AWE Core 8.D.12 Documentation
AWE Core 8 Integration Guide
Table of Contents
  1. Introduction
    1. Terms and Definitions
    2. Additional Documentation
  2. Overview of Integration Steps
  3. Including Headers and Link Libraries
    1. Required Header Files
    2. Required Libraries
    3. Helper Code
  4. Setting Up the AWE Flash FS Instance (Optional)
    1. Declaring the Required Variables
    2. Defining the Required Callbacks
    3. Configuring the AWE Flash FS Instance
    4. Initializing the AWE Flash FS Instance
  5. Setting Up the AWE Instance
    2. Configuring the AWE Instance
    3. Initializing the IO Pins
    4. Initializing the AWE Instance
    5. Registering the AWE callbacks
  6. Setting up a Tuning Interface
  7. Realtime Audio
    1. RT Audio Introduction
    2. RT Audio Integration Steps
    3. Sample Formats and Converting to Fract32
    4. Multi-Rate Processing
    5. Multi-Rate Scheduling
    6. Multi-Instance Scheduling
    7. Multi-Rate and Multi-Instance Profiling
    8. Preemption Overhead Outside of the Layout
  8. Deferred Processing
  9. Standalone Operation
    1. Loading from an Array
  10. AWE Core Scheduling and Priority
  11. Setting up a Control Interface
    1. Control Interface Overview
    2. Control Interface Steps
  12. Optimization
    1. Heap Sizing and Placement
    2. Module List Optimization
  13. Multiple AWE Instances
    1. Multiple AWE Instances Introduction
    2. Multi Instance Guide
      1. Multi Instance Progressive Loading
    3. Multi Canvas Guide
      1. Multi Canvas Tuning Interface Setup
      2. Multi Canvas Pseudocode Examples
  14. Latency
    1. Overview of Latency in AWE Core
    2. Conditions that Impact Latency
      1. Equivalent Block Sizes -- Double Buffering
      2. Order of AWECore API Calls -- Import Pump Export
      3. Pump Inline with Callback -- Pump Context
  15. Troubleshooting and Common Pitfalls
This document is meant to be a "Quick-Start" on how to integrate AWE Core. Advanced concepts are left out. Before reading this document, please see the Theory Of Operation document.
The AWE Core™ is a hardware-independent, reconfigurable audio-processing engine. The AWE Core includes over 400 audio-processing Modules, from mixers and filters to compressors and FFTs, that can be combined to easily create complex signal processing flows. The AWE Core operates by passing audio through a user-defined sequence of these Modules, as directed by Configuration-data at run-time.
Term Definition
API Application Interface
AWE Instance The main AWE Core object
Tuning Interface The interface by which commands/replies are transferred
Layout Audio Weaver signal processing flow
Sub-Layout Clock-divided section of a layout
AWB Audio Weaver Binary File
AWD Audio Weaver Design File
AWE Audio Weaver
AWS Audio Weaver Script File
BSP Board Support Package
IPC Inter Process Communication
RTOS Realtime operating system
RT Real-time
This document will go over the basics of integrating the AWE Core. It also includes a Doxygen-generated map of all the available API Functions, Macros, Data Structures, etc. API Doc.
For a brief view of the API, see the 'AWECore_cheatsheet.pdf' in this package.
For a more detailed description of the Tuning Protocol and the various transport methods, please see the Tuning Protocol document here.
Here are the basic steps to integrate AWE Core.
  1. Include headers and link libraries
  2. Define/allocate required variables
  3. Configure the audio IO data structures
  4. Initialize the API
  5. Setup a tuning interface
  6. Setup realtime audio
  7. Setup a control interface (optional based on product intent)
  8. Verify proper scheduling/priority.
Include Headers and Link Libraries
Header Files
  • AWECore.h
    • include's all of the required header files. Does not declare anything, only include's.
  • AWEInstance.h
    • AWEInstance.h contains most of the API declarations and structs required for an integration. This serves as the central API document.
  • TargetProcessor.h, and the Target-specific header file
    • For instance, on an M7 DSPC will provide the file “ARM_CortexM7_TargetProcessor.h”.
  • StandardDefs.h
    • Defines the AWE Core audio types
  • Errors.h
    • When doing error checking on API calls, negative return values correspond to an error. The error can be determined by using the definitions in Errors.h.
  • ModuleList.h
    • Every AWE Core deliverable contains a default ModuleList.h (in the SampleApp/[Target name]/Source folder) that includes a list of all the available modules. This file can be modified to account for custom modules, or modules that are not required for the target application.
Required Libraries
  • AWECore
    • This is the main AWE Core library.
    • The exact name and extension will vary from platform to platform, but will always have the basename "awecore".
Helper Code / Optional
  • AWECoreUtils (AWECoreUtils.c/AWECoreUtils.h)
    • AWECoreUtils contains various helper code including SPI/UART helper functions, a Multi-instance reply table generator, and a CRC computer for preparing custom replies to AWE Server. AWECoreUtils.h API Doc
  • ProxyIDs.h
    • ProxyIDs.h contains a list of all the AWE Core tuning commands. ProxyIDs.h
  • Additional Module Pack Libraries
    • Additional module pack libraries can be linked in (VUI modules, 3rd party custom modules, etc).
Setting up the AWE Flash FS Instance (Optional)
A number of variables must be defined before configuring/initializing the AWE Flash File System (FS) Instance. FlashFSInstance.h
  • The AWEFlashFSInstance object encapsulates a single AWE Flash File System instance. It must be defined so it doesn't go out of scope, for example as static or global, and be initialized to zeros.
     //declare and initialize to zeros
     AWEFlashFSInstance g_AWEFlashFSInstance = {0};
  • Define the following macros for flash memory size in bytes, erasable block (or segment) size and the start offset for the Flash File System. Make sure the start offset does not overlap with other data in the Flash device, like application loader file etc. It’s recommended to use the available free space in the flash from the end. Following are the example macros of a 64MB flash device.
     // Specify flash memory available for flash file system
     #define FLASH_MEMORY_SIZE_IN_BYTES 0x4000000
     #define ERASEABLE_SECTOR_SIZE 0x10000
     // 704KB from the beginning is for application loader file
     #define FILE_SYSTEM_START_OFFSET 0xB0000
     #define SECTOR_ERASE_TIME_MS    400
Later, in the initialization section, it will become clear that there are several fields of the AWEFlashFSInstance structure that must be configured before it can be used.
