AWE Core 8.D.11 Documentation
The AWEInstance API Header File. More...
#include <stdlib.h>#include <string.h>#include <stddef.h>#include "TargetProcessor.h"#include "AWELoggingDefs.h"Go to the source code of this file.
Data Structures | |
| struct | _AWEInstance |
| The AWE instance. More... | |
| struct | AWEBuildVersionInfo |
| Build versioning structure returned by awe_getBuildVersionInfo. More... | |
Macros | |
| #define | AWE_PROFILING_DISABLE_BOTH_LAYOUT_MODULE 0u |
| Public macros to control profiling status. | |
| #define | AWE_PROFILING_ENABLE_BOTH_LAYOUT_MODULE 1u |
| #define | AWE_PROFILING_ENABLE_ONLY_MODULE 2u |
| #define | AWE_PROFILING_ENABLE_ONLY_LAYOUT 3u |
| #define | AWE_MODULE_PROFILING_BIT_POS 0 |
| Profiling options bit masks and values. | |
| #define | AWE_MODULE_PROFILING_BIT_MASK 1 |
| #define | AWE_MODULE_PROFILING_AVERAGE (0x0u << AWE_MODULE_PROFILING_BIT_POS) |
| #define | AWE_MODULE_PROFILING_PEAK (0x1u << AWE_MODULE_PROFILING_BIT_POS) |
| #define | AWE_ACCURATE_PROFILING_BIT_POS 1 |
| #define | AWE_ACCURATE_PROFILING_BIT_MASK 2 |
| #define | AWE_ENABLE_ACCURATE_PROFILING (0x0u << AWE_ACCURATE_PROFILING_BIT_POS) |
| #define | AWE_DISABLE_ACCURATE_PROFILING (0x1u << AWE_ACCURATE_PROFILING_BIT_POS) |
Typedefs | |
| typedef void(* | cbAweLogging_t) (struct _AWEInstance *pAWE, INT32 level, UINT32 type, void *payload, INT32 payloadSizeInBytes) |
| OPTIONAL This callback is invoked from multiple places in the AWE framework to log any message to the BSP. More... | |
| typedef INT32(* | cbAweEventTrigger_t) (struct _AWEInstance *pAWE, INT32 eventType, UINT32 moduleObjId, void *payload, INT32 payloadSizeInBytes, void *userHandle) |
| OPTIONAL These callback are invoked only from the Event Module. More... | |
| typedef INT32(* | cbAweEventRegister_t) (struct _AWEInstance *pAWE, INT32 eventType, UINT32 moduleObjId, INT32 payloadSizeInBytes, void **userHandle) |
| The Event Register callback is called by an Event Module when it is constructed. More... | |
| typedef INT32(* | cbAweEventDeregister_t) (struct _AWEInstance *pAWE, INT32 eventType, UINT32 moduleObjId, void **userHandle) |
| The Event Deregister callback is called by the Event Module when it is destroyed. More... | |
| typedef struct _AWEInstance | AWEInstance |
| typedef struct AWEBuildVersionInfo | AWEBuildVersionInfo_t |
| Build versioning structure returned by awe_getBuildVersionInfo. | |
| typedef INT32 | packetProcessFunction(AWEInstance *pAWE) |
Functions | |
| INT32 | awe_init (AWEInstance *pAWE) |
| Initialize the instance. More... | |
| INT32 | awe_initPin (IOPinDescriptor *pPin, UINT32 channels, const char *name) |
| Initialize an input or output pin. More... | |
| void | awe_initFlashFS (AWEInstance *pAWE, AWEFlashFSInstance *pAWEFlashFSInstance) |
| Initialize the file system. More... | |
| INT32 | awe_packetProcess (AWEInstance *pAWE) |
| Process an AWEInstance's newly received tuning packet. More... | |
| INT32 | awe_packetProcessMulti (AWEInstance *pAWE, BOOL isTuningInstance) |
| Multi-instance Wrapper for tuning packet processing. More... | |
| INT32 | awe_audioPump (AWEInstance *pAWE, UINT32 layoutIndex) |
| Audio pump function. More... | |
| INT32 | awe_audioImportSamples (const AWEInstance *pAWE, const void *inSamples, INT32 inStride, INT32 channel, SampleType inType) |
| Import samples from a user buffer to a channel. More... | |
| INT32 | awe_audioExportSamples (const AWEInstance *pAWE, void *outSamples, INT32 outStride, INT32 channel, SampleType outType) |
