AWE Core 8.D.13 Documentation
Loading...
Searching...
No Matches
Data Structures | Macros | Typedefs | Functions
AWEInstance.h File Reference
The AWEInstance API Header File. More...
#include <stdlib.h>
#include <string.h>
#include <stddef.h>
#include "TargetProcessor.h"
#include "FlashFSInstance.h"
#include "Pin.h"
#include "ModuleDescriptorList.h"
#include "AWELoggingDefs.h"
Data Structures
struct  _AWEInstance
 The AWE instance. More...
struct  AWEBuildVersionInfo
 Build versioning structure returned by awe_getBuildVersionInfo. More...
Macros
#define AWE_PROFILING_DISABLE_BOTH_LAYOUT_MODULE   0u
 Public macros to control profiling status.
#define AWE_PROFILING_ENABLE_BOTH_LAYOUT_MODULE   1u
#define AWE_PROFILING_ENABLE_ONLY_MODULE   2u
#define AWE_PROFILING_ENABLE_ONLY_LAYOUT   3u
#define AWE_MODULE_PROFILING_BIT_POS   0
 Profiling options bit masks and values.
#define AWE_MODULE_PROFILING_BIT_MASK   1
#define AWE_MODULE_PROFILING_AVERAGE   (0x0u << AWE_MODULE_PROFILING_BIT_POS)
#define AWE_MODULE_PROFILING_PEAK   (0x1u << AWE_MODULE_PROFILING_BIT_POS)
#define AWE_ACCURATE_PROFILING_BIT_POS   1
#define AWE_ACCURATE_PROFILING_BIT_MASK   2
#define AWE_ENABLE_ACCURATE_PROFILING   (0x0u << AWE_ACCURATE_PROFILING_BIT_POS)
#define AWE_DISABLE_ACCURATE_PROFILING   (0x1u << AWE_ACCURATE_PROFILING_BIT_POS)
#define AWE_CACHE_CALLBACK_TYPE_INVALIDATE   0
 Macros for cache coherence handling.
#define AWE_CACHE_CALLBACK_TYPE_WRITEBACK   1
#define MAX_TARGET_THREADS   (32)
 Max number of layout threads per AWE Instance.
Typedefs
typedef void(* cbAweLogging_t) (struct _AWEInstance *pAWE, INT32 level, UINT32 type, void *payload, INT32 payloadSizeInBytes)
 OPTIONAL This callback is invoked from multiple places in the AWE framework to log any message to the BSP.
typedef INT32(* cbAweEventTrigger_t) (struct _AWEInstance *pAWE, INT32 eventType, UINT32 moduleObjId, void *payload, INT32 payloadSizeInBytes, void *userHandle)
 OPTIONAL These callback are invoked only from the Event Module.
typedef INT32(* cbAweEventRegister_t) (struct _AWEInstance *pAWE, INT32 eventType, UINT32 moduleObjId, INT32 payloadSizeInBytes, void **userHandle)
 The Event Register callback is called by an Event Module when it is constructed.
typedef INT32(* cbAweEventDeregister_t) (struct _AWEInstance *pAWE, INT32 eventType, UINT32 moduleObjId, void **userHandle)
 The Event Deregister callback is called by the Event Module when it is destroyed.
typedef struct _AWEInstance AWEInstance
 The AWE instance.
typedef struct AWEBuildVersionInfo AWEBuildVersionInfo_t
typedef INT32 packetProcessFunction(AWEInstance *pAWE)
Functions
INT32 awe_init (AWEInstance *pAWE)
 Initialize the instance.
INT32 awe_initPin (IOPinDescriptor *pPin, UINT32 channels, const char *name)
void awe_initFlashFS (AWEInstance *pAWE, AWEFlashFSInstance *pAWEFlashFSInstance)
 Initialize the file system.
INT32 awe_packetProcess (AWEInstance *pAWE)
INT32 awe_packetProcessMulti (AWEInstance *pAWE, BOOL isTuningInstance)
 Multi-instance Wrapper for tuning packet processing.
INT32 awe_audioPump (AWEInstance *pAWE, UINT32 layoutIndex)
 Audio pump function.
INT32 awe_audioImportSamples (const AWEInstance *pAWE, const void *inSamples, INT32 inStride, INT32 channel, SampleType inType)
INT32 awe_audioExportSamples (const AWEInstance *pAWE, void *outSamples, INT32 outStride, INT32 channel, SampleType outType)
INT32 awe_audioIsStarted (const AWEInstance *pAWE)
INT32 awe_audioIsStartedMulti (const AWEInstance *pAWE)
 Check if all instances are running in multi-instance system.
