpAudio(void * args)
INT32 pumpMask;
INT32 schedPolicy, ret, targetPriority;
targetPriority = AUDIO_PUMP_PRIO - instanceId;
schedParam.sched_priority = targetPriority;
schedPolicy = SCHED_FIFO;
int policy;
pthread_getschedparam(currentHandle, &policy, &schedParam);
if ((SCHED_FIFO != policy) || (schedParam.sched_priority != targetPriority))
printf("Warning: Failed to increase priority of audio simulation thread to %d\nTry running as root\n", targetPriority);
snprintf(threadNameBuffer, 16, "awe%d_pump", instanceId);
ret = pthread_setname_np(audioPumpAllThreadHandles[instanceId], threadNameBuffer);
if (!quiet)
printf("Starting pump thread for instance %d\n", instanceId);
while (!exitAudioPumpThread)
sem_wait(&pumpSems[instanceId]);
if (instanceId == 0)
for (int i = 0; i < configParams.inChannels ; i++)
if (ret)
printf("Error: awe_audioImportSamples() failed, channel = %d, error = %d\n", i, ret);
for (int ix = 1; ix < NUM_INSTANCES; ix++)
sem_post(&pumpSems[ix]);
for (int j = 0; j < pAWE->numThreads; j++)
if (pumpMask & (1U << j))
if (ret > 0)
for (int i = 0; i < configParams.outChannels ; i++)
if (ret)
printf("Error: awe_audioExportSamples() failed, channel = %d, error = %d\n", i, ret);
pumpCnts[instanceId]++;
return NULL;
struct timespec ts;
struct timespec ts_tmp;
long time_nsec;
long long accumulated_time1;
long long accumulated_time2;
long long overshoot = 0.0;
(void) args;
ts.tv_sec = 0;
ts_tmp.tv_sec = 0;
ts_tmp.tv_nsec = 0;
int policy;
if ((SCHED_FIFO != policy) || (schedParam.sched_priority != AUDIO_CALLBACK_PRIO))
printf("Warning: Failed to increase priority of audio simulation thread to %d\nTry running as root\n", AUDIO_CALLBACK_PRIO);
char threadNameBuffer[32];
snprintf(threadNameBuffer, 32, "awe_callback");
ret = pthread_setname_np(audioCallbackThreadHandle, threadNameBuffer);
if (ret)
callbackCnt++;
sem_post(&pumpSems[0]);
ts.tv_nsec = time_nsec - overshoot;
accumulated_time1 = ((long long)ts_tmp.tv_sec*1000000000) + ts_tmp.tv_nsec + time_nsec - overshoot;
while(1)
overshoot = (accumulated_time2 - accumulated_time1);
break;
else
return NULL;
exitAudioCallbackThread = 0;
callbackCnt = 0;
memset(pumpCnts, 0, sizeof(pumpCnts));
INT32 ret = pthread_create(&audioCallbackThreadHandle, NULL, audioCallbackSimulator, NULL);
if (ret)
return 0;
audioStarted = 1;
if (!quiet)
printf("Audio Started\n");
return 0;
if (audioStarted)
INT32 ret;
exitAudioCallbackThread = 1;
if (ret != 0)
if (!quiet)
UINT32 avgCycles;
const FLOAT32 clockRatios = configParams.coreSpeed / configParams.profileSpeed;
printf("\nAudio Stopped\n");
for (int i = 0; i < NUM_INSTANCES; i++)
avgCycles = 0;
printf("-- Pumped instance %d %llu times, average cycles per pump: %f\n", i, pumpCnts[i],
(avgCycles >> 8) * clockRatios);
audioStarted = 0;
return 0;
BOOL usrInitFlashFileSystem(void)
return SUCCESS;
BOOL usrReadFlashMemory(UINT32 nAddress, UINT32 * pBuffer, UINT32 nDWordsToRead)
BOOL bSuccess = 0;
if(nDWordsToRead == 0)
return SUCCESS;