| Export samples to a user buffer from a channel. More... | |
| INT32 | awe_audioIsStarted (const AWEInstance *pAWE) |
| Check if this instance is running. More... | |
| INT32 | awe_audioGetPumpMask (AWEInstance *pAWE) |
| Test if AWE is ready to run. More... | |
| INT32 | awe_audioIsReadyToPumpMulti (AWEInstance *pAWE, UINT32 instanceID) |
| Test if AWE is ready to run on secondary instances (ID > 0). More... | |
| UINT32 | awe_audioStartPreemption (AWEInstance *pAWE, INT32 coreAffinity) |
| Function to correct overhead outside of the Audio Weaver, like Audio DMA ISR. More... | |
| UINT32 | awe_audioEndPreemption (AWEInstance *pAWE, UINT32 start_time, INT32 coreAffinity) |
| INT32 | awe_deferredSetCall (AWEInstance *pAWE) |
| Perform deferred awe set on a module. More... | |
| INT32 | awe_loadAWBfromArray (AWEInstance *pAWE, const UINT32 *pCommands, UINT32 arraySize, UINT32 *pPos) |
| Executes packet commands from an in-memory array. More... | |
| INT32 | awe_loadAWBfromFile (AWEInstance *pAWE, const char *binaryFile, UINT32 *pPos) |
| Load an AWB file from stdio. More... | |
| INT32 | awe_loadAWBfromFlash (AWEInstance *pAWE, const char *binaryFile, UINT32 *pPos) |
| Load an AWB file from the flash. More... | |
| void | awe_layoutGetChannelCount (const AWEInstance *pAWE, UINT32 pinIdx, UINT32 *inCount, UINT32 *outCount) |
| Returns the number of channels in the Layout's input and output pins. More... | |
| INT32 | awe_layoutGetInputBlockSize (const AWEInstance *pAWE, UINT32 pinIdx, UINT32 *blockSize) |
| Returns the block size of a pin. More... | |
| INT32 | awe_layoutGetInputSampleRate (const AWEInstance *pAWE, UINT32 pinIdx, FLOAT32 *sampleRate) |
| Returns the sample rate of an input pin. More... | |
| INT32 | awe_layoutIsValid (const AWEInstance *pAWE) |
| Determines if a layout is loaded and valid. More... | |
| INT32 | awe_ctrlSetValue (const AWEInstance *pAWE, UINT32 handle, const void *value, INT32 arrayOffset, UINT32 length) |
| Set a scalar or array value of a module variable by handle. More... | |
| INT32 | awe_ctrlGetValue (const AWEInstance *pAWE, UINT32 handle, void *value, INT32 arrayOffset, UINT32 length) |
| Get a scalar or array value of a module variable by handle. More... | |
| INT32 | awe_ctrlSetStatus (const AWEInstance *pAWE, UINT32 handle, UINT32 status) |
| Set the runtime status of a module. More... | |
| INT32 | awe_ctrlGetStatus (const AWEInstance *pAWE, UINT32 handle, UINT32 *status) |
| Get the runtime status of a module. More... | |
| INT32 | awe_ctrlSetValueMask (const AWEInstance *pAWE, UINT32 handle, const void *value, INT32 arrayOffset, UINT32 length, UINT32 mask) |
| Set a scalar or array value of a module variable by handle with mask. More... | |
| INT32 | awe_ctrlGetValueMask (const AWEInstance *pAWE, UINT32 handle, void *value, INT32 arrayOffset, UINT32 length, UINT32 mask) |
| Get a scalar or array value of a module variable by handle with mask. More... | |
| INT32 | awe_ctrlGetModuleClass (const AWEInstance *pAWE, UINT32 handle, UINT32 *pClassID) |
| Get an object class from its handle. More... | |
| INT32 | awe_setProfilingStatus (AWEInstance *pAWE, UINT32 status) |
| Enable or disable the profiling ability of the AWE Core. More... | |
| INT32 | awe_setProfilingOptions (AWEInstance *pAWE, UINT32 optionsMask, UINT32 profilingOptions) |
| Function to set profiling options like average or peak profiling on modules and turn on or off accurate profiling. More... | |