INT32 awe_audioGetPumpMask (AWEInstance *pAWE)
 Test if AWE is ready to run.
INT32 awe_audioIsReadyToPumpMulti (AWEInstance *pAWE, UINT32 instanceID)
 Test if AWE is ready to run on secondary instances (ID > 0).
UINT32 awe_audioStartPreemption (AWEInstance *pAWE, INT32 coreAffinity)
 Function to correct overhead outside of the Audio Weaver, like Audio DMA ISR.
UINT32 awe_audioEndPreemption (AWEInstance *pAWE, UINT32 start_time, INT32 coreAffinity)
INT32 awe_deferredSetCall (AWEInstance *pAWE)
INT32 awe_loadAWBfromArray (AWEInstance *pAWE, const UINT32 *pCommands, UINT32 arraySize, UINT32 *pPos)
INT32 awe_loadSubcanvasAWBfromArray (AWEInstance *pAWE, UINT32 SubcanvasModObjectID, const UINT32 *pCommands, UINT32 arraySize, UINT32 *pPos)
 Executes packet commands from an in-memory array and loads AWB in Subcanvas module.
INT32 awe_loadAWBfromFile (AWEInstance *pAWE, const char *binaryFile, UINT32 *pPos)
 Load an AWB file from stdio.
INT32 awe_loadSubcanvasAWBfromFile (AWEInstance *pAWE, UINT32 SubcanvasModObjectID, const char *binaryFile, UINT32 *pPos)
 Load an AWB file from stdio into Subcanvas module.
INT32 awe_loadAWBfromFlash (AWEInstance *pAWE, const char *binaryFile, UINT32 *pPos)
 Load an AWB file from the flash.
INT32 awe_loadSubcanvasAWBfromFlash (AWEInstance *pAWE, UINT32 SubcanvasModObjectID, const char *binaryFile, UINT32 *pPos)
void awe_layoutGetChannelCount (const AWEInstance *pAWE, UINT32 pinIdx, UINT32 *inCount, UINT32 *outCount)
 Returns the number of channels in the Layout's input and output pins.
INT32 awe_layoutGetInputBlockSize (const AWEInstance *pAWE, UINT32 pinIdx, UINT32 *blockSize)
 Returns the block size of a pin.
INT32 awe_layoutGetInputSampleRate (const AWEInstance *pAWE, UINT32 pinIdx, FLOAT32 *sampleRate)
 Returns the sample rate of an input pin.
INT32 awe_layoutIsValid (const AWEInstance *pAWE)
INT32 awe_ctrlSetValue (AWEInstance *pAWE, UINT32 handle, const void *value, INT32 arrayOffset, UINT32 length)
INT32 awe_ctrlGetValue (AWEInstance *pAWE, UINT32 handle, void *value, INT32 arrayOffset, UINT32 length)
INT32 awe_ctrlSetStatus (AWEInstance *pAWE, UINT32 handle, UINT32 status)
 Set the runtime status of a module.
INT32 awe_ctrlGetStatus (AWEInstance *pAWE, UINT32 handle, UINT32 *status)
 Get the runtime status of a module.
INT32 awe_ctrlSetValueMask (AWEInstance *pAWE, UINT32 handle, const void *value, INT32 arrayOffset, UINT32 length, UINT32 mask)
 Set a scalar or array value of a module variable by handle with mask.
INT32 awe_ctrlGetValueMask (AWEInstance *pAWE, UINT32 handle, void *value, INT32 arrayOffset, UINT32 length, UINT32 mask)
 Get a scalar or array value of a module variable by handle with mask.
INT32 awe_ctrlGetModuleClass (AWEInstance *pAWE, UINT32 handle, UINT32 *pClassID)
INT32 awe_setProfilingStatus (AWEInstance *pAWE, UINT32 status)
INT32 awe_setProfilingOptions (AWEInstance *pAWE, UINT32 optionsMask, UINT32 profilingOptions)
 Function to set profiling options like average or peak profiling on modules and turn on or off accurate profiling.
INT32 awe_getProfilingOptions (AWEInstance *pAWE, UINT32 *profilingOptions)
 Function to get current profiling options.
INT32 awe_getAverageLayoutCycles (AWEInstance *pAWE, UINT32 layoutIdx, UINT32 *averageCycles)
void awe_setInstancesInfo (AWEInstance **pInstances, INT32 numAweInstancesOnCore)
 Setup function only intended for systems with multiple AWE Instances in a single core.