AWE Flash File System requires callbacks they must be defined before initializing the AWE Flash FS Instance.
  • Init callback to handle any flash device specific configuration. This is called during initialization time (awe_init) and every time Erase Flash is triggered. Following is a sample 'init' callback.
     /// @name  BOOL usrInitFlashFileSystem(void)
     /// @brief Callback to initialize Flash device
     /// @retval     TRUE  - Initialization is success
     /// @retval     FALSE - Initialization failed
         // Implement any flash specific initializations
         // Return FALSE up on failure
         return 1;
     }   // End usrInitFlashFileSystem
  • Read callback to fetch requested words from the flash. Following is a sample 'Read' callback.
     /// @name  BOOL usrReadFlashMemory(UINT32 nAddress, UINT32 * pBuffer, UINT32 nDWordsToRead)
     /// @brief Read 4-byte words from flash memory
     /// @param[in]  UINT32  nAddress - address in flash to start reading
     /// @param[in]  UINT32 *pBuffer  - buffer to read into
     /// @param[in]  UINT32  nDWordsToRead - number of 4-bytes elements to read
     /// @retval     TRUE  - read succeeded
     /// @retval     FALSE - read failed
         // Check for the count zero and skip remaining
         if(nDWordsToRead == 0)
             return 1;
         // Flash specific read implementation
         return 1;
     }   // End usrReadFlashMemory
  • Write callback to write requested words on to the flash. Following is a sample 'Write' callback.
     /// @name  BOOL usrWriteFlashMemory(UINT32 nAddress, UINT32 * pBuffer, UINT32 nDWordsToWrite)
     /// @brief Write 4-byte words to flash memory
     /// @param[in]  UINT32  nAddress - address in flash to start writing
     /// @param[in]  UINT32 * pBuffer  - buffer to write into
     /// @param[in]  UINT32  nDWordsToWrite - number of 4-bytes elements to write
     /// @retval     TRUE  - write succeeded
     /// @retval     FALSE - write failed
         if(nDWordsToWrite == 0)
             return 1;
         // Flash device write specific implementation
         return 1;
     }   // End usrWriteFlashMemory
  • Erase callback to erase flash sectors. Following is a sample 'Erase' callback.
     /// @name  BOOL usrEraseFlashSector(UINT32 nStartingAddress, UINT32 nNumberOfSectors)
     /// @brief Erase flash memory starting at address for number of sectors
     /// @param[in]  UINT32  nStartingAddress - address in flash to start erasing
     /// @param[in]  UINT32  nNumberOfSectors  - number of flash memory sectors to erase
     /// @retval     TRUE  - erase succeeded
     /// @retval     FALSE - erase failed
         UINT32 nSectorAddress, index;
         nSectorAddress = nStartingAddress;
         // Loop through number of sectors and erase each sector
         for (index = 0; index < nNumberOfSectors; index++)
             // Flash device specific sector erase implementation
             // with sector start address 'nSectorAddress'
             // Go to next sector start address
             nSectorAddress += ERASEABLE_SECTOR_SIZE;
         return 1;
     }   // End usrEraseFlashMemorySector
Now that the required variables have been declared, the AWE Flash FS Instance will be configured by assigning its members and pointers.
  • First, ensure that the AWEFlashFSInstance is initialized to zeros. If not, explicitly initialize to 0 with memset.
      memset(&g_AWEFlashFSInstance, 0, sizeof(AWEFlashFSInstance) );
    • Initialize the callback pointers of ‘cbInit’, ‘cbEraseSector’, ‘cbFlashWrite’ and ‘cbFlashRead’ in the AWE Flash FS Instance.
       g_AWEFlashFSInstance.cbInit = &usrInitFlashFileSystem;
       g_AWEFlashFSInstance.cbEraseSector = &usrEraseFlashMemorySector;
       g_AWEFlashFSInstance.cbFlashWrite = &usrWriteFlashMemory;
       g_AWEFlashFSInstance.cbFlashRead = &usrReadFlashMemory;
    • Initialize the flash specific settings of flash size in bytes, erasable block or sector size, start offset and block or sector erase time.
       g_AWEFlashFSInstance.flashSizeInBytes = FLASH_MEMORY_SIZE_IN_BYTES;
       g_AWEFlashFSInstance.flashErasableBlockSizeInBytes = ERASEABLE_SECTOR_SIZE;
       g_AWEFlashFSInstance.flashStartOffsetInBytes = FILE_SYSTEM_START_OFFSET;
       g_AWEFlashFSInstance.flashEraseTimeInMs = (INT32)((FLOAT32)((( (FLASH_MEMORY_SIZE_IN_BYTES - FILE_SYSTEM_START_OFFSET)/ ERASEABLE_SECTOR_SIZE)*SECTOR_ERASE_TIME_MS/1000) + 0.5f) + 5);
    Next, initialize the AWE Flash FS Instance by calling the awe_initFlashFS() function. **This must happen before calling awe_init().** If awe_initFlashFS() is called after awe_init, the initialization will fail.
    awe_initFlashFS(&g_AWEInstance, &g_AWEFlashFSInstance);
    • Assign pFlashFileSystem in AWE Instance to AWE Flash FS instance.
       g_AWEInstance.pFlashFileSystem = &g_AWEFlashFSInstance;
The code above will initialize the AWE Flash FS Instance.
Setting up the AWE Instance
A number of variables must be defined before configuring/initializing the AWE Instance.
  • The AWECore Instance object encapsulates a single AWE Core instance. Most API calls take an AWECore Instance as the first argument. It must be defined so it doesn't go out of scope, for example as static or global, and be initialized to zeros.
     AWEInstance g_AWEInstance = {0};
    Later, in the initialization section, it will become clear that there are several fields of the AWECore Instance structure that must be configured before it can be used to process audio data.
  • The IOPinDescriptor objects describe input and output data buffers and their properties. They must be defined so they don't go out of scope, for example as static. NOTE: multiple IO pins not supported. There can only be one input pin and one output pin. All API's that take the argument "pinIdx" will always pass in 0.
  • A module descriptor table that contains an array of pointers to modules that are available to the AWE Instance. The table is initialized at compile time. It must be defined so they don't go out of scope, for example as static.
     //The list of class objects is defined in ModuleList.h
     const void* g_module_descriptor_table[] = { LISTOFCLASSOBJECTS};
  • The module descriptor list can be dynamically extended at runtime by providing the AWEInstance struct with a Module Descriptor List.
