AWE Core 8.D.13 Documentation
Loading...
Searching...
No Matches
LinuxAppMulti.c
Examples.
Examples
* Simple Multi-Instance AWECore Linux Application
* Description: Sample app to show basic usage of AWECore's multi-instance features
* A multi-instance AWECore integration with simulated real-time audio on Linux.
* Includes an ethernet/TCPIP tuning interface to connect to AWE Server on port 15092
* Each instance of AWECore shares a tuning packet buffer and shared heap.
* AWE Instance 1 is connected to ethernet interface and will internally signal Instance 2 to process packets when needed.
* AWE Instance 2 polls continuously for packets in its own thread.
* AWE Instance 2 is triggered to pump by AWE Instance 1, which is in turn triggered by simulated real-time audio callback.
* Copyright: (c) 2023 DSP Concepts, Inc. All rights reserved.
* 3235 Kifer Road
* Santa Clara, CA 95054-1527
#define _GNU_SOURCE
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <unistd.h>
#include <sys/types.h>
#include <sys/socket.h>
#include <errno.h>
#include <signal.h>
#include <netinet/in.h>
#include <pthread.h>
#include <sched.h>
#include <math.h>
#include <time.h>
#include <semaphore.h>
#include <signal.h>
#include <time.h>
#include <sys/time.h>
#include "AWECore.h"
#include "ProxyIDs.h"
#include "AWECoreUtils.h"
#include "TargetInfo.h"
//#define TUNING_DEBUG_PRINTS 1
float coreSpeed;
float profileSpeed;
float sampleRate;
UINT32 fundamentalBlockSize;
UINT32 inChannels;
UINT32 outChannels;
UINT32 profileStatus;
UINT32 profileOptions;
INT32 tuningPort;
UINT32 tuningInstance;
} ConfigParameters;
// Config parameters to control from app arguments
// AWB with 2 instances used in layout
const unsigned int loopback_dualcore_startAudio_InitCommands[] = {
0x0002000c, 0x00060006, 0x473b8000, 0x40040002, 0x00000100, 0x00000000, 0x00060006, 0x473b8000,
0x40040002, 0x00000100, 0x00000000, 0x00060006, 0x473b8000, 0x40040002, 0x00000100, 0x00000000,
0x00060106, 0x473b8000, 0x40040002, 0x00000100, 0x00000000, 0x00040007, 0x00000001, 0x00000001,
0x00040007, 0x00000002, 0x00000002, 0x000b000f, 0xbeef1039, 0x00000001, 0x00000005, 0x00000003,
0x00000000, 0x00000001, 0x00000000, 0x00000100, 0x00000000, 0x000b010f, 0xbeef1039, 0x00000001,
0x00000005, 0x00000001, 0x00000000, 0x00000001, 0x00000000, 0x00000100, 0x00000000, 0x0009000f,
0xbeef0866, 0x00000101, 0x00000002, 0x00000001, 0x00000003, 0x00000001, 0x00000000, 0x0007000f,
0xbeef086d, 0x00000001, 0x00000001, 0x00000003, 0x00000000, 0x00080065, 0x0000680a, 0x00000000,
0x00000400, 0x00000002, 0xc0a00000, 0x40a00000, 0x000c010f, 0xbeef103a, 0x00000100, 0x00000006,
0x00000001, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000100, 0x00000000, 0x0007010f,
0xbeef086d, 0x00000001, 0x00000001, 0x00000001, 0x00000000, 0x00080165, 0x0000480a, 0x00000000,
0x00000400, 0x00000002, 0xc0a00000, 0x40a00000, 0x000c000f, 0xbeef103a, 0x00000100, 0x00000006,
0x00000003, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000100, 0x00000000, 0x0007000f,
0xbeef086d, 0x00000001, 0x00000001, 0x00000003, 0x00000000, 0x00080065, 0x0000880a, 0x00000000,
0x00000400, 0x00000002, 0xc0a00000, 0x40a00000, 0x0009000f, 0xbeef0866, 0x00000101, 0x00000002,
0x00000003, 0x00000002, 0x00000000, 0x00000001, 0x00040010, 0x00000006, 0x00000001, 0x000a002f,
0x0000000a, 0x00000000, 0x00000005, 0x00000004, 0x00000006, 0x00000007, 0x00000008, 0x00000009,
0x00040110, 0x00000003, 0x00000001, 0x0007012f, 0x00000005, 0x00000000, 0x00000003, 0x00000002,
0x00000004, 0x0006013c, 0x00003008, 0x00000000, 0x00000100, 0x00000000, 0x0006003c, 0x00007008,
0x00000001, 0x00000100, 0x00000000, 0x0002001b, 0x00000000,
const unsigned int loopback_dualcore_startAudio_InitCommands_Len = sizeof(loopback_dualcore_startAudio_InitCommands) / sizeof(int);
// Macro to enable/disable simulated flash file system
//#define ENABLE_FAKE_FLASH_FILE_SYSTEM
// Don't load AWB on startup, to avoid compatibility issues with prebuilt C array above
#define LOAD_MULTICORE_AWB 1
#define NUM_INSTANCES 4
// By default, use the last instance as tuning master
#define DEFAULT_TUNING_MASTER_INSTANCE NUM_INSTANCES-1
#ifdef ENABLE_FAKE_FLASH_FILE_SYSTEM
// Emulate AWE Flash File System with file operation and with a global big array
// 1M words (4MB) per instance
// All number below in bytes
#define FLASH_ERASABLE_BLOCK_SIZE 1024*4
#define FLASH_SIZE_PER_INSTANCE 1024*1024*4
#define FLASH_ERASE_TIME_SEC 5
UINT32 g_AWEEmulatedFFS[1024*1024*NUM_INSTANCES];
#endif
// Table of AWE Instances used for multi-instance applications
AWEInstance *pInstances[NUM_INSTANCES];
AWEFlashFSInstance *pFlashFSInstances[NUM_INSTANCES];
#endif
// LISTOFCLASSOBJECTS comes from ModuleList.h .. shared by both instances
// Providing two tables so that different modules lists can be tested
// on different instances.
