Examples.
#define _GNU_SOURCE
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <unistd.h>
#include <sys/types.h>
#include <sys/socket.h>
#include <errno.h>
#include <signal.h>
#include <netinet/in.h>
#include <pthread.h>
#include <sched.h>
#include <math.h>
#include <time.h>
#include <semaphore.h>
#include <signal.h>
#include <time.h>
#include "TargetInfo.h"
float coreSpeed;
float profileSpeed;
float sampleRate;
UINT32 fundamentalBlockSize;
UINT32 inChannels;
UINT32 outChannels;
UINT32 profileStatus;
INT32 tuningPort;
} ConfigParameters;
const unsigned int loopback_dualcore_startAudio_InitCommands[] = {
0x0002000c, 0x00060006, 0x473b8000, 0x40040002, 0x00000100, 0x00000000, 0x00060006, 0x473b8000,
0x40040002, 0x00000100, 0x00000000, 0x00060006, 0x473b8000, 0x40040002, 0x00000100, 0x00000000,
0x00060106, 0x473b8000, 0x40040002, 0x00000100, 0x00000000, 0x00040007, 0x00000001, 0x00000001,
0x00040007, 0x00000002, 0x00000002, 0x000b000f, 0xbeef1039, 0x00000001, 0x00000005, 0x00000003,
0x00000000, 0x00000001, 0x00000000, 0x00000100, 0x00000000, 0x000b010f, 0xbeef1039, 0x00000001,
0x00000005, 0x00000001, 0x00000000, 0x00000001, 0x00000000, 0x00000100, 0x00000000, 0x0009000f,
0xbeef0866, 0x00000101, 0x00000002, 0x00000001, 0x00000003, 0x00000001, 0x00000000, 0x0007000f,
0xbeef086d, 0x00000001, 0x00000001, 0x00000003, 0x00000000, 0x00080065, 0x0000680a, 0x00000000,
0x00000400, 0x00000002, 0xc0a00000, 0x40a00000, 0x000c010f, 0xbeef103a, 0x00000100, 0x00000006,
0x00000001, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000100, 0x00000000, 0x0007010f,
0xbeef086d, 0x00000001, 0x00000001, 0x00000001, 0x00000000, 0x00080165, 0x0000480a, 0x00000000,
0x00000400, 0x00000002, 0xc0a00000, 0x40a00000, 0x000c000f, 0xbeef103a, 0x00000100, 0x00000006,
0x00000003, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000100, 0x00000000, 0x0007000f,
0xbeef086d, 0x00000001, 0x00000001, 0x00000003, 0x00000000, 0x00080065, 0x0000880a, 0x00000000,
0x00000400, 0x00000002, 0xc0a00000, 0x40a00000, 0x0009000f, 0xbeef0866, 0x00000101, 0x00000002,
0x00000003, 0x00000002, 0x00000000, 0x00000001, 0x00040010, 0x00000006, 0x00000001, 0x000a002f,
0x0000000a, 0x00000000, 0x00000005, 0x00000004, 0x00000006, 0x00000007, 0x00000008, 0x00000009,
0x00040110, 0x00000003, 0x00000001, 0x0007012f, 0x00000005, 0x00000000, 0x00000003, 0x00000002,
0x00000004, 0x0006013c, 0x00003008, 0x00000000, 0x00000100, 0x00000000, 0x0006003c, 0x00007008,
0x00000001, 0x00000100, 0x00000000, 0x0002001b, 0x00000000,
const unsigned int loopback_dualcore_startAudio_InitCommands_Len = sizeof(loopback_dualcore_startAudio_InitCommands) / sizeof(int);
#define LOAD_MULTICORE_AWB 1
#define NUM_INSTANCES 4
#ifndef TUNING_MASTER_INSTANCE
#define TUNING_MASTER_INSTANCE 0
#endif
#ifdef ENABLE_FAKE_FLASH_FILE_SYSTEM
#define FLASH_ERASABLE_BLOCK_SIZE 1024*4
#define FLASH_SIZE_PER_INSTANCE 1024*1024*4
#define FLASH_ERASE_TIME_SEC 5
UINT32 g_AWEEmulatedFFS[1024*1024*NUM_INSTANCES];
#endif
#define MAX_PUMP_COUNT 30
INT32 g_nPumpCount[NUM_INSTANCES];
#endif
LISTOFCLASSOBJECTS
UINT32 sharedHeap[SHARED_HEAP_SIZE_LINUX];