| INT32 | awe_getProfilingOptions (AWEInstance *pAWE, UINT32 *profilingOptions) |
| Function to get current profiling options. More... | |
| INT32 | awe_getAverageLayoutCycles (AWEInstance *pAWE, UINT32 layoutIdx, UINT32 *averageCycles) |
| Get the average cycles of a running layout, in units of cycles at profileSpeed. More... | |
| void | awe_setInstancesInfo (AWEInstance **pInstances, INT32 numAweInstancesOnCore) |
| Setup function only intended for systems with multiple AWE Instances in a single core. More... | |
| INT32 | awe_fwSetLayoutCoreAffinity (AWEInstance *pAWE, INT32 layoutNumber, INT32 coreAffinity) |
| Set the core affinity of the layout in layoutNumber. More... | |
| INT32 | awe_fwGetLayoutCoreAffinity (AWEInstance *pAWE, INT32 layoutNumber) |
| Get the core affinity of the layout in layoutNumber, initializes to 0 and can be set with awe_fwSetLayoutCoreAffinity. More... | |
| INT32 | awe_getBuildVersionInfo (AWEBuildVersionInfo_t *pBuildVersionInfo) |
| Get the AWECore build number and version information. More... | |
| INT32 | awe_setInstanceStandaloneAWBLoad (AWEInstance *pAWE, INT32 status) |
| This function can be used to achieve Progressive Loading on a multi-instance system. More... | |
| INT32 | awe_registerLoggingCallback (AWEInstance *pAWE, cbAweLogging_t cbAweLogging, INT32 logLevel, UINT32 logTypeMask) |
| Register the logging callback with required logging level and logging type mask. More... | |
| INT32 | awe_registerEventCallbacks (AWEInstance *pAWE, cbAweEventTrigger_t cbAweEventTrigger, cbAweEventRegister_t cbAweEventRegister, cbAweEventDeregister_t cbAweEventDeregister) |
| Register the event callbacks used by the Event Module. More... | |
| INT32 | awe_resetState (AWEInstance *pAWE) |
| Walk through each module in each layout in an instance and calls reset function, if exists, clears wire buffers and clears IO buffers and layout masks. More... | |
| typedef void(* cbAweLogging_t) (struct _AWEInstance *pAWE, INT32 level, UINT32 type, void *payload, INT32 payloadSizeInBytes) |
User should register the callback via awe_registerLoggingCallback, which requires logging level and type mask. type is a 32-bit bitfield, with each bit representing a type of message. These types are defined in the framework and provide information about where the logging messages come from.
| typedef INT32(* cbAweEventTrigger_t) (struct _AWEInstance *pAWE, INT32 eventType, UINT32 moduleObjId, void *payload, INT32 payloadSizeInBytes, void *userHandle) |
Use the awe_registerEventCallbacks to register them The Event Trigger callback is called when an Event Module is triggered in the layout. Depending on the Event Module configuration, this may happen inline in the module processing, or it may happen during deferred processing. In the latter case, there may be a delay between the actual event trigger and calling this Event Trigger callback. If this returns a negative number, then it is assumed that the Event Trigger was not successfully processed and the module's numFailedTriggers parameter will increment. If there is no Event Trigger callback registered, then the Event Module can never generate an event.
| typedef INT32(* cbAweEventRegister_t) (struct _AWEInstance *pAWE, INT32 eventType, UINT32 moduleObjId, INT32 payloadSizeInBytes, void **userHandle) |
| typedef INT32(* cbAweEventDeregister_t) (struct _AWEInstance *pAWE, INT32 eventType, UINT32 moduleObjId, void **userHandle) |
| typedef struct _AWEInstance AWEInstance |
The AWE instance.