const void* module_descriptor_table_1[] =
LISTOFCLASSOBJECTS
#ifndef LISTOFCLASSOBJECTS2
#define LISTOFCLASSOBJECTS2 LISTOFCLASSOBJECTS
#endif
const void* module_descriptor_table_2[] =
LISTOFCLASSOBJECTS2
// Allocate shared heap buffer, used by all instances
UINT32 sharedHeap[SHARED_HEAP_SIZE_LINUX];
// Universal packet buffer used by all AWE instances
UINT32 tuningPacketBuffer[MAX_COMMAND_BUFFER_LEN];
#ifdef USE_SAME_BUFFER_PACKET_REPLY
UINT32 *tuningReplyBuffer = tuningPacketBuffer;
#else
UINT32 tuningReplyBuffer[MAX_COMMAND_BUFFER_LEN];
#endif
// Audio buffers
UINT32 *audioInputBuffer;
UINT32 *audioOutputBuffer;
pthread_t packetProcessHandles[NUM_INSTANCES];
pthread_t audioPumpAllThreadHandles[NUM_INSTANCES];
sem_t pumpSems[NUM_INSTANCES];
sem_t packetProcessSems[NUM_INSTANCES];
INT32 exitAudioCallbackThread;
INT32 audioStarted;
unsigned long long callbackCnt;
unsigned long long pumpCnts[NUM_INSTANCES];
INT32 quiet;
// Tuning parameters
int sockfd, newsockfd;
int exitPrimaryTuningThread = 0;
int exitSecondaryTuningThreads = 0;
int exitAudioPumpThread = 0;
#define DEFAULT_TUNING_PORT (15092)
#define DEFAULT_BLOCK_SIZE (256) // Reasonable block size to simulate real time callbacks!!!
// increase priority levels for AWE threads
// Audio callback functions must be highest priority to avoid
// missing real time requirements. Pump is right after,
// followed by tuning interface where actions can be performed
// in the background.
#define AUDIO_CALLBACK_PRIO (99)
#define AUDIO_PUMP_PRIO (AUDIO_CALLBACK_PRIO - 1)
#define TUNING_THREAD_PRIO (AUDIO_PUMP_PRIO - NUM_INSTANCES)
void error(const char *msg)
perror(msg);
exit(1);
void sig_handler(int signo)
// Cought user termination signal
int i;
// Close tuning instance thread first to avoid potential conflict
// between tuning packets and destroy command processing
exitPrimaryTuningThread = 1;
exitAudioPumpThread = 1;
close(newsockfd);
shutdown(sockfd, SHUT_RDWR);
close(sockfd);
pthread_join(packetProcessHandles[configParams.tuningInstance], NULL);
// Destroy the layout next, then we can close down secondary tuning threads
if (pInstances[configParams.tuningInstance]->pPacketBuffer)
UINT32 destroyCommand = (2 << 16) | PFID_Destroy; // 0x0002000c
UINT32 pos = 0;
INT32 ret = awe_loadAWBfromArray(pInstances[configParams.tuningInstance], &destroyCommand, 1, &pos);
if (!quiet)
if (ret)
printf("Layout destroy failed, ret = %d\n", ret);
else
printf("Layout destroy success\n");
// Wait for all threads to close
exitSecondaryTuningThreads = 1;
for (i = 0; i < NUM_INSTANCES; i++)
sem_post(&pumpSems[i]);
sem_post(&packetProcessSems[i]);
if (i != configParams.tuningInstance)
pthread_join(packetProcessHandles[i], NULL);
pthread_join(audioPumpAllThreadHandles[i], NULL);
// Free memory
free(audioInputBuffer);
free(audioOutputBuffer);
sem_destroy(&pumpSems[i]);
sem_destroy(&packetProcessSems[i]);
free(pInstances[i]->pFastHeapA);
free(pInstances[i]->pFastHeapB);
free(pInstances[i]->pSlowHeap);
free((void*)pInstances[i]->pName);
free(pInstances[i]);
free(pFlashFSInstances[i]);
#endif
FILE *fPtr = NULL;
// Preserve emulated FFS into a file
fPtr = fopen("AWE_FFS_Emulated.bin", "wb");
if (fPtr)
fwrite(g_AWEEmulatedFFS, 1, sizeof(g_AWEEmulatedFFS), fPtr);
fclose(fPtr);
#endif
if (!quiet)
printf("Exiting LinuxAppMulti\n");
exit(0);
printf(
"Usage: %s [args]\n"
" -profStatus:N set profiling status (0 - disable, 1 - enable(default), 2 - enable module level only, 3 - enable top level only)\n"
" -profOptions:N set accurate profiling option (0 - enable, 1 - disable(default))\n"
" -bsize:N default 256, Audio block size for the system\n"
" -tport:N default 15092, port number for socket interface. user can choose between 15002 - 15098\n"
" -tuningInstance:N instance to use as primary tuning instance. default is numInstances - 1\n"
" -quiet print only error messages\n"
" -h, --help show this message\n"
"This program exercises the AWECore library with %d AWEInstances.\n",
program, NUM_INSTANCES);
exit(0);
void usrLogging(AWEInstance* pAWE, INT32 level, UINT32 type, void* payload, INT32 payloadSizeInBytes)