memcpy(pBuffer, &g_AWEEmulatedFFS[nAddress >> 2], nDWordsToRead*sizeof(UINT32));
return SUCCESS;
BOOL usrWriteFlashMemory(UINT32 nAddress, UINT32 * pBuffer, UINT32 nDWordsToWrite)
BOOL bSuccess = 0;
if(nDWordsToWrite == 0)
return SUCCESS;
memcpy(&g_AWEEmulatedFFS[nAddress >> 2], pBuffer, nDWordsToWrite*sizeof(UINT32));
return SUCCESS;
BOOL usrEraseFlashMemorySector(UINT32 nStartingAddress, UINT32 nNumberOfSectors)
memset(&g_AWEEmulatedFFS[nStartingAddress >> 2], 0xffu, nNumberOfSectors * FLASH_ERASABLE_BLOCK_SIZE);
#endif
void InitializeAWEInstance(
AWEInstance * awePtr, INT32 instanceId)
int ret = 0;
UINT32 module_descriptor_table_1_size = sizeof(module_descriptor_table_1) / sizeof(module_descriptor_table_1[0]);
UINT32 module_descriptor_table_2_size = sizeof(module_descriptor_table_2) / sizeof(module_descriptor_table_2[0]);
#endif
pAweFFSPtr->
cbInit = &usrInitFlashFileSystem;
#endif
if (instanceId == NUM_INSTANCES - 1)
awePtr->
numModules = module_descriptor_table_2_size;
else
awePtr->
numModules = module_descriptor_table_1_size;
awePtr->
slowHeapSize = SLOW_HEAP_SIZE_LINUX / NUM_INSTANCES;
awePtr->
pName = malloc(
sizeof(
char) * 8);
sprintf((
char*)awePtr->
pName,
"awe#%d", instanceId);
if (instanceId == TUNING_MASTER_INSTANCE)
int i, j;
ret =
awe_initPin(&aweInputPin, configParams.inChannels, NULL);
if (ret != 0)
printf("awe_initPin inputPin failed on AWEInstance 0\n");
ret =
awe_initPin(&aweOutputPin, configParams.outChannels, NULL);
if (ret != 0)
printf("awe_initPin outputPin failed on AWEInstance 0\n");
#ifndef PI
#define PI 3.141592653589793
#endif
float blockRate = configParams.sampleRate / configParams.fundamentalBlockSize;
audioInputBuffer[i * configParams.inChannels + j] = float_to_fract32(sinf(2.f * PI *
(j + 1) * blockRate * (i / configParams.sampleRate)));
if (ret != 0)
printf("awe_init on instance %d failed with %d\n", instanceId, ret);
else
if (!quiet)
printf("Initialized instance %d\n", instanceId);
int i;
if ((TUNING_MASTER_INSTANCE < 0) || (TUNING_MASTER_INSTANCE >= NUM_INSTANCES))
printf("Provided TUNING_MASTER_INSTANCE of %d is out of range. Value should be [0 %d]\n",TUNING_MASTER_INSTANCE, NUM_INSTANCES-1);
return 0;
configParams.fundamentalBlockSize = DEFAULT_BLOCK_SIZE;
configParams.tuningPort = DEFAULT_TUNING_PORT;
configParams.profileOptions = 1;
quiet = 0;
for (i = 1; i < argc; i++)
const char *arg = argv[i];
else if (0 == strncmp(arg, "-profOptions:", 13))
configParams.profileOptions = atoi(arg + 13);
quiet = 1;
else if ((0 == strncmp(arg, "-help", 5)) || (0 == strncmp(arg, "-h", 2)))
usage(argv[0]);
if (!quiet)
printf("\nAWECore initialised with the following parameters\n");
printf("-cf: %f Hz\n", configParams.coreSpeed);
printf("-pf: %f Hz\n", configParams.profileSpeed);
printf("-sr: %f Hz\n", configParams.sampleRate);
printf("-bsize: %u\n", configParams.fundamentalBlockSize);
printf("-inchans: %u\n", configParams.inChannels);
printf("-outchans: %u\n", configParams.outChannels);
printf("-tport: %d\n", configParams.tuningPort);
