Typedefs | |
| typedef void(* | cbAweOSLogging_t) (AWEOSInstance *pAWEOS, INT32 level, UINT32 type, void *payload, INT32 payloadSizeInBytes) |
| OPTIONAL This callback is invoked from multiple places in the AWE framework to log any message to the BSP. More... | |
| typedef INT32(* | cbAweOSEventTrigger_t) (AWEOSInstance *pAWEOS, INT32 eventType, UINT32 moduleObjId, void *payload, INT32 payloadSizeInBytes, void *userHandle) |
| OPTIONAL These callback are invoked only from the Event Module. More... | |
| typedef INT32(* | cbAweOSEventRegister_t) (AWEOSInstance *pAWEOS, INT32 eventType, UINT32 moduleObjId, INT32 payloadSizeInBytes, void **userHandle) |
| The Event Register callback is called by an Event Module when it is constructed. More... | |
| typedef INT32(* | cbAweOSEventDeregister_t) (AWEOSInstance *pAWEOS, INT32 eventType, UINT32 moduleObjId, void **userHandle) |
| The Event Deregister callback is called by the Event Module when it is destroyed. More... | |
Functions | |
| UINT32 | aweOS_getThreadPIDs (AWEOSInstance *pAWEOS, AWEOSThreadPIDs_t *threadPIDs) |
| Return the PIDs of all internally spawned AWE Core OS threads. More... | |
| INT32 | aweOS_getParamDefaults (AWEOSConfigParameters *aweParams) |
| Populates an AWEOSConfigParameters structure with defaults. More... | |
| INT32 | aweOS_init (AWEOSInstance **pAWEOS, const AWEOSConfigParameters *aweParams, const void *pModuleDescriptorTable, UINT32 moduleDescriptorTableSize) |
| Initialize the AWEOSInstance with the specified configuration parameters. More... | |
| INT32 | aweOS_tuningSocketOpen (AWEOSInstance **pAWEOS, INT32 portNo, UINT32 numInstances) |
| Initialize and open an integrated TCP/IP tuning interface socket. More... | |
| void | aweOS_tuningSocketClose (AWEOSInstance *pAWEOS) |
| Close a running integrated TCP tuning socket. More... | |
| INT32 | aweOS_tuningLoggingEnable (AWEOSInstance *pAWEOS, char *path, char *baseName, UINT32 verbosity) |
| Enable logging of the tuning packets sent and received by the AWEOSInstance. More... | |
| INT32 | aweOS_loadAWBFromArray (AWEOSInstance *pAWEOS, const UINT32 *pArray, UINT32 arraySize, UINT32 *pErrorOffset) |
| Executes packet commands from an in-memory array. More... | |
| INT32 | aweOS_loadAWBFile (AWEOSInstance *pAWEOS, const char *binaryFile, UINT32 *pErrorOffset) |
| Executes packet commands from an AWB file on the filesystem. More... | |
| INT32 | aweOS_layoutGetChannelCount (const AWEOSInstance *pAWEOS, UINT32 *inCount, UINT32 *outCount) |
| Returns the number of input and output channels in the loaded layout. More... | |
| INT32 | aweOS_layoutGetBlockSize (const AWEOSInstance *pAWEOS, UINT32 *blockSize) |
| Returns the block size of the loaded layout. More... | |
| INT32 | aweOS_layoutGetSampleRate (const AWEOSInstance *pAWEOS, FLOAT32 *sampleRate) |
| Returns the sample rate of the loaded layout. More... | |
| INT32 | aweOS_audioPumpAll (AWEOSInstance *pAWEOS) |
| Pump one fundamental block size of audio through the loaded layout and all of its sublayouts. More... | |
| INT32 | aweOS_audioImportSamples (AWEOSInstance *pAWEOS, void *inSamples, INT32 inStride, INT32 channel, SampleType inType) |
| Import samples from an audio buffer to a specific channel of the AWEOSInstance's input pin. More... | |
| INT32 | aweOS_audioExportSamples (AWEOSInstance *pAWEOS, void *outSamples, INT32 outStride, INT32 channel, SampleType outType) |
| Export samples to a user buffer from a specific channel of the AWEOSInstance's output pin. More... | |
| INT32 | aweOS_layoutIsValid (const AWEOSInstance *pAWEOS) |
| Determines if a layout is loaded and valid. More... | |