  • Memory heaps that the AWE Core uses for its own local processing. The integrator must provide word-aligned blocks of memory that are persistent. For example,
     UINT32 g_FastHeapA[FAST_HEAP_A_SIZE];
     UINT32 g_FastHeapB[FAST_HEAP_B_SIZE];
     UINT32 g_SlowHeap[SLOW_HEAP_SIZE];
    where FAST_HEAP_A_SIZE, FAST_HEAP_B_SIZE, and SLOW_HEAP_SIZE are chosen appropriately for the system. See the Optimization section for more details.
  • A command packet buffer of type UINT32[264] that is the destination of tuning commands.
     #define PACKET_BUFFER_SIZE 264
     UINT32 AWE_Packet_Buffer[PACKET_BUFFER_SIZE];
  • A reply packet buffer of type UINT32[264] where the AWE Core places replies to tuning commands.
     UINT32 AWE_Packet_Buffer_Reply[PACKET_BUFFER_SIZE];
    Note: The standard packet size is 264. If a different packet size is needed, please contact DSPC Engineering.
Now that the required variables have been declared, the AWE Instance will be configured by assigning its members and pointers.
  • First, ensure that the AWECore Instance is initialized to zeros.
  • Assign the instanceID to 0.
     g_AWEInstance.instanceId = 0;
  • Assign the AWEInstance’s “pInputPin” and “pOutputPin” pointers to the input and output pin descriptors.
     g_AWEInstance.pInputPin = &aweInputPin;
     g_AWEInstance.pOutputPin = &aweOutputPin;
  • Assign the AWEInstance’s “pPacketBuffer” pointer to the command buffer that was declared above.
     g_AWEInstance.pPacketBuffer = AWE_Packet_Buffer;
  • Assign the AWEInstance’s “pReplyBuffer” pointer to the reply buffer. (Note that this can be assigned to the same buffer as the send buffer if a single buffer for send/reply is desired.)
     g_AWEInstance.pReplyBuffer = AWE_Packet_Buffer_Reply;
  • Assign the AWEInstance’s “packetBufferSize” member to 264.
     g_AWEInstance.packetBufferSize = PACKET_BUFFER_SIZE;
  • Assign the “moduleDescriptorTable” pointer to the module descriptor table.
     g_AWEInstance.pModuleDescriptorTable = g_module_descriptor_table;
  • Assign the “numModules” member to the number of modules. This can be determined by taking the sizeof the module descriptor table and dividing it by the sizeof the first element of the module descriptor table.
     UINT32 module_descriptor_table_size = sizeof(g_module_descriptor_table) / sizeof(g_module_descriptor_table[0]);
     g_AWEInstance.numModules = module_descriptor_table_size;
  • Assign the “numThreads” to the number of audio processing threads. See the Multi-Rate section for more info.
     g_AWEInstance.numThreads = 2; //dual threaded, supports two blocksizes
  • Assign the “sampleRate” member to the fundamental sample rate of the system.
     g_AWEInstance.sampleRate = 48000.0f;
  • Assign the “fundamentalBlockSize” member to the fundamental block size of the system. This is typically the DMA block size. Every layout that is run on the system must have a block size that is a multiple of this fundamental block size.
     #define AWE_BLOCK_SIZE 32
     g_AWEInstance.fundamentalBlockSize = AWE_BLOCK_SIZE;
  • Assign the “pFlashFileSystem” member to 0 unless an Audio Weaver Flash File System will be implemented.
     g_AWEInstance.pFlashFileSystem = 0;
  • Assign the “fastHeapASize”, “slowHeapSize” and “fastHeapBSize” members to the heap sizes.
     g_AWEInstance.fastHeapASize = FAST_HEAP_A_SIZE;
     g_AWEInstance.fastHeapBSize = FAST_HEAP_B_SIZE;
     g_AWEInstance.slowHeapSize = SLOW_HEAP_SIZE;
  • Assign the “pFastHeapA”, “pSlowHeap” and “pFastHeapB” pointers to the heaps that were previously allocated.
     g_AWEInstance.pFastHeapA = g_FastHeapA;
     g_AWEInstance.pFastHeapB = g_FastHeapB;
     g_AWEInstance.pSlowHeap = g_SlowHeap;
  • Assign the “coreSpeed” and “profileSpeed” members to the CPU/profiling speed of the system. Only used for profiling displays in Audio Weaver tools.
     g_AWEInstance.coreSpeed = 10e6f;
     g_AWEInstance.profileSpeed = 10e6f;
  • Assign the “name”, this will be displayed in the AWE Server dialog as the name of the instance. Max length of 8 characters.
     g_AWEInstance.pName = “mytarget”;
  • Assign the "userVersion" member to be a UINT32 value. The value and meaning is entirely up to the integrator.
     //this example represents a date
     g_AWEInstance.userVersion = (UINT32) 06212019;
  • Assign callback pointers "cbAudioStart", "cbAudioStop". These are optional callbacks and user can define in the BSP to be notified by the AWE Core framework when the layout Design started or stoped.
     g_AWEInstance.cbAudioStart = &usrCallbackAudioStart;
     g_AWEInstance.cbAudioStop = &usrCallbackAudioStop;
     /// METHOD:  INT32 usrCallbackAudioStart(AWEInstance *pAWE)
     /// PURPOSE: Start audio processing callback
         // Target specific configurations, if any, before starting the layout pump.
         // Like enabling audio IO interrupts etc.
         return 0;
     }   // End usrCallbackAudioStart
     /// METHOD:  INT32 usrCallbackAudioStop(AWEInstance *pAWE)
     /// PURPOSE: Stop audio processing callback
         // Target specific configurations, if any, before destroying the layout.
         return 0;
     }   // End usrCallbackAudioStop
  • Assign callback pointer "cbCacheInvalidate". This is an optional callback. When defined, it is called from multiple places in AWE Core to invalidate or flush the shared memory cache. The FFSWrapper modules, ChangeThread module, and general Multi Instance functionality all utilize this callback. It is the user's responsibility to check if the provided address and length to be invalidated or flushed are in the cached region to avoid unnecessary overhead. Please note that this function may be called once per audio block in certain cases, such as with the ChangeThread module.
     g_AWEInstance.cbCacheInvalidate = &usrCallbackCacheInvalidate;
     /// METHOD:  usrCallbackCacheInvalidate
     /// PURPOSE: Invalidate cache region
     INT32 usrCallbackCacheInvalidate(AWEInstance *pAWE, void* pStartAddr, UINT32 lengthInWords, INT32 CacheCallbackType)
         // Validate input argument pStartAddr. If it falls in the cached region then invalidate or flush cache region with start address pStartAddr and end address (pStartAddr+length-1).
         if (CacheCallbackType == AWE_CACHE_CALLBACK_TYPE_WRITEBACK)
             // Target specific cache flush (writeback) logic.
         elseif (CacheCallbackType == AWE_CACHE_CALLBACK_TYPE_INVALIDATE)
             // Target specific cache invalidation logic.
        return 0;
     }   // End usrCallbackCacheInvalidate
    Note: This callback may be called from different thread contexts and it is the user's responsibility to make sure flush and invalidate operations are atomic.