| INT32 awe_init | ( | AWEInstance * | pAWE | ) |
Call this once you have assigned all of the required members/pointers of the AWE Instance, and after calling awe_InitPin on both input and output pins. Calling awe_init before assigning all members of the instance structure or initializing the pins will result in crashes/erratic behavior.
| pAWE | instance to initialize |
| INT32 awe_initPin | ( | IOPinDescriptor * | pPin, |
| UINT32 | channels, | ||
| const char * | name | ||
This function must be called for both the input and output pins. Must be called BEFORE the awe_init API function.
| [in] | pPin | the pin instance to initialize |
| [in] | channels | number of channels |
| [in] | name | optional pin name |
| void awe_initFlashFS | ( | AWEInstance * | pAWE, |
| AWEFlashFSInstance * | pAWEFlashFSInstance | ||
| pAWEFlashFSInstance | the file system instance |
| INT32 awe_packetProcess | ( | AWEInstance * | pAWE | ) |
| [in] | pAWE | The AWE instance pointer to process |
| INT32 awe_packetProcessMulti | ( | AWEInstance * | pAWE, |
| BOOL | isTuningInstance | ||
If called by the tuning instance, call whenever a complete packet is received. Wait until the return value is not E_MULTI_PACKET_WAITING to forward reply back to the tuning interface. If called by a non-tuning instance, poll continuously in a low-priority task.
| [in] | isTuningInstance | Boolean marking if the instance calling this API implements the tuning interface |
| INT32 awe_audioPump | ( | AWEInstance * | pAWE, |
| UINT32 | layoutIndex | ||
Call this in your audio thread once you have imported the data you wish to process. Before pumping, you must also check that the AudioWeaver buffers have been filled (awe_getPumpMask) and that audio has been started (awe_audioIsStarted). This function will return 1 if awe_deferredSetCall needs to be called. This is for modules that need to do more time consuming calculations, like calculating filter coefficients. For example, a SOF Control module needs to calculate new coeffs when the frequency is modified by the control input.
| [in] | pAWE | AWE instance pointer |
| [in] | layoutIndex | the layout index to pump |
| INT32 awe_audioImportSamples | ( | const AWEInstance * | pAWE, |
| const void * | inSamples, | ||
| INT32 | inStride, | ||
| INT32 | channel, | ||
| SampleType | inType | ||
The value of the fundamentalBlockSize member of the AWEInstance determines the number of samples that are imported with each call. Call this function once for each audio input channel on the hardware. Channel matching between hardware capabilities and layout will be done automatically. For example, if the target has only 1 audio input channel, and if a layout with 3 input channels is loaded, the second and third channels of the layout input will be all zeros. Inversely, if there are more HW input channels than the layout expects, then they are ignored.
The value of inStride defines the number of samples to skip between each read, and should be the number of interleaved channels in the inSamples buffer being read from. A typical usage for a single source, interleaved stereo input could look like:
| [in] | pAWE | AWE instance |
| [in] | inSamples | pointer to first sample in buffer to import for current channel |
| [in] | inStride | input buffer import stride |
| [in] | channel | channel to write to |
| INT32 awe_audioExportSamples | ( | const AWEInstance * | pAWE, |
| void * | outSamples, | ||
| INT32 | outStride, | ||
| SampleType | outType | ||
The value of the fundamentalBlockSize member of the AWEInstance determines the number of samples that are exported with each call. Call this function once for each audio output channel on the hardware. Like awe_audioImportSamples, this will do channel matching automatically. For example, if the target has 3 audio output channels, and if a layout with 1 output channel is loaded, the second and third channels of the exported output will be all zeros. Inversely, if the layout has more output channels than the target supports, they are ignored.
