Examples.
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <unistd.h>
#include <sys/types.h>
#include <sys/socket.h>
#include <signal.h>
#include <netinet/in.h>
#include <pthread.h>
#include <math.h>
#include <errno.h>
#include <time.h>
#include <sys/time.h>
#include <semaphore.h>
#include "TargetInfo.h"
float coreSpeed;
float profileSpeed;
float sampleRate;
UINT32 fundamentalBlockSize;
UINT32 inChannels;
UINT32 outChannels;
UINT32 profileStatus;
INT32 tuningPort;
} ConfigParameters;
INT32 *audioInputBuffer = NULL;
INT32 *audioOutputBuffer = NULL;
static BOOL quiet = FALSE;
LISTOFCLASSOBJECTS
UINT32 awePacketBufferReply[MAX_COMMAND_BUFFER_LEN];
UINT32 *fastHeapA;
UINT32 *fastHeapB;
UINT32 *slowHeap;
UINT32 heapSizeFastA = FASTA_HEAP_SIZE_LINUX;
UINT32 heapSizeFastB = FASTB_HEAP_SIZE_LINUX;
UINT32 heapSizeSlow = SLOW_HEAP_SIZE_LINUX;
pthread_t tuningThreadHandle;
pthread_t processThreadHandle;
pthread_t audioPumpAllThreadHandle;
pthread_mutex_t packetMutex;
sem_t pumpSem;
INT32 audioStarted = 0;
int sockfd, newsockfd;
int exitTuning = 0;
INT32 pumpActive = 0;
INT32 eventRegisterCnt = 0;
#define AUDIO_CALLBACK_PRIO 9
#define AUDIO_PUMP_PRIO 8
#define TUNING_THREAD_PRIO 7
printf(
"Usage: %s [args]\n"
" -profStatus:N set profiling status (0 - disable, 1 - enable(default), 2 - enable module level only, 3 - enable top level only)\n"
" -tport:N default 15002, port number for socket interface. User can choose between 15002 - 15098\n"
"This program exercises the AWECore library.\n",
program, FASTA_HEAP_SIZE_LINUX, FASTB_HEAP_SIZE_LINUX, SLOW_HEAP_SIZE_LINUX);
exit(0);
void destroyApp(void)
UINT32 pos = 0;
if (ret)
printf("Layout destroy failed, ret = %d\n", ret);
else
printf("Layout destroy success\n");
free(audioInputBuffer);
free(audioOutputBuffer);
free(fastHeapA);
free(fastHeapB);
free(slowHeap);
fastHeapA = NULL;
fastHeapB = NULL;
slowHeap = NULL;
void error(const char *msg)
perror(msg);
exit(1);
void sig_handler(int signo)
if (signo == SIGINT)
exitTuning = 1;
close(newsockfd);
shutdown(sockfd, SHUT_RDWR);
close(sockfd);
pthread_join(tuningThreadHandle, NULL);
destroyApp();
printf("Exiting LinuxApp\n");
exit(0);
void usrLogging(
AWEInstance* pAWE, INT32 level, UINT32 type,
void* payload, INT32 payloadSizeInBytes)
struct timeval ts;
char timeCh[25];
gettimeofday(&ts, NULL);
if (payloadSizeInBytes > 0)
INT32 usrEventRegister(
AWEInstance* pAWE, INT32 eventType, UINT32 moduleObjId, INT32 payloadSizeInBytes,
void** userHandle)
INT32 usrEventDeregister(
void** userHandle)
INT32 usrEventTrigger(
void* payload, INT32 payloadSizeInBytes,
void* userHandle)
struct timeval ts;
char timeCh[25];
if (eventType == 10)
else
void resetTuningSocket()
socklen_t clilen;
struct sockaddr_in cli_addr;
close(newsockfd);
listen(sockfd, 5);
#ifdef TUNING_DEBUG_PRINTS
printf("Listening again for connection on port %d\n", configParams.tuningPort);
#endif
clilen = sizeof(cli_addr);
newsockfd = accept(sockfd,
&clilen);
if (newsockfd < 0)
exitTuning = 1;
printf("ERROR on accept, %d\n", newsockfd);
return;
printf( "Found connection again!\n");
#endif
(void) arg;
socklen_t clilen;
INT32 schedPolicy, ret;
int socketOption;
schedPolicy = SCHED_FIFO;
if (ret != 0)
if (sockfd < 0)
printf("ERROR opening socket, %d\n", sockfd);
return NULL;
socketOption = 1;
sizeof(serv_addr)) < 0)
printf("ERROR on binding\n");
return NULL;
listen(sockfd, 5);
&clilen);
if (newsockfd < 0)
return NULL;
while (!exitTuning)
while(1)
UINT32 plen;
INT32 readBytes, n;
if (readBytes <= 0)
if (readBytes == 0)
printf("ERROR: socket read 0 length packet, attempt to reconnect\n");
else
printf("ERROR: socket read error, attempt to reconnect -- ret = %d, errno = %d\n", readBytes, errno);
#endif
resetTuningSocket();
break;
while (readBytes < plen)
printf("Didn't read the entire packet! readBytes = %d, totalPacketLength = %u\nReading again\n", readBytes, plen);
#endif
readBytes += recv(newsockfd, &((
char*)aweInstance.
