Modules | |
| Creating a Plugin | |
| Using the AudioWeaver Plugin API to create a dynamically loadable list of modules. | |
| Loading a Plugin | |
| Using the AudioWeaver Plugin API to load plugin libraries. | |
Data Structures | |
| struct | _AWEPluginModuleArray |
| A list of module classes provided by a plugin. More... | |
| struct | _AWEPlugin |
| A struct encapsulating the functionality which can be provided by a plugin library. More... | |
| struct | _awe_PluginCallbacks |
| Callbacks passed by the loader to each plugin entrypoint. More... | |
Macros | |
| #define | AWE_PLUGIN_API_VERSION_MAX_LENGTH 63 |
| Maximum length of the AWE_PLUGIN_API_VERSION. | |
| #define | AWE_PLUGIN_API_VERSION "1" |
| Version of the AudioWeaver Plugin API. | |
Typedefs | |
| typedef struct _AWEPluginModuleArray | AWEPluginModuleArray |
| A list of module classes provided by a plugin. | |
| typedef struct _AWEPlugin | AWEPlugin |
| A struct encapsulating the functionality which can be provided by a plugin library. | |
| typedef struct _awe_PluginCallbacks | awe_PluginCallbacks |
| Callbacks passed by the loader to each plugin entrypoint. | |
| #define AWE_PLUGIN_API_VERSION_MAX_LENGTH 63 |
This does not include the null-terminator.
| #define AWE_PLUGIN_API_VERSION "1" |
Must be a null-terminated character string with length less than AWE_PLUGIN_API_VERSION_MAX_LENGTH.
| typedef struct _AWEPlugin AWEPlugin |
This struct is to be returned by the plugin's AWEPlugin_initialize entrypoint. Optional fields can be set to NULL.
| typedef struct _awe_PluginCallbacks awe_PluginCallbacks |
The plugin entrypoint should prefer to use these functions during initialization. They are guaranteed to outlive the plugin, so it is safe to cache them internally. This is typically necessary if memory is to be freed in the plugin's cleanup function. They may be NULL, in which case the plugin entrypoint must either choose to use a fallback or simply return NULL to indicate an initialization failure.
