Examples.
#include "ModuleList.h"
#include <stdlib.h>
#include <errno.h>
#include <math.h>
#include <float.h>
#include <unistd.h>
#include <sys/types.h>
#include <pthread.h>
#include <sched.h>
#include <signal.h>
#include <time.h>
#include <sys/time.h>
#include <semaphore.h>
#define true 1
#define false 0
#define FASTHEAP_A_SIZE 4200000
#define FASTHEAP_B_SIZE 4200000
#define SLOWHEAP_SIZE 4200000
UINT32 *fastHeapA;
UINT32 *fastHeapB;
UINT32 *slowHeap;
UINT32 heapSizeFastA = FASTHEAP_A_SIZE;
UINT32 heapSizeFastB = FASTHEAP_B_SIZE;
UINT32 heapSizeSlow = SLOWHEAP_SIZE;
sem_t pumpSem;
INT32 audioStarted = 0;
INT32 pumpActive = 0;
static UINT32 quiet = false;
static unsigned long long count = 0;
static UINT32 ErrMask = false;
INT32 *inputBuffer, *outputBuffer;
UINT8 *inputBuffer1, *outputBuffer1;
FILE *fin;
FILE *fout;
LISTOFCLASSOBJECTS
void sig_handler(int signo)
if (!quiet)
printf("Exiting Libtester\n");
exit(0);
void copyright()
printf(
"%s\nAWE Core OS Libtester Copyright (c) DSP Concepts 2013-2022\n", versionInfo.
textVer);
printf(
"Usage: %s [args]\n"
" -in:<file> input file to process\n"
" -out:<file> output file\n"
" -profStatus set profiling status (0 - disable, 1 - enable, 2 - enable module level only, 3 - enable top level only)\n"
" -wait default disabled, sets up the integrated socket interface and waits for the designer to connect\n"
" -tport default 15002, port number for socket interface. User can choose between 15002 - 15098\n"
" -tlog enable tuning packet logging\n"
"This program exercises the AWECoreOS library.\n",
program,FASTHEAP_A_SIZE,FASTHEAP_B_SIZE,SLOWHEAP_SIZE);
exit(0);
void usrLogging(
AWEOSInstance* pAWEOS, INT32 level, UINT32 type,
void* payload, INT32 payloadSizeInBytes)
struct timeval ts;
char timeCh[25];
gettimeofday(&ts, NULL);
if (payloadSizeInBytes > 0)
INT32 usrEventRegister(
AWEOSInstance* pAWEOS, INT32 eventType, UINT32 moduleObjId, INT32 payloadSizeInBytes,
void** userHandle)
INT32 usrEventDeregister(
void** userHandle)
INT32 usrEventTrigger(
void* payload, INT32 payloadSizeInBytes,
void* userHandle)
struct timeval ts;
char timeCh[25];
if (eventType == 10)
else
struct timespec ts;
struct timespec ts_tmp;
long time_nsec;
long long accumulated_time1;
long long accumulated_time2;
long long overshoot = 0.0;
(void) args;
audioStarted = 1;
ts.tv_sec = 0;
ts_tmp.tv_sec = 0;
ts_tmp.tv_nsec = 0;
int target_priority = max_priority - 2;
int policy;
if ((SCHED_FIFO != policy) ||
if (!pumpActive)
sem_post(&pumpSem);
while (overshoot > time_nsec)
overshoot -= time_nsec;
sem_post(&pumpSem);
else
overshoot = 0.0;
ts.tv_nsec = time_nsec;
accumulated_time1 = ((long long)ts_tmp.tv_sec*1000000000) + ts_tmp.tv_nsec + time_nsec;
while(1)
overshoot += (accumulated_time2 - accumulated_time1);
break;
else
return NULL;
void destroyExample()
INT32 ret;
free(inputBuffer);
free(outputBuffer);
free(fastHeapA);
free(fastHeapB);
free(slowHeap);
inputBuffer = NULL;
outputBuffer = NULL;
fastHeapA = NULL;
fastHeapB = NULL;
slowHeap = NULL;
INT32 ret;
FLOAT32 sampleRate;
printf("Loaded layout with inChans = %u, outChans = %u, blockSize = %u, sampleRate = %f\n", layoutInChannels, layoutOutChannels, blockSize, sampleRate);
if (0 != ret)
return 0;
count = 0;
while (1 != audioStarted)
if (!quiet)
printf("\n\nAudio Started\n");
return 0;
if (audioStarted)
INT32 ret;
exitAudioCallbackThread = 1;
if (0 != ret)
audioStarted = 0;
ErrMask = false;
if (!quiet)
UINT32 avgCycles;
printf("\nAudio Stopped\n");
printf(
"Processed %llu audio frames with I/O block size of %u -- average cycles: %f\n", count, configParams.