  • Assign callback pointer "cbGetLayoutThreadPriority". This is an optional callback, when defined, called from a module requesting the priority of the thread corresponding to the layoutNum argument. BSP should return the priority of the thread from which awe_audioPump() called with the layoutNum.
     g_AWEInstance.cbGetLayoutThreadPriority = &usrCallbackGetLayoutThreadPriority;
     /// METHOD:  usrCallbackGetLayoutThreadPriority
     /// PURPOSE: Return the thread priority corresponding to the layoutNum
     INT32 usrCallbackGetLayoutThreadPriority(AWEInstance *pAWE, INT32 layoutNum)
         INT32 threadPriority;
         if (layoutNum == 0)
             // Priority of the first layout, where awe_audioPump(&g_AWEInstance, 0); is called.
             threadPriority = firstLayoutThreadPriority;
         elseif (layoutNum == 1)
             // Priority of the second layout, where awe_audioPump(&g_AWEInstance, 1); is called.
             threadPriority = secondLayoutThreadPriority;
         elseif (layoutNum == 2)
             // Priority of the third layout, where awe_audioPump(&g_AWEInstance, 2); is called.
             threadPriority = thirdLayoutThreadPriority;
         and so on up to NUM_THREADS.
         return threadPriority;
     }   // End usrCallbackGetLayoutThreadPriority
  • Assign callback pointer "cbAweForwardPacket" in the tuning master instance (where awe_packetProcessMulti() called with second argument as TRUE). This is an optional callback. When defined, it is called whenever tuning master has a packet to be forwarded to secondary instances. Callback is called with target instance ID to which the packet belongs to. BSP can make use of this callback to trigger (via interrupt or semaphore or any event depending on the platform) corresponding instance packet processing thread (which may be on different core or in different thread on the same core).
     g_AWEInstance.cbAweForwardPacket = &aweuser_forwardPacketCallback;
     /// METHOD:  aweuser_forwardPacketCallback
     /// PURPOSE: Callback indicates there is a packet to be forwarded
     INT32 aweuser_forwardPacketCallback(AWEInstance *pAWE, INT32 instanceID)
         // pAWE is always from tuning master, just for reference only and generally has no usage.
         // Check for the valid instance ID and trigger the corresponding packet processing of instanceID.
         if (instanceID < NUM_INSTANCES)
             // Semaphore or interrupt or any event.
             sem_post(&packetProcessSems[instanceID]);
        return 0;
     }   // End aweuser_forwardPacketCallback
The next step is to first initialize the IO Pins followed by initializing the AWE Instance using specific API functions.
Simply call the awe_initPin() function and pass it the input pin, the desired channel count (determined by audio HW), and an optional pin name.
define TWO_CHANNELS 2 int ret = awe_initPin(&aweInputPin, TWO_CHANNELS, NULL);
The code above would initialize the input pin with 2 channels, and the default name.
Initializing the output pin is the same as the input pin, but the output pin is passed in.
#define SIX_CHANNELS 6
int ret = awe_initPin(&aweOutputPin, SIX_CHANNELS, "outpin");
The code above would initialize the output pin with 6 channels with the name "outpin".
Next, initialize the AWE Instance by calling the awe_init() function. This must happen as the last initialization step. If awe_init() is called before the AWE Instance structure is configured or before the IO pins are initialized, the initialization will fail.
int ret = awe_init(&g_AWEInstance);
The code above will initialize the AWE Instance.
Registering AWE Callbacks
After initialization of the AWE Instance, users can optionally register callbacks supported by the AWE Core. AWE Core supports callbacks for logging functionality (awe_registerLoggingCallback), and for Event module support (awe_registerEventCallbacks).
In both the logging and event callbacks described below, the payload passed to the user callback functions is not guaranteed to persist after the user function returns. Any handling or copying of the payload must be completed before the function is returned. The user is responsible for making sure to return these functions quickly - any expensive processing of logging or events should be done in a separate thread to avoid interrupting audio processing.
Logging
The AWE Core logging functionality provides log information to BSPs that have registered a callback function. Log level (Error, Warning, Info, Debug), as well as a log type (bitfield), are provided as part of the log messages. The user can configure which log levels and log types to filter out using the awe_registerLoggingCallback function. The register function can be called at any time after awe_init, and the registered log level and log types can be updated with subsequent calls.
To receive callbacks from AWE Core for logging messages, the application needs to define a function matching the signature of cbAweLogging_t. A simple example of a user function that prints a timestamp and the content of the logging payload is shown below. Note that the payload is always an ASCII message with no trailing newline.
    void usrLogging(AWEInstance* pAWE, INT32 level, UINT32 type, void* payload, INT32 payloadSizeInBytes)
        struct timeval ts;
        char timeCh[25];
        // Get current time for log
        gettimeofday(&ts, NULL);
The memory used for the payload passed to the logging function is not guaranteed to persist after the user logging function is returned from. Any handling or copying of the payload must be completed before the function is returned.
See LinuxApp.c for more details of an example use case.
Events
The AWE Core has an Event Module that can trigger callbacks to the system when events occur in the layout. The meaning of the event must be defined by the Event Module user and the application has to understand how to respond to different event types. Similarly to the logging feature, event callbacks must be registered with the AWEInstance for the Event Module to be able to trigger any events. The Event Module supports 3 callbacks:
  1. cbAweEventTrigger_t : Called by the Event Module when an event trigger is detected
  2. cbAweEventRegister_t : (optional) Called by the Event Module when it is constructed
  3. cbAweEventDeregister_t : (optional) Called by the Event Module when it is destroyed
These callbacks must be registered using awe_registerEventCallbacks. See LinuxApp.c for an example use case.