struct timeval ts;
char timeCh[25];
char instCh[11];
// Get current time for log
gettimeofday(&ts, NULL);
snprintf(instCh, 11, "inst %d - ", (INT32)pAWE->instanceId);
if (payloadSizeInBytes > 0)
printf("%s%s%s\n", timeCh, instCh, (char *)payload);
INT32 aweuser_forwardPacketCallback(AWEInstance *pAWE, INT32 instanceID)
(void)pAWE;
// Check for the valid instance ID
if (instanceID < NUM_INSTANCES)
sem_post(&packetProcessSems[instanceID]);
return 0;
void resetTuningSocket()
socklen_t clilen;
struct sockaddr_in cli_addr;
close(newsockfd);
listen(sockfd, 5);
#ifdef TUNING_DEBUG_PRINTS
if (!quiet)
printf("Listening again for connection on port %d\n", configParams.tuningPort);
#endif
clilen = sizeof(cli_addr);
newsockfd = accept(sockfd,
&clilen);
if (newsockfd < 0)
printf("ERROR on accept, %d\n", newsockfd);
return;
/* Enter a tuning loop. This will be in a separate thread from audio processing */
if (!quiet)
printf( "Found connection again!\n");
#endif
Tuning packets can be recieved and processed here. Another implementation
may choose to process the packet in another thread.
(void) arg;
socklen_t clilen;
INT32 schedPolicy, ret;
int socketOption;
AWEInstance * pAWE = pInstances[configParams.tuningInstance];
schedPolicy = SCHED_RR;
if (ret != 0)
char threadNameBuffer[16];
snprintf(threadNameBuffer, 16, "awe%d_packet", (INT32)configParams.tuningInstance);
ret = pthread_setname_np(packetProcessHandles[configParams.tuningInstance], threadNameBuffer);
if (ret)
printf("Failed to set thread name to %s\n", threadNameBuffer);
if (sockfd < 0)
printf("ERROR opening socket, %d\n", sockfd);
return NULL;
// Set the socket connection option to immediately allow reuse of port upon losing connection
socketOption = 1;
sizeof(serv_addr)) < 0)
printf("ERROR on binding\n");
return NULL;
listen(sockfd, 5);
if (!quiet)
&clilen);
if (newsockfd < 0)
return NULL;
if (!quiet)
while (!exitPrimaryTuningThread)
// Setup sleep time for 2.5 ms
struct timespec ts;
ts.tv_nsec = 500000;
ts.tv_sec = 0;
while(1)
UINT32 plen;
INT32 readBytes, n;
/* Only read from socket if multi-instance packet API isn't waiting on a response from another AWE instance */
readBytes = recv(newsockfd, pAWE->pPacketBuffer, MAX_COMMAND_BUFFER_LEN * sizeof(pAWE->pPacketBuffer[0]), 0);
if (readBytes <= 0)
if (readBytes == 0)
printf("ERROR: socket read 0 length packet, attempt to reconnect\n");
else
printf("ERROR: socket read error, attempt to reconnect -- ret = %d, errno = %d\n", readBytes, errno);
#endif
resetTuningSocket();
break;
// May not have received the whole message. Read again if not
while (readBytes < plen)
printf("Didn't read the entire packet! readBytes = %d, totalPacketLength = %u\nReading again\n", readBytes, plen);
#endif
readBytes += recv(newsockfd, &((char*)pAWE->pPacketBuffer)[readBytes], MAX_COMMAND_BUFFER_LEN * sizeof(pAWE->pPacketBuffer[0]), 0);
// Process the received message (may involve signaling instance 2 to process packet)
ret = awe_packetProcessMulti(pAWE, TRUE);
// Send reply packet back to PC if multi-instance packet API is not waiting on a response packet
if (plen <= 0)
printf("Got bad plen = %u\n", plen);
n = write(newsockfd, pAWE->pReplyBuffer, plen * sizeof(pAWE->pReplyBuffer[0]));
if (n < plen)
printf("ERROR: Packet reply transmit failed -- ret = %d\n", n);
#endif
break;
else
// Sleep while waiting for other instances to process packets
return NULL;
void* packetProcessThread(void * args)
AWEInstance * pAWE = (AWEInstance *) args;
INT32 instanceId = pAWE->instanceId;
schedParam.sched_priority = TUNING_THREAD_PRIO - instanceId;
if (ret != 0)
printf("Failed to increase priority of tuning thread %d with error: %s \nTry running with sudo\n", instanceId, strerror(ret));
snprintf(threadNameBuffer, 16, "awe%d_packet", instanceId);
pthread_setname_np(packetProcessHandles[instanceId], threadNameBuffer);
if (ret)
if (!quiet)
printf("Starting instance %d packet process thread\n", instanceId);
while (!exitSecondaryTuningThreads)
// Pend on a signal. If not using the cbAweForwardPacket, then the user can periodically poll the awe_packetProcessMulti function.