fundamentalBlockSize,
return 0;
copyright();
INT32 tuningPort = 15002;
const char *awbpath = NULL;
const char *infile = NULL;
const char *outfile = NULL;
UINT32 profileStatus = 1;
UINT32 waitFlag = false;
UINT32 tlog = false;
FLOAT32 layoutSampleRate = 0;
UINT32 inSize, outSize;
UINT32 i,j;
INT32 ret;
if (1 == argc)
usage(argv[0]);
else
printf("\nEntered parameters\n");
for (i = 1; i < argc; i++)
const char *arg = argv[i];
profileStatus = atoi(arg + 12);
printf("profStatus: %u\n", profileStatus);
configParams.
coreSpeed = (float)atof(arg + 4);
awbpath = arg + 6;
else if (0 == strncmp(arg, "-in:", 4))
infile = arg + 4;
printf("-in: %s\n",infile);
else if (0 == strncmp(arg, "-out:", 5))
outfile = arg + 5;
printf("-out: %s\n",outfile);
else if (0 == strncmp(arg, "-wait", 5))
waitFlag = true;
printf("-wait: %u\n",waitFlag);
tuningPort = atoi(arg + 7);
printf("-tport: %d\n",tuningPort);
else if (0 == strncmp(arg, "-tlog", 5))
tlog = true;
printf("-tlog: %u\n",tlog);
quiet = true;
printf("-quiet: %u\n",quiet);
else
if (!waitFlag )
if ((!awbpath) || (!outfile) || (!infile))
printf("Please rerun with the missing file arguments defined\n");
printf(" -load: %s\n", awbpath ? awbpath : "Missing");
printf(" -in: %s\n", infile ? infile : "Missing");
printf(" -out: %s\n", outfile ? outfile : "Missing");
exit(1);
if (!quiet)
printf("\naweOS initialised with the following parameters\n");
printf(
"Name: %s\n",configParams.
pName);
printf(
"-cf: %f Hz\n",configParams.
coreSpeed);
printf(
"num of Threads:%u\n",configParams.
numThreads);
if (profileStatus)
else
if (waitFlag)
printf("-wait: Set up the intergrated tuning interface and wait for the designer to connect\n");
else
printf("-wait: No tuning interface. Process the audio i/o files and the supplied design\n");
if (tlog)
printf("-tlog: Tuning log is enabled\n");
else
printf("-tlog: Tuning log is disabled\n");
printf("The following i/o files are used\n");
printf("-in: %s\n",infile ? infile : "undefined");
printf("-out: %s\n",outfile ? outfile : "undefined");
printf("\n\n");
if (true == waitFlag)
pthread_mutex_init(&audioThreadMutex, NULL);
pthread_cond_init (&audioThreadCond, NULL);
sem_init(&pumpSem, 0, 0);
ret =
aweOS_init(&g_AWEOSInstance, &configParams, moduleDescriptorTable, moduleDescriptorTableSize);
if (!quiet)
printf("aweOS Initialised\n\n");
else
printf(
"aweOS init failed. exiting application with error = %d %s\n",ret,
aweOS_errorToString(ret));
exit(1);
if (!quiet)
printf("aweOS profiling is disabled\n");
else
printf(
"aweOS_setProfilingStatus: profiling status set failed. exiting application with error = %d %s\n",ret,
exit(1);
if (ret)
if (!quiet)
if (ret)
if (!quiet)
if (tlog)
if (!quiet)
printf("aweOS integrated tuning interface logging enabled, with the mode set to TUNING_LOG_INFO\n");
else
printf(
"aweOS_tuningLoggingEnable: failed with the error = %d %s\n",ret,
if ( NULL != awbpath )
UINT32 position;
fin = fopen(awbpath, "rb");
if (NULL == fin )
printf("Error string: %s \nPlease check the path\n", strerror(errno));
exit(1);
if (!quiet)
printf("The layout %s loaded with parameters\n", awbpath);
else
exit(1);
printf(
"Error: aweOS_layoutGetChannelCount failed: error = %d %s\n", ret,
exit(1);
printf(
"Error: aweOS_layoutGetBlockSize failed: error = %d %s\n", ret,
exit(1);
printf(
"Error: aweOS_layoutGetSampleRate failed: error = %d %s\n", ret,
exit(1);
if (!quiet)
printf("sr: %f\ninchans: %u\noutchans: %u\nbsize: %u\n\n", layoutSampleRate, layoutInChannels, layoutOutChannels, layoutBlockSize);