The next step is to implement a tuning interface – arguably the most important component of a successful AWE Core integration as it provides essential debugging capabilities. The tuning interface communicates commands/replies to and from the AWE Instance. For example, these commands can instantiate a layout, or set and query the value of a module parameter.
Different platforms will support different transport protocols for the tuning interface. AWE Server supports USB, TCP/IP (sockets), RS232, SPI, etc. Helper code is available to aid in the development of these different transport layers on the target. It is the responsibility of the integrator to enable the transport protocol for the tuning commands to be passed to and from the platform.
Here are the basic steps for setting up and using a tuning interface with AWE Server.
  1. Setup/test the desired transport layer between the board and the PC. Make sure that packets of length 264 words can be passed back and forth (echo). The protocol can be verified completely independently of AWE Core using some kind of simple application.
  2. Once data can be passed, the tuning interface should be setup to receive commands from AWE Server. This process varies from protocol to protocol.
  3. Once commands are received from AWE Server, they will need to be processed by the AWE Instance using awe_packetProcess(). Once a command is received from AWE Server, copy it into the AWE_Packet_Buffer and then call awe_packetProcess(&g_AWEInstance) on the instance. Remember that this packet buffer has been registered with the AWE Instance, which is why the awe_packetProcess(&g_AWEInstance) function does not need to take an argument to the packet buffer.
  4. The awe_packetProcess() function will process the packet, and then generate a reply in the AWEInstance.pReplyBuffer. If the same buffer is used for both send and reply, the reply message will overwrite the original command.
  5. Finally, the reply is sent back to the AWE Server over the transport layer. See the following pseudocode representation of the complete transaction.
    int sizeOfPacket = 264;
    readPacket(&AWE_Packet_Buffer, sizeOfPacket);
    awe_packetProcess(&g_AWEInstance);
    writePacket(&AWE_Packet_Buffer_Reply, sizeOfPacket);
    Real-time Audio
The next step is to integrate real-time audio. AWE Core aside, real-time audio can be a tricky topic. Before attempting to integrate real-time audio into an AWE Core system, please ensure that the integrator has a basic understanding of digital audio and real-time audio processing. Here are some helpful links.
http://www.rossbencina.com/code
Giulio Moro - Assessing the stability of audio code for real time low latency embedded processing
RealTime Audio Integration Steps
  1. Verifying Audio HW IO with a Passthrough Ensure that audio can be cleanly passed between input/output without the AWE Core involved in the signal path. A simple sine wave input into the system can often be the best audio source for this type of test, as any distortion or dropouts are more easily audible than with a more complex signal. This step is critical to ensure a high fidelity audio system, and can vary greatly from platform to platform. For instance, an embedded target might utilize the HW’s audio IO DMA, while Linux systems may use ALSA or something similar.
  2. Determining Audio HW Settings and Configuring the AWE Instance. These steps will describe how to set up the AWE Instance for RT Audio support.
    1. Configure the sample rate and block size. For example, if the audio HW reads in samples at a block size of 32, then the AWE Instance’s fundamental blockSize should be set to 32. The block size of any layout loaded on the target must be a multiple of this fundamental block size. If the HW’s sampling rate is 44100.0, then the AWE Instance’s sampleRate should be set to 44100.0.
    2. Determine the sample format of the audio HW. See the Audio Sample Formatting section below for more information on audio sample formatting.
    3. Determine the Input/Output channel count of the audio HW. AWE Core needs to be able to import/export data for each available HW channel. For each available hardware input channel, the application will need to call awe_audioImportSamples(), and, likewise, awe_audioExportSamples() will need to be called for each available hardware output channel. Using these channel-by-channel functions make it easy to aggregate multiple audio sources into a single, multi-channel input or output. Additionally, the Import and Export functions automatically handle what is referred to as 'channel matching'. Since AWE Core is designed to be flexible and Audio Weaver layouts are designed to be portable, the number of channels in a layout need not match the number of HW inputs and outputs in a system. If a layout has more I/O channels than the hardware channel count, then the Import and Export functions will automatically fill the input signal with additional zero'd channels, and will ignore any additional output channels. Similarly, if the layout loaded has fewer channels than the hardware channel count, then the Import and Export functions will ignore the additional HW input channels, and fill the additional HW output channels with zeros.
  3. The Realtime Audio Loop. These steps describe what should happen inside the audio loop after configuration is complete.
    1. In the audio loop, check to see that a valid layout is loaded and that audio has been started with the API calls awe_layoutIsValid() and awe_audioIsStarted(). In multi-instance systems with shared heap defined, please use awe_audioIsStartedMulti() instead of awe_audioIsStarted() on the primary instance (instance with ID 0). Please refer Multi-Instance Scheduling section below for more details about multi-instance scheduling.
    2. Call awe_audioImportSamples() for each input channel and pass in the audio data from the audio HW.
    3. Get the “layoutMask” from the awe_audioGetPumpMask() function. This will return a bit vector of the audio processing layouts that need to be pumped. The number of audio layouts to pump is determined by the number of clock-dividers (bufferup/down paths) in the .awb. The layoutMask bit vector should be bitwise AND'ed (&) with 1 << N, for N=0:numThreads-1, to determine which layouts are ready to be pumped. Based on the system's capabilities, each layout should be pumped at it's own interrupt level/thread priority. See the Multi-Rate section for more information.
    4. Call awe_audioPump() for each layout as determined by the layoutMask above. The layout index will be the value of N from above.
    5. Call awe_audioExportSamples() for each output channel and pass in the audio HW’s output data.
    6. Repeat.
The data type of the input and output audio data is determined by the audio hardware. Typically, digital audio is represented as fixed point data in 16, 24, or 32 bit depth. The audio sample formats supported by AWE Core's awe_audioImportSamples() and awe_audioExportSamples() functions, as defined in SampleType in StandardDefs.h, are:
  • Sample16bit - Fixed point 16 bit audio data stored in 16 bit data type. Also known as Q15 format.
  • Sample24bit_low - Fixed point 24 bit audio stored in 32 bit data type. Right justified, so the 24 bits of data are stored in the lowest 24 bits of the 32 bit word.
  • Sample24bit_high - Fixed point 24 bit audio stored in 32 bit data type. Left justified, so the 24 bits of data are stored in the highest 24 bits of the 32 bit word. If both right justified and left justified formatting is available on the hardware, then choose left justified (Sample24bit_high) for a slight performance improvement.
  • Sample32bit - Fixed point 32 bit audio data. Also known as Q31 format. This data is passed directly to the signal processing chain without conversion.
