AWE Core 8.D.13 Documentation
Loading...
Searching...
No Matches
Data Structures | Typedefs | Functions
Module Descriptor List
Mutate the list of available module classes at runtime. More...
Data Structures
struct  _ModuleDescriptorListEntry
 Element of _ModuleDescriptorList. More...
 Linked list containing module descriptor entries. More...
Typedefs
typedef struct _ModuleDescriptorListEntry ModuleDescriptorListEntry
typedef struct _ModuleDescriptorList ModuleDescriptorList
Functions
bool _ModuleDescriptorList::awe_moduleDescriptorList_prepend (ModuleDescriptorList *list, ModuleDescriptorListEntry *entry)
 Insert an entry at the beginning of the list.
bool _ModuleDescriptorList::awe_moduleDescriptorList_append (ModuleDescriptorList *list, ModuleDescriptorListEntry *entry)
 Insert an entry at the end of the list.
ModuleDescriptorListEntry_ModuleDescriptorList::awe_moduleDescriptorList_removeHead (ModuleDescriptorList *list)
 Remove the first entry of the module descriptor list.
Detailed Description
Typedef Documentation
◆ ModuleDescriptorListEntry
Contains a pointer to an array of module descriptors (used by awe_moduleDescriptorList_* API functions).
See also
Should be initialized to zeros and manipulated with mutator functions.
Function Documentation
◆ awe_moduleDescriptorList_prepend()
bool awe_moduleDescriptorList_prepend ( ModuleDescriptorList list,
ModuleDescriptorListEntry entry
Parameters
[in]listModuleDescriptorList to mutate.
[in]entryEntry to prepend. Note that the list does not take ownership of the entry. If it was dynamically allocated, the caller is responsible for freeing it.
Returns
True if the operation was successful, false otherwise.
◆ awe_moduleDescriptorList_append()
bool awe_moduleDescriptorList_append ( ModuleDescriptorList list,
Parameters
[in]entryEntry to append. Note that the list does not take ownership of the entry. If it was dynamically allocated, the caller is responsible for freeing it.
Returns
◆ awe_moduleDescriptorList_removeHead()
ModuleDescriptorListEntry * awe_moduleDescriptorList_removeHead ( ModuleDescriptorList list)
Parameters
Returns
The entry which was removed, or NULL if the list is empty/invalid. If the entry was dynamically allocated, then it is now safe to free it.