pPacketBuffer)[readBytes], MAX_COMMAND_BUFFER_LEN *
sizeof(aweInstance.
pPacketBuffer[0]), 0);
if (readBytes > plen)
printf("ERROR: read %d bytes, expected maximum is %u. Exiting.\n", readBytes, plen);
#endif
break;
pthread_mutex_lock(&packetMutex);
pthread_mutex_unlock(&packetMutex);
if (n < plen)
printf("ERROR: Packet reply transmit failed -- ret = %d\n", n);
#endif
break;
return NULL;
void* aweuser_pumpAllAudio(void * args)
(void) args;
INT32 pumpMask;
INT32 ix;
INT32 i;
schedParam.sched_priority = AUDIO_PUMP_PRIO;
if (ret != 0)
printf("Failed to increase priority of audio pump thread to real time with error: %s \nTry running with sudo\n", strerror(ret));
printf("Starting pump all thread\n");
while (1)
sem_wait(&pumpSem);
pumpActive = 1;
if (pumpMask & (1U << ix))
if (ret > 0)
pumpActive = 0;
return NULL;
struct timespec ts;
struct timespec ts_tmp;
long time_nsec;
long long accumulated_time;
long long target_time;
long long overshoot = 0.0;
(void) args;
ts.tv_sec = 0;
ts.tv_sec = 0;
ts_tmp.tv_sec = 0;
ts_tmp.tv_nsec = 0;
if (ret != 0)
printf("Failed to increase priority of audio callback thread with error: %s \nTry running with sudo\n", strerror(ret));
if (!pumpActive)
sem_post(&pumpSem);
while (overshoot > time_nsec)
overshoot -= time_nsec;
sem_post(&pumpSem);
else
overshoot = 0.0;
ts.tv_nsec = time_nsec;
target_time = ((long long)ts_tmp.tv_sec*1000000000) + ts_tmp.tv_nsec + time_nsec;
while(1)
accumulated_time = ((long long)ts_tmp.tv_sec*1000000000) + ts_tmp.tv_nsec;
if (accumulated_time >= target_time)
overshoot += (accumulated_time - target_time);
break;
else
ts.tv_nsec = (long)(target_time - accumulated_time);
return NULL;
(void) pAWE;
pthread_create(&audioCallbackThreadHandle, NULL, audioCallbackSimulator, NULL);
audioStarted = 1;
printf("Audio Started\n");
return 0;
(void) pAWE;
if(audioCallbackThreadHandle)
exitAudioCallbackThread = 1;
pthread_join(audioCallbackThreadHandle, NULL);
if (audioStarted)
printf("Audio Stopped\n");
audioStarted = 0;
return 0;
void InitializeAWEInstance()
int ret = 0;
int i, j;
aweInstance.
aweInstance.
coreSpeed = configParams.coreSpeed;
aweInstance.
pName = TARGET_NAME;
ret =
awe_initPin(&aweInputPin, configParams.inChannels, NULL);
if (ret != 0)
ret =
awe_initPin(&aweOutputPin, configParams.outChannels, NULL);
if (ret != 0)
if (ret != 0)
if (ret != 0)
printf("awe_setProfilingStatus failed with error code: %d\n", ret);
if (ret != 0)
printf("awe_registerLoggingCallback failed with error code: %d\n", ret);
if (ret != 0)
printf("awe_registerEventCallbacks failed with error code: %d\n", ret);
#ifndef PI
#define PI 3.141592653589793
#endif
audioInputBuffer[i * configParams.inChannels + j] = float_to_fract32(sinf(2.f*PI*(j+1)*((float)configParams.sampleRate/configParams.fundamentalBlockSize) * (i / (float)configParams.sampleRate)));
INT32 i;
UINT32 inSize, outSize;
const char *awbpath = NULL;
INT32 ret;
configParams.fundamentalBlockSize = BASE_BLOCK_SIZE;
configParams.tuningPort = 15002;
for (i = 1; i < argc; i++)
const char *arg = argv[i];
printf("profStatus:%u\n",configParams.profileStatus);
printf("-bsize: %u\n",configParams.fundamentalBlockSize);
printf("-inchans: %u\n",configParams.inChannels);
printf("-outchans: %u\n",configParams.outChannels);
printf("-tport: %d\n",configParams.tuningPort);
quiet = TRUE;
printf("-quiet: %d\n",quiet);
awbpath = arg + 6;
else
usage(argv[0]);
if (!quiet)
printf("\nAWECore version %u.%c.%u.%u.%c (build %u) initialized with the following parameters\n\n",
else
printf("\nAWECore version %u.%c.%u.%u (build %u) initialized with the following parameters\n\n",
if (configParams.profileStatus)
else
audioInputBuffer = malloc(inSize * sizeof(INT32));
audioOutputBuffer = malloc(outSize * sizeof(INT32));
InitializeAWEInstance();
if ( NULL != awbpath )
FILE *fin;
UINT32 position;
fin = fopen(awbpath, "rb");
if (NULL == fin )
printf("Please check the path\n");
exit(1);
printf("The layout %s loaded successfully\n", awbpath);
else
exit(1);
pthread_mutex_init(&packetMutex, NULL);
sem_init(&pumpSem, 0, 0);
pthread_create(&tuningThreadHandle, NULL, tuningPacketThread, NULL);
pthread_create(&audioPumpAllThreadHandle, NULL, aweuser_pumpAllAudio, NULL);
pthread_join(audioPumpAllThreadHandle, NULL);
return 0;
The AWECore API Header File.