UINT32 tuningPacketBuffer[MAX_COMMAND_BUFFER_LEN];
#ifdef USE_SAME_BUFFER_PACKET_REPLY
UINT32 *tuningReplyBuffer = tuningPacketBuffer;
#else
UINT32 tuningReplyBuffer[MAX_COMMAND_BUFFER_LEN];
#endif
UINT32 *audioInputBuffer;
UINT32 *audioOutputBuffer;
pthread_t packetProcessHandles[NUM_INSTANCES];
pthread_t audioPumpAllThreadHandles[NUM_INSTANCES];
sem_t pumpSems[NUM_INSTANCES];
INT32 exitAudioCallbackThread;
INT32 audioStarted;
unsigned long long callbackCnt;
unsigned long long pumpCnts[NUM_INSTANCES];
INT32 quiet;
int sockfd, newsockfd;
int exitTuning = 0;
#define DEFAULT_TUNING_PORT (15092)
#define DEFAULT_BLOCK_SIZE (256)
#define AUDIO_CALLBACK_PRIO (99)
#define AUDIO_PUMP_PRIO (AUDIO_CALLBACK_PRIO - 1)
#define TUNING_THREAD_PRIO (AUDIO_PUMP_PRIO - NUM_INSTANCES)
void error(const char *msg)
perror(msg);
exit(1);
void sig_handler(int signo)
if (signo == SIGINT)
exitTuning = 1;
close(newsockfd);
shutdown(sockfd, SHUT_RDWR);
close(sockfd);
pthread_join(packetProcessHandles[TUNING_MASTER_INSTANCE], NULL);
FILE *fPtr = NULL;
fPtr = fopen("AWE_FFS_Emulated.bin", "wb");
if (fPtr)
fwrite(g_AWEEmulatedFFS, 1, sizeof(g_AWEEmulatedFFS), fPtr);
fclose(fPtr);
#endif
if (pInstances[0]->pPacketBuffer)
UINT32 pos = 0;
if (!quiet)
if (ret)
printf("Layout destroy failed, ret = %d\n", ret);
else
printf("Layout destroy success\n");
if (!quiet)
printf("Exiting LinuxAppMulti\n");
exit(0);
printf(
"Usage: %s [args]\n"
" -profStatus:N set profiling status (0 - disable, 1 - enable(default), 2 - enable module level only, 3 - enable top level only)\n"
" -bsize:N default 256, Audio block size for the system\n"
" -tport:N default 15092, port number for socket interface. User can choose between 15002 - 15098\n"
" -quiet print only error messages\n"
" -h, -help show this message\n"
"This program exercises the AWECore library with 2 AWEInstances.\n",
program);
exit(0);
void resetTuningSocket()
socklen_t clilen;
struct sockaddr_in cli_addr;
close(newsockfd);
listen(sockfd, 5);
#ifdef TUNING_DEBUG_PRINTS
if (!quiet)
printf("Listening again for connection on port %d\n", configParams.tuningPort);
#endif
clilen = sizeof(cli_addr);
newsockfd = accept(sockfd,
&clilen);
if (newsockfd < 0)
exitTuning = 1;
printf("ERROR on accept, %d\n", newsockfd);
return;
if (!quiet)
printf( "Found connection again!\n");
#endif
(void) arg;
socklen_t clilen;
INT32 schedPolicy, ret;
int socketOption;
schedPolicy = SCHED_RR;
if (ret != 0)
char threadNameBuffer[16];
snprintf(threadNameBuffer, 16, "awe0_packet");
ret = pthread_setname_np(packetProcessHandles[0], threadNameBuffer);
if (ret)
printf("Failed to set thread name to %s\n", threadNameBuffer);
if (sockfd < 0)
printf("ERROR opening socket, %d\n", sockfd);
return NULL;
socketOption = 1;
sizeof(serv_addr)) < 0)
printf("ERROR on binding\n");
return NULL;
listen(sockfd, 5);
if (!quiet)
&clilen);
if (newsockfd < 0)
return NULL;
if (!quiet)
while (!exitTuning)
struct timespec ts;
ts.tv_nsec = 2500000;
ts.tv_sec = 0;
while(1)
UINT32 plen;
INT32 readBytes, n;
g_nPumpCount[TUNING_MASTER_INSTANCE] = 0;
