A very simple example of a single instance integration without real-time audio on Linux.
A very simple example of a single instance integration without real-time audio on Linux. Ethernet tuning interface. Examples
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <unistd.h>
#include <sys/types.h>
#include <sys/socket.h>
#include <netinet/in.h>
#include <pthread.h>
#include "TargetInfo.h"
static IOPinDescriptor g_InputPin[1];
static IOPinDescriptor g_OutputPin[1];
const void* g_module_descriptor_table[] =
LISTOFCLASSOBJECTS
#define MASTER_HEAP_SIZE (1024*1024)
#define FASTB_HEAP_SIZE (1024*1024)
#define SLOW_HEAP_SIZE (1024*1024)
UINT32 g_FastHeapA[MASTER_HEAP_SIZE];
UINT32 g_SlowHeap[MASTER_HEAP_SIZE];
UINT32 g_FastHeapB[MASTER_HEAP_SIZE];
UINT32 AWE_Packet_Buffer[264];
UINT32 AWE_Packet_Buffer_Reply[264];
void error(const char *msg)
perror(msg);
exit(1);
void *tuningPacketRxThread(void*)
int sockfd, newsockfd;
socklen_t clilen;
unsigned char buffer[264];
int n;
if (sockfd < 0)
error("ERROR opening socket");
serv_addr.sin_port = htons(15098);
sizeof(serv_addr)) < 0)
error("ERROR on binding");
listen(sockfd,5);
clilen = sizeof(cli_addr);
newsockfd = accept(sockfd,
&clilen);
if (newsockfd < 0)
error("ERROR on accept");
int i=1;
printf( "entering loop ...\n");
while(1)
memset((void*) AWE_Packet_Buffer, 0, 264);
n = read(newsockfd,AWE_Packet_Buffer,264*sizeof(AWE_Packet_Buffer[0]));
if (n < 0) error("ERROR reading from socket");
unsigned int plen = AWE_Packet_Buffer[0]>>16;
n = write(newsockfd,AWE_Packet_Buffer,plen*sizeof(AWE_Packet_Buffer[0]));
if (n < 0) error("ERROR writing to socket");
close(newsockfd);
close(sockfd);
void InitializeAWEInstance()
int ret = 0;
UINT32 module_descriptor_table_size = sizeof(g_module_descriptor_table) / sizeof(g_module_descriptor_table[0]);
g_AWEInstance.
g_AWEInstance.
pName = TARGET_NAME;
ret =
awe_initPin(g_InputPin, INPUT_CHANNEL_COUNT, NULL);
if (ret != 0)
ret =
awe_initPin(g_OutputPin, OUTPUT_CHANNEL_COUNT, NULL);
if (ret != 0)
if (ret != 0)
pthread_t rxthread_id;
pthread_t processthread_id;
InitializeAWEInstance();
pthread_create(&rxthread_id, NULL, tuningPacketRxThread, NULL);
pthread_join(rxthread_id, NULL);
while(1)
The AWECore API Header File.
#define PACKET_OPCODE(x)
Get the OPCODE of the packet.
Definition AWECoreUtils.h:50
#define PACKET_INSTANCEID(x)
This will get the instance ID of a packet.
Definition AWECoreUtils.h:46
Initialize the instance.
The AWE instance.
Definition AWEInstance.h:113
IOPinDescriptor * pInputPin
Definition AWEInstance.h:193
const char * pName
Definition AWEInstance.h:265
float profileSpeed
Profiling clock speed in Hz.
Definition AWEInstance.h:257
UINT32 * pReplyBuffer
Reply buffer pointer.
Definition AWEInstance.h:239
UINT32 * pFastHeapB
The second fast heap, B .
Definition AWEInstance.h:125
UINT32 numThreads
Definition AWEInstance.h:269
IOPinDescriptor * pOutputPin
Definition AWEInstance.h:199
UINT32 * pPacketBuffer
The Packet buffer pointer.
Definition AWEInstance.h:230
UINT32 slowHeapSize
The slow heap size.
Definition AWEInstance.h:139
UINT32 fundamentalBlockSize
Definition AWEInstance.h:276
UINT32 * pSlowHeap
The slow heap.
Definition AWEInstance.h:128
float sampleRate
Definition AWEInstance.h:272
UINT32 packetBufferSize
Packet buffer size.
Definition AWEInstance.h:246
UINT32 fastHeapBSize
The fast heap B size.
Definition AWEInstance.h:136
Definition AWEInstance.h:281
float coreSpeed
Definition AWEInstance.h:254
UINT32 instanceId
The ID of this instance.
Definition AWEInstance.h:118
UINT32 numModules
Definition AWEInstance.h:209
Pointer to module table.
Definition AWEInstance.h:217
UINT32 fastHeapASize
Definition AWEInstance.h:133
UINT32 * pFastHeapA
Fast heap A.
Definition AWEInstance.h:122
