AWE Core 8.D.13 Documentation
Loading...
Searching...
No Matches
Data Fields
_AWEInstance Struct Reference
The AWE instance. More...
#include <Include/AWEInstance.h>
Data Fields
UINT32 instanceId
 The ID of this instance.
UINT32 * pFastHeapA
 Fast heap A.
UINT32 * pFastHeapB
 The second fast heap, B .
UINT32 * pSlowHeap
 The slow heap.
UINT32 fastHeapASize
UINT32 fastHeapBSize
 The fast heap B size.
UINT32 slowHeapSize
 The slow heap size.
INT32(* cbAudioStart )(struct _AWEInstance *PAWE)
INT32(* cbAudioStop )(struct _AWEInstance *pAWE)
 OPTIONAL.
INT32(* cbPostDestroy )(struct _AWEInstance *pAWE)
 OPTIONAL.
INT32(* cbCacheInvalidate )(struct _AWEInstance *pAWE, void *nStartingAddress, UINT32 lengthInWords, INT32 CacheCallbackType)
 OPTIONAL This callback is invoked wherever cache flush or invalidation is required, either in the framework or in modules.
INT32(* cbGetLayoutThreadPriority )(struct _AWEInstance *pAWE, INT32 layoutNum)
 OPTIONAL This callback is invoked from a module which is going to split the internal processing into multiple parallel threads at the same thread priority as the layout priority.
INT32(* cbAweForwardPacket )(struct _AWEInstance *pAWE, INT32 instanceID)
 OPTIONAL This callback is invoked from awe_packetProcessMulti when the received packet is to secondary instances so that the BSP can use events to signal corresponding core to wakeup packet processing thread on secondary instances.
IOPinDescriptor * pInputPin
 A BSP author must define/allocate an input pin in their BSP and assign it to this member NOTE: AudioWeaver only supports single input/output pins, so the pin must have only ONE element Example: static IOPinDescriptor s_InputPin[1];.
IOPinDescriptor * pOutputPin
 A BSP author must define/allocate an output pin in their BSP and assign it to this member NOTE: AudioWeaver only supports single input/output pins, so the pin must have only ONE element Example: static IOPinDescriptor s_OutputPin[1];.
UINT32 numModules
const ModClassModule ** pModuleDescriptorTable
 Pointer to module table.
ModuleDescriptorListmoduleDescriptors
 Pointer to a _ModuleDescriptorList struct.
UINT32 * pPacketBuffer
 The Packet buffer pointer.
UINT32 * pReplyBuffer
 Reply buffer pointer.
UINT32 packetBufferSize
 Packet buffer size.
UINT32 userVersion
 User Version word.
float coreSpeed
float profileSpeed
 Profiling clock speed in Hz.
const char * pName
UINT32 numThreads
float sampleRate
UINT32 fundamentalBlockSize
AWEFlashFSInstancepFlashFileSystem
volatile UINT32 * pSharedHeap
 AWE Core shared memory definitions.
UINT32 sharedHeapSize
 The shared heap size, in 32-bit words.
UINT32 numProcessingInstances
 The number of audio processing instances of AWE Core configured on a single target.
UINT32 _Reserved [316]
 Internal members.
Detailed Description
The AWE instance.
Examples
ControlApp.c, LinuxApp.c, LinuxAppMulti.c, bare_metal_example.c, and singleinstance_simple.c.
Field Documentation
◆ instanceId
UINT32 _AWEInstance::instanceId
Single instance systems should always be 0. The instanceID of the AWEInstance must match the instanceID of your desired AWE commands. For example, if your packet router is routing commands to this instance with an address of 16, the instance's instanceID must be 16. See Packet Routing pseudocode above
Examples
◆ pFastHeapA
UINT32* _AWEInstance::pFastHeapA
Fast heap A.
This is the main heap. AWE heaps are user allocated memory required by the AWE Instance.
Examples
◆ fastHeapASize
UINT32 _AWEInstance::fastHeapASize
Heap sizes will vary from platform to platform, and also depend on the size of a layout. A good place to start for each heap is 1048576, however this will be too large for some platforms.
Examples
◆ cbAudioStart
INT32(* _AWEInstance::cbAudioStart) (struct _AWEInstance *PAWE)
A user will define their own callback function and initialize this member with a pointer to their function. This callback can be used for whatever the BSP author pleases, including configuring audio devices based on layout properties, etc..
Examples
ControlApp.c, LinuxApp.c, and LinuxAppMulti.c.
◆ cbAudioStop
INT32(* _AWEInstance::cbAudioStop) (struct _AWEInstance *pAWE)
OPTIONAL.
This callback is invoked when a layout is stopped or a StopAudio command is sent A user will define their own callback function and init this member with a pointer to their function. This callback can also be used for whatever the BSP author pleases, including halting audio streams, freeing buffers, etc...
