Enumeration of Proxy function IDs.
| Enumerator |
| PFID_Undefined  | Undefined ID - zero.
| PFID_SetCall  | Function ID for awe_fwSetCall().
| PFID_GetCall  | Function ID for awe_fwGetCall().
| PFID_GetClassType  | Function ID for awe_fwGetClassType().
| PFID_GetPinType  | Function ID for awe_fwGetPinType().
| PFID_ClassWire_Constructor  | Function ID for ClassWire_Constructor().
| PFID_BindIOToWire  | Function ID for BindIOToWire().
| PFID_FetchValue  | Function ID for awe_fwFetchValue().
| PFID_SetValue  | Function ID for awe_fwSetValue().
| PFID_GetHeapCount  | Function ID for awe_fwGetHeapCount().
| PFID_GetHeapSize  | Function ID for awe_fwGetHeapSize().
| PFID_Destroy  | Function ID for awe_fwDestroy().
| PFID_GetCIModuleCount  | Function ID for awe_fwGetAweInstanceModuleCount().
| PFID_GetCIModuleInfo  | Function ID for awe_fwGetAweInstanceModuleInfo().
| PFID_ClassModule_Constructor  | Function ID for ClassModule_Constructor().
| PFID_ClassLayout_Constructor  | Function ID for awe_fwLayoutConstructor().
| PFID_SetModuleState  | Function ID for awe_fwSetModuleState().
| PFID_GetModuleState  | Function ID for awe_fwGetModuleState().
| PFID_PumpModule  | Function ID for awe_fwPumpModule().
| PFID_ClassLayout_Process  | Function ID for awe_fwLayoutProcess().
| PFID_GetFirstObject  | Function ID for awe_fwGetFirstObject().
| PFID_GetNextObject  | Function ID for awe_fwGetNextObject().
| PFID_GetFirstIO  | Function ID for awe_fwGetFirstIO().
| PFID_GetNextIO  | Function ID for awe_fwGetNextIO().
| PFID_StartAudio  | Function ID for StartAudio().
| PFID_StopAudio  | Function ID for StopAudio().
| PFID_FetchValues  | Function ID for awe_fwFetchValue().
| PFID_SetValues  | Function ID for awe_fwSetValue().
| PFID_GetSizeofInt  | Function ID for sizeof(INT32).
| PFID_GetFirstFile  | Function ID for awe_GetFirstFile().
| PFID_GetNextFile  | Function ID for awe_GetNextFile().
| PFID_OpenFile  | Function ID for awe_OpenFile().
| PFID_ReadFile  | Function ID for awe_ReadFile().
| PFID_WriteFile  | Function ID for awe_WriteFile().
| PFID_CloseFile  | Function ID for awe_CloseFile().
| PFID_DeleteFile  | Function ID for awe_DeleteFile().
| PFID_ExecuteFile  | Function ID for awe_ExecuteFile().
| PFID_EraseFlash  | Function ID for awe_EraseFlash().
| PFID_GetTargetInfo  | Function ID for awe_GetTargetInfo().
| PFID_GetFileSystemInfo  | Function ID for awe_GetFileSystemInfo().
| PFID_GetProfileValues  | Function ID for awe_fwGetProfileValues().
| PFID_FileSystemReset  | Function ID for awe_FileSystemReset().
| PFID_GetObjectByID  | Function ID for awe_fwGetObjectByID().
| PFID_AddModuleToLayout  | Function ID for awe_fwAddModuleToLayout().
| PFID_SetValueCall  | Function ID for awe_fwSetValue() awe_fwSetCall().
| PFID_AllocateHeaps  | Allocate framework heaps.
| PFID_DestroyHeaps  | Destroy framework heaps.
| PFID_WritePumpRead  | Single message write-pump-read combo.
| PFID_SetValueSetCall  | Function ID for awe_fwSetValue() followed by awe_fwSetCall.
| PFID_SetValuesSetCall  | Function ID for awe_fwSetValues() followed by awe_fwSetCall.
