AWE Core 8.D.12 Documentation
Data Fields
_AWEFlashFSInstance Struct Reference
The DSPC Flash File System Instance. More...
#include <Include/FlashFSInstance.h>
Data Fields
UINT32 flashSizeInBytes
 Size of flash memory - if non-zero, next two values must also be non-zero.
UINT32 flashErasableBlockSizeInBytes
 Size of flash erase block.
UINT32 flashStartOffsetInBytes
 Offset into start of flash used for file system.
UINT32 flashEraseTimeInMs
 Flash erase time in milliseconds.
BOOL(* cbInit )(void)
 User function to initialize flash file system.
BOOL(* cbEraseSector )(UINT32 nStartingAddress, UINT32 nNumberOfSectors)
 User callback function to erase one or more sectors.
BOOL(* cbFlashWrite )(UINT32 nFlashAddress, UINT32 *pBuffer, UINT32 nDWordsToWrite)
 User callback function to write to flash.
BOOL(* cbFlashRead )(UINT32 nFlashAddress, UINT32 *pBuffer, UINT32 nDWordsToRead)
 User function to read from flash.
INT32(* cbFlashProcessCmd )(struct _AWEInstance *pAWE)
 Optional user callback function to return the next command from an awb in flash. More...
UINT32 _Reserved [59]
 Reserved member.
Detailed Description
Optional – SINGLE INSTANCE ONLY
Examples
LinuxAppMulti.c.
Field Documentation
◆ cbFlashProcessCmd
INT32(* _AWEFlashFSInstance::cbFlashProcessCmd) (struct _AWEInstance *pAWE)
Only required for multi-instance BSPs. If not defined, awb commands are processed internally in the associated AWEInstance. The command to be processed is in pAWE->pPacketBuffer. Parse the instanceID/opcode with AWECoreUtils, and route/process it on the desired instance.