Internally, all inputs and outputs to Audio Weaver layouts are of type Sample32bit, also referred to as fract32 within a layout. This is done to guarantee portability of any signal processing layout to any target system, regardless of the hardware's native audio data type. The awe_audioImportSamples() and awe_audioExportSamples() functions will convert to and from the Sample32bit data as needed based on the integrator's supplied _SampleType argument. If the target's native audio sample formatting is not one of those listed above, then the integrator will have to manually convert the data to one of the supported types before using the import and export functions.
Since some common target systems natively support floating point audio, helper functions are provided to convert between float<-->fract32 in AWECoreUtils.c, which is provided in the AWE Core package. Add AWECoreUtils.c to the build project to access the sample-by-sample conversion functions float_to_fract32 and fract32_to_float. See the API in doc AWECoreUtils.h for more info.
The AWE Core allows audio to be processed at multiple block rates. For example, consider a system with two processing paths: one that processes time-domain data in blocks of 32 samples and another that processes frequency-domain data in blocks of 64 samples but at 1/2 the rate of the time-domain path. Such a system is shown in the figure below. It uses BufferUp and BufferDown modules to connect the different block size domains. These modules effectively partition the layout into 2 sub-layouts operating at different block rates.
Multi-Rate Layout
The two paths are executed at different rates and AWE Core’s awe_audioGetPumpMask() API call provides a mechanism to determine when the processing for each path should be initiated. Consider the following pseudocode:
layoutMask= awe_audioGetPumpMask(&g_AWEInstance);
if (layoutMask & 0x1) raise(AWEProcess_HiPrio);
if (layoutMask & 0x2) raise(AWEProcess_LowPrio);
AWEProcess_HiPrio()
    awe_audioPump(&g_AWEInstance, 0); // small block size path
AWEProcess_LowPrio()
    awe_audioPump(&g_AWEInstance, 1); // large block size path
This code tests which sub-layouts have accumulated enough data to execute. The layoutMask variable contains a 1 in each bit position corresponding to sub-layout that is ready to execute. For example, if layouts 0 and 1 are ready to execute, layoutMask would be 0x00000003.
Lower numbered sub-layouts correspond to smaller block sizes. In the pseudo-code, a signal is raised for each sub-layout that is ready to be pumped.
High Level OS Profiling on Multi Core Devices
Profiling designs on high-level OSes is challenging because layout threads may run on any available core at any given time. An OS-level mechanism to lock a particular thread to a certain core may be available. If so, one can notify AWECore that a layout thread will run on a specific core, and more accurate profiling will be shown in AWE Server. These functions are awe_fwSetLayoutCoreAffinity() and awe_fwGetLayoutCoreAffinity(). By default, all layouts are assumed to run on core 0.
Real-time constraints dictate that if the 64 sample sub-layout is executed in the same context as the 32 sample sub-layout, both will need to complete processing before the next block of 32 samples arrives or real-time will be broken. This imposes an unnecessarily strict constraint on the 64 sample sub-layout – its processing need only be completed before the next block of 64 samples is accumulated. Thus, its processing time can, in principle, be spread over 2 of the 32 sample block times without breaking real-time. In practice, this is achieved by executing the two sub-layouts in separate contexts. The sub-layout with the shorter block size should have higher priority so that it can preempt the processing of the sub-layout with the longer block size. In this way, the real time constraints of each sub-layout can be accommodated. The following figure shows the timing for this example:
Multi-Rate Threading Model
In the multi-instance environment where instance 0 is the master with interface to audio IO peripherals, it's common to have bigger layout block size on secondary instances then the layout block size on instance 0. In this situation, it's not a good practice to signal secondary instances at the fundamental block rate. To avoid unnecessary overhead with signalling secondary instances at higher block rate, user must call awe_audioIsReadyToPumpMulti() API and if it returns TRUE then signal the secondary instance.
  • If there are two instances, call awe_audioIsReadyToPumpMulti() to check if the second instance is ready to pump as
     if (awe_audioIsReadyToPumpMulti(&g_AWEInstance, 1))
         // Signal secondary instance to check for the pump mask, through either raise() or any other option depending on the target
  • Call the above function, as many times as the slave instances (with ID > 0) and signal the corresponding instance.
  • When this function is called with instance id 0 or invalid ID, it always returns FALSE.
Note: It is recommended to call awe_audioIsReadyToPumpMulti() before calling awe_audioGetPumpMask() in instance 0. When instance 0 is implementing low latency path (i.e. calling of audioPump in the DMA handler), this may affect the starting time of the secondary instances when awe_audioIsReadyToPumpMulti() is called at the end. To keep the secondary instances start time in align with instance 0, call awe_audioIsReadyToPumpMulti() before blocking DMA handler with low latency audio pump call.
    //Call awe_audioIsReadyToPumpMulti() to trigger secondary instances
    // Repeat for all secondary instances
    //Get the pump mask of instance 0
    layoutMask = awe_audioGetPumpMask(&g_AWEInstance);
In a multi rate processing with different priorities of each processing thread, it's quite common that the low priority thread processing is preempted by the high priority thread processing which affects the profiling of low priority thread processing due to the continuous clock counter. By default, AWE Core corrects the overhead by the high priority thread processing due to preemption. Currently the preemption overhead correction is supported on all the platforms except Windows (WIN32) and Linux.
In a system with multiple AWE Instances in the same core, user must call awe_setInstancesInfo() API to enable the preemption overhead correction in profiling. Call this API as the last step in init sequence after all AWE Instances are configured and initialized.
  • Declare a global array of AWEInstance pointers with size for number of AWE Instances in a single core
     AWEInstance *g_pInstances[NUM_AWE_INSTANCES];
  • Initialize the array with each instance pointer
     for (int i = 0; i < NUM_AWE_INSTANCES; i++)
         g_pInstances[i] = &g_AWEInstance[i];
  • Call awe_setInstancesInfo() API to initialize overhead correction in the profiling. When multiple instances are running on the same core and each instance packet processing is in a dedicated thread, it is recommended to use cbAweForwardPacket callback to trigger corresponding packet processing. If no callback is used and loading multi-instance AWB with one of awe_loadAWB functions, then this can lead to unexpected behavior.
     awe_setInstancesInfo(g_pInstances, NUM_AWE_INSTANCES);
In a multi-rate or multi-instance systems, when the low priority layout processing is preempted by high priority layout processing, the profiling overhead of the high priority layout processing is corrected by default within the AWE Core framework. To include overhead due to external events like DMA ISR, call awe_audioStartPreemption() and awe_audioEndPreemption as explained below.
