Loading...
Searching...
No Matches
LayoutControl.c
Examples.
Examples
* LayoutControl
* Description: Pump a .wav file through a .awb layout. Set/get module variables with control API
* This example shows how to load an .awb from an file, and then
* how to get and set module variables with the Control Interface API.
* The example will stream an audio file called in_s32_stereo.raw
* and write the processed output to out_s32_stereo.raw
* This example meets all the conditions to achieve 0 blocks of
* latency in the AWE Core OS audio path. See the Latency section
* of the docs for more info.
* 3235 Kifer Road
* Santa Clara, CA 95054-1527
#include "AWECoreOS.h"
#include "ModuleList.h"
#include <errno.h>
#include <math.h>
#include <float.h>
#include <stdlib.h>
// Defines
#define true 1
#define false 0
// Passthrough layout releated includes
#include "PassthroughSubcanvasContainer_ControlInterface.h"
const char inFilename[] = "../Audio/in_s32_stereo.raw"; // input audio file: stereo 32-bit fixed-point
const char outFilename[] = "../Audio/out_s32_stereo.raw"; // output audio file: stereo 32-bit fixed-point
const char awbFilename[] = "../Designs/PassthroughSubcanvasContainer.awb"; // Awb file that is used
const char awbFilename_subcanvas[] = "../Designs/ControlAppSubcanvas.awb"; // Awb file that is used
FILE *fin;
FILE *fout;
// Declare an AWEOSInstance pointer.
// Declare an AWEOSConfigParameters structure. The members of this structure determine the configuration of the AWEInstance members.
// For this example, it will be populated with defaults
// Declare a module descriptor table. This module descriptor table includes the modules as defined in ModuleList.h (which we will ship)
LISTOFCLASSOBJECTS
// Floating-point comparison function used for verification
// Inspired by: http://floating-point-gui.de/errors/comparison/
int awe_isNearlyEqual(float a, float b, float epsilon)
float absA = fabsf(a);
float absB = fabsf(b);
float diff = fabsf(a - b);
if (a == b) { // to handle infinities
return 1;
// a or b is zero or both are extremely close to it
// relative error is less meaningful here
} else { // use relative error
if ((absA + absB) < FLT_MAX)
else
void destroyExample()
INT32 ret;
fclose(fin);
fclose(fout);
free(inputBuffer);
free(outputBuffer);
inputBuffer = NULL;
outputBuffer = NULL;
ret = aweOS_destroy(&g_AWEOSInstance);
if (ret != E_SUCCESS)
printf("aweOS_destroy returned error = %d (%s)\n", ret, aweOS_errorToString(ret));
int main()
//Allocate a fastheapA
#define FASTHEAP_A_SIZE 420000
static UINT32 fastHeapA[FASTHEAP_A_SIZE];
configParams.pFastHeapA = fastHeapA;
configParams.fastHeapASize = FASTHEAP_A_SIZE;
//Allocate a fastheapB
#define FASTHEAP_B_SIZE 420000
static UINT32 fastHeapB[FASTHEAP_B_SIZE];
configParams.pFastHeapB = fastHeapB;
configParams.fastHeapBSize = FASTHEAP_B_SIZE;
//Allocate a slowheap
#define SLOWHEAP_SIZE 420000
static UINT32 slowHeap[SLOWHEAP_SIZE];
configParams.pSlowHeap = slowHeap;
configParams.slowHeapSize = SLOWHEAP_SIZE;
INT32 ret;
//Initialize the AWEOSInstance with the parameters that were previously set in the config structure
if (E_SUCCESS == ret)
printf("aweOS Initialised \n");
else
printf("aweOS init failed. exiting application with error = %d %s\n", ret, aweOS_errorToString(ret));
exit(1);
//Load the AWB from file
UINT32 position=0;
ret = aweOS_loadAWBFile(g_AWEOSInstance, awbFilename, &position);
printf("Loaded layout loaded from file %s\n", awbFilename);
else
if (E_NOSUCHFILE == ret || E_CANTOPEN == ret)
printf("Layout %s load unsuccessful with Error = %d %s \n", awbFilename, ret, aweOS_errorToString(ret));
else
printf("Layout %s load unsuccessful in the positions %u with Error = %d %s \n", awbFilename, position, ret, aweOS_errorToString(ret));
exit(1);
//Check if the layout is valid
ret = aweOS_layoutIsValid(g_AWEOSInstance);
if (1 != ret)
printf("Error: Loaded layout is not valid: error = %d %s\n", ret, aweOS_errorToString(ret));
exit(1);
//Check if the Audio has started
ret = aweOS_audioIsStarted(g_AWEOSInstance);
if (1 != ret)
printf("Error: Audio not started: error = %d %s\n", ret, aweOS_errorToString(ret));
exit(1);
// Get the layout I/O configuration Input, Output and block size
// Input and output blocksizes are the same in all layouts
FLOAT32 SR;
ret = aweOS_layoutGetChannelCount(g_AWEOSInstance, &layoutInChannels, &layoutOutChannels);
if (E_SUCCESS != ret)
printf("Error: GetChannelCount failed: error = %d %s\n", ret, aweOS_errorToString(ret));
exit(1);
ret = aweOS_layoutGetBlockSize(g_AWEOSInstance, &layoutBlockSize);
printf("Error: GetBlockSize failed: error = %d %s\n", ret, aweOS_errorToString(ret));
exit(1);
ret = aweOS_layoutGetSampleRate(g_AWEOSInstance, &SR);
printf("Error: GetSampleRate failed: error = %d %s\n", ret, aweOS_errorToString(ret));
exit(1);
printf("Layout loaded with inputChannels=%u, outputChannels=%u, blockSize=%u, SR=%f\n", layoutInChannels, layoutOutChannels, layoutBlockSize, SR);
//Prepare the stereo input and output buffers
UINT32 inSize, outSize;
//The system is hardcoded for 2 channels.