| INT32 | aweOS_audioIsStarted (const AWEOSInstance *pAWEOS) |
| Check if this instance has received an Audio Start command. More... | |
| const char * | aweOS_errorToString (INT32 errorCode) |
| Convert an error code (INT32) to its corresponding error string. More... | |
| INT32 | aweOS_tuningPacketProcess (AWEOSInstance *pAWEOS) |
| Process the packet buffer in the AWEOSInstance. More... | |
| INT32 | aweOS_ctrlSetValue (const AWEOSInstance *pAWEOS, UINT32 handle, void *value, INT32 arrayOffset, UINT32 length) |
| Set a scalar or array value(s) of a module parameter by handle. More... | |
| INT32 | aweOS_ctrlGetValue (const AWEOSInstance *pAWEOS, UINT32 handle, void *value, INT32 arrayOffset, UINT32 length) |
| Get a scalar or array value(s) of a module parameter by handle. More... | |
| INT32 | aweOS_ctrlSetStatus (const AWEOSInstance *pAWEOS, UINT32 handle, UINT32 *status) |
| Set the status of a module. More... | |
| INT32 | aweOS_ctrlGetStatus (const AWEOSInstance *pAWEOS, UINT32 handle, UINT32 *status) |
| Get the status of a module. More... | |
| INT32 | aweOS_ctrlSetValueMask (const AWEOSInstance *pAWEOS, UINT32 handle, void *value, INT32 arrayOffset, UINT32 length, UINT32 mask) |
| Set a scalar or array value(s) of a module variable by handle with mask. More... | |
| INT32 | aweOS_ctrlGetValueMask (const AWEOSInstance *pAWEOS, UINT32 handle, void *value, INT32 arrayOffset, UINT32 length, UINT32 mask) |
| Get a scalar or array value(s) of a module variable by handle with mask. More... | |
| INT32 | aweOS_ctrlGetModuleClass (const AWEOSInstance *pAWEOS, UINT32 handle, UINT32 *pClassID) |
| Get a module's object class from its handle. More... | |
| INT32 | aweOS_destroy (AWEOSInstance **pAWEOS) |
| Destroys the AWEOSInstance and closes all associated threads. More... | |
| INT32 | aweOS_setProfilingStatus (AWEOSInstance *pAWEOS, UINT32 status) |
| Enable or disable the profiling ability of the AWE Core OS Instance. More... | |
| INT32 | aweOS_getAverageLayoutCycles (AWEOSInstance *pAWEOS, UINT32 idx, UINT32 *averageCycles) |
| Get the average cycles of a running layout, in units of cycles at profileSpeed. More... | |
| void | aweOS_getVersion (AWEOSVersionInfo_t *versionInfo) |
| Get the version information of the AWE Core OS library. More... | |
| INT32 | aweOS_audioRecordingEnable (AWEOSInstance *pAWEOS, char *path, char *baseName, UINT32 bufferLength, SampleType sampleType) |
| Enables recording of all input and output audio of AWEOSInstance. More... | |
| INT32 | aweOS_audioRecordingRegisterNotificationCallback (AWEOSInstance *pAWEOS, recordNotificationCallbackFunction recordNotificationCallback, UINT32 recordNotificationMask) |
| Register a callback function for audio recording event notificiations. More... | |
| INT32 | aweOS_audioRecordingDisable (AWEOSInstance *pAWEOS) |
| Disable recording of input and output audio of AWEOSInstance. More... | |
| INT32 | aweOS_wavFileOpen (const char *file, FLOAT32 *sampleRate, UINT32 *numChannels, UINT32 *sampleSize, UINT32 *numSamples, FILE **fp) |
| Open a .wav file and populate the user arguments with the header information in the file. More... | |
| INT32 | aweOS_wavFileCreate (const char *file, FLOAT32 sampleRate, UINT32 numChannels, UINT32 sampleSize, FILE **fp) |
| Create a .wav file and populate the header with the passed in arguments. More... | |
| INT32 | aweOS_wavFileWrite (FILE *fp, void *samples, UINT32 numSamples, UINT32 sampleSize) |
| Write audio data to .wav file created using aweOS_wavFileCreate. More... | |
| INT32 | aweOS_wavFileRead (FILE *fp, void *samples, UINT32 numSamples, UINT32 sampleSize) |