| PFID_GetCallFetchValue  | Function ID for awe_GetCall() followed by awe_fwFetchValue().
| PFID_GetCallFetchValues  | Function ID for awe_GetCall() followed by awe_fwFetchValues().
| PFID_SetPointer  | Function ID for awe_fwSetPointer().
| PFID_CreateLookupTable  | Function ID for awe_fwcreateLookupTable().
| PFID_DerefPointer  | Function ID for awe_fwDerefPointer().
| PFID_GetWireType  | Function ID for awe_fwGetWireType().
| PFID_SetInstanceID  | Function ID for awe_fwSetInstanceID().
| PFID_Get_Flash_Erase_Time  | Function ID for awe_fwGetFlashEraseTime().
| PFID_DestroyAll  | Function ID for awe_fwDestroyAll().
| PFID_GetFirstCore  | Function ID for report first core.
| PFID_GetNextCore  | Function ID for report next core.
| PFID_GetCores  | Function ID for GetCores().
| PFID_FetchValues_float  | Function ID for awe_fwFetchValue() as float.
| PFID_GetCallFetchValues_float  | Function ID for awe_GetCall() as float followed by awe_fwFetchValue().
| PFID_SetValues_float  | Function ID for awe_fwSetValue() as float.
| PFID_SetValuesSetCall_float  | Function ID for awe_fwSetValues() as float followed by awe_fwSetCall.
| PFID_FetchValue_float  | Function ID for awe_fwFetchValue() as float.
| PFID_GetCallFetchValue_float  | Function ID for awe_GetCall() as float followed by awe_fwFetchValue().
| PFID_SetValue_float  | Function ID for awe_fwSetValue() as float.
| PFID_SetValueSetCall_float  | Function ID for awe_fwSetValue() followed by awe_fwSetCall.
| PFID_SetValuesPartial  | Function ID for awe_fwSetValue().
| PFID_SetValuesPartial_float  | Function ID for awe_fwSetValue() as float.
| PFID_SetCores  | Function ID for GetCores().
| PFID_CheckMemory  | Special for target integrity bchecks.
| PFID_StartAudio2  | Start audio without callback.
| PFID_StopAudio2  | Stop audio without callback.
| PFID_GetValueHandle  | Get value(s) by handle.
| PFID_SetValueHandle  | Set value(s) by handle.
| PFID_GetStatusHandle  | Get module status by handle.
| PFID_SetStatusHandle  | Set module status by handle.
| PFID_GetValueHandleMask  | Get value(s) by handle and mask.
| PFID_SetValueHandleMask  | Set value(s) by handle and mask.
| PFID_GetExtendedInfo  | Get extended target info.
| PFID_GetCores2  | Function ID for GetCores().
| PFID_CreateWireBufferPool  | Function ID for awe_fwCreateWireBufferPool().
| PFID_CreateWireInBufferPool  | Function ID for awe_fwCreateWireInBufferPool().
| PFID_GetSharedHeapSize  | Get the shared heap size.
| PFID_GetLayoutCoreAffinity  | Function ID for awe_fwGetLayoutCoreAffinity.
| PFID_GetProfileValuesPreCalc  | Function ID for awe_fwGetProfileValuesPreCalc().
| PFID_GetAllProfiling  | Function ID for awe_fwGetAllProfiling().
| PFID_GetAllMatchingModules  | Retrieves all modules of a classID from the running layout.
| PFID_SetProfilingStatus  | Set the profiling status (disable, enable all, enable module only or enable layout only)
| PFID_GetProfilingStatus  | Get the current profiling status.
| PFID_SetProfilingOptions  | Set the profiling options like average or peak on modules, enable or disable accurate profiling.
| PFID_GetProfilingOptions  | Get the current profiling options.
| PFID_ClearProfilingValues  | Clear all the profiling values of a layout (top and modules)
| PFID_ResetState  | To reset all modules and layout masks.
| PFID_ResetModule  | To reset single module.