//Prepare the stereo input and output buffers, and open files
if (NULL == fin )
printf("Error opening input file %s\n", inFilename);
printf("Error %d \n", errno);
exit(1);
else
printf("Opening input file %s\n", inFilename);
if (NULL == fout)
printf("Error opening input file %s\n", outFilename);
exit(1);
else
printf("Opening output file %s\n", outFilename);
//Set Scaler1 gain attributes
float scaler1Gain;
float scaler1TargetGain;
float sinkValue;
long count = 0;
long subcount = 0;
int numSamplesRead = 0;
float subCanvasSetValue;
UINT32 classId;
//NOTE: All handle/ID/size macros passed into the aweOS_ctrl API's are found in the ControlInterface header file, "passthrough_ControlInterface.h"
//This header file was generated by Designer, alongside the corresponding .awb layout "passthrough_InitAWB.h".
//Check that the layout has the correct control modules in it
//Scaler module check
ret = aweOS_ctrlGetModuleClass(g_AWEOSInstance, AWE_Scaler1_gain_HANDLE, &classId);
// Check that module assigned this object ID is of module class Scaler
if (AWE_Scaler1_classID != classId )
printf("Error: Scaler1 module not found in layout (%u)\n", AWE_Scaler1_classID );
exit(1);
else
printf("Error: aweOS_ctrlGetModuleClass with error = %d %s\n", ret,aweOS_errorToString(ret));
// Meter module check
ret = aweOS_ctrlGetModuleClass(g_AWEOSInstance, AWE_Meter1_value_HANDLE, &classId);
// Check that module assigned this object ID is of module class Meter
if (AWE_Meter1_classID != classId)
printf("Error: Meter module not found in layout (%u)\n",AWE_Meter1_classID);
exit(1);
else
printf("Error: aweOS_ctrlGetModuleClass with error = %d %s\n", ret, aweOS_errorToString(ret));
ret = aweOS_ctrlGetValue(g_AWEOSInstance, AWE_Scaler1_gain_HANDLE, &scaler1Gain, 0, AWE_Scaler1_gain_SIZE);
printf("\nGetValue: Default scaler1Gain = %f, error = %d\n", scaler1Gain, ret);
else
printf("Error: aweOS_ctrlGetValue with error = %d %s\n", ret, aweOS_errorToString(ret));
//Set the gain to -10 dB
scaler1Gain = -10.0;
ret = aweOS_ctrlSetValue(g_AWEOSInstance, AWE_Scaler1_gain_HANDLE, ( void *)&scaler1Gain, 0, AWE_Scaler1_gain_SIZE);
else
printf("Error: aweOS_ctrlSetValue with error = %d %s\n", ret, aweOS_errorToString(ret));
else
ret = aweOS_ctrlGetValue(g_AWEOSInstance, AWE_Scaler1_targetGain_HANDLE, &scaler1TargetGain, 0, AWE_Scaler1_targetGain_SIZE);
else
//Process the input data
INT32 i, j;
INT32 numOutFrames;
ret = aweOS_audioImportSamples(g_AWEOSInstance, inputBuffer + i, inputChannels, i, Sample32bit);
printf("Error: aweOS_audioImportSamples() failed: error = %d %s exiting application\n", ret, aweOS_errorToString(ret));
exit(1);
aweOS_audioPumpAll(g_AWEOSInstance);
ret = aweOS_audioExportSamples(g_AWEOSInstance, outputBuffer + i, outputChannels, i, Sample32bit);
printf("Error: aweOS_audioExportSamples() failed: error = %d %s exiting application\n", ret, aweOS_errorToString(ret));
exit(1);
count++;
// Print the Meter1 value every 1024 pump cycles
if (1024 == count)
subcount++;
count = 0;
ret = aweOS_ctrlGetValue(g_AWEOSInstance, AWE_Meter1_value_HANDLE, &meter1Values, 0, AWE_Meter1_value_SIZE);
else
if (subcount == 2)
printf("\n ---- LATE LOADING SUBCANVAS AWB. ---- \n\n");