sem_wait(&packetProcessSems[instanceId]);
// Call the packet process
awe_packetProcessMulti(pAWE, FALSE);
return NULL;
void* aweuser_pumpAudio(void * args)
// Represents the callback function from the audio framework
INT32 pumpMask;
INT32 schedPolicy, ret, targetPriority;
INT32 needDeferred = 0;
targetPriority = AUDIO_PUMP_PRIO - instanceId;
schedParam.sched_priority = targetPriority;
schedPolicy = SCHED_FIFO;
int policy;
pthread_getschedparam(currentHandle, &policy, &schedParam);
if ((SCHED_FIFO != policy) || (schedParam.sched_priority != targetPriority))
printf("Warning: Failed to increase priority of audio simulation thread to %d\nTry running as root\n", targetPriority);
snprintf(threadNameBuffer, 16, "awe%d_pump", instanceId);
ret = pthread_setname_np(audioPumpAllThreadHandles[instanceId], threadNameBuffer);
if (!quiet)
printf("Starting pump thread for instance %d\n", instanceId);
while (!exitAudioPumpThread)
sem_wait(&pumpSems[instanceId]);
if (instanceId == 0)
// Import new samples only for layout 0
for (int i = 0; i < configParams.inChannels ; i++)
ret = awe_audioImportSamples(pAWE, &audioInputBuffer[i], configParams.inChannels, i, Sample32bit);
if (ret)
printf("Error: awe_audioImportSamples() failed, channel = %d, error = %d\n", i, ret);
// Pump any required sublayouts
pumpMask = awe_audioGetPumpMask(pAWE);
// Instance 1 has to signal all other instances to run
for (int ix = 1; ix < NUM_INSTANCES; ix++)
sem_post(&pumpSems[ix]);
// Each sublayout should be pumped in its own thread,
// but running all sequentially here for simplicity. This does not
// propertly handle sublayouts at higher clockDividers, as all sublayouts
// must complete at layout input blockrate.
for (int j = 0; j < pAWE->numThreads; j++)
if (pumpMask & (1U << j))
// Pump the sublayout.
ret |= awe_audioPump(pAWE, j);
// Do deferred processing if needed
// ret = 1 means that at least one layout required new deferred processing this pump.
// needDeferred is needed here because there could be more than 1 deferred call needed,
// but we are only doing 1 deferred call per pump so we need to persist this value
// for the next pump.
if (needDeferred || ret)
// This could be done in a loop until ret == 0, but doing one per fundamental period
// is more conservative at the cost of potentially taking longer to update a module parameter
needDeferred = awe_deferredSetCall(pAWE);
ret = 0;
// Export samples
for (int i = 0; i < configParams.outChannels ; i++)
ret = awe_audioExportSamples(pAWE, &audioOutputBuffer[i], configParams.outChannels, i, Sample32bit);
if (ret)
printf("Error: awe_audioExportSamples() failed, channel = %d, error = %d\n", i, ret);
pumpCnts[instanceId]++;
} // if layout valid
return NULL;
// Attempts to get accurate pumping rate on average by correction for overshoot
// caused by timer resolution
struct timespec ts;
struct timespec ts_tmp;
long time_nsec;
long long accumulated_time1;
long long accumulated_time2;
long long overshoot = 0.0;
(void) args;
// Setup sleep time for fundamental blocksize
ts.tv_sec = 0;
ts_tmp.tv_sec = 0;
ts_tmp.tv_nsec = 0;
int policy;
if ((SCHED_FIFO != policy) || (schedParam.sched_priority != AUDIO_CALLBACK_PRIO))
printf("Warning: Failed to increase priority of audio simulation thread to %d\nTry running as root\n", AUDIO_CALLBACK_PRIO);
char threadNameBuffer[32];
snprintf(threadNameBuffer, 32, "awe_callback");
ret = pthread_setname_np(audioCallbackThreadHandle, threadNameBuffer);
if (ret)
callbackCnt++;
// Kick off the primary audio thread
// Do it only upon all instances started
if (awe_audioIsStartedMulti(pInstances[0]))
sem_post(&pumpSems[0]);
// Subtract any overshoot from the last sleep to balance block rate
// Will there be a chance of overshoot > time_nsec ???
