Loading...
Searching...
No Matches
Data Structures | Macros | Typedefs | Enumerations
AWECoreOS Types
Data Structures
struct  AWEOSAudioRecordNotification
 Audio recording notification callback argument structure. More...
struct  AWEOSThreadPIDs
 Internal threading PID structure, meant to be used with aweOS_getThreadPIDs. More...
struct  AWEOSVersionInfo
 Versioning structure returned by aweOS_getVersion. More...
struct  AWEOSConfigParameters
 AWEOSConfigParameters. More...
Macros
#define TUNING_LOG_NONE   0
 AWE Core OS internal tuning interface logging verbosity level: disabled – no logging.
#define TUNING_LOG_ERROR   1
 AWE Core OS internal tuning interface logging verbosity level: low – log only errors.
#define TUNING_LOG_INFO   2
 AWE Core OS internal tuning interface logging verbosity level: medium – log errors and header info from all packets sent and received.
#define TUNING_LOG_DATA   3
 AWE Core OS internal tuning interface logging verbosity level: high –log errors, header info, and raw packet content for all packets.
#define TUNING_LOG_DEBUG   TUNING_LOG_DATA
#define AUDIO_RECORDING_NOTIFICATION_ERRORS   (1 << 0)
 Audio recording: Notify only on errors.
#define AUDIO_RECORDING_NOTIFICATION_XRUNS   (1 << 1)
 Audio recording: Notify only on overruns.
#define AUDIO_RECORDING_NOTIFICATION_ALL   (AUDIO_RECORDING_NOTIFICATION_ERRORS | AUDIO_RECORDING_NOTIFICATION_XRUNS)
 Audio recording: Notify on errors and overruns.
Typedefs
typedef struct AWEOSAudioRecordNotification AWEOSAudioRecordNotification_t
typedef void(* recordNotificationCallbackFunction) (AWEOSAudioRecordNotification_t *)
 Audio recording notification callback type.
typedef struct AWEOSThreadPIDs AWEOSThreadPIDs_t
typedef struct AWEOSVersionInfo AWEOSVersionInfo_t
typedef void AWEOSInstance
typedef struct AWEOSConfigParameters AWEOSConfigParameters
Enumerations
enum  STATUS { ERROR , INPUT_OVERRUN , OUTPUT_OVERRUN }
 Audio recording notification status type.
Detailed Description
Typedef Documentation
◆ AWEOSInstance
The instance itself is opaque, and it is configured with aweOS_getParamDefaults and aweOS_init. This handle will be passed to most API functions. Multi Instance integrations can utilize an array of AWEOSInstances (see the MultiInstance example app)
◆ AWEOSConfigParameters
The AWE Core OS Configuration Parameter Structure
This structure will hold the config parameters for the AWE Core OS instance. A user must create one of these per AWEOSInstance, and either populate it in manually, or call the aweOS_getParamDefaults to populate it with defaults. Once the structure has been configured, it is passed in to the aweOS_init function with an AWEOSInstance, and the instance is initialized with the given configuration parameters. The heap pointers, pPacketBuffer and pReplyBuffer will be assigned to NULL when calling aweOS_getParamDefaults. If they are not overwritten by user, then memory is allocated in aweOS_init. Internally allocated heap sizes can be controlled via the heapSize configuration parameters.