| Read audio data from .wav file opened using aweOS_wavFileOpen. More... | |
| INT32 | aweOS_wavFileClose (FILE *fp) |
| Close the.wav file opened using aweOS_wavFileOpen or aweOS_wavFileCreate. More... | |
| INT32 | aweOS_setInstancesInfo (AWEOSInstance **pInstances, INT32 numInstances) |
| Profiling related setup function only intended for systems with multiple AWEOS Instances in a single application. More... | |
| INT32 | aweOS_registerLoggingCallback (AWEOSInstance *pAWEOS, cbAweOSLogging_t cbAweOSLogging, INT32 logLevel, UINT32 logTypeMask) |
| Register the logging callback with required logging level and logging type mask. More... | |
| INT32 | aweOS_registerEventCallbacks (AWEOSInstance *pAWEOS, cbAweOSEventTrigger_t cbAweOSEventTrigger, cbAweOSEventRegister_t cbAweOSEventRegister, cbAweOSEventDeregister_t cbAweOSEventDeregister) |
| Register the event callbacks used by the Event Module. More... | |
| typedef void(* cbAweOSLogging_t) (AWEOSInstance *pAWEOS, INT32 level, UINT32 type, void *payload, INT32 payloadSizeInBytes) |
User should register the callback via aweOS_registerLoggingCallback, which requires logging level and type mask. type is a 32-bit bitfield, with each bit representing a type of message. These types are defined in the framework and provide information about where the logging messages come from.
| typedef INT32(* cbAweOSEventTrigger_t) (AWEOSInstance *pAWEOS, INT32 eventType, UINT32 moduleObjId, void *payload, INT32 payloadSizeInBytes, void *userHandle) |
Use the aweOS_registerEventCallbacks to register them The Event Trigger callback is called when an Event Module is triggered in the layout. Depending on the Event Module configuration, this may happen inline in the module processing, or it may happen during deferred processing. In the latter case, there may be a delay between the actual event trigger and calling this Event Trigger callback. If this returns a negative number, then it is assumed that the Event Trigger was not successfully processed and the module's numFailedTriggers parameter will increment. If there is no Event Trigger callback registered, then the Event Module can never generate an event.
| typedef INT32(* cbAweOSEventRegister_t) (AWEOSInstance *pAWEOS, INT32 eventType, UINT32 moduleObjId, INT32 payloadSizeInBytes, void **userHandle) |
| typedef INT32(* cbAweOSEventDeregister_t) (AWEOSInstance *pAWEOS, INT32 eventType, UINT32 moduleObjId, void **userHandle) |
| UINT32 aweOS_getThreadPIDs | ( | AWEOSInstance * | pAWEOS, |
| AWEOSThreadPIDs_t * | threadPIDs | ||
Get the PIDs of internal AWE Core OS pump, work, and socket threads. Provide a pointer to an AWEOSThreadPIDs struct, which is populated with available IDs when the API is called. See the AWEOSThreadPIDs struct for details. The max size of the pumpThreadPIDs array will always be numThreads If no layout is loaded, numPumpThreads and pumpThreadPIDs are zeroed. If the user does not open a tuning socket, socketThreadPID = 0.
Note: Only internally spawned pump thread PIDs will be returned, NOT the main audio thread (created by user, calls aweOS_audioPumpAll()). In low latency mode (layoutBS == fundamentalBS), the base layout audio pump is executed on the MAIN USER AUDIO THREAD. As a result, this API will skip the base layout, and begin the PID returning at the second layout.
| [in] | pAWEOS | AWE Core OS instance pointer |
| [in] | threadPIDs | AWEOSThreadPIDs struct ptr which is populated with PIDs |
| INT32 aweOS_getParamDefaults | ( | AWEOSConfigParameters * | aweParams | ) |
Once it has been populated with defaults, the user can overwrite the members as needed for custom configuration.