ts.tv_nsec = time_nsec - overshoot;
accumulated_time1 = ((long long)ts_tmp.tv_sec*1000000000) + ts_tmp.tv_nsec + time_nsec - overshoot;
while(1)
overshoot = (accumulated_time2 - accumulated_time1);
break;
else
return NULL;
INT32 aweuser_audioStart(AWEInstance *pAWE)
// Kick off real-time audio simulation thread, instance 0 is the driver
if (!audioStarted && pAWE->instanceId == 0)
exitAudioCallbackThread = 0;
callbackCnt = 0;
memset(pumpCnts, 0, sizeof(pumpCnts));
INT32 ret = pthread_create(&audioCallbackThreadHandle, NULL, audioCallbackSimulator, NULL);
if (ret)
return 0;
audioStarted = 1;
if (!quiet)
printf("Audio Started\n");
return 0;
INT32 aweuser_audioStop(AWEInstance *pAWE)
if (audioStarted)
INT32 ret;
exitAudioCallbackThread = 1;
if (ret != 0)
if (!quiet)
UINT32 avgCycles;
const FLOAT32 clockRatios = configParams.coreSpeed / configParams.profileSpeed;
printf("\nAudio Stopped\n");
for (int i = 0; i < NUM_INSTANCES; i++)
ret = awe_getAverageLayoutCycles(pInstances[i], 0, &avgCycles);
if (ret != E_SUCCESS)
avgCycles = 0;
printf("-- Pumped instance %d %llu times, average cycles per pump: %f\n", i, pumpCnts[i],
(avgCycles >> 8) * clockRatios);
audioStarted = 0;
return 0;
INT32 aweuser_destroyCmd(AWEInstance *pAWE)
(void) pAWE;
// INSERT USER SPECIFIC DESTROY CODE HERE
return 0;
// Flash File System Callbacks
BOOL usrInitFlashFileSystem(void)
return SUCCESS;
} // End usrInitFlashFileSystem
BOOL usrReadFlashMemory(UINT32 nAddress, UINT32 * pBuffer, UINT32 nDWordsToRead)
BOOL bSuccess = 0;
// Check for the count zero and skip remaining
if(nDWordsToRead == 0)
return SUCCESS;
// nAddress is an offset in bytes
memcpy(pBuffer, &g_AWEEmulatedFFS[nAddress >> 2], nDWordsToRead*sizeof(UINT32));
return SUCCESS;
} // End usrReadFlashMemory
BOOL usrWriteFlashMemory(UINT32 nAddress, UINT32 * pBuffer, UINT32 nDWordsToWrite)
BOOL bSuccess = 0;
if(nDWordsToWrite == 0)
return SUCCESS;
memcpy(&g_AWEEmulatedFFS[nAddress >> 2], pBuffer, nDWordsToWrite*sizeof(UINT32));
return SUCCESS;
} // End usrWriteFlashMemory
BOOL usrEraseFlashMemorySector(UINT32 nStartingAddress, UINT32 nNumberOfSectors)
// Set memory to 0xff, simulating flash erase state
memset(&g_AWEEmulatedFFS[nStartingAddress >> 2], 0xffu, nNumberOfSectors * FLASH_ERASABLE_BLOCK_SIZE);
#endif
void InitializeAWEInstance(AWEInstance * awePtr, INT32 instanceId)
int ret = 0;
UINT32 module_descriptor_table_1_size = sizeof(module_descriptor_table_1) / sizeof(module_descriptor_table_1[0]);
UINT32 module_descriptor_table_2_size = sizeof(module_descriptor_table_2) / sizeof(module_descriptor_table_2[0]);
AWEFlashFSInstance *pAweFFSPtr = pFlashFSInstances[instanceId];
#endif
// Clear AWEInstance before initializing
memset(awePtr, 0, sizeof(AWEInstance) );
// Setup Flash File System
memset(pAweFFSPtr, 0, sizeof(AWEFlashFSInstance) );
pAweFFSPtr->cbInit = &usrInitFlashFileSystem;
pAweFFSPtr->cbEraseSector = &usrEraseFlashMemorySector;
pAweFFSPtr->cbFlashWrite = &usrWriteFlashMemory;
pAweFFSPtr->cbFlashRead = &usrReadFlashMemory;
// Contiguous memory is used to simulate FFS for all instances, one after the other.
