typedef struct AWEOSAudioRecordNotification  | AWEOSAudioRecordNotification_t |
|   | Audio recording notification callback argument structure.
typedef void(*  | recordNotificationCallbackFunction) (AWEOSAudioRecordNotification_t *) |
|   | Audio recording notification callback type.
typedef struct AWEOSThreadPIDs  | AWEOSThreadPIDs_t |
|   | Internal threading PID structure, meant to be used with aweOS_getThreadPIDs.
typedef struct AWEOSVersionInfo  | AWEOSVersionInfo_t |
|   | Versioning structure returned by aweOS_getVersion.
| typedef void  | AWEOSInstance |
|   | The AWE Core OS Instance instance type.  More...
| typedef struct AWEOSConfigParameters  | AWEOSConfigParameters |
|   | AWEOSConfigParameters.  More...
| typedef void(*  | cbAweOSLogging_t) (AWEOSInstance *pAWEOS, INT32 level, UINT32 type, void *payload, INT32 payloadSizeInBytes) |
|   | OPTIONAL This callback is invoked from multiple places in the AWE framework to log any message to the BSP.  More...
| typedef INT32(*  | cbAweOSEventTrigger_t) (AWEOSInstance *pAWEOS, INT32 eventType, UINT32 moduleObjId, void *payload, INT32 payloadSizeInBytes, void *userHandle) |
|   | OPTIONAL These callback are invoked only from the Event Module.  More...
| typedef INT32(*  | cbAweOSEventRegister_t) (AWEOSInstance *pAWEOS, INT32 eventType, UINT32 moduleObjId, INT32 payloadSizeInBytes, void **userHandle) |
|   | The Event Register callback is called by an Event Module when it is constructed.  More...
| typedef INT32(*  | cbAweOSEventDeregister_t) (AWEOSInstance *pAWEOS, INT32 eventType, UINT32 moduleObjId, void **userHandle) |
|   | The Event Deregister callback is called by the Event Module when it is destroyed.  More...
| UINT32  | aweOS_getThreadPIDs (AWEOSInstance *pAWEOS, AWEOSThreadPIDs_t *threadPIDs) |
|   | Return the PIDs of all internally spawned AWE Core OS threads.  More...
| INT32  | aweOS_getParamDefaults (AWEOSConfigParameters *aweParams) |
|   | Populates an AWEOSConfigParameters structure with defaults.  More...
| INT32  | aweOS_init (AWEOSInstance **pAWEOS, const AWEOSConfigParameters *aweParams, const void *pModuleDescriptorTable, UINT32 moduleDescriptorTableSize) |
|   | Initialize the AWEOSInstance with the specified configuration parameters.  More...
| INT32  | aweOS_tuningSocketOpen (AWEOSInstance **pAWEOS, INT32 portNo, UINT32 numInstances) |
|   | Initialize and open an integrated TCP/IP tuning interface socket.  More...
| void  | aweOS_tuningSocketClose (AWEOSInstance *pAWEOS) |
|   | Close a running integrated TCP tuning socket.  More...
| INT32  | aweOS_tuningLoggingEnable (AWEOSInstance *pAWEOS, char *path, char *baseName, UINT32 verbosity) |
|   | Enable logging of the tuning packets sent and received by the AWEOSInstance.  More...
| INT32  | aweOS_loadAWBFromArray (AWEOSInstance *pAWEOS, const UINT32 *pArray, UINT32 arraySize, UINT32 *pErrorOffset) |
|   | Executes packet commands from an in-memory array.  More...
| INT32  | aweOS_loadAWBFile (AWEOSInstance *pAWEOS, const char *binaryFile, UINT32 *pErrorOffset) |
|   | Executes packet commands from an AWB file on the filesystem.  More...
| INT32  | aweOS_layoutGetChannelCount (const AWEOSInstance *pAWEOS, UINT32 *inCount, UINT32 *outCount) |
|   | Returns the number of input and output channels in the loaded layout.  More...
| INT32  | aweOS_layoutGetBlockSize (const AWEOSInstance *pAWEOS, UINT32 *blockSize) |
|   | Returns the block size of the loaded layout.  More...
| INT32  | aweOS_layoutGetSampleRate (const AWEOSInstance *pAWEOS, FLOAT32 *sampleRate) |
|   | Returns the sample rate of the loaded layout.  More...
| INT32  | aweOS_audioPumpAll (AWEOSInstance *pAWEOS) |
|   | Pump one fundamental block size of audio through the loaded layout and all of its sublayouts.  More...
| INT32  | aweOS_audioImportSamples (AWEOSInstance *pAWEOS, void *inSamples, INT32 inStride, INT32 channel, SampleType inType) |
|   | Import samples from an audio buffer to a specific channel of the AWEOSInstance's input pin.  More...
| INT32  | aweOS_audioExportSamples (AWEOSInstance *pAWEOS, void *outSamples, INT32 outStride, INT32 channel, SampleType outType) |
|   | Export samples to a user buffer from a specific channel of the AWEOSInstance's output pin.  More...
| INT32  | aweOS_layoutIsValid (const AWEOSInstance *pAWEOS) |
|   | Determines if a layout is loaded and valid.  More...
| INT32  | aweOS_audioIsStarted (const AWEOSInstance *pAWEOS) |
|   | Check if this instance has received an Audio Start command.  More...