| [out] | outSamples | pointer to first sample in buffer to export to |
| [in] | outStride | output buffer export stride |
| [in] | channel | channel to read from |
| INT32 awe_audioIsStarted | ( | const AWEInstance * | pAWE | ) |
A BSP author can use this to determine if the instance is already running to avoid pumping audio through a dead layout.
| pAWE | instance pointer |
| INT32 awe_audioGetPumpMask | ( | AWEInstance * | pAWE | ) |
This will return the "layout mask" which is a bit vector of threads to run. For a simple, single threaded system, the bitvector will be 0x1. If a previous pump is not complete and the layout is ready to pump again, an overflow is detected by this function. In this condition, the layoutMask bit for the overflowed layout will be zero, which prevents the layout from being pumped again. Example: int layoutMask = awe_audioGetPumpMask(&g_AWEInstance); if (layoutMask > 0) { if (layoutMask & 0x1) { int ret = awe_audioPump(&g_AWEInstance, 0); } }
| INT32 awe_audioIsReadyToPumpMulti | ( | AWEInstance * | pAWE, |
| UINT32 | instanceID | ||
This must be used in multi-instance applications to determine when to trigger secondary instances. Failure to do so can result in pumping at the wrong rates. This avoids unneccessary interrupts on secondary instances where layout block size is higher than the fundamental block size. This function returns TRUE or FALSE. When it returns TRUE, corresponding secondary instance is ready to signal. When this function is called with instance ID 0 or invalid ID, then always False is returned. Example: int pumpSlaveInstance = awe_audioIsReadyToPumpMulti(&g_AWEInstance, 1); if (pumpSlaveInstance) { Signal slave core to get pump mask raise(); }
| instanceID | AWE instance ID |
| UINT32 awe_audioStartPreemption | ( | AWEInstance * | pAWE, |
| INT32 | coreAffinity | ||
Call this function at the very beginning of the DMA ISR and store the returned value, which is an argument to following end function call. For the use case where multiple instances exists on the same core, this function can be called with any instance's AWEInstance pointer, provided that the user called awe_setInstancesInfo during the startup. Example: UINT32 start_time = awe_audioStartPreemption(&g_AWEInstance, coreAffinity);
| coreAffinity | Core affinity from which this function is called |
| UINT32 awe_audioEndPreemption | ( | AWEInstance * | pAWE, |
| UINT32 | start_time, | ||
Call this function at the end in the DMA ISR with start_time returned by awe_audioStartPreemption(). If the DMA ISR has low latency audio pump calls, then this function must be called before the audio pump and call awe_audioStartPreemption() again after pump. Note that the funtion awe_audioStartPreemption() must be called first, before calling awe_audioEndPreemption(). For the use case where multiple instances exists on the same core, this function can be called with any instance's AWEInstance pointer, provided that the user called awe_setInstancesInfo during the startup. Example: awe_audioEndPreemption(&g_AWEInstance, start_time, coreAffinity);
| start_time | Start time returned by the corresponding start function "awe_audioStartPreemption" |
| INT32 awe_deferredSetCall | ( | AWEInstance * | pAWE | ) |
Each call to awe_deferredSetCall processes a single module. Usually this function would be called repeatedly until the return value is 0.
| INT32 awe_loadAWBfromArray | ( | AWEInstance * | pAWE, |
| const UINT32 * | pCommands, | ||
| UINT32 | arraySize, | ||
| UINT32 * | pPos | ||
Designer can generate AWB arrays directly from a layout.
| [in] | pCommands | Buffer with commands to execute |
| [in] | arraySize | Number of DWords in command buffer |
| [out] | pPos | Report failing word index |
| INT32 awe_loadAWBfromFile | ( | AWEInstance * | pAWE, |
| const char * | binaryFile, | ||
| [in] | binaryFile | AWB file to be loaded |
| INT32 awe_loadAWBfromFlash | ( | AWEInstance * | pAWE, |
| void awe_layoutGetChannelCount | ( | const AWEInstance * | pAWE, |
| UINT32 | pinIdx, | ||
| UINT32 * | inCount, | ||
| UINT32 * | outCount | ||
| [in] | pinIdx | which input pin (always 0) |
| [out] | inCount | channels in primary input pin |
| [out] | outCount | channels in primary output pin |
| INT32 awe_layoutGetInputBlockSize | ( | const AWEInstance * | pAWE, |
| UINT32 * | blockSize | ||
Because the block size of the output pin is inherited from the input pin, the user only needs to check the input pin.