printf("-profStatus: %u\n", configParams.profileStatus);
printf("-profOptions: %u\n", configParams.profileOptions);
printf("TUNING_MASTER_INSTANCE: %d\n", TUNING_MASTER_INSTANCE);
printf("Running with same buffer for packet and reply.\n");
#endif
FILE *fPtr = NULL;
memset(g_AWEEmulatedFFS, 0xffu, sizeof(g_AWEEmulatedFFS));
fPtr = fopen("AWE_FFS_Emulated.bin", "rb");
if (fPtr)
INT32 ret;
ret = fread(g_AWEEmulatedFFS, 1, sizeof(g_AWEEmulatedFFS), fPtr);
if (ret <= 0)
printf("Failed to read emulated AWE FFS from the file.");
fclose(fPtr);
#endif
audioInputBuffer = malloc(configParams.inChannels * configParams.fundamentalBlockSize * sizeof(UINT32));
audioOutputBuffer = malloc(configParams.outChannels * configParams.fundamentalBlockSize * sizeof(UINT32));
#endif
InitializeAWEInstance(pInstances[i], i);
if (configParams.profileOptions == 1)
else
pthread_create(&packetProcessHandles[TUNING_MASTER_INSTANCE], NULL, tuningPacketThread, pInstances[TUNING_MASTER_INSTANCE]);
sem_init(&packetProcessSems[i], 0, 0);
if (i != TUNING_MASTER_INSTANCE)
pthread_create(&packetProcessHandles[i], NULL, packetProcessThread, pInstances[i]);
sem_init(&pumpSems[i], 0, 0);
pthread_create(&audioPumpAllThreadHandles[i], NULL, aweuser_pumpAudio, pInstances[i]);
if (LOAD_MULTICORE_AWB)
UINT32 position;
INT32 ret =
awe_loadAWBfromArray(pInstances[TUNING_MASTER_INSTANCE], loopback_dualcore_startAudio_InitCommands, loopback_dualcore_startAudio_InitCommands_Len, &position);
printf("Error loading awb: error = %d, at offset %u\n", ret, position);
else
printf("Loaded multi-instance awb\n");
while (1)
struct timespec ts;
ts.tv_nsec = 100000000;
ts.tv_sec = 0;
return 0;
The AWECore API Header File.
Definition: AWECoreUtils.h:40
Definition: AWECoreUtils.h:43
INT32 awe_packetProcessMulti(AWEInstance *pAWE, BOOL isTuningInstance)
Multi-instance Wrapper for tuning packet processing.
Audio pump function.
void awe_setInstancesInfo(AWEInstance **pInstances, INT32 numAweInstancesOnCore)
Setup function only intended for systems with multiple AWE Instances in a single core.
INT32 awe_registerLoggingCallback(AWEInstance *pAWE, cbAweLogging_t cbAweLogging, INT32 logLevel, UINT32 logTypeMask)
INT32 awe_audioIsStartedMulti(const AWEInstance *pAWE)
Check if all instances are running in multi-instance system.
INT32 awe_getAverageLayoutCycles(AWEInstance *pAWE, UINT32 layoutIdx, UINT32 *averageCycles)
void awe_initFlashFS(AWEInstance *pAWE, AWEFlashFSInstance *pAWEFlashFSInstance)
Initialize the file system.
INT32 awe_setProfilingOptions(AWEInstance *pAWE, UINT32 optionsMask, UINT32 profilingOptions)
Function to set profiling options like average or peak profiling on modules and turn on or off accura...
Test if AWE is ready to run.
INT32 awe_audioIsReadyToPumpMulti(AWEInstance *pAWE, UINT32 instanceID)
Test if AWE is ready to run on secondary instances (ID > 0).
Initialize the instance.
#define E_MULTI_PACKET_WAITING
Multi-instance packet has been forwarded but has not yet been serviced.