INT32 awe_fwSetLayoutCoreAffinity (AWEInstance *pAWE, INT32 layoutNumber, INT32 coreAffinity)
 Set the core affinity of the layout in layoutNumber.
INT32 awe_fwGetLayoutCoreAffinity (AWEInstance *pAWE, INT32 layoutNumber)
 Get the core affinity of the layout in layoutNumber, initializes to 0 and can be set with awe_fwSetLayoutCoreAffinity.
INT32 awe_getBuildVersionInfo (AWEBuildVersionInfo_t *pBuildVersionInfo)
 Get the AWECore build number and version information.
INT32 awe_setInstanceStandaloneAWBLoad (AWEInstance *pAWE, INT32 status)
 This function can be used to achieve Progressive Loading on a multi-instance system.
INT32 awe_registerLoggingCallback (AWEInstance *pAWE, cbAweLogging_t cbAweLogging, INT32 logLevel, UINT32 logTypeMask)
INT32 awe_registerEventCallbacks (AWEInstance *pAWE, cbAweEventTrigger_t cbAweEventTrigger, cbAweEventRegister_t cbAweEventRegister, cbAweEventDeregister_t cbAweEventDeregister)
INT32 awe_resetState (AWEInstance *pAWE)
 Walk through each module in each layout in an instance and calls reset function, if exists, clears wire buffers and clears IO buffers and layout masks.
Detailed Description
Typedef Documentation
◆ cbAweLogging_t
User should register the callback via awe_registerLoggingCallback, which requires logging level and type mask. type is a 32-bit bitfield, with each bit representing a type of message. These types are defined in the framework and provide information about where the logging messages come from. Type can be used to filter or do custom handling of certain messages. The payload pointer can be treated as a char *.
◆ cbAweEventTrigger_t
Use the awe_registerEventCallbacks to register them The Event Trigger callback is called when an Event Module is triggered in the layout. Depending on the Event Module configuration, this may happen inline in the module processing, or it may happen during deferred processing. In the latter case, there may be a delay between the actual event trigger and calling this Event Trigger callback. If this returns a negative number, then it is assumed that the Event Trigger was not successfully processed and the module's numFailedTriggers parameter will increment. If there is no Event Trigger callback registered, then the Event Module can never generate an event.
◆ cbAweEventRegister_t
◆ cbAweEventDeregister_t
Function Documentation
◆ awe_init()
INT32 awe_init ( AWEInstance pAWE)
Call this once you have assigned all of the required members/pointers of the AWE Instance, and after calling awe_InitPin on both input and output pins. Calling awe_init before assigning all members of the instance structure or initializing the pins will result in crashes/erratic behavior.
Parameters
pAWEinstance to initialize
Returns
E_SUCCESS, E_NULL_PACKET_BUFFER_POINTER, E_NULL_REPLY_BUFFER_POINTER, E_ZERO_PACKET_BUFFER_LENGTH, E_EXCEPTION, E_PARAMETER_ERROR, E_NOT_CREATED
Examples
ControlApp.c, LinuxApp.c, LinuxAppMulti.c, bare_metal_example.c, and singleinstance_simple.c.
◆ awe_initPin()
INT32 awe_initPin ( IOPinDescriptor *  pPin,
UINT32  channels,
const char *  name
This function must be called for both the input and output pins. Must be called BEFORE the awe_init API function.
Parameters
[in]pPinthe pin instance to initialize
[in]channelsnumber of channels
[in]nameoptional pin name
Returns
E_SUCCESS, E_NOT_OBJECT
Examples
◆ awe_initFlashFS()
void awe_initFlashFS ( AWEInstance pAWE,
AWEFlashFSInstance pAWEFlashFSInstance
Parameters
pAWEFlashFSInstancethe file system instance
Examples
LinuxAppMulti.c.
◆ awe_packetProcess()
INT32 awe_packetProcess ( AWEInstance pAWE)
Parameters
[in]pAWEThe AWE instance pointer to process
Returns
error E_SUCCESS, E_COMMAND_NOT_IMPLEMENTED, E_MESSAGE_LENGTH_TOO_LONG, E_CRC_ERROR, E_BADPACKET
Examples
LinuxApp.c, bare_metal_example.c, and singleinstance_simple.c.
◆ awe_packetProcessMulti()
INT32 awe_packetProcessMulti ( AWEInstance pAWE,
If called by the tuning instance, call whenever a complete packet is received. Wait until the return value is not E_MULTI_PACKET_WAITING to forward reply back to the tuning interface. If called by a non-tuning instance, poll continuously in a low-priority task.