| [in] | pAWE | The AWE Instance |
| [out] | blockSize | block size of input pin |
| INT32 awe_layoutGetInputSampleRate | ( | const AWEInstance * | pAWE, |
| FLOAT32 * | sampleRate | ||
Because the sample rate of the output pin is inherited from the input pin, the user only needs to check the input pin.
| [out] | sampleRate | the input pin sample rate |
| INT32 awe_layoutIsValid | ( | const AWEInstance * | pAWE | ) |
| INT32 awe_ctrlSetValue | ( | const AWEInstance * | pAWE, |
| UINT32 | handle, | ||
| const void * | value, | ||
| INT32 | arrayOffset, | ||
| UINT32 | length | ||
| [in] | pAWE | instance pointer |
| [in] | arrayOffset | array index if array |
| [in] | length | number of elements. 1 if scaler |
| INT32 awe_ctrlGetValue | ( | const AWEInstance * | pAWE, |
| INT32 awe_ctrlSetStatus | ( | const AWEInstance * | pAWE, |
| UINT32 | status | ||
0 = Active, 1 = Bypass, 2 = Mute, 3 = Inactive
| INT32 awe_ctrlGetStatus | ( | const AWEInstance * | pAWE, |
| UINT32 * | status | ||
| [out] | status | pointer to return status value |
| INT32 awe_ctrlSetValueMask | ( | const AWEInstance * | pAWE, |
| UINT32 | length, | ||
| UINT32 | mask | ||
A mask allows you to only call module's set function for a single variable.
| [in] | length | number of elements if array. 1 if scaler |
| [in] | mask | mask to use - 0 to not call set function |
| INT32 awe_ctrlGetValueMask | ( | const AWEInstance * | pAWE, |
| UINT32 | mask | ||
| INT32 awe_ctrlGetModuleClass | ( | const AWEInstance * | pAWE, |
| UINT32 * | pClassID | ||
| pAWE | instance pointer | |
| INT32 awe_setProfilingStatus | ( | AWEInstance * | pAWE, |
Both top and module level profiling and preemption overhead correction enabled by default at awe_init. Use this function if you wish to selectively enable or disable per pump profiling during runtime. Disabling profiling saves a small amount of cycles per pump. User can also enable or disable independently module level profiling and top level profiling and overhead correction due to preemption. It is recommended to call this function during initialization before starting a layout to have correct profiling behavior.
| status | 0 to disable both, 1 to enable both, 2 to enable module level only, 3 to enable top level only |
| INT32 awe_setProfilingOptions | ( | AWEInstance * | pAWE, |
| UINT32 | optionsMask, | ||
| UINT32 | profilingOptions | ||
To set module peak profiling and to enable accurate profiling, call the function with optionsMask as AWE_MODULE_PROFILING_BIT_MASK|AWE_ACCURATE_PROFILING_BIT_MASK and profilingOptions as AWE_MODULE_PROFILING_PEAK|AWE_ENABLE_ACCURATE_PROFILING. It is recommended to call this function during initialization before starting a layout to have correct profiling behavior.
| pAWE | [in] instance pointer |
| optionsMask | [in] mask AWE_MODULE_PROFILING_BIT_MASK to control module profiling type and AWE_ACCURATE_PROFILING_BIT_MASK to control accurate profiling. |
| profilingOptions | [in] profiling options value corresponding to the mask to set. |
| INT32 awe_getProfilingOptions | ( | AWEInstance * | pAWE, |
| UINT32 * | profilingOptions | ||
| profilingOptions | [out] pointer to return current setting of all profiling options. When failure occured, the value of all zeros returned. |
| INT32 awe_getAverageLayoutCycles | ( | AWEInstance * | pAWE, |
| UINT32 | layoutIdx, | ||
Returns cycles in 24.8 format, so shift right by 8 bits for integer value. To get CPU cycles, multiply by target cpuSpeed / profileSpeed. If a previous pump is not complete and the layout is ready to pump again, an overflow is detected. When in this state, the awe_getAverageLayoutCycles api will return the averageCycles = AWE_PUMP_OVF_MAX_AVG_CYCLES (0xFFFFFFFF).