If heap pointers are left as NULL, then the aweOS_init function internally allocates heaps of the sizes specified by the heapSize parameters. If a user wants specific control of heap memory locations, allocate the memory for the heaps before calling aweOS_init and overwrite the heapSize parameters with the allocated sizes.
pPacketBuffer and pReplyBuffer should only be non-NULL if a user created tuning interface is being used in place of aweOS_tuningSocketOpen.
| [out] | aweParams | the AWEOSConfigParameters struct |
| INT32 aweOS_init | ( | AWEOSInstance ** | pAWEOS, |
| const AWEOSConfigParameters * | aweParams, | ||
| const void * | pModuleDescriptorTable, | ||
| UINT32 | moduleDescriptorTableSize | ||
A user will define an AWEOSInstance pointer (handle) and pass a pointer to it (double pointer) to this function, along with the configured aweParams struct (see AWEOSConfigParameters). The AWEOSInstance will be allocated and then its members will be set with the values of the user's aweParams. This function must be called before using any other function that requires an AWEOSInstance as an argument. Failure to do so will lead to memory corruption and program crashes.
| [out] | pAWEOS | Double pointer to the AWEOSInstance variable. This will be the "handle" of the AWEOSInstance. |
| [in] | aweParams | The user's AWEOSConfigParameters structure |
| [in] | pModuleDescriptorTable | A ptr to the module table (see ModuleList.h) |
| [in] | moduleDescriptorTableSize | The size of the moduleDescriptorTable |
| INT32 aweOS_tuningSocketOpen | ( | AWEOSInstance ** | pAWEOS, |
| INT32 | portNo, | ||
| UINT32 | numInstances | ||
AWE Core OS has an optional integrated tuning interface that is enabled by calling this function after the AWEOSInstance has been initialized. A TCP socket is opened on the specified port for the passed in instance. For multiple AWEOSInstances on a single tuning interface, pass in the array of instances and the number of instances. For a single shared tuning interface, each AWEOSInstance's instanceID should be uniquely configured to 0, 16, 32, etc. For multiple AWEOSInstances where each instance has it's own tuning interface, call this function for each instance with unique ports for each call. For multiple sockets, both instance's should be configured with instanceID member set to 0. See the MultiInstance example for more information.
| [in] | pAWEOS | AWE Core OS instance double pointer |
| [in] | portNo | port to open the socket on. Must be even number between 15002 and 15098 |
| [in] | numInstances | number of AWEOSInstances that the opened socket will service. If using Multi-Instance single socket, then this will be the number of instances in the array. For single instances, always pass in 1. |
| void aweOS_tuningSocketClose | ( | AWEOSInstance * | pAWEOS | ) |
Call this function to close an AWEOSInstance's integrated tuning socket. Note: For a multi-instance tuning integrated socket, aweOS_tuningSocketClose only needs to be called on the first instance in the array. For multiple sockets, aweOS_tuningSocketClose should be called for each instance with an open socket.
| INT32 aweOS_tuningLoggingEnable | ( | AWEOSInstance * | pAWEOS, |
| char * | path, | ||
| char * | baseName, | ||
| UINT32 | verbosity | ||
Will create new uniquely named .log files in the specified directory. Logging tuning packets can be useful for debugging purposes. This will only log packets sent and received by the internal socket based tuning interface enabled with aweOS_tuningSocketOpen. Tuning logging is disabled by default. Call this after aweOS_init for proper functionality. The output file path and name are set only on the first call to this function. Subsequent calls can be used only to update the verbosity level of the logging (TUNING_LOG_NONE can be used to stop logging entirely). If aweOS_tuningSocketClose or aweOS_destroy are called, then this function must be called again to re-enable tuning packet logging.