| const char *  | aweOS_errorToString (INT32 errorCode) |
|   | Convert an error code (INT32) to its corresponding error string.  More...
| INT32  | aweOS_tuningPacketProcess (AWEOSInstance *pAWEOS) |
|   | Process the packet buffer in the AWEOSInstance.  More...
| INT32  | aweOS_ctrlSetValue (const AWEOSInstance *pAWEOS, UINT32 handle, void *value, INT32 arrayOffset, UINT32 length) |
|   | Set a scalar or array value(s) of a module parameter by handle.  More...
| INT32  | aweOS_ctrlGetValue (const AWEOSInstance *pAWEOS, UINT32 handle, void *value, INT32 arrayOffset, UINT32 length) |
|   | Get a scalar or array value(s) of a module parameter by handle.  More...
| INT32  | aweOS_ctrlSetStatus (const AWEOSInstance *pAWEOS, UINT32 handle, UINT32 *status) |
|   | Set the status of a module.  More...
| INT32  | aweOS_ctrlGetStatus (const AWEOSInstance *pAWEOS, UINT32 handle, UINT32 *status) |
|   | Get the status of a module.  More...
| INT32  | aweOS_ctrlSetValueMask (const AWEOSInstance *pAWEOS, UINT32 handle, void *value, INT32 arrayOffset, UINT32 length, UINT32 mask) |
|   | Set a scalar or array value(s) of a module variable by handle with mask.  More...
| INT32  | aweOS_ctrlGetValueMask (const AWEOSInstance *pAWEOS, UINT32 handle, void *value, INT32 arrayOffset, UINT32 length, UINT32 mask) |
|   | Get a scalar or array value(s) of a module variable by handle with mask.  More...
| INT32  | aweOS_ctrlGetModuleClass (const AWEOSInstance *pAWEOS, UINT32 handle, UINT32 *pClassID) |
|   | Get a module's object class from its handle.  More...
| INT32  | aweOS_destroy (AWEOSInstance **pAWEOS) |
|   | Destroys the AWEOSInstance and closes all associated threads.  More...
| INT32  | aweOS_setProfilingStatus (AWEOSInstance *pAWEOS, UINT32 status) |
|   | Enable or disable the profiling ability of the AWE Core OS Instance.  More...
| INT32  | aweOS_getAverageLayoutCycles (AWEOSInstance *pAWEOS, UINT32 idx, UINT32 *averageCycles) |
|   | Get the average cycles of a running layout, in units of cycles at profileSpeed.  More...
| void  | aweOS_getVersion (AWEOSVersionInfo_t *versionInfo) |
|   | Get the version information of the AWE Core OS library.  More...
| INT32  | aweOS_audioRecordingEnable (AWEOSInstance *pAWEOS, char *path, char *baseName, UINT32 bufferLength, SampleType sampleType) |
|   | Enables recording of all input and output audio of AWEOSInstance.  More...
| INT32  | aweOS_audioRecordingRegisterNotificationCallback (AWEOSInstance *pAWEOS, recordNotificationCallbackFunction recordNotificationCallback, UINT32 recordNotificationMask) |
|   | Register a callback function for audio recording event notificiations.  More...
| INT32  | aweOS_audioRecordingDisable (AWEOSInstance *pAWEOS) |
|   | Disable recording of input and output audio of AWEOSInstance.  More...
| INT32  | aweOS_wavFileOpen (const char *file, FLOAT32 *sampleRate, UINT32 *numChannels, UINT32 *sampleSize, UINT32 *numSamples, FILE **fp) |
|   | Open a .wav file and populate the user arguments with the header information in the file.  More...
| INT32  | aweOS_wavFileCreate (const char *file, FLOAT32 sampleRate, UINT32 numChannels, UINT32 sampleSize, FILE **fp) |
|   | Create a .wav file and populate the header with the passed in arguments.  More...
| INT32  | aweOS_wavFileWrite (FILE *fp, void *samples, UINT32 numSamples, UINT32 sampleSize) |
|   | Write audio data to .wav file created using aweOS_wavFileCreate.  More...
| INT32  | aweOS_wavFileRead (FILE *fp, void *samples, UINT32 numSamples, UINT32 sampleSize) |
|   | Read audio data from .wav file opened using aweOS_wavFileOpen.  More...
| INT32  | aweOS_wavFileClose (FILE *fp) |
|   | Close the.wav file opened using aweOS_wavFileOpen or aweOS_wavFileCreate.  More...
| INT32  | aweOS_setInstancesInfo (AWEOSInstance **pInstances, INT32 numInstances) |
|   | Profiling related setup function only intended for systems with multiple AWEOS Instances in a single application.  More...
| INT32  | aweOS_registerLoggingCallback (AWEOSInstance *pAWEOS, cbAweOSLogging_t cbAweOSLogging, INT32 logLevel, UINT32 logTypeMask) |
|   | Register the logging callback with required logging level and logging type mask.  More...
| INT32  | aweOS_registerEventCallbacks (AWEOSInstance *pAWEOS, cbAweOSEventTrigger_t cbAweOSEventTrigger, cbAweOSEventRegister_t cbAweOSEventRegister, cbAweOSEventDeregister_t cbAweOSEventDeregister) |
|   | Register the event callbacks used by the Event Module.  More...