readBytes = recv(newsockfd, tuningPacketBuffer, MAX_COMMAND_BUFFER_LEN * sizeof(tuningPacketBuffer[0]), 0);
if (readBytes <= 0)
if (readBytes == 0)
printf("ERROR: socket read 0 length packet, attempt to reconnect\n");
else
printf("ERROR: socket read error, attempt to reconnect -- ret = %d, errno = %d\n", readBytes, errno);
#endif
resetTuningSocket();
break;
while (readBytes < plen)
printf("Didn't read the entire packet! readBytes = %d, totalPacketLength = %u\nReading again\n", readBytes, plen);
#endif
readBytes += recv(newsockfd, &((char*)tuningPacketBuffer)[readBytes], MAX_COMMAND_BUFFER_LEN * sizeof(tuningPacketBuffer[0]), 0);
n = write(newsockfd, tuningReplyBuffer, plen * sizeof(tuningReplyBuffer[0]));
if (n < plen)
printf("ERROR: Packet reply transmit failed -- ret = %d\n", n);
#endif
break;
else
return NULL;
void* packetProcessThread(void * args)
struct timespec ts;
schedParam.sched_priority = TUNING_THREAD_PRIO - instanceId;
if (ret != 0)
printf("Failed to increase priority of tuning thread %d with error: %s \nTry running with sudo\n", instanceId, strerror(ret));
snprintf(threadNameBuffer, 16, "awe%d_packet", instanceId);
pthread_setname_np(packetProcessHandles[instanceId], threadNameBuffer);
if (ret)
if (!quiet)
printf("Starting instance %d packet process thread\n", instanceId);
ts.tv_nsec = 5000000;
ts.tv_sec = 0;
while(1)
g_nPumpCount[instanceId] = 0;
return NULL;
void* aweuser_pumpAudio(void * args)
INT32 pumpMask;
INT32 schedPolicy, ret, targetPriority;
targetPriority = AUDIO_PUMP_PRIO - instanceId;
schedParam.sched_priority = targetPriority;
schedPolicy = SCHED_FIFO;
int policy;
pthread_getschedparam(currentHandle, &policy, &schedParam);
if ((SCHED_FIFO != policy) || (schedParam.sched_priority != targetPriority))
printf("Warning: Failed to increase priority of audio simulation thread to %d\nTry running as root\n", targetPriority);
snprintf(threadNameBuffer, 16, "awe%d_pump", instanceId);
ret = pthread_setname_np(audioPumpAllThreadHandles[instanceId], threadNameBuffer);
if (!quiet)
printf("Starting pump thread for instance %d\n", instanceId);
while (1)
sem_wait(&pumpSems[instanceId]);
if (instanceId == 0)
for (int i = 0; i < configParams.inChannels ; i++)
if (ret)
printf("Error: awe_audioImportSamples() failed, channel = %d, error = %d\n", i, ret);
for (int ix = 1; ix < NUM_INSTANCES; ix++)
sem_post(&pumpSems[ix]);
if (g_nPumpCount[instanceId] < MAX_PUMP_COUNT)
for (int j = 0; j < pAWE->numThreads; j++)
if (pumpMask & (1U << j))
if (ret > 0)
g_nPumpCount[instanceId]++;
for (int i = 0; i < configParams.outChannels ; i++)
if (ret)
printf("Error: awe_audioExportSamples() failed, channel = %d, error = %d\n", i, ret);
pumpCnts[instanceId]++;
return NULL;
struct timespec ts;
struct timespec ts_tmp;
long time_nsec;
long long accumulated_time1;
long long accumulated_time2;
long long overshoot = 0.0;
(void) args;
ts.tv_sec = 0;
ts_tmp.tv_sec = 0;
ts_tmp.tv_nsec = 0;
int policy;
if ((SCHED_FIFO != policy) || (schedParam.sched_priority != AUDIO_CALLBACK_PRIO))
printf("Warning: Failed to increase priority of audio simulation thread to %d\nTry running as root\n", AUDIO_CALLBACK_PRIO);
