HelloWorld.c
Examples.
Examples
* Hello World
* Description: Initialize an AWEOSInstance, open a tuning interface, connect to AWE Server. AWE Server will display the instance name "HiWorld"
* 3235 Kifer Road
* Santa Clara, CA 95054-1527
* This example demonstrates initializing an AWEOSInstance and opening an integrated tuning interface. All default parameters are used, except for the instance name, which is changed to "HiWorld".
* With this simple application, an integrated tuning socket is opened on port 15002. Run the example, and use AWE Server to connect via <Target's IP adress> and port 15002
* This example is not realtime audio enabled, however module regression tests can be run from Matlab. (As long as they are not RT tests)
#include <stdio.h>
#include "AWECoreOS.h"
#include "ModuleList.h"
#define PORTNO 15002
//Step 1: Declare an AWEInstance pointer. This will be your handle that is passed in to most of the functions. Memory for the instance is allocated by aweOS_init()
//Step 2: Declare an AWEOSConfigParameters structure. The members of this structure determine the configuration of the AWEInstance members. For this example, it will be populated with defaults
//Step 3: Declare a module descriptor table which will be passed into aweOS_init. This module descriptor table includes the modules as defined in ModuleList.h.
LISTOFCLASSOBJECTS
//Step 4: Calculate the size of the module descriptor table, which will be passed in to aweOS_init.
int main()
printf("Entering Default Configuration Example ... \n");
//Step 5: Populate the configParams structure with DSPC defined default values.
//Step 5a. Overwrite the name to "HiWorld"
configParams.pName = "HiWorld";
//Step 6: Initialize the AWEInstance with the parameters that were previously set in the config structure. This will allocate the AWEInstance, assign its members, etc.
INT32 ret = aweOS_init(&g_AWEOSInstance, &configParams, moduleDescriptorTable, moduleDescriptorTableSize);
//Step 7: Check if the aweOS_init succeeded. If it didn't then terminate the executable.
if (ret != 0)
printf("aweOS_init failed with error code %d %s. exiting application \n", ret, aweOS_errorToString(ret));
else
printf("AWEOSInstance succesfully initialized... \n");
//Step 8 (OPTIONAL): Open the aweOS integrated tuning interface. Note that this cannot be called before a succesful initialization. If called without succesful aweOS_init, it will fail
INT32 interfaceRet = aweOS_tuningSocketOpen(&g_AWEOSInstance, PORTNO, 1);
if (interfaceRet != 0)
printf("Failed to open integrated tuning interface \n");
else
printf("Opened TCP tuning interface on port %d: Waiting for AWE Server Connection from PC... \n", PORTNO);
//Step 9: Enter main idle loop
while (1)
usleep(1000);
return 0;
void AWEOSInstance
Definition: AWECoreOS.h:106
AWEOSConfigParameters.
Definition: AWECoreOS.h:117
const char * pName
Name of target.
Definition: AWECoreOS.h:133
