Loading...
Searching...
No Matches
Data Structures | Macros | Typedefs | Enumerations | Functions
AWECoreOS.h File Reference
The AWE Core OS API header file. More...
#include "StandardDefs.h"
#include "stdio.h"
#include <stddef.h>
#include <string.h>
#include <unistd.h>
#include <sys/types.h>
#include <sys/socket.h>
#include <netinet/in.h>
#include "Errors.h"
#include <sched.h>
#include "ProxyIDs.h"
#include <semaphore.h>
#include "AWELoggingDefs.h"
Data Structures
struct  AWEOSAudioRecordNotification
 Audio recording notification callback argument structure. More...
struct  AWEOSThreadPIDs
 Internal threading PID structure, meant to be used with aweOS_getThreadPIDs. More...
struct  AWEOSVersionInfo
 Versioning structure returned by aweOS_getVersion. More...
struct  AWEOSConfigParameters
 AWEOSConfigParameters. More...
Macros
#define TUNING_LOG_NONE   0
 AWE Core OS internal tuning interface logging verbosity level: disabled – no logging.
#define TUNING_LOG_ERROR   1
 AWE Core OS internal tuning interface logging verbosity level: low – log only errors.
#define TUNING_LOG_INFO   2
 AWE Core OS internal tuning interface logging verbosity level: medium – log errors and header info from all packets sent and received.
#define TUNING_LOG_DATA   3
 AWE Core OS internal tuning interface logging verbosity level: high –log errors, header info, and raw packet content for all packets.
#define TUNING_LOG_DEBUG   TUNING_LOG_DATA
#define AUDIO_RECORDING_NOTIFICATION_ERRORS   (1 << 0)
 Audio recording: Notify only on errors.
#define AUDIO_RECORDING_NOTIFICATION_XRUNS   (1 << 1)
 Audio recording: Notify only on overruns.
#define AUDIO_RECORDING_NOTIFICATION_ALL   (AUDIO_RECORDING_NOTIFICATION_ERRORS | AUDIO_RECORDING_NOTIFICATION_XRUNS)
 Audio recording: Notify on errors and overruns.
Typedefs
typedef struct AWEOSAudioRecordNotification AWEOSAudioRecordNotification_t
typedef void(* recordNotificationCallbackFunction) (AWEOSAudioRecordNotification_t *)
 Audio recording notification callback type.
typedef struct AWEOSThreadPIDs AWEOSThreadPIDs_t
typedef struct AWEOSVersionInfo AWEOSVersionInfo_t
typedef void AWEOSInstance
typedef struct AWEOSConfigParameters AWEOSConfigParameters
typedef void(* cbAweOSLogging_t) (AWEOSInstance *pAWEOS, INT32 level, UINT32 type, void *payload, INT32 payloadSizeInBytes)
 OPTIONAL This callback is invoked from multiple places in the AWE framework to log any message to the BSP.
typedef INT32(* cbAweOSEventTrigger_t) (AWEOSInstance *pAWEOS, INT32 eventType, UINT32 moduleObjId, void *payload, INT32 payloadSizeInBytes, void *userHandle)
 OPTIONAL These callback are invoked only from the Event Module.
typedef INT32(* cbAweOSEventRegister_t) (AWEOSInstance *pAWEOS, INT32 eventType, UINT32 moduleObjId, INT32 payloadSizeInBytes, void **userHandle)
 The Event Register callback is called by an Event Module when it is constructed.
typedef INT32(* cbAweOSEventDeregister_t) (AWEOSInstance *pAWEOS, INT32 eventType, UINT32 moduleObjId, void **userHandle)
 The Event Deregister callback is called by the Event Module when it is destroyed.
Enumerations
enum  STATUS { ERROR , INPUT_OVERRUN , OUTPUT_OVERRUN }
 Audio recording notification status type.
Functions
UINT32 aweOS_getThreadPIDs (AWEOSInstance *pAWEOS, AWEOSThreadPIDs_t *threadPIDs)
INT32 aweOS_getParamDefaults (AWEOSConfigParameters *aweParams)
INT32 aweOS_init (AWEOSInstance **pAWEOS, const AWEOSConfigParameters *aweParams, const void *pModuleDescriptorTable, UINT32 moduleDescriptorTableSize)
INT32 aweOS_tuningSocketOpen (AWEOSInstance **pAWEOS, INT32 portNo, UINT32 numInstances)
void aweOS_tuningSocketClose (AWEOSInstance *pAWEOS)
 Close a running integrated TCP tuning socket.
INT32 aweOS_tuningLoggingEnable (AWEOSInstance *pAWEOS, char *path, char *baseName, UINT32 verbosity)
INT32 aweOS_loadAWBFromArray (AWEOSInstance *pAWEOS, const UINT32 *pArray, UINT32 arraySize, UINT32 *pErrorOffset)
INT32 aweOS_loadAWBFile (AWEOSInstance *pAWEOS, const char *binaryFile, UINT32 *pErrorOffset)
INT32 aweOS_loadSubcanvasAWBfromArray (AWEOSInstance *pAWEOS, UINT32 SubcanvasModObjectID, const UINT32 *pCommands, UINT32 arraySize, UINT32 *pPos)
 Executes packet commands from an in-memory array and loads AWB in Subcanvas module.
INT32 aweOS_loadSubcanvasAWBfromFile (AWEOSInstance *pAWEOS, UINT32 SubcanvasModObjectID, const char *binaryFile, UINT32 *pPos)
 Load an AWB file from stdio into Subcanvas module.