| [in] | path | Path to desired logging directory. Will use current directory if NULL or "" |
| [in] | baseName | Base name of logging file. Will use 'awe_tuning' if NULL or "". path + baseName must be < 1024 chars. |
| [in] | verbosity | Verbosity level of tuning log. One of TUNING_LOG_NONE, TUNING_LOG_ERROR, TUNING_LOG_INFO, TUNING_LOG_DATA |
| INT32 aweOS_loadAWBFromArray | ( | AWEOSInstance * | pAWEOS, |
| const UINT32 * | pArray, | ||
| UINT32 | arraySize, | ||
| UINT32 * | pErrorOffset | ||
AWE Designer can generate AWB arrays directly from a layout, which can then be compiled directly into the application. See Tools->Generate Target Files in Designer.
| [in] | pArray | Array of commands |
| [in] | arraySize | Size of command array |
| [out] | pErrorOffset | Report failing word index |
| INT32 aweOS_loadAWBFile | ( | AWEOSInstance * | pAWEOS, |
| const char * | binaryFile, | ||
AWB files can be generated for any layout from AWE Designer using Tools->Generate Target Files.
| [in] | binaryFile | full filepath to AWB file on fileystem |
| INT32 aweOS_layoutGetChannelCount | ( | const AWEOSInstance * | pAWEOS, |
| UINT32 * | inCount, | ||
| UINT32 * | outCount | ||
| [out] | inCount | number of input channels |
| [out] | outCount | number of output channles |
| INT32 aweOS_layoutGetBlockSize | ( | const AWEOSInstance * | pAWEOS, |
| UINT32 * | blockSize | ||
Input and output blockSize are the same for all layouts.
| [out] | blockSize | block size of layout |
| INT32 aweOS_layoutGetSampleRate | ( | const AWEOSInstance * | pAWEOS, |
| FLOAT32 * | sampleRate | ||
Input and output sample rates are the same for all layouts.
| [out] | sampleRate | sample rate of layout |
| INT32 aweOS_audioPumpAll | ( | AWEOSInstance * | pAWEOS | ) |
This function will coordinate the audio processing threads to process audio through the loaded layouts and sublayouts as needed. The user calls this function in their audio callback, which should be set to the highest priority possible on the system, after calling aweOS_audioImportSamples and aweOS_audioExportSamples. Each sublayout (including the base layout) gets its own thread where the audio will be pumped. The priority level of each sublayout's pump thread will decrement by one from the audio callback's priority level. For example, if the audio callback has priority 99, and the loaded layout has 2 sublayouts, 1 with a clockdivider of 1 and the other with a clockdivider of 16, thread priority levels will be: (audiocallback: 99, pumpthread0: 98, pumpthread1: 97). AWE Core OS names these threads if given permission, and the names/priorities can be seen with top/htop in Linux. To ensure a close to real-time priority system, the priority level of the audio callback that calls this function must be greater than (AWEOSConfigParameters.numThreads + 2). If this function is not called at a high enough priority to set the decreasing priorities, all pumpthreads are set to the current priority, and E_PRIORITY_NOT_HI_ENOUGH is returned. Users can ignore this error at their own risk. If this function isn't called at any RT priority level, then E_CALLBACK_NOT_REALTIME is returned. Note: Linux requires elevated privileges to change thread priority levels (i.e., application should be run as root). If the application does not have permission to set priorities, then E_PRIORITY_NOT_HI_ENOUGH is returned.
| INT32 aweOS_audioImportSamples | ( | AWEOSInstance * | pAWEOS, |
| void * | inSamples, | ||
| INT32 | inStride, | ||
| INT32 | channel, | ||
| SampleType | inType | ||
The value of the fundamentalBlockSize member of the AWEOSInstance determines the number of samples that are imported with each call. Call this function once for each audio channel available from the input audio device. Channel matching between hardware capabilities and layout will be done automatically. For example, if the audio device has only 1 audio input channel, and if a layout with 3 input channels is loaded, the second and third channels of the layout input will be all zeros. Inversely, if there are more input audio device channels than the layout expects, then they are ignored.