if (1 != ret)
exit(1);
if (1 != ret)
exit(1);
#ifndef PI
#define PI 3.141592653589793
#endif
printf(
"Failed to open aweOS integrated tuning interface on Port number: %d with the error = %d %s \n", tuningPort, ret,
else
if (!quiet)
printf("aweOS integrated tuning interface is open on Port number: %d\n", tuningPort);
int target_priority = max_priority - 3;
int policy;
printf("Warning: Failed to increase priority of audio thread to %d\nTry running as root\n", target_priority);
while (1)
sem_wait(&pumpSem);
pumpActive = 1;
printf(
"Error: aweOS_audioImportSamples() failed: error = %d %s \n", ret,
if (ErrMask == 0)
ErrMask = true;
printf(
"Error: aweOS_audioExportSamples() failed: error = %d %s \n", ret,
count++;
pumpActive = 0;
return 0;
else
INT32 numSamplesRead = 0;
UINT32 wfNumChannels=0 , wfSampleSize =0, wfNumSamples = 0, outSampleSize = 0;
FLOAT32 wfSampleRate=0;
UINT32 chOffset=0;
ret =
aweOS_wavFileOpen(infile, &wfSampleRate, &wfNumChannels, &wfSampleSize, &wfNumSamples, &fin);
printf(
"Error opening input file %s return with error: %d %s\n", infile, ret,
exit(1);
else
if (!quiet)
printf("Opening input file %s with paramerters\n", infile);
printf("sr: %f \nchannels: %u \nsampleWidth: %u \nTotalSamples: %u\n\n", wfSampleRate, wfNumChannels ,wfSampleSize, wfNumSamples);
if (wfSampleRate != layoutSampleRate)
printf("Warning: Mismatch in sampleRate \nInput file %s sr: %f and Layout %s sr: %f\n",infile, wfSampleRate, awbpath, layoutSampleRate);
if (wfNumChannels != layoutInChannels)
printf("Warning: Mismatch in number of input channels \nInput file %s inchans: %u and Layout %s inchans: %u\n",infile, wfNumChannels, awbpath, layoutInChannels );
if (4 == wfSampleSize)
else if (2 == wfSampleSize)
else
printf("Error processing input file %s unspported sample type: %u\n", infile, wfSampleSize);
printf("Currently only 2 bytes and 4 bytes sample sizes supported\n");
exit(1);
outsampleType = wfsampleType;
outSampleSize = wfSampleSize;
printf(
"\nError creating the output file %s return with error: %d %s\n", outfile, ret ,
exit(1);
else
if (!quiet)
printf("\nCreating the output file %s with paramerters\n", outfile);
printf("sr: %f (from input .wav)\nchannels: %u (from layout)\nsampleWidth: %u (from input .wav)\n", wfSampleRate, layoutOutChannels, outSampleSize);
inputBuffer1 = malloc(inSize * wfSampleSize);
outputBuffer1 = malloc(outSize * outSampleSize);
if (!quiet)
printf("\nStarting to process [%s] into [%s]\n\n", infile, outfile);
while ((numSamplesRead =
aweOS_wavFileRead(fin, inputBuffer1, inSize, wfSampleSize)) > 0)
for (i = 0, chOffset = 0; i < wfNumChannels; i++, chOffset += wfSampleSize)
else
printf(
"Error: aweOS_audioImportSamples() failed: error = %d %s exiting application\n", ret,
exit(1);
if (ErrMask == false)
ErrMask = true;
for (i = 0, chOffset = 0; i < layoutOutChannels; i++, chOffset += outSampleSize)
ret =
aweOS_audioExportSamples(g_AWEOSInstance, (INT32 *)(outputBuffer1 + chOffset), layoutOutChannels, i, outsampleType);
else
ret =
aweOS_audioExportSamples(g_AWEOSInstance, (INT16 *)(outputBuffer1 + chOffset), layoutOutChannels, i, outsampleType);
printf(
"Error: aweOS_audioExportSamples() failed: error = %d %s exiting application\n", ret,
exit(1);
count++;
printf("\n");
printf(
"Processed Audio Frames: %llu (block size %u)copied it to output file: %s\n", count, configParams.
fundamentalBlockSize, outfile);
destroyExample();
return 0;
#define E_SUCCESS
OK result.