char threadNameBuffer[32];
snprintf(threadNameBuffer, 32, "awe_callback");
ret = pthread_setname_np(audioCallbackThreadHandle, threadNameBuffer);
if (ret)
callbackCnt++;
sem_post(&pumpSems[0]);
ts.tv_nsec = time_nsec - overshoot;
accumulated_time1 = ((long long)ts_tmp.tv_sec*1000000000) + ts_tmp.tv_nsec + time_nsec - overshoot;
while(1)
overshoot = (accumulated_time2 - accumulated_time1);
break;
else
return NULL;
exitAudioCallbackThread = 0;
callbackCnt = 0;
memset(pumpCnts, 0, sizeof(pumpCnts));
INT32 ret = pthread_create(&audioCallbackThreadHandle, NULL, audioCallbackSimulator, NULL);
if (ret)
return 0;
audioStarted = 1;
if (!quiet)
printf("Audio Started\n");
return 0;
if (audioStarted)
INT32 ret;
exitAudioCallbackThread = 1;
if (ret != 0)
if (!quiet)
UINT32 avgCycles;
const FLOAT32 clockRatios = configParams.coreSpeed / configParams.profileSpeed;
printf("\nAudio Stopped\n");
for (int i = 0; i < NUM_INSTANCES; i++)
avgCycles = 0;
printf("-- Pumped instance %d %llu times, average cycles per pump: %f\n", i, pumpCnts[i],
(avgCycles >> 8) * clockRatios);
audioStarted = 0;
return 0;
BOOL usrInitFlashFileSystem(void)
return SUCCESS;
BOOL usrReadFlashMemory(UINT32 nAddress, UINT32 * pBuffer, UINT32 nDWordsToRead)
BOOL bSuccess = 0;
if(nDWordsToRead == 0)
return SUCCESS;
memcpy(pBuffer, &g_AWEEmulatedFFS[nAddress >> 2], nDWordsToRead*sizeof(UINT32));
return SUCCESS;
BOOL usrWriteFlashMemory(UINT32 nAddress, UINT32 * pBuffer, UINT32 nDWordsToWrite)
BOOL bSuccess = 0;
if(nDWordsToWrite == 0)
return SUCCESS;
memcpy(&g_AWEEmulatedFFS[nAddress >> 2], pBuffer, nDWordsToWrite*sizeof(UINT32));
return SUCCESS;
BOOL usrEraseFlashMemorySector(UINT32 nStartingAddress, UINT32 nNumberOfSectors)
memset(&g_AWEEmulatedFFS[nStartingAddress >> 2], 0xffu, nNumberOfSectors * FLASH_ERASABLE_BLOCK_SIZE);
#endif
void InitializeAWEInstance(
AWEInstance * awePtr, INT32 instanceId)
int ret = 0;
UINT32 module_descriptor_table_size = sizeof(module_descriptor_table) / sizeof(module_descriptor_table[0]);
#endif
pAweFFSPtr->
cbInit = &usrInitFlashFileSystem;
#endif
awePtr->
awePtr->
slowHeapSize = SLOW_HEAP_SIZE_LINUX / NUM_INSTANCES;
awePtr->
pName = malloc(
sizeof(
char) * 8);
sprintf((
char*)awePtr->
pName,
"awe#%d", instanceId);
int i, j;
ret =
awe_initPin(&aweInputPin, configParams.inChannels, NULL);
if (ret != 0)
printf("awe_initPin inputPin failed on AWEInstance 0\n");
ret =
awe_initPin(&aweOutputPin, configParams.outChannels, NULL);
if (ret != 0)
printf("awe_initPin outputPin failed on AWEInstance 0\n");
#ifndef PI
#define PI 3.141592653589793
#endif
float blockRate = configParams.sampleRate / configParams.fundamentalBlockSize;
audioInputBuffer[i * configParams.inChannels + j] = float_to_fract32(sinf(2.f * PI *
(j + 1) * blockRate * (i / configParams.sampleRate)));
if (ret != 0)
printf("awe_init on instance %d failed with %d\n", instanceId, ret);
else
if (!quiet)
printf("Initialized instance %d\n", instanceId);
int i;
if ((TUNING_MASTER_INSTANCE < 0) || (TUNING_MASTER_INSTANCE >= NUM_INSTANCES))