Examples
◆ cbPostDestroy
INT32(* _AWEInstance::cbPostDestroy) (struct _AWEInstance *pAWE)
OPTIONAL.
This callback is invoked at the end of the PFID_Destroy command. A user will define their own callback function and init this member with a pointer to their function. This callback can be used for any custom destroy/cleanup tasks.
Examples
◆ cbCacheInvalidate
INT32(* _AWEInstance::cbCacheInvalidate) (struct _AWEInstance *pAWE, void *nStartingAddress, UINT32 lengthInWords, INT32 CacheCallbackType)
This callback is useful in the FFSWrapper where the FFS bin file stored in L2/L3 RAM. The callback is also useful for Multi Instance environments where the shared heap is allocated in a cached region. The callback function expects following arguments; the start address of the memory to be invalidated or flushed, length in 32-bit words and an integer indicating cache callback type to write back (flush) or invalidate - AWE_CACHE_CALLBACK_TYPE_WRITEBACK to write back and AWE_CACHE_CALLBACK_TYPE_INVALIDATE to invalidate.
◆ cbGetLayoutThreadPriority
INT32(* _AWEInstance::cbGetLayoutThreadPriority) (struct _AWEInstance *pAWE, INT32 layoutNum)
BSP is responsible to return the thread priority of the layoutNum.
◆ cbAweForwardPacket
INT32(* _AWEInstance::cbAweForwardPacket) (struct _AWEInstance *pAWE, INT32 instanceID)
Note that only tuning master should register this callback and pAWE argument is always a pointer to the tuning instance.
Examples
LinuxAppMulti.c.
◆ numModules
UINT32 _AWEInstance::numModules
This can be manually set, or it can be determined by getting the size of the module descriptor table. Example: UINT32 module_descriptor_table_size = sizeof(g_module_descriptor_table) / sizeof(g_module_descriptor_table[0]); AWEInstance1.numModules = module_descriptor_table_size;
Examples
◆ pModuleDescriptorTable
const ModClassModule** _AWEInstance::pModuleDescriptorTable
The module table is the list of modules that will be included in the instance. See the provided "ModuleList.h" header for syntax specifics. Any set of available modules can be included/excluded from the instance by simply adding or removing them from the table. Note: this is often used for reducing the memory usage in production. AudioWeaver Designer can generate a ModuleList.h from a layout that ONLY includes the modules used in that layout.
Examples
◆ pPacketBuffer
UINT32* _AWEInstance::pPacketBuffer
A BSP author must allocate a buffer of length packetBufferSize and set pPacketBuffer to the address of that buffer. Example: g_AWEInstance.packetBufferSize = packetBufferSize; UINT32 AWE_Packet_Buffer[g_AWEInstance.packetBufferSize]; g_AWEInstance.pPacketBuffer = AWE_Packet_Buffer;
Examples
◆ pReplyBuffer
UINT32* _AWEInstance::pReplyBuffer
Initialized the same way as pPacketBuffer. The pPacketBuffer will be processed and the reply will be inserted into pReplyBuffer. Example: g_AWEInstance.packetBufferSize = packetBufferSize; UINT32 AWE_Reply_Buffer[g_AWEInstance.packetBufferSize]; g_AWEInstance.pReplyBuffer = AWE_Reply_Buffer;
Examples
◆ packetBufferSize
UINT32 _AWEInstance::packetBufferSize
Packet buffer size.
Must be initialized to the size of the BSP's packet buffers. The recommended packet buffer size is 264 32-bit words. If you need to use a smaller packetBufferSize due to memory constraints on your target, please contact DSPC Engineering. (The absolute minimum packetBufferSize is 16 and absolute max is 4105)
Examples
◆ userVersion
UINT32 _AWEInstance::userVersion
User Version word.
A BSP author can initialize this to any UINT32 value they would like. Should mean something to the BSP author, but no required meaning/syntax.
Examples
bare_metal_example.c.
◆ pName
const char* _AWEInstance::pName
Can be any 8 character string Name of this instance as a string
Examples
◆ fundamentalBlockSize
UINT32 _AWEInstance::fundamentalBlockSize
In order for a layout to run on an instance, it must be a multiple of the fundamental blocksize
Examples
◆ pFlashFileSystem
AWEFlashFSInstance* _AWEInstance::pFlashFileSystem
OPTIONAL if no FFS. If implementing the optional flash file system, then assign this pointer to your properly initialized flash file system instance
Examples
ControlApp.c, LinuxApp.c, LinuxAppMulti.c, and singleinstance_simple.c.
◆ pSharedHeap
volatile UINT32* _AWEInstance::pSharedHeap
Not required if using only single-instance AWE Core The shared heap.
Examples
LinuxAppMulti.c.
◆ _Reserved
UINT32 _AWEInstance::_Reserved[316]
Internal members.
Reserved memory.