Parameters
[in]isTuningInstanceBoolean marking if the instance calling this API implements the tuning interface
Returns
error E_SUCCESS, E_MULTI_PACKET_WAITING, E_COMMAND_NOT_IMPLEMENTED,
Examples
LinuxAppMulti.c.
◆ awe_audioPump()
INT32 awe_audioPump ( AWEInstance pAWE,
UINT32  layoutIndex
Call this in your audio thread once you have imported the data you wish to process. Before pumping, you must also check that the AudioWeaver buffers have been filled (awe_getPumpMask) and that audio has been started (awe_audioIsStarted). This function will return 1 if awe_deferredSetCall needs to be called. This is for modules that need to do more time consuming calculations, like calculating filter coefficients. For example, a SOF Control module needs to calculate new coeffs when the frequency is modified by the control input.
Parameters
[in]pAWEAWE instance pointer
[in]layoutIndexthe layout index to pump
Returns
E_SUCCESS, E_NO_LAYOUTS, or 1 (indicating that deferred set is needed, see documentation)
Examples
ControlApp.c, LinuxApp.c, LinuxAppMulti.c, and bare_metal_example.c.
◆ awe_audioImportSamples()
INT32 awe_audioImportSamples ( const AWEInstance pAWE,
const void *  inSamples,
INT32  inStride,
INT32  channel,
SampleType  inType
The value of the fundamentalBlockSize member of the AWEInstance determines the number of samples that are imported with each call. Call this function once for each audio input channel on the hardware. Channel matching between hardware capabilities and layout will be done automatically. For example, if the target has only 1 audio input channel, and if a layout with 3 input channels is loaded, the second and third channels of the layout input will be all zeros. Inversely, if there are more HW input channels than the layout expects, then they are ignored.
The value of inStride defines the number of samples to skip between each read, and should be the number of interleaved channels in the inSamples buffer being read from. A typical usage for a single source, interleaved stereo input could look like:
awe_audioImportSamples(pAWE, inSamples + 0, 2, 0, Sample32bit);
awe_audioImportSamples(pAWE, inSamples + 1, 2, 1, Sample32bit);
@ Sample32bit
Data is 32 bit PCM .
Definition StandardDefs.h:231
Parameters
[in]inSamplespointer to first sample in buffer to import for current channel
[in]inStrideinput buffer import stride
[in]channelchannel to write to
[in]inTypetype of input data
Returns
E_SUCCESS, E_AUDIO_NOT_STARTED, E_PARAMETER_ERROR
Examples
◆ awe_audioExportSamples()
INT32 awe_audioExportSamples ( const AWEInstance pAWE,
void *  outSamples,
INT32  outStride,
INT32  channel,
SampleType  outType
The value of the fundamentalBlockSize member of the AWEInstance determines the number of samples that are exported with each call. Call this function once for each audio output channel on the hardware. Like awe_audioImportSamples, this will do channel matching automatically. For example, if the target has 3 audio output channels, and if a layout with 1 output channel is loaded, the second and third channels of the exported output will be all zeros. Inversely, if the layout has more output channels than the target supports, they are ignored.
awe_audioExportSamples(pAWE, &outSamples[0], 3, 0, Sample32bit);
awe_audioExportSamples(pAWE, &outSamples[1], 3, 1, Sample32bit);
awe_audioExportSamples(pAWE, &outSamples[2], 3, 2, Sample32bit);
Parameters
[out]outSamplespointer to first sample in buffer to export to
[in]outStrideoutput buffer export stride
[in]channelchannel to read from
[in]outTypetype of output data
Returns
Examples
◆ awe_audioIsStarted()
INT32 awe_audioIsStarted ( const AWEInstance pAWE)
A BSP author can use this to determine if the instance is already running to avoid pumping audio through a dead layout.
Parameters
pAWEinstance pointer
Returns
0 if audio is not started, 1 if audio is started. No error conditions
Examples
◆ awe_audioIsStartedMulti()
INT32 awe_audioIsStartedMulti ( const AWEInstance pAWE)
This is intended to call only in multi-instance systems and if it is called from other systems (pSharedHeap == NULL) then it returns False. A BSP author (multi-instance) can use this to determine if all the instances are already running to synchronize pumping of all instances.
Parameters
Returns
0 if audio is not started or no sharedHeap, 1 if audio is started. No error conditions
Examples
LinuxAppMulti.c.
