Examples.
#include <float.h>
#include <math.h>
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include "TargetInfo.h"
#include "PassthroughSubcanvasContainer_InitAWB.h"
#include "PassthroughSubcanvasContainer_ControlInterface.h"
#include "ControlAppSubcanvas_InitAWB.h"
const char inFilename[] = "../Audio/in_s32_stereo.raw";
const char outFilename[] = "../Audio/out_s32_stereo.raw";
LISTOFCLASSOBJECTS
UINT32 fastHeapA[FASTA_HEAP_SIZE];
UINT32 fastHeapB[FASTB_HEAP_SIZE];
UINT32 slowHeap[SLOW_HEAP_SIZE];
FILE *fin;
FILE *fout;
int awe_isNearlyEqual(float a, float b, float epsilon)
float absA = fabsf(a);
float absB = fabsf(b);
float diff = fabsf(a - b);
if (a == b) {
return 1;
} else {
if ((absA + absB) < FLT_MAX)
else
void destroyExample()
UINT32 position;
printf("Failed to destroy subcanvas AWB with error %d ", ret);
fclose(fin);
fclose(fout);
free(inputBuffer);
free(outputBuffer);
inputBuffer = NULL;
outputBuffer = NULL;
void InitializeAWEInstance()
int ret;
aweInstance.
aweInstance.
pName = NULL;
ret =
awe_initPin(&aweInputPin, NUM_INPUT_CHANNELS, NULL);
if (ret != 0)
ret =
awe_initPin(&aweOutputPin, NUM_OUTPUT_CHANNELS, NULL);
if (ret != 0)
if (ret != 0)
printf("awe_init failed\n");
if (ret != 0)
printf("awe_setProfilingStatus failed\n");
int main() {
INT32 ret = 0;
UINT32 position;
UINT32 inSize, outSize;
InitializeAWEInstance();
ret =
awe_loadAWBfromArray(&aweInstance, Instance0_InitCommands, Instance0_InitCommands_Len, &position);
printf("Error loading AWB from array: error = %d, at offset %u\n", ret, position);
exit(1);
if (ret != 1)
exit(1);
if (ret != 1)
exit(1);
printf("Error: GetBlockSize failed: error = %d\n", ret);
exit(1);
printf("Layout loaded with inputChannels=%u, outputChannels=%u, blockSize=%u\n", layoutInChannels, layoutOutChannels, layoutBlockSize);
if (fin == NULL)
printf("Error opening file %s\n", inFilename);
exit(1);
if (fout == NULL)
printf("Error opening file %s\n", outFilename);
exit(1);
float scaler1Gain;
float sinkValue;
float scaler1TargetGain;
float subCanvasSetValue;
long count = 0;
long subCount = 0;
int numSamplesRead = 0;
UINT32 classId;
int deferredFlag = 1;
UINT32 pumpMask;
int moduleFound = 0;
if (classId == AWE_Scaler1_classID)
moduleFound = 1;
if (!moduleFound)
printf("Error: Scaler1 module not found in layout\n");
if (classId == AWE_Meter1_classID)
moduleFound = 1;
if (!moduleFound)
printf("Error: Meter1 module not found in layout\n");
printf("\n");
scaler1Gain = -10.0;
ret =
awe_ctrlSetValue(&aweInstance, AWE_Scaler1_gain_HANDLE, (
const void *)&scaler1Gain, 0, AWE_Scaler1_gain_SIZE);
ret =
awe_ctrlGetValue(&aweInstance, AWE_Scaler1_gain_HANDLE, &scaler1Gain, 0, AWE_Scaler1_gain_SIZE);
ret =
awe_ctrlGetValue(&aweInstance, AWE_Scaler1_targetGain_HANDLE, &scaler1TargetGain, 0, AWE_Scaler1_targetGain_SIZE);
INT32 i, j;
INT32 numOutFrames;
printf("Error: audio import failed: error = %d\n", ret);
if (pumpMask & 1U)
if (ret < 0)
printf("Error: audio pump failed: layout=%d, error=%d\n", 0, ret);
else if (ret == 1)
while(deferredFlag)
printf("Error: audio export failed: error = %d\n", ret);
count++;
if ((count % 1024) == 0)
subCount++;
ret =
awe_ctrlGetValue(&aweInstance, AWE_Meter1_value_HANDLE, &meter1Values, 0, AWE_Meter1_value_SIZE);
ret =
awe_ctrlGetValue(&aweInstance, AWE_Sink1_value_HANDLE, &sinkValue, 0, AWE_Sink1_value_SIZE);
printf("GetValue: subcanvasSinkValue = %f, error = %d\n", sinkValue, ret);
if (subCount == 2)