| layoutIdx | Layout index (typically 0, except in advanced use cases) |
| averageCycles | Pointer the output (average layout cycles) |
| void awe_setInstancesInfo | ( | AWEInstance ** | pInstances, |
| INT32 | numAweInstancesOnCore | ||
Call this function at startup after awe_init is done in the sequence. Enables both accurate profiling and loading of multi-instance designs.
| [in] | pInstances | Array of AWE Instance pointers that process on one core. Array must exist as long as the system is active. |
| [in] | numAweInstancesOnCore | Number of AWE Instances in pInstances array. |
| INT32 awe_fwSetLayoutCoreAffinity | ( | AWEInstance * | pAWE, |
| INT32 | layoutNumber, | ||
Used to get more accurate profiling in multithreaded systems.
| [in] | pAWE | AWE instance pointer (this) |
| [in] | layoutNumber | the layout index to set the core affinity. |
| [in] | coreAffinity | core affinity to set in the layout. |
| INT32 awe_fwGetLayoutCoreAffinity | ( | AWEInstance * | pAWE, |
| INT32 | layoutNumber | ||
| [in] | layoutNumber | the layout index to get the core affinity. |
| INT32 awe_getBuildVersionInfo | ( | AWEBuildVersionInfo_t * | pBuildVersionInfo | ) |
| [in,out] | pBuildVersionInfo | Pointer of type AWEBuildVersionInfo_t to return build version information |
| INT32 awe_setInstanceStandaloneAWBLoad | ( | AWEInstance * | pAWE, |
| INT32 | status | ||
Indicates this instance loads AWB in standalone mode.
| [in] | status | Boolean flag indicates to enable or disable standalone loading. 1 - to enable standalone mode, 0 - to disable standalone mode. Default disabled. |
| INT32 awe_registerLoggingCallback | ( | AWEInstance * | pAWE, |
| cbAweLogging_t | cbAweLogging, | ||
| INT32 | logLevel, | ||
| UINT32 | logTypeMask | ||
| [in] | cbAweLogging | Function pointer of the logging callback. |
| [in] | logLevel | Logging level. 0 = AWE_LOG_LEVEL_NONE (DISABLED), 1 = AWE_LOG_LEVEL_ERROR, 2 = AWE_LOG_LEVEL_WARNING, 3 = AWE_LOG_LEVEL_INFO, 4 = AWE_LOG_LEVEL_DEBUG |
| [in] | logTypeMask | Logging type mask. Combination of any logging type like AWE_LOG_SYSTEM_MSG | AWE_LOG_CPU_OVERFLOW_MSG. Use AWE_LOG_ALL_TYPE_MASK to subscribe to all logging message types Please note that logging messages never end with a newline so the user callback has to apply that as desired. |
| INT32 awe_registerEventCallbacks | ( | AWEInstance * | pAWE, |
| cbAweEventTrigger_t | cbAweEventTrigger, | ||
| cbAweEventRegister_t | cbAweEventRegister, | ||
| cbAweEventDeregister_t | cbAweEventDeregister | ||
cbAweEventTrigger must be non-null. The cbAweEventRegister and cbAweEventDeregister can be null.
| [in] | cbAweEventTrigger | Function pointer of the event trigger callback |
| [in] | cbAweEventRegister | Function pointer of the event register callback (optional) |
| [in] | cbAweEventDeregister | Function pointer of the event deregister callback (optional) |
| INT32 awe_resetState | ( | AWEInstance * | pAWE | ) |
Calling this function while audio processing is ongoing can cause audio glitches. It is recommended to stop audio before calling the layout reset function.