◆ awe_audioGetPumpMask()
INT32 awe_audioGetPumpMask ( AWEInstance pAWE)
This will return the "layout mask" which is a bit vector of threads to run. For a simple, single threaded system, the bitvector will be 0x1. If a previous pump is not complete and the layout is ready to pump again, an overflow is detected by this function. In this condition, the layoutMask bit for the overflowed layout will be zero, which prevents the layout from being pumped again. Example: int layoutMask = awe_audioGetPumpMask(&g_AWEInstance); if (layoutMask > 0) { if (layoutMask & 0x1) { int ret = awe_audioPump(&g_AWEInstance, 0); } }
Parameters
pAWEAWE instance
Returns
bit vector of threads to run, 0 if no threads, E_AUDIO_NOT_STARTED
Examples
◆ awe_audioIsReadyToPumpMulti()
INT32 awe_audioIsReadyToPumpMulti ( AWEInstance pAWE,
UINT32  instanceID
This must be used in multi-instance applications to determine when to trigger secondary instances. Failure to do so can result in pumping at the wrong rates. This avoids unneccessary interrupts on secondary instances where layout block size is higher than the fundamental block size. This function returns TRUE or FALSE. When it returns TRUE, corresponding secondary instance is ready to signal. When this function is called with instance ID 0 or invalid ID, then always False is returned. Example: int pumpSlaveInstance = awe_audioIsReadyToPumpMulti(&g_AWEInstance, 1); if (pumpSlaveInstance) { Signal slave core to get pump mask raise(); }
Parameters
pAWEAWE instance
instanceIDAWE instance ID
Returns
true or false
Examples
LinuxAppMulti.c.
◆ awe_audioStartPreemption()
UINT32 awe_audioStartPreemption ( AWEInstance pAWE,
INT32  coreAffinity
Call this function at the very beginning of the DMA ISR and store the returned value, which is an argument to following end function call. For the use case where multiple instances exists on the same core, this function can be called with any instance's AWEInstance pointer, provided that the user called awe_setInstancesInfo during the startup. Example: UINT32 start_time = awe_audioStartPreemption(&g_AWEInstance, coreAffinity);
Parameters
pAWEAWE instance
coreAffinityCore affinity from which this function is called
Returns
start time stamp in cycles at profiling clock
◆ awe_audioEndPreemption()
UINT32 awe_audioEndPreemption ( AWEInstance pAWE,
UINT32  start_time,
INT32  coreAffinity
Call this function at the end in the DMA ISR with start_time returned by awe_audioStartPreemption(). If the DMA ISR has low latency audio pump calls, then this function must be called before the audio pump and call awe_audioStartPreemption() again after pump. Note that the funtion awe_audioStartPreemption() must be called first, before calling awe_audioEndPreemption(). For the use case where multiple instances exists on the same core, this function can be called with any instance's AWEInstance pointer, provided that the user called awe_setInstancesInfo during the startup. Example: awe_audioEndPreemption(&g_AWEInstance, start_time, coreAffinity);
Parameters
pAWEAWE instance
start_timeStart time returned by the corresponding start function "awe_audioStartPreemption"
Returns
Elapsed time between start preempt and this function
◆ awe_deferredSetCall()
INT32 awe_deferredSetCall ( AWEInstance pAWE)
Each call to awe_deferredSetCall processes a single module. Usually this function would be called repeatedly until the return value is 0.
Parameters
Returns
finishedProcessing Will return 1 when processing is incomplete, 0 when complete. No error codes.
Examples
◆ awe_loadAWBfromArray()
INT32 awe_loadAWBfromArray ( AWEInstance pAWE,
const UINT32 *  pCommands,
UINT32  arraySize,
UINT32 *  pPos
Designer can generate AWB arrays directly from a layout.
Parameters
[in]pCommandsBuffer with commands to execute
[in]arraySizeNumber of DWords in command buffer
[out]pPosReport failing word index
Returns
E_SUCCESS E_EXCEPTION E_UNEXPECTED_EOF E_END_OF_FILE E_MESSAGE_LENGTH_TOO_LONG E_BADPACKET
Examples
ControlApp.c, LinuxApp.c, and LinuxAppMulti.c.
◆ awe_loadSubcanvasAWBfromArray()
INT32 awe_loadSubcanvasAWBfromArray ( AWEInstance pAWE,
UINT32  arraySize,
UINT32 *  pPos
Designer can generate AWB arrays directly from a Subcanvas layout.