printf("\n ---- LATE LOADING SUBCANVAS AWB. ---- \n\n");
printf("Failed to reload the subcanvas AWB with error %d \n", ret);
destroyExample();
exit(1);
else
printf("\n --- SETTING subcanvasSinkValue VALUE TO 8.0f --- \n");
subCanvasSetValue = 8.0f;
ret =
awe_ctrlSetValue(&aweInstance, AWE_DC1_value_HANDLE, (
const void *)&subCanvasSetValue, 0, AWE_DC1_value_SIZE);
printf("Failed to set subcanvasSetValue with error %d \n", ret);
#define EPSILON 0.1f
for (j = 0; j < numOutFrames; j++) {
if (awe_isNearlyEqual(expectedValueChannel1, (float)outputBuffer[outputChannels * j], EPSILON) == 0) {
destroyExample();
exit(1);
if (awe_isNearlyEqual(expectedValueChannel2, (float)outputBuffer[outputChannels * j + 1], EPSILON) == 0) {
destroyExample();
exit(1);
ret =
if (sinkValue != subCanvasSetValue)
printf("ERROR: The subcanvas sink value does not match the set value (8.0f) Exiting..\n");
destroyExample();
exit(1);
else
printf("Getting subcanvas sink failed on awe_ctrlGetValue with error %d \n", ret);
printf("\n");
ret =
ret =
destroyExample();
return 0;
The AWECore API Header File.
#define AWE_DESTROY_CMD
the awb destroy command.
Definition AWECoreUtils.h:59
Audio pump function.
INT32 awe_ctrlGetModuleClass(AWEInstance *pAWE, UINT32 handle, UINT32 *pClassID)
INT32 awe_loadSubcanvasAWBfromArray(AWEInstance *pAWE, UINT32 SubcanvasModObjectID, const UINT32 *pCommands, UINT32 arraySize, UINT32 *pPos)
Executes packet commands from an in-memory array and loads AWB in Subcanvas module.
void awe_layoutGetChannelCount(const AWEInstance *pAWE, UINT32 pinIdx, UINT32 *inCount, UINT32 *outCount)
Returns the number of channels in the Layout's input and output pins.
Test if AWE is ready to run.
INT32 awe_ctrlGetValue(AWEInstance *pAWE, UINT32 handle, void *value, INT32 arrayOffset, UINT32 length)
INT32 awe_ctrlSetValue(AWEInstance *pAWE, UINT32 handle, const void *value, INT32 arrayOffset, UINT32 length)
Initialize the instance.
INT32 awe_layoutGetInputBlockSize(const AWEInstance *pAWE, UINT32 pinIdx, UINT32 *blockSize)
Returns the block size of a pin.
#define E_SUCCESS
OK result.
Definition Errors.h:31
@ Sample32bit
Data is 32 bit PCM .
Definition StandardDefs.h:231
The AWE instance.
Definition AWEInstance.h:113
IOPinDescriptor * pInputPin
Definition AWEInstance.h:193
const char * pName
Definition AWEInstance.h:265
float profileSpeed
Profiling clock speed in Hz.
Definition AWEInstance.h:257
UINT32 * pReplyBuffer
Reply buffer pointer.
Definition AWEInstance.h:239
UINT32 * pFastHeapB
The second fast heap, B .
Definition AWEInstance.h:125
UINT32 numThreads
Definition AWEInstance.h:269
IOPinDescriptor * pOutputPin
Definition AWEInstance.h:199
UINT32 * pPacketBuffer
The Packet buffer pointer.
Definition AWEInstance.h:230
Definition AWEInstance.h:147
OPTIONAL.
Definition AWEInstance.h:153
UINT32 slowHeapSize
The slow heap size.
Definition AWEInstance.h:139
UINT32 fundamentalBlockSize
Definition AWEInstance.h:276
UINT32 * pSlowHeap
The slow heap.
Definition AWEInstance.h:128
float sampleRate
Definition AWEInstance.h:272
UINT32 packetBufferSize
Packet buffer size.
Definition AWEInstance.h:246
UINT32 fastHeapBSize
The fast heap B size.
Definition AWEInstance.h:136
Definition AWEInstance.h:281
float coreSpeed
Definition AWEInstance.h:254
UINT32 numModules
Definition AWEInstance.h:209
Pointer to module table.
Definition AWEInstance.h:217
UINT32 fastHeapASize
Definition AWEInstance.h:133
UINT32 * pFastHeapA
Fast heap A.
Definition AWEInstance.h:122