The value of inStride defines the number of samples to skip between each read, and should be the number of interleaved channels in the user's audio buffer being read from. A typical usage for a single source, interleaved stereo input of 32-bit samples could look like this:
| [in] | inSamples | buffer to read input samples from |
| [in] | inStride | input buffer stride |
| [in] | channel | channel of instance pin to write to |
| INT32 aweOS_audioExportSamples | ( | AWEOSInstance * | pAWEOS, |
| void * | outSamples, | ||
| INT32 | outStride, | ||
| SampleType | outType | ||
The value of the fundamentalBlockSize member of the AWEOSInstance determines the number of samples that are exported with each call. Call this function once for each audio output channel available on audio device. Like aweOS_audioImportSamples, this will do channel matching automatically. For example, if the audio device has 3 audio output channels, and if a layout with 1 output channel is loaded, the second and third channels of the exported output will be all zeros. Inversely, if the layout has more output channels than the audio device supports, they are ignored.
| [out] | outSamples | buffer to write output audio to |
| [in] | outStride | output buffer stride |
| [in] | channel | channel of instance pin to read from |
| INT32 aweOS_layoutIsValid | ( | const AWEOSInstance * | pAWEOS | ) |
Use before processing audio in audio callback to avoid pumping through a dead layout. In some applications, the user may want to pass input audio straight to the output device if aweOS_audioIsStarted is TRUE but this function returns FALSE. This design can be useful for debugging audio drivers.
| INT32 aweOS_audioIsStarted | ( | const AWEOSInstance * | pAWEOS | ) |
Audio Start can be received over the tuning interface, and it is also usually the last command in an AWB file. Use this before pumping audio to avoid processing before it has been requested. This command will begin returning 0 once an Audio Stop command is received.
| const char * aweOS_errorToString | ( | INT32 | errorCode | ) |
| [in] | errorCode | error code that you wish to convert |
| INT32 aweOS_tuningPacketProcess | ( | AWEOSInstance * | pAWEOS | ) |
This function should never be called if an AWE Core OS integrated tuning socket is open (see aweOS_tuningSocketOpen). This function is used only by user created tuning interfaces to process received tuning commands. See the Tuning Command Syntax and Protocol document for details.
| INT32 aweOS_ctrlSetValue | ( | const AWEOSInstance * | pAWEOS, |
| UINT32 | handle, | ||
| void * | value, | ||
| INT32 | arrayOffset, | ||
| UINT32 | length | ||
Module handles and parameter sizes can be generated for any layout using Tools->Generate Target Files in AWE Designer. Select the ControlInterface.h checkbox to generate control files.
| [in] | arrayOffset | array offset if array. 0 if scalar. |
| [in] | length | number of elements to set if array. 1 if scalar. |
| INT32 aweOS_ctrlGetValue | ( | const AWEOSInstance * | pAWEOS, |
| [out] | value | retrieved value(s) |
| [in] | arrayOffset | array offset if array. 0 if scalar |
| [in] | length | number of elements to retrieve if array. 1 if scalar |
| INT32 aweOS_ctrlSetStatus | ( | const AWEOSInstance * | pAWEOS, |
| UINT32 * | status | ||
Valid status values are:
0=Active
1=Bypass
2=Mute
3=Inactive
Module handles sizes can be generated for any layout using Tools->Generate Target Files in AWE Designer. Select the ControlInterface.h checkbox to generate control files.
| INT32 aweOS_ctrlGetStatus | ( | const AWEOSInstance * | pAWEOS, |
| [out] | status | returned status |
| INT32 aweOS_ctrlSetValueMask | ( | const AWEOSInstance * | pAWEOS, |
| UINT32 | length, | ||
| UINT32 | mask | ||
A mask allows you to only call module's set function for a single variable, or skip the set function all together. For advanced users.
| [in] | length | number of elements if array. 1 if scalar |
| [in] | mask | mask to use - 0 to not call set function. |
| INT32 aweOS_ctrlGetValueMask | ( | const AWEOSInstance * | pAWEOS, |
| UINT32 | mask | ||
A mask allows you to only call module's get function for a single variable, or skip the get function all together. For advanced users.