  • DMA ISR without low latency audio pump:
     DMA ISR()
         UINT32 start_time;
         INT32 coreAffinity = 0;
         // For embedded targets, default core affinity is 0 in AWE Core.
         // For other targets like Linux based, get the core affinity from which this function is called.
         // Call the start preemption API to get the start time stamp
         start_time = awe_audioStartPreemption(&g_AWEInstance, coreAffinity);
         // All the audio import calls here
         // All the audio export calls here
         // Get pump mask and other code
         // Call the end preemption API to include this ISR overhead in any low priority active layout(s)
         awe_audioEndPreemption(&g_AWEInstance, start_time, coreAffinity);
DMA ISR with low latency audio pump:
  DMA ISR()
      UINT32 start_time;
      // Call the end preemption API to include overhead by import calls in any low priority active layout(s)
      // Call the low latency audio pump. Overhead due to this pump call in any low priority active layout(s) is corrected by the AWE Core framework
      // Call the start preemption API to get the start time stamp, after low latency pump call to include overhead due to export calls
      // Call the end preemption API to include overhead by export calls in any low priority active layout(s)
  • To correct overhead due to multiple external events (for example, DMA ISR and UART IST in baremetal BSP), user has to call the above methods in each event and additional handling needs to be done in one os some of the external event handling routines. Following is the example use case correcting overhead due to DMA ISR and UART ISR in typical baremetal BSP.
     // Global variable which counts overhead by the high priority interrupt (UART ISR in this case)
     UINT32 uartOverhead = 0;
     DMA ISR()
         UINT32 start_time;
         // Clear the high priority event overhead at the beginning
         uartOverhead = 0;
         // Consider high priority event overhead if it happened from this ISR
         awe_audioEndPreemption(&g_AWEInstance, start_time + uartOverhead, coreAffinity);
     UART ISR()
         UINT32 start_time;
         // UART packets handling
         // Accumulate the overhead for the low priority events (DMA ISR in this case) to address recursive preemptions in the same DMA block
         uartOverhead += awe_audioEndPreemption(&g_AWEInstance, start_time, coreAffinity);
    Deferred Processing
There are certain AWE modules that need to perform time consuming calculations, for example when the cutoff frequency of a Second Order Filter module is changed, the filter coefficients need to be recalculated. Performing these calculations in the audio processing context can cause it to overrun. To address this issue, certain modules defer those calculations until the firmware calls awe_deferredSetCall().
Note: For module authors, the awe_deferredSetCall() function calls the module's Set function with a mask of 0xFFFFFF00.
An integrator can check for any required deferred processing using the return value of awe_audioPump(), which will return TRUE if any deferred processing is pending. If deferred processing is needed, then call awe_deferredSetCall() at a priority that is lower than the audio processing. awe_deferredSetCall() performs deferred processing for a single module, and returns TRUE if there is more deferred processing that is pending. Thus it should be called repeatedly until it returns FALSE.
//g_bDeferredProcessingRequired is returned by awe_audioPump()
if (g_bDeferredProcessingRequired || bMoreProcessingRequired)
    g_bDeferredProcessingRequired = FALSE;
    bMoreProcessingRequired = awe_deferredSetCall(&g_AWEInstance);
At this point, the integrator should be able to load a layout from Audio Weaver Designer and run it on the target via the Tuning Interface. Once a Layout in Designer has been completed, it is easy to switch to stand-alone operation. Simply ask Audio Weaver to "Generate Target Files", and the Layout's configuration-data will be generated as a C array to be compiled into the system.
From the viewpoint of AWE Core, the signal processing layout is described by a data array of binary Audio Weaver commands. This command array is generated by Audio Weaver Designer using the Tools/Generate Target Files menu item and enabling the [BaseName]_initAWB checkbox. The layout is loaded into an AWE Core instance by making a call to awe_loadAWBfromArray with the command array, its size in 32-bit words, and the AWEInstance as arguments. If an error occurs during loading, then the offset of the offending AWB command is returned to the pPos argument.
INT32 err = awe_loadAWBfromArray (&g_AWEInstance, pCommands,arraySize, &nErrOffset);
if (err)
    // report the error
    printf(“error code %u due to command at position %u\n”, err, nErrOffset);
    // handle the error
awe_loadAWBfromArray() will load the entire array of commands and process them locally on the AWE Instance. If an array of commands needs to be loaded on a remote instance, it can be loaded command by command with the awe_getNextAWBCmd() helper function in AWECoreUtils.h. Each command is parsed so that they can be routed to the remote instance.
All priority and interrupt issues are managed outside of the AWE Core by the firmware integrator since the AWE Core has no knowledge of the supporting processing environment it is being integrated into. The following processing context may be implemented using interrupt handlers or using OS threads/tasks. The main requirement is that the processing context is implemented at different preemptible priority levels.
A basic Audio Weaver platform has a minimum of five priority levels of processing. From highest priority to lowest priority:
  • Priority 1: Tuning Communication I/O Task: Receives/sends data over the communication transport layer, for example RS232, USB, SPI, or Ethernet. Note: Tuning commands are not processed in this context; data is simply moved into and out of the tuning packet buffer. Action: Insert received data into the tuning packet buffer or send reply data from tuning packet buffer. When a complete packet has been received, signal the low priority idle task to process it.
  • Priority 2: Audio I/O Task: Complete audio frame has been received. Blocks of audio samples are exchanged between DMA buffers and the AWE Core input and output buffers. Action: Copy new audio samples into AWE layout input buffers copy latest AWE layout processed audio samples to output buffers if enough audio samples are available trigger Priority 3 and/or Priority 4 tasks to perform signal processing.
  • Priority 3: Audio Processing Task: Process one AWE layout-defined frame of audio samples. Action: At this priority level, the active signal processing layout is processed with awe_audioPump().
  • Priority 4: Lower Priority Audio Processing (multi-rate) Task: Process one larger AWE layout-defined frame of audio samples. Action: At this priority level, longer duration signal processing is initiated with awe_audioPump() but at a lower priority than the normal audio processing above.
  • Priority 5: Background Processing Task: In background / idle loop context, non-real-time tasks are processed. This includes the processing of tuning commands, deferred processing, and any Control Interface processing. Action:
    • Process a received tuning command.
    • Process any deferred processing needed for a single module.
    • Perform any needed interaction with the layout from the firmware.
