Examples.
#include "ModuleList.h"
#include <errno.h>
#include <math.h>
#include <float.h>
#include <stdlib.h>
#define true    1
#define false   0
#include "passthrough_ControlInterface.h"
const char inFilename[] =  "../Audio/in_s32_stereo.raw";
const char outFilename[] = "../Audio/out_s32_stereo.raw";
const char awbFilename[] = "../Designs/passthrough.awb";
FILE *fin;
FILE *fout;
    LISTOFCLASSOBJECTS
int awe_isNearlyEqual(float a, float b, float epsilon)
    float absA = fabsf(a);
    float absB = fabsf(b);
    float diff = fabsf(a - b);
    if (a == b) {
        return 1;
    } else {
        if ((absA + absB) < FLT_MAX)
        else
void destroyExample()
    INT32 ret;
    fclose(fin);
    fclose(fout);
    free(inputBuffer);
    free(outputBuffer);
    inputBuffer = NULL;
    outputBuffer = NULL;
int main()
    #define FASTHEAP_A_SIZE 420000
    static UINT32 fastHeapA[FASTHEAP_A_SIZE];
    #define FASTHEAP_B_SIZE 420000
    static UINT32 fastHeapB[FASTHEAP_B_SIZE];
    #define SLOWHEAP_SIZE 420000
    static UINT32 slowHeap[SLOWHEAP_SIZE];
    INT32 ret;
    ret =
aweOS_init(&g_AWEOSInstance, &configParams, moduleDescriptorTable, moduleDescriptorTableSize);
        printf("aweOS Initialised \n");
    else
        printf(
"aweOS init failed. exiting application with error = %d %s\n", ret,
aweOS_errorToString(ret));
        exit(1);
    UINT32 position=0;
        printf("Loaded layout loaded from file %s\n", awbFilename);
    else
            printf(
"Layout %s load unsuccessful with Error = %d %s \n", awbFilename, ret,
        else
            printf(
"Layout %s load unsuccessful in the positions %u with Error = %d %s \n", awbFilename, position, ret,
        exit(1);
    if (1 != ret)
        exit(1);
    if (1 != ret)
        exit(1);
    FLOAT32 SR;
        exit(1);
        exit(1);
        exit(1);
    printf("Layout loaded with inputChannels=%u, outputChannels=%u, blockSize=%u, SR=%f\n", layoutInChannels, layoutOutChannels, layoutBlockSize, SR);
    UINT32 inSize, outSize;
    if (NULL == fin )
        printf("Error opening input file %s\n", inFilename);
        printf("Error %d \n", errno);
        exit(1);
    else
        printf("Opening input file %s\n", inFilename);
    if (NULL == fout)
        printf("Error opening input file %s\n", outFilename);
        exit(1);
    else
        printf("Opening output file %s\n", outFilename);
    float scaler1Gain;
    float scaler1TargetGain;
    long count = 0;
    int numSamplesRead = 0;
    UINT32 classId;
        if (AWE_Scaler1_classID != classId )
            printf("Error: Scaler1 module not found in layout (%u)\n", AWE_Scaler1_classID );
            exit(1);
    else
        if (AWE_Meter1_classID != classId)
            printf("Error: Meter module not found in layout (%u)\n",AWE_Meter1_classID);
            exit(1);
    else
    ret =
aweOS_ctrlGetValue(g_AWEOSInstance, AWE_Scaler1_gain_HANDLE, &scaler1Gain, 0, AWE_Scaler1_gain_SIZE);
        printf("\nGetValue: Default scaler1Gain = %f, error = %d\n", scaler1Gain, ret);
    else
    scaler1Gain = -10.0;
    ret =
aweOS_ctrlSetValue(g_AWEOSInstance, AWE_Scaler1_gain_HANDLE, (
void *)&scaler1Gain, 0, AWE_Scaler1_gain_SIZE);
    else
    ret =
    else
    ret =
aweOS_ctrlGetValue(g_AWEOSInstance, AWE_Scaler1_targetGain_HANDLE, &scaler1TargetGain, 0, AWE_Scaler1_targetGain_SIZE);
    else
        INT32 i, j;
        INT32 numOutFrames;
                printf(
"Error: aweOS_audioImportSamples() failed: error = %d %s exiting application\n", ret,
                exit(1);
                printf(
"Error: aweOS_audioExportSamples() failed: error = %d %s exiting application\n", ret,
                exit(1);
        count++;
        if (1024 == count)
            count = 0;
            ret =
aweOS_ctrlGetValue(g_AWEOSInstance, AWE_Meter1_value_HANDLE, &meter1Values, 0, AWE_Meter1_value_SIZE);
            else
#define EPSILON 0.1f
        for (j = 0; j < numOutFrames; j++)
            if (awe_isNearlyEqual(expectedValueChannel1, (float)outputBuffer[outputChannels * j], EPSILON) == 0)
                destroyExample();
                exit(1);
            if (awe_isNearlyEqual(expectedValueChannel2, (float)outputBuffer[outputChannels * j + 1], EPSILON) == 0)
                destroyExample();
                exit(1);
    printf("\n");
    ret =
    else
    ret =
    else
    UINT32 avgCycles;
    printf("Processed %ld audio frames -- average cycles per pump = %u\n", count, avgCycles);
    destroyExample();
    return 0;
#define E_CANTOPEN
Can't open the specified file.
Definition: Errors.h:157
#define E_NOSUCHFILE
The specified file does not exist.
Definition: Errors.h:160
#define E_SUCCESS
OK result.
Definition: Errors.h:31
@ Sample32bit
Data is 32 bit PCM .
void AWEOSInstance
Definition: AWECoreOS.h:106
INT32 aweOS_ctrlGetValue(const AWEOSInstance *pAWEOS, UINT32 handle, void *value, INT32 arrayOffset, UINT32 length)
Get a scalar or array value(s) of a module parameter by handle.
INT32 aweOS_ctrlGetModuleClass(const AWEOSInstance *pAWEOS, UINT32 handle, UINT32 *pClassID)
Get a module's object class from its handle.
INT32 aweOS_ctrlSetValue(const AWEOSInstance *pAWEOS, UINT32 handle, void *value, INT32 arrayOffset, UINT32 length)
Set a scalar or array value(s) of a module parameter by handle.
AWEOSConfigParameters.
Definition: AWECoreOS.h:117
UINT32 fastHeapBSize
Definition: AWECoreOS.h:123
UINT32 * pFastHeapA
Pointer to fast heap A.
Definition: AWECoreOS.h:119
UINT32 * pSlowHeap
Pointer to slow heap.
Definition: AWECoreOS.h:121
UINT32 slowHeapSize
Definition: AWECoreOS.h:124
UINT32 * pFastHeapB
Pointer to fast heap B.
Definition: AWECoreOS.h:120
UINT32 fastHeapASize
Definition: AWECoreOS.h:122