| INT32 aweOS_ctrlGetModuleClass | ( | const AWEOSInstance * | pAWEOS, |
| UINT32 * | pClassID | ||
| [in] | pAWEOS | instance pointer |
| INT32 aweOS_destroy | ( | AWEOSInstance ** | pAWEOS | ) |
Frees all internal memory and sets the AWEOSInstance to NULL.
| [in] | pAWEOS | pointer to pointer of AWE Core OS instance to destroy |
| INT32 aweOS_setProfilingStatus | ( | AWEOSInstance * | pAWEOS, |
| UINT32 | status | ||
Both top and module level profiling enabled by default by aweOS_init. Use this function to selectively enable or disable per pump profiling during runtime. Disabling profiling saves a small amount of cycles per pump. Do not call this API from the audio start/stop callbacks. User can also enable or disable independently module level profiling and top level profiling.
| [in] | status | 0 to disable both, 1 to enable both, 2 to enable module level only and 3 to enable top level only |
| INT32 aweOS_getAverageLayoutCycles | ( | AWEOSInstance * | pAWEOS, |
| UINT32 | idx, | ||
Returns cycles in 24.8 format, so shift right by 8 bits for integer value. To get CPU cycles, multiply by target cpuSpeed / profileSpeed.
| [in] | idx | Layout index (typically 0, except in advanced use cases) |
| [out] | averageCycles | Pointer to average cycles |
| void aweOS_getVersion | ( | AWEOSVersionInfo_t * | versionInfo | ) |
Can be used without initializing an AWEOSInstance. AWE Core OS versions are of form <tuningVer>.<majorAPIVer>.<minorAPIVer>.<processorVer>. All values are integers execpt for majorAPIVer, which is a single, capital letter.
| [out] | versionInfo | Pointer to a version info data structure |
| INT32 aweOS_audioRecordingEnable | ( | AWEOSInstance * | pAWEOS, |
| char * | path, | ||
| UINT32 | bufferLength, | ||
| SampleType | sampleType | ||
Will create unique input and output .wav files in the specified directory. Recording input and output audio can be useful for debugging purposes. Audio recording happens in a background thread so as not to interrupt real time audio processing. If the system is heavily loaded, it is possible that overruns can occur while writing the audio to files. If overruns do occur on the system, increasing the size of bufferLength and using the 'Sample16bit' sampleType can help avoid missed audio samples in the recorded files. Audio recording is disabled by default at aweOS_init time. Call this function after aweOS_init to enable recording on the next Audio Start command. For greater control of audio recording capabilities, see the Wave File Source and Sink modules in Designer.
Recording audio during real-time processing
| [in] | path | Path to desired logging directory. Will use the directory application is called from if NULL or "" |
| [in] | baseName | Base name of audio files. Will use 'awe_audio' if NULL or "" |
| [in] | bufferLength | Length in milliseconds of audio FIFO used to buffer audio data for writing to file. Increase to handle large system I/O costs and avoid xruns |
| [in] | sampleType | Data type of recorded audio. Supports 'Sample32bit' and 'Sample16bit' only |
| INT32 aweOS_audioRecordingRegisterNotificationCallback | ( | AWEOSInstance * | pAWEOS, |
| recordNotificationCallbackFunction | recordNotificationCallback, | ||
| UINT32 | recordNotificationMask | ||
Events include errors (file create or I/O) or xruns. Mask controls which type of notifications to enable for callback. First bit of mask enables error notifications, second bit enables xrun notifications. An AWEOSAudioRecordNotification_t structure is passed as the only argument to the callback function.
| [in] | recordNotificationCallback | Function pointer to register for error/info notification during recording |
| [in] | recordNotificationMask | Bit mask to control notification types |
| INT32 aweOS_audioRecordingDisable | ( | AWEOSInstance * | pAWEOS | ) |
Can be called during runtime while audio recording is ongoing to halt recording. To record audio again on next Audio Start command, must call aweOS_audioRecordingEnable again.
