#define  | UINT32_DEFINED |
#define  | INT32_DEFINED |
#define  | BOOL   INT32 |
#define  | MAXINT32   ((INT32)0x7fffffffUL) |
#define  | MININT32   ((INT32)~MAXINT32) |
#define  | UINT64_DEFINED |
#define  | INT64_DEFINED |
#define  | MAXINT64   ((INT64)0x7ffffffffffffffffULL) |
#define  | MININT64   ((INT64)~MAXINT64) |
#define  | FLOAT32_DEFINED |
#define  | FLOAT64_DEFINED |
#define  | INT16_DEFINED |
#define  | UINT16_DEFINED |
#define  | INT8_DEFINED |
#define  | UINT8_DEFINED |
#define  | INT_DEFINED |
#define  | UINT   unsigned int |
#define  | BYTE_DEFINED |
#define  | PBYTE   unsigned char * |
#define  | TRUE   1 |
#define  | FALSE   0 |
#define  | WORD   unsigned short |
#define  | PWORD   unsigned short * |
#define  | DWORD   unsigned long |
#define  | PDWORD   unsigned long * |
#define  | NUMOF(x)   (sizeof(x) / sizeof(*x)) |
#define  | NULL   0 |
#define  | SUCCESS   1 |
#define  | FAILURE   0 |
#define  | PASTE(x,  y)   x ## y |
#define  | EVAL(x,  y)   PASTE(x, y) |
#define  | FIXNAME(x)   EVAL(MODULE_PREFIX, x) |
#define  | AWE_UNUSED_VARIABLE(x)   ((void)(x)) |
#define  | SAMPLETYPE_DEFINED |
#define  | DLLSYMBOL |
#define  | CXX_NOWARN_DLLCLASSIF |
#define  | CXX_RESTORE_DLLCLASSIF |
typedef unsigned int  | UINT32 |
typedef int  | INT32 |
typedef unsigned long long  | UINT64 |
typedef long long  | INT64 |
typedef float  | FLOAT32 |
typedef double  | FLOAT64 |
typedef short  | INT16 |
typedef unsigned short  | UINT16 |
typedef signed char  | INT8 |
typedef unsigned char  | UINT8 |
typedef int  | INT |
typedef unsigned char  | BYTE |
typedef enum _SampleType  | SampleType |
|   | Type of data for I/O.
◆ _SampleType
| Enumerator |
| Sample16bit  | Data is 16 bit PCM.
| Sample24bit_low  | Data is 24 bit PCM aligned to the low bit in 32 bit buffers.
| Sample24bit_high  | Data is 24 bit PCM aligned to the high bit in 32 bit buffers.
| Sample32bit  | Data is 32 bit PCM .
