More...
#include "ProxyIDs.h"
#include "Errors.h"
#include "TargetProcessor.h"
#define | MAX_PROCESSING_INSTANCES (256) |
#define | PACKET_LENGTH_WORDS(x) (x[0]>>16) |
| | This will determine the length of a packet in words.
#define | PACKET_LENGTH_BYTES(x) ((x[0]>>16) * sizeof(x[0])) |
| | This will determine the length of a packet in bytes.
| #define | PACKET_INSTANCEID(x) (x[0] >> 8) & 0xff |
| | This will get the instance ID of a packet.
| #define | PACKET_OPCODE(x) ((INT32)x[0] & 0xffU) |
| | Get the OPCODE of the packet.
#define | AWB_DONE 1 |
| | return value that indicates that the end of the AWB has been reached
#define | AWB_NOT_DONE 0 |
| | return value that indicates that the end of the AWB has been reached and another command should be processed
| #define | AWE_DESTROY_CMD 0x0002000CU |
| | the awb destroy command.
#define | INCOMPLETE_PACKET 0 |
#define | COMPLETE_NEW_PACKET 1 |
#define | COMPLETE_REPEATED_PACKET 2 |
| #define | FLOAT_TO_FRACT32_DEFINED |
| | Convert audio data from floating point to Fract32 sample by sample.
| #define | FRACT32_TO_FLOAT_DEFINED |
| | Convert audio data from fract32 to float sample by sample.
| void | GenerateInstanceTableReply (UINT32 *pPacketBuffer, UINT32 numInstances, UINT32 *pInstanceTable) |
| | Generate an instance table reply for Server based on the arguments.
INT32 | float_to_fract32 (FLOAT32 x) |
FLOAT32 | fract32_to_float (INT32 x) |
| INT32 | awe_getNextAWBCmd (const UINT32 *pArray, UINT32 arraySize, UINT32 *pErrorOffset, UINT32 *pPacketBuffer) |
| | Get the next command from an array of AWB commands and write it into a packetBuffer to be processed.
◆ PACKET_INSTANCEID
| #define PACKET_INSTANCEID |
x | ) |
- Examples
- singleinstance_simple.c.
◆ PACKET_OPCODE
| #define PACKET_OPCODE |
x | ) |
- Examples
◆ AWE_DESTROY_CMD
| #define AWE_DESTROY_CMD 0x0002000CU |
load this as an awb array to destroy a running awb
- Examples
- ControlApp.c.
◆ FLOAT_TO_FRACT32_DEFINED
| #define FLOAT_TO_FRACT32_DEFINED |
- Parameters
| [in] | x | The floating point value that you wish to convert |
- Returns
- The converted value in fract32 format
◆ FRACT32_TO_FLOAT_DEFINED
| #define FRACT32_TO_FLOAT_DEFINED |
- Parameters
| [in] | x | The fract32 point value that you wish to convert |
- Returns
- The converted value as a float
◆ GenerateInstanceTableReply()
| void GenerateInstanceTableReply |
UINT32 * |
pPacketBuffer, |
UINT32 |
numInstances, |
UINT32 * |
pInstanceTable |
- Parameters
| [out] | pPacketBuffer | pointer to your instance's packet buffer |
| [in] | numInstances | number of instances on your system |
| [in] | pInstanceTable | pointer to your instanceID's table |
◆ awe_getNextAWBCmd()
| INT32 awe_getNextAWBCmd |
const UINT32 * |
pArray, |
UINT32 |
arraySize, |
UINT32 * |
pErrorOffset, |
UINT32 * |
pPacketBuffer |
- Parameters
| [in] | *pArray | The AWB array |
| [in] | arraySize | The size of the AWB array |
| [out] | *pErrorOffset | current position in the array (index of command) |
| [in] | *pPacketBuffer | The packetBuffer to write the next command into. |
- Returns
- AWB_NOT_DONE if processing of array is not complete