Definition: Errors.h:31
enum _SampleType SampleType
Type of data for I/O.
@ Sample32bit
Data is 32 bit PCM .
@ Sample16bit
Data is 16 bit PCM.
Definition: StandardDefs.h:222
#define TUNING_LOG_INFO
Definition: AWECoreOS.h:54
void AWEOSInstance
Definition: AWECoreOS.h:106
INT32 aweOS_wavFileCreate(const char *file, FLOAT32 sampleRate, UINT32 numChannels, UINT32 sampleSize, FILE **fp)
Create a .wav file and populate the header with the passed in arguments.
INT32 aweOS_wavFileRead(FILE *fp, void *samples, UINT32 numSamples, UINT32 sampleSize)
Read audio data from .wav file opened using aweOS_wavFileOpen.
INT32 aweOS_registerLoggingCallback(AWEOSInstance *pAWEOS, cbAweOSLogging_t cbAweOSLogging, INT32 logLevel, UINT32 logTypeMask)
INT32 aweOS_wavFileWrite(FILE *fp, void *samples, UINT32 numSamples, UINT32 sampleSize)
Write audio data to .wav file created using aweOS_wavFileCreate.
void aweOS_getVersion(AWEOSVersionInfo_t *versionInfo)
Get the version information of the AWE Core OS library.
INT32 aweOS_registerEventCallbacks(AWEOSInstance *pAWEOS, cbAweOSEventTrigger_t cbAweOSEventTrigger, cbAweOSEventRegister_t cbAweOSEventRegister, cbAweOSEventDeregister_t cbAweOSEventDeregister)
INT32 aweOS_setProfilingStatus(AWEOSInstance *pAWEOS, UINT32 status)
Enable or disable the profiling ability of the AWE Core OS Instance.
INT32 aweOS_wavFileOpen(const char *file, FLOAT32 *sampleRate, UINT32 *numChannels, UINT32 *sampleSize, UINT32 *numSamples, FILE **fp)
Open a .wav file and populate the user arguments with the header information in the file.
INT32 aweOS_wavFileClose(FILE *fp)
Close the.wav file opened using aweOS_wavFileOpen or aweOS_wavFileCreate.
Versioning structure returned by aweOS_getVersion.
Definition: AWECoreOS.h:93
const char * textVer
String of form: "AWECoreOS Version 8.A.1.1 -- Build Number 1234".
Definition: AWECoreOS.h:100
AWEOSConfigParameters.
Definition: AWECoreOS.h:117
float profileSpeed
Definition: AWECoreOS.h:132
UINT32 fastHeapBSize
Definition: AWECoreOS.h:123
const char * pName
Name of target.
Definition: AWECoreOS.h:133
float coreSpeed
Processor clock speed in Hz.
Definition: AWECoreOS.h:131
UINT32 * pFastHeapA
Pointer to fast heap A.
Definition: AWECoreOS.h:119
UINT32 numThreads
Definition: AWECoreOS.h:134
UINT32 fundamentalBlockSize
Definition: AWECoreOS.h:136
UINT32 * pSlowHeap
Pointer to slow heap.
Definition: AWECoreOS.h:121
UINT32 outChannels
Definition: AWECoreOS.h:138
UINT32 packetBufferSize
Size of packet buffers.
Definition: AWECoreOS.h:129
UINT32 slowHeapSize
Definition: AWECoreOS.h:124
Definition: AWECoreOS.h:126
UINT32 * pFastHeapB
Pointer to fast heap B.
Definition: AWECoreOS.h:120
UINT32 fastHeapASize
Definition: AWECoreOS.h:122
float sampleRate
Sample rate of audio device.
Definition: AWECoreOS.h:135
UINT32 inChannels
Definition: AWECoreOS.h:137
Definition: AWECoreOS.h:125