Definition: Errors.h:384
#define E_SUCCESS
OK result.
Definition: Errors.h:31
@ PFID_Destroy
Function ID for awe_fwDestroy().
Definition: ProxyIDs.h:68
@ Sample32bit
Data is 32 bit PCM .
The AWE instance.
Definition: AWEInstance.h:109
IOPinDescriptor * pInputPin
Definition: AWEInstance.h:181
const char * pName
Definition: AWEInstance.h:253
float profileSpeed
Profiling clock speed in Hz.
Definition: AWEInstance.h:245
UINT32 * pReplyBuffer
Reply buffer pointer.
Definition: AWEInstance.h:227
UINT32 * pFastHeapB
The second fast heap, B .
Definition: AWEInstance.h:121
UINT32 numThreads
Definition: AWEInstance.h:257
IOPinDescriptor * pOutputPin
Definition: AWEInstance.h:187
UINT32 * pPacketBuffer
The Packet buffer pointer.
Definition: AWEInstance.h:218
Definition: AWEInstance.h:143
OPTIONAL.
Definition: AWEInstance.h:149
UINT32 slowHeapSize
The slow heap size.
Definition: AWEInstance.h:135
Definition: AWEInstance.h:264
UINT32 * pSlowHeap
The slow heap.
Definition: AWEInstance.h:124
float sampleRate
Definition: AWEInstance.h:260
UINT32 packetBufferSize
Packet buffer size.
Definition: AWEInstance.h:234
volatile UINT32 * pSharedHeap
AWE Core shared memory definitions.
Definition: AWEInstance.h:275
UINT32 fastHeapBSize
The fast heap B size.
Definition: AWEInstance.h:132
INT32(* cbAweForwardPacket)(struct _AWEInstance *pAWE, INT32 instanceID)
OPTIONAL This callback is invoked from awe_packetProcessMulti when the received packet is to secondar...
Definition: AWEInstance.h:173
UINT32 numProcessingInstances
The number of audio processing instances of AWE Core configured on a single target.
Definition: AWEInstance.h:281
UINT32 sharedHeapSize
The shared heap size, in 32-bit words.
Definition: AWEInstance.h:278
Definition: AWEInstance.h:269
float coreSpeed
Definition: AWEInstance.h:242
UINT32 instanceId
The ID of this instance.
Definition: AWEInstance.h:114
UINT32 numModules
Definition: AWEInstance.h:197
Pointer to module table.
Definition: AWEInstance.h:205
UINT32 fastHeapASize
Definition: AWEInstance.h:129
UINT32 * pFastHeapA
Fast heap A.
Definition: AWEInstance.h:118
The DSPC Flash File System Instance.
Definition: FlashFSInstance.h:40
UINT32 flashEraseTimeInMs
Flash erase time in milliseconds.
Definition: FlashFSInstance.h:51
BOOL(* cbFlashRead)(UINT32 nFlashAddress, UINT32 *pBuffer, UINT32 nDWordsToRead)
User function to read from flash.
Definition: FlashFSInstance.h:63
BOOL(* cbFlashWrite)(UINT32 nFlashAddress, UINT32 *pBuffer, UINT32 nDWordsToWrite)
User callback function to write to flash.
Definition: FlashFSInstance.h:60
UINT32 flashStartOffsetInBytes
Offset into start of flash used for file system.
Definition: FlashFSInstance.h:48
UINT32 flashSizeInBytes
Size of flash memory - if non-zero, next two values must also be non-zero.
Definition: FlashFSInstance.h:42
BOOL(* cbEraseSector)(UINT32 nStartingAddress, UINT32 nNumberOfSectors)
User callback function to erase one or more sectors.
Definition: FlashFSInstance.h:57
UINT32 flashErasableBlockSizeInBytes
Size of flash erase block.
Definition: FlashFSInstance.h:45
BOOL(* cbInit)(void)
User function to initialize flash file system.
Definition: FlashFSInstance.h:54