// So, set the size offset accordingly. i.e. each instance size is the end address of that
// instance part.
pAweFFSPtr->flashSizeInBytes = FLASH_SIZE_PER_INSTANCE * (instanceId + 1);
pAweFFSPtr->flashErasableBlockSizeInBytes = FLASH_ERASABLE_BLOCK_SIZE;
pAweFFSPtr->flashStartOffsetInBytes = FLASH_SIZE_PER_INSTANCE * instanceId;
pAweFFSPtr->flashEraseTimeInMs = FLASH_ERASE_TIME_SEC;
awe_initFlashFS(awePtr, pAweFFSPtr);
awePtr->pFlashFileSystem = pAweFFSPtr;
#endif
// Set pointers to universal AWE packet buffer, same buffer for all instances
awePtr->pPacketBuffer = tuningPacketBuffer;
awePtr->pReplyBuffer = tuningReplyBuffer;
awePtr->packetBufferSize = MAX_COMMAND_BUFFER_LEN;
if (instanceId == NUM_INSTANCES - 1)
awePtr->pModuleDescriptorTable = module_descriptor_table_2;
awePtr->numModules = module_descriptor_table_2_size;
else
awePtr->pModuleDescriptorTable = module_descriptor_table_1;
awePtr->numModules = module_descriptor_table_1_size;
awePtr->numThreads = NUM_THREADS;
awePtr->sampleRate = configParams.sampleRate;
awePtr->fundamentalBlockSize = configParams.fundamentalBlockSize;
awePtr->fastHeapASize = FASTA_HEAP_SIZE_LINUX / NUM_INSTANCES;
awePtr->fastHeapBSize = FASTB_HEAP_SIZE_LINUX / NUM_INSTANCES;
awePtr->slowHeapSize = SLOW_HEAP_SIZE_LINUX / NUM_INSTANCES;
awePtr->sharedHeapSize = SHARED_HEAP_SIZE_LINUX;
awePtr->pFastHeapA = malloc(awePtr->fastHeapASize * sizeof(UINT32));
awePtr->pFastHeapB = malloc(awePtr->fastHeapBSize * sizeof(UINT32));
awePtr->pSlowHeap = malloc(awePtr->slowHeapSize * sizeof(UINT32));
awePtr->pSharedHeap = sharedHeap;
awePtr->coreSpeed = configParams.coreSpeed;
awePtr->profileSpeed = configParams.profileSpeed;
// Give each instance a unique name
awePtr->pName = malloc(sizeof(char) * 8);
sprintf((char*)awePtr->pName, "awe#%d", instanceId);
awePtr->instanceId = instanceId;
// Need to set this value for all instances
awePtr->numProcessingInstances = NUM_INSTANCES;
awePtr->cbAudioStart = aweuser_audioStart;
awePtr->cbAudioStop = aweuser_audioStop;
awePtr->cbPostDestroy = aweuser_destroyCmd;
awe_registerLoggingCallback(awePtr, &usrLogging, AWE_LOG_LEVEL_INFO, AWE_LOG_ALL_TYPE_MASK);
if (instanceId == configParams.tuningInstance)
awePtr->cbAweForwardPacket = aweuser_forwardPacketCallback;
int i, j;
// Only instance 0 deals with inputs and outputs,
// so only this instance needs pins and audio start/stop
awePtr->pInputPin = &aweInputPin;
awePtr->pOutputPin = &aweOutputPin;
ret = awe_initPin(&aweInputPin, configParams.inChannels, NULL);
if (ret != 0)
printf("awe_initPin inputPin failed on AWEInstance 0\n");
ret = awe_initPin(&aweOutputPin, configParams.outChannels, NULL);
if (ret != 0)
printf("awe_initPin outputPin failed on AWEInstance 0\n");
#ifndef PI
#define PI 3.141592653589793
#endif
// Fill audio input buffers with full scale sin waves
float blockRate = configParams.sampleRate / configParams.fundamentalBlockSize;
audioInputBuffer[i * configParams.inChannels + j] = float_to_fract32(sinf(2.f * PI *
(j + 1) * blockRate * (i / configParams.sampleRate)));
ret = awe_init(awePtr);
if (ret != 0)
printf("awe_init on instance %d failed with %d\n", instanceId, ret);
else
if (!quiet)
printf("Initialized instance %d\n", instanceId);
int i;
configParams.fundamentalBlockSize = DEFAULT_BLOCK_SIZE;
configParams.tuningPort = DEFAULT_TUNING_PORT;
configParams.tuningInstance = DEFAULT_TUNING_MASTER_INSTANCE;
// profileOptions controls accurate profiling option (0 - enable and 1 - disable accurate profiling).
// Disabling overhead correction by default because when this app runs by default on a SMP system,
// each instance’s processing thread can execute in parallel on separate cores. This parallel
// execution can cause spurious cycle count correction and result in corrupted profiling and
// incorrect overflow counting.
// Running this app with a tool like taskset (‘sudo taskset -c 0 ./LinuxAppMulti’)
// will force all of the threads (instances) to execute on a single core with each instance at different priority.
// So it is recommended to enable accurate profiling via command line argument -profOptions.