Parameters
[in]SubcanvasModObjectIDObject ID of the Subcanvas module
Returns
E_SUCCESS E_CLASS_NOT_SUPPORTED E_EXCEPTION E_UNEXPECTED_EOF E_END_OF_FILE E_MESSAGE_LENGTH_TOO_LONG E_BADPACKET
Examples
ControlApp.c.
◆ awe_loadAWBfromFile()
INT32 awe_loadAWBfromFile ( AWEInstance pAWE,
const char *  binaryFile,
UINT32 *  pPos
Parameters
[in]binaryFileAWB file to be loaded
Returns
E_SUCCESS E_EXCEPTION E_UNEXPECTED_EOF E_END_OF_FILE E_MESSAGE_LENGTH_TOO_LONG E_BADPACKET E_CANTOPEN
Examples
LinuxApp.c.
◆ awe_loadSubcanvasAWBfromFile()
INT32 awe_loadSubcanvasAWBfromFile ( AWEInstance pAWE,
UINT32 *  pPos
Parameters
Returns
E_SUCCESS E_CLASS_NOT_SUPPORTED E_EXCEPTION E_UNEXPECTED_EOF E_END_OF_FILE E_MESSAGE_LENGTH_TOO_LONG E_BADPACKET E_CANTOPEN
◆ awe_loadAWBfromFlash()
INT32 awe_loadAWBfromFlash ( AWEInstance pAWE,
UINT32 *  pPos
Parameters
Returns
◆ awe_loadSubcanvasAWBfromFlash()
INT32 awe_loadSubcanvasAWBfromFlash ( AWEInstance pAWE,
UINT32 *  pPos
Parameters
Returns
◆ awe_layoutGetChannelCount()
void awe_layoutGetChannelCount ( const AWEInstance pAWE,
UINT32  pinIdx,
UINT32 *  inCount,
UINT32 *  outCount
Parameters
[in]pinIdxwhich input pin (always 0)
[out]inCountchannels in primary input pin
[out]outCountchannels in primary output pin
Examples
ControlApp.c.
◆ awe_layoutGetInputBlockSize()
INT32 awe_layoutGetInputBlockSize ( const AWEInstance pAWE,
UINT32  pinIdx,
UINT32 *  blockSize
Because the block size of the output pin is inherited from the input pin, the user only needs to check the input pin.
Parameters
[in]pAWEThe AWE Instance
[out]blockSizeblock size of input pin
Returns
E_SUCCESS, E_NO_LAYOUTS, E_PIN_ID_NOT_FOUND
Examples
ControlApp.c.
◆ awe_layoutGetInputSampleRate()
INT32 awe_layoutGetInputSampleRate ( const AWEInstance pAWE,
UINT32  pinIdx,
FLOAT32 *  sampleRate
Because the sample rate of the output pin is inherited from the input pin, the user only needs to check the input pin.
Parameters
[out]sampleRatethe input pin sample rate
Returns
◆ awe_layoutIsValid()
INT32 awe_layoutIsValid ( const AWEInstance pAWE)
Parameters
Returns
0 if layout is not valid/loaded, 1 if layout is valid. No error codes.
Examples
◆ awe_ctrlSetValue()
INT32 awe_ctrlSetValue ( AWEInstance pAWE,
UINT32  handle,
const void *  value,
INT32  arrayOffset,
UINT32  length
This is a 32 bit interface, when setting values in a fract16 array, you must always set the adjacent member as well. Indexes in the array are 1 index for 2 packed fract16 words.
Parameters
[in]pAWEinstance pointer
[in]handlepacked object handle
[in]valuevalue(s) to set
[in]arrayOffsetarray index if array
[in]lengthnumber of elements. 1 if scaler
Returns
E_SUCCESS, E_ARGUMENT_ERROR, E_BAD_MEMBER_INDEX, E_CLASS_NOT_SUPPORTED, E_LINKEDLIST_CORRUPT, E_NO_MORE_OBJECTS
Examples
ControlApp.c, and bare_metal_example.c.
◆ awe_ctrlGetValue()
INT32 awe_ctrlGetValue ( AWEInstance pAWE,
UINT32  handle,
void *  value,
INT32  arrayOffset,
UINT32  length
This is a 32 bit interface, when getting values from a packed fract16 array you must also get its adjacent value and mask and convert the low or high word as appropriate. Indexes in the array are 1 index for 2 packed fract16 words.