| INT32 aweOS_wavFileOpen | ( | const char * | file, |
| FLOAT32 * | sampleRate, | ||
| UINT32 * | numChannels, | ||
| UINT32 * | sampleSize, | ||
| UINT32 * | numSamples, | ||
| FILE ** | fp | ||
Returns the pointer to the opened file in the fp argument. No audio data is read in this function call. Use aweOS_wavFileRead to access the audio data after the file is opened. aweOS_wavFileClose can be used to close the file once fully read.
| [in] | file | full path to name of the .wav file |
| [out] | sampleRate | sample rate value extracted from header |
| [out] | numChannels | number of audio channels extracted from header |
| [out] | sampleSize | size of each audio sample, in bytes |
| [out] | numSamples | total number of audio samples in file |
| [out] | fp | pointer to opened FILE |
| INT32 aweOS_wavFileCreate | ( | const char * | file, |
| FLOAT32 | sampleRate, | ||
| UINT32 | numChannels, | ||
| UINT32 | sampleSize, | ||
| FILE ** | fp | ||
Returns the pointer to the created file in the fp argument. No audio data is written in this function call. Use aweOS_wavFileWrite to write the audio data after the file is created. aweOS_wavFileClose can be used to close the file once fully written.
| [in] | sampleRate | sample rate |
| [in] | numChannels | number of audio channels in data to be written |
| [in] | sampleSize | size of each audio sample, in bytes |
| [out] | fp | pointer to created FILE |
| INT32 aweOS_wavFileWrite | ( | FILE * | fp, |
| void * | samples, | ||
| UINT32 | numSamples, | ||
| UINT32 | sampleSize | ||
| [in] | fp | pointer to file to write data to |
| [in] | samples | pointer to buffer of samples to write to file |
| [in] | numSamples | total number of samples to write |
| INT32 aweOS_wavFileRead | ( | FILE * | fp, |
| [in] | fp | pointer to file to read data from |
| [out] | samples | pointer to buffer to populate with samples from file |
| [in] | numSamples | total number of samples to read |
| INT32 aweOS_wavFileClose | ( | FILE * | fp | ) |
| INT32 aweOS_setInstancesInfo | ( | AWEOSInstance ** | pInstances, |
Call this function at startup after aweOS_init is done in the sequence.
| [in] | pInstances | Array of AWEOS Instance pointers. Array must exist as long as the system is active. |
| [in] | numInstances | Number of AWEOS Instances in pInstances array. |
| INT32 aweOS_registerLoggingCallback | ( | AWEOSInstance * | pAWEOS, |
| cbAweOSLogging_t | cbAweOSLogging, | ||
| INT32 | logLevel, | ||
| UINT32 | logTypeMask | ||
| [in] | pAWEOS | AWEOS instance pointer |
| [in] | cbAweOSLogging | Function pointer of the logging callback |
| [in] | logLevel | Logging level. 0 = AWE_LOG_LEVEL_NONE, 1 = AWE_LOG_LEVEL_ERROR, 2 = AWE_LOG_LEVEL_WARNING, 3 = AWE_LOG_LEVEL_INFO, 4 = AWE_LOG_LEVEL_DEBUG |
| [in] | logTypeMask | Logging type mask. Combination of any logging type like AWE_LOG_SYSTEM_MSG_ASCII | AWE_LOG_DATA_DUMP_FLOAT Please note that ASCII messages don't end with a newline so the user callback has to apply that as desired. |
| INT32 aweOS_registerEventCallbacks | ( | AWEOSInstance * | pAWEOS, |
| cbAweOSEventTrigger_t | cbAweOSEventTrigger, | ||
| cbAweOSEventRegister_t | cbAweOSEventRegister, | ||
| cbAweOSEventDeregister_t | cbAweOSEventDeregister | ||
cbAweOSEventTrigger must be non-null. The cbAweOSEventRegister and cbAweOSEventDeregister can be null.
| [in] | cbAweOSEventTrigger | Function pointer of the event trigger callback. |
| [in] | cbAweOSEventRegister | Function pointer of the event register callback. |
| [in] | cbAweOSEventDeregister | Function pointer of the event deregister callback. |