//late load the subcanvas AWB. SubcanvasSinkValue should now be 3
ret = aweOS_loadSubcanvasAWBfromFile(g_AWEOSInstance, AWE_Subcanvas1____SC_ID, awbFilename_subcanvas, &position);
printf("Failed to reload the subcanvas AWB with error %d \n", ret);
destroyExample();
exit(1);
else
printf("\n --- SETTING subcanvasSinkValue VALUE TO 8.0f --- \n");
subCanvasSetValue = 8.0f;
ret = aweOS_ctrlSetValue(g_AWEOSInstance, AWE_DC1_value_HANDLE, &subCanvasSetValue, 0, AWE_DC1_value_SIZE);
printf("Failed to set subcanvasSetValue with error %d \n", ret);
//Perform inline verification
//Channel 1 is expected to be attenuated by -10 dB
//Channel 2 is expected to be passed through without modification
#define EPSILON 0.1f
for (j = 0; j < numOutFrames; j++)
if (awe_isNearlyEqual(expectedValueChannel1, (float)outputBuffer[outputChannels * j], EPSILON) == 0)
destroyExample();
exit(1);
if (awe_isNearlyEqual(expectedValueChannel2, (float)outputBuffer[outputChannels * j + 1], EPSILON) == 0)
destroyExample();
exit(1);
// There is no latency introduced through this audio path
printf("\n");
//verify that the subcanvas sink value was actually set to 8.0f in the pump loop...
ret = aweOS_ctrlGetValue(g_AWEOSInstance, AWE_Sink1_value_HANDLE, &sinkValue, 0, AWE_Sink1_value_SIZE);
if (ret == E_SUCCESS)
printf("GetValue: subcanvasSinkValue = %f, error = %d\n", sinkValue, ret);
if (sinkValue != subCanvasSetValue)
printf("ERROR: The subcanvas sink value does not match the set value (8.0f) Exiting..\n");
destroyExample();
exit(1);
else
printf("Getting subcanvas sink failed on aweOS_ctrlGetValue with error %d \n", ret);
else
else
UINT32 avgCycles;
ret = aweOS_getAverageLayoutCycles(g_AWEOSInstance, 0, &avgCycles);
printf("Processed %ld audio frames -- average cycles per pump = %u\n", count, avgCycles);
//Clean up
destroyExample();
return 0;
#define E_CANTOPEN
Can't open the specified file.
Definition Errors.h:157
#define E_NOSUCHFILE
The specified file does not exist.
Definition Errors.h:160
#define E_SUCCESS
OK result.
Definition Errors.h:31
@ Sample32bit
Data is 32 bit PCM .
Definition StandardDefs.h:231
void AWEOSInstance
Definition AWECoreOS.h:107
INT32 aweOS_ctrlGetValue(const AWEOSInstance *pAWEOS, UINT32 handle, void *value, INT32 arrayOffset, UINT32 length)
Get a scalar or array value(s) of a module parameter by handle.
INT32 aweOS_ctrlGetModuleClass(const AWEOSInstance *pAWEOS, UINT32 handle, UINT32 *pClassID)
Get a module's object class from its handle.
INT32 aweOS_ctrlSetValue(const AWEOSInstance *pAWEOS, UINT32 handle, void *value, INT32 arrayOffset, UINT32 length)
Set a scalar or array value(s) of a module parameter by handle.
INT32 aweOS_loadSubcanvasAWBfromFile(AWEOSInstance *pAWEOS, UINT32 SubcanvasModObjectID, const char *binaryFile, UINT32 *pPos)
Load an AWB file from stdio into Subcanvas module.
AWEOSConfigParameters.
Definition AWECoreOS.h:118
UINT32 fastHeapBSize
Definition AWECoreOS.h:124
UINT32 * pFastHeapA
Pointer to fast heap A.
Definition AWECoreOS.h:120
UINT32 * pSlowHeap
Pointer to slow heap.
Definition AWECoreOS.h:122
UINT32 slowHeapSize
Definition AWECoreOS.h:125
UINT32 * pFastHeapB
Pointer to fast heap B.
Definition AWECoreOS.h:121
UINT32 fastHeapASize
Definition AWECoreOS.h:123