Parameters
[out]valuevalue(s) to get
Returns
Examples
◆ awe_ctrlSetStatus()
INT32 awe_ctrlSetStatus ( AWEInstance pAWE,
UINT32  handle,
UINT32  status
0 = Active, 1 = Bypass, 2 = Mute, 3 = Inactive
Parameters
[in]statusstatus to set
Returns
E_SUCCESS, E_NOT_MODULE, E_LINKEDLIST_CORRUPT, E_NO_MORE_OBJECTS
◆ awe_ctrlGetStatus()
INT32 awe_ctrlGetStatus ( AWEInstance pAWE,
UINT32  handle,
UINT32 *  status
Parameters
[out]statuspointer to return status value
Returns
E_SUCCESS, E_NOT_MODULE, E_LINKEDLIST_CORRUPT, E_NO_MORE_OBJECTS, E_PARAMETER_ERROR
◆ awe_ctrlSetValueMask()
INT32 awe_ctrlSetValueMask ( AWEInstance pAWE,
UINT32  handle,
const void *  value,
INT32  arrayOffset,
UINT32  length,
UINT32  mask
A mask allows you to only call module's set function for a single variable.
Parameters
[in]lengthnumber of elements if array. 1 if scaler
[in]maskmask to use - 0 to not call set function
Returns
E_SUCCESS, E_ARGUMENT_ERROR, E_BAD_MEMBER_INDEX, E_CLASS_NOT_SUPPORTED, E_OBJECT_ID_NOT_FOUND, E_NOT_MODULE
◆ awe_ctrlGetValueMask()
INT32 awe_ctrlGetValueMask ( AWEInstance pAWE,
UINT32  handle,
void *  value,
INT32  arrayOffset,
UINT32  length,
UINT32  mask
Parameters
[in]maskmask to use - 0 to not call get function
Returns
◆ awe_ctrlGetModuleClass()
INT32 awe_ctrlGetModuleClass ( AWEInstance pAWE,
UINT32  handle,
UINT32 *  pClassID
Parameters
[in]handlehandle of object to find
[out]pClassIDpointer to found object class
Returns
E_SUCCESS, E_NO_MORE_OBJECTS, E_LINKEDLIST_CORRUPT
Examples
◆ awe_setProfilingStatus()
INT32 awe_setProfilingStatus ( AWEInstance pAWE,
UINT32  status
Both top and module level profiling and preemption overhead correction enabled by default at awe_init. Use this function if you wish to selectively enable or disable per pump profiling during runtime. Disabling profiling saves a small amount of cycles per pump. User can also enable or disable independently module level profiling and top level profiling and overhead correction due to preemption. It is recommended to call this function during initialization before starting a layout to have correct profiling behavior.
Parameters
status0 to disable both, 1 to enable both, 2 to enable module level only, 3 to enable top level only
Returns
E_SUCCESS, E_NOT_OBJECT, E_PARAMETER_ERROR
Examples
◆ awe_setProfilingOptions()
INT32 awe_setProfilingOptions ( AWEInstance pAWE,
UINT32  optionsMask,
To set module peak profiling and to enable accurate profiling, call the function with optionsMask as AWE_MODULE_PROFILING_BIT_MASK|AWE_ACCURATE_PROFILING_BIT_MASK and profilingOptions as AWE_MODULE_PROFILING_PEAK|AWE_ENABLE_ACCURATE_PROFILING. It is recommended to call this function during initialization before starting a layout to have correct profiling behavior.
Parameters
pAWE[in] instance pointer
optionsMask[in] mask AWE_MODULE_PROFILING_BIT_MASK to control module profiling type and AWE_ACCURATE_PROFILING_BIT_MASK to control accurate profiling.
profilingOptions[in] profiling options value corresponding to the mask to set.
Returns
Examples
LinuxAppMulti.c.
◆ awe_getProfilingOptions()
INT32 awe_getProfilingOptions ( AWEInstance pAWE,
UINT32 *  profilingOptions
Parameters
profilingOptions[out] pointer to return current setting of all profiling options. When failure occured, the value of all zeros returned.
Returns
◆ awe_getAverageLayoutCycles()
INT32 awe_getAverageLayoutCycles ( AWEInstance pAWE,
UINT32  layoutIdx,
UINT32 *  averageCycles
Returns cycles in 24.8 format, so shift right by 8 bits for integer value. To get CPU cycles, multiply by target cpuSpeed / profileSpeed. If a previous pump is not complete and the layout is ready to pump again, an overflow is detected. When in this state, the awe_getAverageLayoutCycles api will return the averageCycles = AWE_PUMP_OVF_MAX_AVG_CYCLES (0xFFFFFFFF).