printf("Provided TUNING_MASTER_INSTANCE of %d is out of range. Value should be [0 %d]\n",TUNING_MASTER_INSTANCE, NUM_INSTANCES-1);
return 0;
configParams.fundamentalBlockSize = DEFAULT_BLOCK_SIZE;
configParams.tuningPort = DEFAULT_TUNING_PORT;
quiet = 0;
for (i = 1; i < argc; i++)
const char *arg = argv[i];
quiet = 1;
else if ((0 == strncmp(arg, "-help", 5)) || (0 == strncmp(arg, "-h", 2)))
usage(argv[0]);
if (!quiet)
printf("\nAWECore initialised with the following parameters\n");
printf("-cf: %f Hz\n", configParams.coreSpeed);
printf("-pf: %f Hz\n", configParams.profileSpeed);
printf("-sr: %f Hz\n", configParams.sampleRate);
printf("-bsize: %u\n", configParams.fundamentalBlockSize);
printf("-inchans: %u\n", configParams.inChannels);
printf("-outchans: %u\n", configParams.outChannels);
printf("-tport: %d\n", configParams.tuningPort);
printf("-profStatus: %u\n", configParams.profileStatus);
printf("TUNING_MASTER_INSTANCE: %d\n", TUNING_MASTER_INSTANCE);
printf("Running with same buffer for packet and reply.\n");
#endif
FILE *fPtr = NULL;
memset(g_AWEEmulatedFFS, 0xffu, sizeof(g_AWEEmulatedFFS));
fPtr = fopen("AWE_FFS_Emulated.bin", "rb");
if (fPtr)
INT32 ret;
ret = fread(g_AWEEmulatedFFS, 1, sizeof(g_AWEEmulatedFFS), fPtr);
if (ret <= 0)
printf("Failed to read emulated AWE FFS from the file.");
fclose(fPtr);
#endif
audioInputBuffer = malloc(configParams.inChannels * configParams.fundamentalBlockSize * sizeof(UINT32));
audioOutputBuffer = malloc(configParams.outChannels * configParams.fundamentalBlockSize * sizeof(UINT32));
for (i = 0; i < NUM_INSTANCES; i++)
g_nPumpCount[i] = 0;
#endif
InitializeAWEInstance(pInstances[i], i);
pthread_create(&packetProcessHandles[TUNING_MASTER_INSTANCE], NULL, tuningPacketThread, pInstances[TUNING_MASTER_INSTANCE]);
if (i != TUNING_MASTER_INSTANCE)
pthread_create(&packetProcessHandles[i], NULL, packetProcessThread, pInstances[i]);
sem_init(&pumpSems[i], 0, 0);
pthread_create(&audioPumpAllThreadHandles[i], NULL, aweuser_pumpAudio, pInstances[i]);
if (LOAD_MULTICORE_AWB)
UINT32 position;
INT32 ret =
awe_loadAWBfromArray(pInstances[TUNING_MASTER_INSTANCE], loopback_dualcore_startAudio_InitCommands, loopback_dualcore_startAudio_InitCommands_Len, &position);
printf("Error loading awb: error = %d, at offset %u\n", ret, position);
else
printf("Loaded multi-instance awb\n");
pthread_join(packetProcessHandles[i], NULL);
pthread_join(audioPumpAllThreadHandles[i], NULL);
free(audioInputBuffer);
free(audioOutputBuffer);
free(pInstances[i]->pFastHeapA);
free(pInstances[i]->pFastHeapB);
free(pInstances[i]->pSlowHeap);
free((void*)pInstances[i]->pName);
free(pInstances[i]);
free(pFlashFSInstances[i]);
#endif
return 0;
The AWECore API Header File.
Definition: AWECoreUtils.h:40
Definition: AWECoreUtils.h:43
INT32 awe_packetProcessMulti(AWEInstance *pAWE, BOOL isTuningInstance)
Multi-instance Wrapper for tuning packet processing.
Audio pump function.
void awe_setInstancesInfo(AWEInstance **pInstances, INT32 numAweInstancesOnCore)
Setup function only intended for systems with multiple AWE Instances in a single core.