// For SMP processing with accurate profiling, the application needs to explicitly assign each thread
// to run on a particular core (see sched_setaffinity for Linux targets) and inform AWE Core about these
// core affinities using awe_fwSetLayoutCoreAffinity. This is out of scope for this reference application.
configParams.profileOptions = 1;
quiet = 0;
// Handle user inputs
for (i = 1; i < argc; i++)
const char *arg = argv[i];
else if (0 == strncmp(arg, "-profOptions:", 13))
configParams.profileOptions = atoi(arg + 13);
else if (0 == strncmp(arg, "-tuningInstance:", 16))
configParams.tuningInstance = atoi(arg + 16);
quiet = 1;
else if ((0 == strncmp(arg, "-help", 5)) || (0 == strncmp(arg, "-h", 2)) || (0 == strncmp(arg, "--help", 6)))
usage(argv[0]);
// Check configParams.tuningInstance for within the range and return if failed.
if ((configParams.tuningInstance < 0) || (configParams.tuningInstance >= NUM_INSTANCES))
printf("Provided tuningInstance of %d is out of range. Value should be [0 %d]\n",(INT32)configParams.tuningInstance, NUM_INSTANCES-1);
return 0;
if (!quiet)
printf("\nAWECore initialised with the following parameters\n");
printf("-cf: %f Hz\n", configParams.coreSpeed);
printf("-pf: %f Hz\n", configParams.profileSpeed);
printf("-sr: %f Hz\n", configParams.sampleRate);
printf("-bsize: %u\n", configParams.fundamentalBlockSize);
printf("-inchans: %u\n", configParams.inChannels);
printf("-outchans: %u\n", configParams.outChannels);
printf("-tport: %d\n", configParams.tuningPort);
printf("-profStatus: %u\n", configParams.profileStatus);
printf("-profOptions: %u\n", configParams.profileOptions);
printf("configParams.tuningInstance: %d\n", (INT32)configParams.tuningInstance);
printf("Running with same buffer for packet and reply.\n");
#endif
// Setup signal handler to kill sockets
FILE *fPtr = NULL;
// Check if emulated FFS exist and load it on startup into global array
// First, set global array to erase all state
memset(g_AWEEmulatedFFS, 0xffu, sizeof(g_AWEEmulatedFFS));
fPtr = fopen("AWE_FFS_Emulated.bin", "rb");
if (fPtr)
INT32 ret;
ret = fread(g_AWEEmulatedFFS, 1, sizeof(g_AWEEmulatedFFS), fPtr);
if (ret <= 0)
printf("Failed to read emulated AWE FFS from the file.");
fclose(fPtr);
#endif
// Allocate audio buffers used by instance 0
audioInputBuffer = malloc(configParams.inChannels * configParams.fundamentalBlockSize * sizeof(UINT32));
audioOutputBuffer = malloc(configParams.outChannels * configParams.fundamentalBlockSize * sizeof(UINT32));
// Allocate the instances needed and then initialize
pInstances[i] = calloc(1, sizeof(AWEInstance));
pFlashFSInstances[i] = calloc(1, sizeof(AWEFlashFSInstance));
#endif
InitializeAWEInstance(pInstances[i], i);
awe_setProfilingStatus(pInstances[i], configParams.profileStatus);
if (configParams.profileOptions == 1)
awe_setProfilingOptions(pInstances[i], AWE_ACCURATE_PROFILING_BIT_MASK, AWE_DISABLE_ACCURATE_PROFILING);
else
awe_setProfilingOptions(pInstances[i], AWE_ACCURATE_PROFILING_BIT_MASK, AWE_ENABLE_ACCURATE_PROFILING);
// Register instance table, required when using multiple AWE instances on a single-core (application dependent on Linux)
awe_setInstancesInfo(pInstances, NUM_INSTANCES);
// Start tuning thread for each instance
pthread_create(&packetProcessHandles[configParams.tuningInstance], NULL, tuningPacketThread, pInstances[configParams.tuningInstance]);
sem_init(&packetProcessSems[i], 0, 0);
pthread_create(&packetProcessHandles[i], NULL, packetProcessThread, pInstances[i]);
// Start audio pump for all instances
sem_init(&pumpSems[i], 0, 0);
pthread_create(&audioPumpAllThreadHandles[i], NULL, aweuser_pumpAudio, pInstances[i]);
if (LOAD_MULTICORE_AWB)
UINT32 position;
INT32 ret = awe_loadAWBfromArray(pInstances[configParams.tuningInstance], loopback_dualcore_startAudio_InitCommands, loopback_dualcore_startAudio_InitCommands_Len, &position);
printf("Error loading awb: error = %d, at offset %u\n", ret, position);
else
printf("Loaded multi-instance awb\n");
while (1)
// Run this loop forever. Do ctrl-c to exit
// Setup sleep time for 100 ms
struct timespec ts;
ts.tv_nsec = 100000000;
ts.tv_sec = 0;
return 0;
The AWECore API Header File.
Definition AWECoreUtils.h:40
Definition AWECoreUtils.h:43
INT32 awe_packetProcessMulti(AWEInstance *pAWE, BOOL isTuningInstance)
Multi-instance Wrapper for tuning packet processing.
Audio pump function.
void awe_setInstancesInfo(AWEInstance **pInstances, INT32 numAweInstancesOnCore)
Setup function only intended for systems with multiple AWE Instances in a single core.