Parameters
layoutIdxLayout index (typically 0, except in advanced use cases)
averageCyclesPointer the output (average layout cycles)
Returns
E_SUCCESS, E_PARAMETER_ERROR, E_NO_LAYOUTS
Examples
LinuxAppMulti.c.
◆ awe_setInstancesInfo()
void awe_setInstancesInfo ( AWEInstance **  pInstances,
Call this function at startup after awe_init is done in the sequence. Enables both accurate profiling and loading of multi-instance designs.
Parameters
[in]pInstancesArray of AWE Instance pointers that process on one core. Array must
exist as long as the system is active.
[in]numAweInstancesOnCoreNumber of AWE Instances in pInstances array.
Examples
LinuxAppMulti.c.
◆ awe_fwSetLayoutCoreAffinity()
INT32 awe_fwSetLayoutCoreAffinity ( AWEInstance pAWE,
INT32  layoutNumber,
INT32  coreAffinity
Used to get more accurate profiling in multithreaded systems.
Parameters
[in]pAWEAWE instance pointer (this)
[in]layoutNumberthe layout index to set the core affinity.
[in]coreAffinitycore affinity to set in the layout.
Returns
E_SUCCESS or E_INVALID_LAYOUT_INDEX if no layout
◆ awe_fwGetLayoutCoreAffinity()
INT32 awe_fwGetLayoutCoreAffinity ( AWEInstance pAWE,
INT32  layoutNumber
Parameters
[in]layoutNumberthe layout index to get the core affinity.
Returns
the core affinity of the requested layout, or E_INVALID_LAYOUT_INDEX if no layout
◆ awe_getBuildVersionInfo()
INT32 awe_getBuildVersionInfo ( AWEBuildVersionInfo_t pBuildVersionInfo)
Parameters
[in,out]pBuildVersionInfoPointer of type AWEBuildVersionInfo_t to return build version information
Returns
Return E_SUCCESS up on success. If pBuildVersionInfo is NULL, E_NOT_OBJECT returned.
Examples
LinuxApp.c.
◆ awe_setInstanceStandaloneAWBLoad()
INT32 awe_setInstanceStandaloneAWBLoad ( AWEInstance pAWE,
INT32  status
Indicates this instance loads AWB in standalone mode.
Parameters
[in]statusBoolean flag indicates to enable or disable standalone loading. 1 - to enable standalone mode, 0 - to disable standalone mode. Default disabled.
Returns
E_NO_HEAP_MEMORY if no shared memory exists and E_SUCCESS otherwise.
◆ awe_registerLoggingCallback()
INT32 awe_registerLoggingCallback ( AWEInstance pAWE,
INT32  logLevel,
UINT32  logTypeMask
Parameters
[in]cbAweLoggingFunction pointer of the logging callback.
[in]logLevelLogging level. 0 = AWE_LOG_LEVEL_NONE (DISABLED), 1 = AWE_LOG_LEVEL_ERROR, 2 = AWE_LOG_LEVEL_WARNING, 3 = AWE_LOG_LEVEL_INFO, 4 = AWE_LOG_LEVEL_DEBUG
[in]logTypeMaskLogging type mask. Combination of any logging type like AWE_LOG_SYSTEM_MSG | AWE_LOG_CPU_OVERFLOW_MSG. Use AWE_LOG_ALL_TYPE_MASK to subscribe to all logging message types Note that logging messages are always char * and never end with a newline. The user callback must apply newlines as desired.
Returns
E_SUCCESS or E_NOT_OBJECT if invalid pAWE or E_PARAMETER_ERROR if invalid cbAweLogging.
Examples
◆ awe_registerEventCallbacks()
INT32 awe_registerEventCallbacks ( AWEInstance pAWE,
cbAweEventTrigger must be non-null. The cbAweEventRegister and cbAweEventDeregister can be null.
Parameters
[in]cbAweEventTriggerFunction pointer of the event trigger callback
[in]cbAweEventRegisterFunction pointer of the event register callback (optional)
[in]cbAweEventDeregisterFunction pointer of the event deregister callback (optional)
Returns
E_SUCCESS on success, or E_NOT_OBJECT if invalid pAWE, or E_PARAMETER_ERROR if invalid cbAweEventTrigger.
Examples
LinuxApp.c.
◆ awe_resetState()
INT32 awe_resetState ( AWEInstance pAWE)
Calling this function while audio processing is ongoing can cause audio glitches. It is recommended to stop audio before calling the layout reset function.
Parameters
Returns
E_SUCCESS on success, or E_NOT_OBJECT if invalid pAWE, or E_NOT_OBJECT_POINTER if an invalid object in the instance layout.