INT32 aweOS_appendModules (AWEOSInstance *pAWEOS, size_t length, const void *const *modules)
 Append an array of module class pointers to the AWECoreOS instance's dynamic module list.
INT32 aweOS_layoutGetChannelCount (const AWEOSInstance *pAWEOS, UINT32 *inCount, UINT32 *outCount)
INT32 aweOS_layoutGetBlockSize (const AWEOSInstance *pAWEOS, UINT32 *blockSize)
INT32 aweOS_layoutGetSampleRate (const AWEOSInstance *pAWEOS, FLOAT32 *sampleRate)
INT32 aweOS_audioPumpAll (AWEOSInstance *pAWEOS)
INT32 aweOS_audioImportSamples (AWEOSInstance *pAWEOS, void *inSamples, INT32 inStride, INT32 channel, SampleType inType)
INT32 aweOS_audioExportSamples (AWEOSInstance *pAWEOS, void *outSamples, INT32 outStride, INT32 channel, SampleType outType)
INT32 aweOS_layoutIsValid (const AWEOSInstance *pAWEOS)
INT32 aweOS_audioIsStarted (const AWEOSInstance *pAWEOS)
const char * aweOS_errorToString (INT32 errorCode)
INT32 aweOS_tuningPacketProcess (AWEOSInstance *pAWEOS)
 Process the packet buffer in the AWEOSInstance.
INT32 aweOS_ctrlSetValue (const AWEOSInstance *pAWEOS, UINT32 handle, void *value, INT32 arrayOffset, UINT32 length)
 Set a scalar or array value(s) of a module parameter by handle.
INT32 aweOS_ctrlGetValue (const AWEOSInstance *pAWEOS, UINT32 handle, void *value, INT32 arrayOffset, UINT32 length)
 Get a scalar or array value(s) of a module parameter by handle.
INT32 aweOS_ctrlSetStatus (const AWEOSInstance *pAWEOS, UINT32 handle, UINT32 *status)
 Set the status of a module.
INT32 aweOS_ctrlGetStatus (const AWEOSInstance *pAWEOS, UINT32 handle, UINT32 *status)
 Get the status of a module.
INT32 aweOS_ctrlSetValueMask (const AWEOSInstance *pAWEOS, UINT32 handle, void *value, INT32 arrayOffset, UINT32 length, UINT32 mask)
 Set a scalar or array value(s) of a module variable by handle with mask.
INT32 aweOS_ctrlGetValueMask (const AWEOSInstance *pAWEOS, UINT32 handle, void *value, INT32 arrayOffset, UINT32 length, UINT32 mask)
 Get a scalar or array value(s) of a module variable by handle with mask.
INT32 aweOS_ctrlGetModuleClass (const AWEOSInstance *pAWEOS, UINT32 handle, UINT32 *pClassID)
 Get a module's object class from its handle.
INT32 aweOS_destroy (AWEOSInstance **pAWEOS)
INT32 aweOS_setProfilingStatus (AWEOSInstance *pAWEOS, UINT32 status)
 Enable or disable the profiling ability of the AWE Core OS Instance.
INT32 aweOS_getAverageLayoutCycles (AWEOSInstance *pAWEOS, UINT32 idx, UINT32 *averageCycles)
void aweOS_getVersion (AWEOSVersionInfo_t *versionInfo)
 Get the version information of the AWE Core OS library.
INT32 aweOS_audioRecordingEnable (AWEOSInstance *pAWEOS, char *path, char *baseName, UINT32 bufferLength, SampleType sampleType)
 Enables recording of all input and output audio of AWEOSInstance.
INT32 aweOS_audioRecordingRegisterNotificationCallback (AWEOSInstance *pAWEOS, recordNotificationCallbackFunction recordNotificationCallback, UINT32 recordNotificationMask)
 Register a callback function for audio recording event notificiations.
INT32 aweOS_audioRecordingDisable (AWEOSInstance *pAWEOS)
 Disable recording of input and output audio of AWEOSInstance.
INT32 aweOS_wavFileOpen (const char *file, FLOAT32 *sampleRate, UINT32 *numChannels, UINT32 *sampleSize, UINT32 *numSamples, FILE **fp)
 Open a .wav file and populate the user arguments with the header information in the file.
INT32 aweOS_wavFileCreate (const char *file, FLOAT32 sampleRate, UINT32 numChannels, UINT32 sampleSize, FILE **fp)
 Create a .wav file and populate the header with the passed in arguments.
INT32 aweOS_wavFileWrite (FILE *fp, void *samples, UINT32 numSamples, UINT32 sampleSize)
 Write audio data to .wav file created using aweOS_wavFileCreate.
INT32 aweOS_wavFileRead (FILE *fp, void *samples, UINT32 numSamples, UINT32 sampleSize)
 Read audio data from .wav file opened using aweOS_wavFileOpen.
INT32 aweOS_wavFileClose (FILE *fp)
 Close the.wav file opened using aweOS_wavFileOpen or aweOS_wavFileCreate.
INT32 aweOS_setInstancesInfo (AWEOSInstance **pInstances, INT32 numInstances)
 Profiling related setup function only intended for systems with multiple AWEOS Instances in a single application.
INT32 aweOS_registerLoggingCallback (AWEOSInstance *pAWEOS, cbAweOSLogging_t cbAweOSLogging, INT32 logLevel, UINT32 logTypeMask)
INT32 aweOS_registerEventCallbacks (AWEOSInstance *pAWEOS, cbAweOSEventTrigger_t cbAweOSEventTrigger, cbAweOSEventRegister_t cbAweOSEventRegister, cbAweOSEventDeregister_t cbAweOSEventDeregister)
Detailed Description