INT32 awe_registerLoggingCallback(AWEInstance *pAWE, cbAweLogging_t cbAweLogging, INT32 logLevel, UINT32 logTypeMask)
INT32 awe_audioIsStartedMulti(const AWEInstance *pAWE)
Check if all instances are running in multi-instance system.
INT32 awe_getAverageLayoutCycles(AWEInstance *pAWE, UINT32 layoutIdx, UINT32 *averageCycles)
void awe_initFlashFS(AWEInstance *pAWE, AWEFlashFSInstance *pAWEFlashFSInstance)
Initialize the file system.
INT32 awe_setProfilingOptions(AWEInstance *pAWE, UINT32 optionsMask, UINT32 profilingOptions)
Function to set profiling options like average or peak profiling on modules and turn on or off accura...
Test if AWE is ready to run.
INT32 awe_audioIsReadyToPumpMulti(AWEInstance *pAWE, UINT32 instanceID)
Test if AWE is ready to run on secondary instances (ID > 0).
Initialize the instance.
#define E_MULTI_PACKET_WAITING
Multi-instance packet has been forwarded but has not yet been serviced.
Definition Errors.h:384
#define E_SUCCESS
OK result.
Definition Errors.h:31
@ PFID_Destroy
Function ID for awe_fwDestroy().
Definition ProxyIDs.h:68
@ Sample32bit
Data is 32 bit PCM .
Definition StandardDefs.h:231
The AWE instance.
Definition AWEInstance.h:113
IOPinDescriptor * pInputPin
Definition AWEInstance.h:193
const char * pName
Definition AWEInstance.h:265
float profileSpeed
Profiling clock speed in Hz.
Definition AWEInstance.h:257
UINT32 * pReplyBuffer
Reply buffer pointer.
Definition AWEInstance.h:239
UINT32 * pFastHeapB
The second fast heap, B .
Definition AWEInstance.h:125
UINT32 numThreads
Definition AWEInstance.h:269
IOPinDescriptor * pOutputPin
Definition AWEInstance.h:199
UINT32 * pPacketBuffer
The Packet buffer pointer.
Definition AWEInstance.h:230
Definition AWEInstance.h:147
OPTIONAL.
Definition AWEInstance.h:153
UINT32 slowHeapSize
The slow heap size.
Definition AWEInstance.h:139
INT32(* cbPostDestroy)(struct _AWEInstance *pAWE)
OPTIONAL.
Definition AWEInstance.h:161
Definition AWEInstance.h:276
UINT32 * pSlowHeap
The slow heap.
Definition AWEInstance.h:128
float sampleRate
Definition AWEInstance.h:272
UINT32 packetBufferSize
Packet buffer size.
Definition AWEInstance.h:246
volatile UINT32 * pSharedHeap
AWE Core shared memory definitions.
Definition AWEInstance.h:287
UINT32 fastHeapBSize
The fast heap B size.
Definition AWEInstance.h:136
INT32(* cbAweForwardPacket)(struct _AWEInstance *pAWE, INT32 instanceID)
OPTIONAL This callback is invoked from awe_packetProcessMulti when the received packet is to secondar...
Definition AWEInstance.h:185
UINT32 numProcessingInstances
The number of audio processing instances of AWE Core configured on a single target.
Definition AWEInstance.h:293
UINT32 sharedHeapSize
The shared heap size, in 32-bit words.
Definition AWEInstance.h:290
Definition AWEInstance.h:281
float coreSpeed
Definition AWEInstance.h:254
UINT32 instanceId
The ID of this instance.
Definition AWEInstance.h:118
UINT32 numModules
Definition AWEInstance.h:209
Pointer to module table.
Definition AWEInstance.h:217
UINT32 fastHeapASize
Definition AWEInstance.h:133
UINT32 * pFastHeapA
Fast heap A.
Definition AWEInstance.h:122
The DSPC Flash File System Instance.
Definition FlashFSInstance.h:40
UINT32 flashEraseTimeInMs
Flash erase time in milliseconds.
Definition FlashFSInstance.h:51
BOOL(* cbFlashRead)(UINT32 nFlashAddress, UINT32 *pBuffer, UINT32 nDWordsToRead)
User function to read from flash.
Definition FlashFSInstance.h:63
BOOL(* cbFlashWrite)(UINT32 nFlashAddress, UINT32 *pBuffer, UINT32 nDWordsToWrite)
User callback function to write to flash.
Definition FlashFSInstance.h:60
UINT32 flashStartOffsetInBytes
Offset into start of flash used for file system.
Definition FlashFSInstance.h:48
UINT32 flashSizeInBytes
Size of flash memory - if non-zero, next two values must also be non-zero.
Definition FlashFSInstance.h:42
BOOL(* cbEraseSector)(UINT32 nStartingAddress, UINT32 nNumberOfSectors)
User callback function to erase one or more sectors.
Definition FlashFSInstance.h:57
UINT32 flashErasableBlockSizeInBytes
Size of flash erase block.
Definition FlashFSInstance.h:45
BOOL(* cbInit)(void)
User function to initialize flash file system.
Definition FlashFSInstance.h:54