INT32 awe_getAverageLayoutCycles(AWEInstance *pAWE, UINT32 layoutIdx, UINT32 *averageCycles)
void awe_initFlashFS(AWEInstance *pAWE, AWEFlashFSInstance *pAWEFlashFSInstance)
Initialize the file system.
Test if AWE is ready to run.
INT32 awe_audioIsReadyToPumpMulti(AWEInstance *pAWE, UINT32 instanceID)
Test if AWE is ready to run on secondary instances (ID > 0).
Initialize the instance.
#define E_MULTI_PACKET_WAITING
Multi-instance packet has been forwarded but has not yet been serviced.
Definition: Errors.h:384
#define E_SUCCESS
OK result.
Definition: Errors.h:31
@ PFID_Destroy
Function ID for awe_fwDestroy().
Definition: ProxyIDs.h:68
@ Sample32bit
Data is 32 bit PCM .
The AWE instance.
Definition: AWEInstance.h:96
IOPinDescriptor * pInputPin
Definition: AWEInstance.h:160
const char * pName
Definition: AWEInstance.h:229
float profileSpeed
Profiling clock speed in Hz.
Definition: AWEInstance.h:221
UINT32 * pReplyBuffer
Reply buffer pointer.
Definition: AWEInstance.h:203
UINT32 * pFastHeapB
The second fast heap, B .
Definition: AWEInstance.h:108
UINT32 numThreads
Definition: AWEInstance.h:233
IOPinDescriptor * pOutputPin
Definition: AWEInstance.h:166
UINT32 * pPacketBuffer
The Packet buffer pointer.
Definition: AWEInstance.h:194
Definition: AWEInstance.h:130
OPTIONAL.
Definition: AWEInstance.h:136
UINT32 slowHeapSize
The slow heap size.
Definition: AWEInstance.h:122
Definition: AWEInstance.h:240
UINT32 * pSlowHeap
The slow heap.
Definition: AWEInstance.h:111
float sampleRate
Definition: AWEInstance.h:236
UINT32 packetBufferSize
Packet buffer size.
Definition: AWEInstance.h:210
volatile UINT32 * pSharedHeap
AWE Core shared memory definitions.
Definition: AWEInstance.h:251
UINT32 fastHeapBSize
The fast heap B size.
Definition: AWEInstance.h:119
UINT32 numProcessingInstances
The number of audio processing instances of AWE Core configured on a single target.
Definition: AWEInstance.h:257
UINT32 sharedHeapSize
The shared heap size, in 32-bit words.
Definition: AWEInstance.h:254
Definition: AWEInstance.h:245
float coreSpeed
Definition: AWEInstance.h:218
UINT32 instanceId
The ID of this instance.
Definition: AWEInstance.h:101
UINT32 numModules
Definition: AWEInstance.h:176
Pointer to module table.
Definition: AWEInstance.h:184
UINT32 fastHeapASize
Definition: AWEInstance.h:116
UINT32 * pFastHeapA
Fast heap A.
Definition: AWEInstance.h:105
The DSPC Flash File System Instance.
Definition: FlashFSInstance.h:40
UINT32 flashEraseTimeInMs
Flash erase time in milliseconds.
Definition: FlashFSInstance.h:51
BOOL(* cbFlashRead)(UINT32 nFlashAddress, UINT32 *pBuffer, UINT32 nDWordsToRead)
User function to read from flash.
Definition: FlashFSInstance.h:63
BOOL(* cbFlashWrite)(UINT32 nFlashAddress, UINT32 *pBuffer, UINT32 nDWordsToWrite)
User callback function to write to flash.
Definition: FlashFSInstance.h:60
UINT32 flashStartOffsetInBytes
Offset into start of flash used for file system.
Definition: FlashFSInstance.h:48
UINT32 flashSizeInBytes
Size of flash memory - if non-zero, next two values must also be non-zero.
Definition: FlashFSInstance.h:42
BOOL(* cbEraseSector)(UINT32 nStartingAddress, UINT32 nNumberOfSectors)
User callback function to erase one or more sectors.
Definition: FlashFSInstance.h:57
UINT32 flashErasableBlockSizeInBytes
Size of flash erase block.
Definition: FlashFSInstance.h:45
BOOL(* cbInit)(void)
User function to initialize flash file system.
Definition: FlashFSInstance.h:54