Definition: AWECoreUtils.h:40
Definition: AWECoreUtils.h:43
INT32 awe_registerEventCallbacks(AWEInstance *pAWE, cbAweEventTrigger_t cbAweEventTrigger, cbAweEventRegister_t cbAweEventRegister, cbAweEventDeregister_t cbAweEventDeregister)
INT32 awe_getBuildVersionInfo(AWEBuildVersionInfo_t *pBuildVersionInfo)
Get the AWECore build number and version information.
Audio pump function.
INT32 awe_registerLoggingCallback(AWEInstance *pAWE, cbAweLogging_t cbAweLogging, INT32 logLevel, UINT32 logTypeMask)
Test if AWE is ready to run.
INT32 awe_loadAWBfromFile(AWEInstance *pAWE, const char *binaryFile, UINT32 *pPos)
Load an AWB file from stdio.
Initialize the instance.
#define E_SUCCESS
OK result.
Definition: Errors.h:31
@ PFID_Destroy
Function ID for awe_fwDestroy().
Definition: ProxyIDs.h:68
@ Sample32bit
Data is 32 bit PCM .
The AWE instance.
Definition: AWEInstance.h:96
IOPinDescriptor * pInputPin
Definition: AWEInstance.h:160
const char * pName
Definition: AWEInstance.h:229
float profileSpeed
Profiling clock speed in Hz.
Definition: AWEInstance.h:221
UINT32 * pReplyBuffer
Reply buffer pointer.
Definition: AWEInstance.h:203
UINT32 * pFastHeapB
The second fast heap, B .
Definition: AWEInstance.h:108
UINT32 numThreads
Definition: AWEInstance.h:233
IOPinDescriptor * pOutputPin
Definition: AWEInstance.h:166
UINT32 * pPacketBuffer
The Packet buffer pointer.
Definition: AWEInstance.h:194
Definition: AWEInstance.h:130
OPTIONAL.
Definition: AWEInstance.h:136
UINT32 slowHeapSize
The slow heap size.
Definition: AWEInstance.h:122
Definition: AWEInstance.h:240
UINT32 * pSlowHeap
The slow heap.
Definition: AWEInstance.h:111
float sampleRate
Definition: AWEInstance.h:236
UINT32 packetBufferSize
Packet buffer size.
Definition: AWEInstance.h:210
UINT32 fastHeapBSize
The fast heap B size.
Definition: AWEInstance.h:119
Definition: AWEInstance.h:245
float coreSpeed
Definition: AWEInstance.h:218
UINT32 numModules
Definition: AWEInstance.h:176
Pointer to module table.
Definition: AWEInstance.h:184
UINT32 fastHeapASize
Definition: AWEInstance.h:116
UINT32 * pFastHeapA
Fast heap A.
Definition: AWEInstance.h:105
Build versioning structure returned by awe_getBuildVersionInfo.
Definition: AWEInstance.h:274
UINT32 buildNumber
Library build number.
Definition: AWEInstance.h:280
UINT32 minorVer
Minor API version.
Definition: AWEInstance.h:277
char hotFixVer
Hot fix version, if the build is a hot fix release.
Definition: AWEInstance.h:279
char majorVer
Major API version (single letter)
Definition: AWEInstance.h:276
UINT32 procVer
Processor specific version.
Definition: AWEInstance.h:278
UINT32 tuningVer
Tuning version.
Definition: AWEInstance.h:275