These three actions must be atomic to avoid the possibility of race conditions due to concurrent access of resources.
A control interface lets the system interact with modules in the running layout directly from the firmware. To access the layout from the API, use Designer to generate a control-interface header file for the layout. Then, use the following API calls define the functionality of the control interface:
Get/set a value of a module: awe_ctrlGetValue() and awe_ctrlSetValue()
Get/Set the status of a module (bypassed, active, inactive, muted): awe_ctrlSetStatus() and awe_ctrlGetStatus()
INT32 awe_ctrlSetStatus(const AWEInstance *pAWE, UINT32 handle, UINT32 status)
INT32 awe_ctrlGetStatus(const AWEInstance *pAWE, UINT32 handle, UINT32 *status)
Check if a module exists, and if so return its ClassID: awe_ctrlGetModuleClass()
The following functions provide finer grained control over how module variables get set and are for advanced users: awe_ctrlSetValueMask() and awe_ctrlGetValueMask()
INT32 awe_ctrlSetValueMask(const AWEInstance *pAWE, UINT32 handle, const void *value, INT32 arrayOffset, UINT32 length, UINT32 mask)
INT32 awe_ctrlGetValueMask(const AWEInstance *pAWE, UINT32 handle, void *value, INT32 arrayOffset, UINT32 length, UINT32 mask)
Note: For multi-instance system with a single layout for all instances, user can't call control API's with one instance to control modules running on different instance. To control modules on other instances (running on another core), there are 3 options:
1) In the signal flow, use ChangeThread to route control signals to an instance (core) and ParamSet module on that instance to control modules.
2) In the application firmware, create tuning packets with commands to control target instance modules as appropriate, with a dedicated IPC (Source module) on that instance.
3) Do the IPC of the control value separately from AWE in whatever way is supported on the target.
To access a module and control it via the Control Interface,
  • Create the desired layout. In the build tab of a module, assign an objectID to the module's that will be accessed. The objectID must be a value between 30000-32767.
  • Generate a ControlInterface.h header file from the layout with Tools->Generate Target Files. Make sure the [BaseName]_ControlInterface.h box is checked.
  • Include the generated [BaseName]_ControlInterface.h file in the AWE Core integration. This file will contain all of the define's required to use the API's control functions.
  • Check if the module exists and is of the right class with awe_ctrlGetModuleClass().
  • Use one of the awe_ctrl functions to set/get something about a module.
    • The handle, length arguments will all be defined in the [BaseName]_ControlInterface.h file that was generated. See the API Doc for details about the control functions arguments/return values.
  • Check the return value for errors and handle appropriately.
See the following example.
    // Does the current AWE model have a SinkInt module with this control object ID?
    if (awe_ctrlGetModuleClass(&g_AWEInstance, AWE_SinkInt1_value_HANDLE, &classID) == OBJECT_FOUND)
        // Check that module assigned this object ID is of module class SinkInt
        if (classID == AWE_SinkInt1_classID)
            // SinkInt module (value is an array)
            awe_ctrlGetValue(&g_AWEInstance, AWE_SinkInt1_value_HANDLE, &nValue, 0, 1);
Optimization
The AWE Core can be optimized for a system for heap space and for image size.
In a typical workflow, the integrator would decide on heap size/placement for development and finally optimized for production.
To decide on heap size/placement for board bring-up, set all three heaps to some small number of 1K word blocks say (1024 * 5). When the BSP is fully developed inspect the memory map to determine how much free space is available in the memory sections that have been assigned to the heaps. Then adjust the heap space to use as much of this memory as is practical. A typical assignment of heap might be to assign processor “tightly coupled memory” to fast heap A, processor RAM to fast heap B, and off-chip SDRAM to the slow heap.
Audio Weaver Designer can also generate the absolute smallest heap sizes needed for a specific layout via Tools->Generate Target Files and selecting [BaseName]_HeapSize.h. This can greatly reduce the memory footprint and aid in optimizing an AWE Core integration.
The ModuleList.h file that is delivered with AWE Core contains a large set of modules. This is convenient during development to provide a large selection of modules with which to design layouts. To optimize for a specific layout at production time, Audio Weaver Designer can generate a ModuleList.h with only the modules used by that layout using Tools->Generate Target Files->[BaseName]_ModuleList.h. Since most modern linkers will only link those modules referenced, this will significantly reduce the image size.
AWE Core target systems can contain multiple AWE Instances. This is useful on a platform with multiple cores when a system needs to do signal processing on each core, or if separate instances are needed for dedicated signal processing tasks.
AWE Core supports two methods of implementing multiple AWE Instances on a target system. Both methods support multiples AWE Instances on a single core, or across multiple cores on a single SOC.
  1. Multi Instance (Recommended): Depends on a 'shared heap' approach. This heap is provided by the user application and is allocated in a shared region of memory accessible to all AWE Core instances on a target. AWE Core handles all tuning packet handling and audio data routing between instances using this shared memory.
    With this approach, a single layout (AWD file) is created and can be distributed across all AWE Core instances. The 'ChangeThread' module in Designer is used to route audio between AWE Core instances and to define the target instance for the downstream modules in the layout..
Note: The Multi Instance feature is currently released as a beta feature, and may change in incompatible ways in future releases.
  1. Multi Canvas: Each AWE Core instance is independently connected to Designer. The user is responsible for routing tuning packets and audio to each instance using their own IPC protocol. Each AWE Core instance has its own independent layout (AWD file). This method might be preferable for those who wish to split signal processing designs among teams, and also results in smaller .awd design files.
Before setting up a multi instance tuning interface, we recommend implementing a single instance tuning interface. This will solidify the theory of operations and allow for easier understanding of the multi instance model.
AWE Core packets always contain a prefixed address called an 'instanceID'. On a single instance system, this instanceID is always 0. However, when developing a multi instance system, commands can be addressed to different instanceID's.
It is important to note that there is normally only one tuning interface between Server and the system. That single tuning interface will receive the packets for all instances and the BSP integrator must route them to the correct instance.
(Multi Instance only): The instanceID of an AWE command is determined by the instanceID of a module/wire in the design. The instanceID is a propagatable field, and can be modified using the 'ChangeThread' module, or, for a source module, by setting the clockDivider field in the build tab of the module properties. The syntax to set the clockDivider field is <clockDivider (#)><threadThead (letter)><instanceID (#)>, so '2B3' will run the source module with clockDivider of 2, on thread B of instance 3. The 'ChangeThread' module exists to take one or more input wires of data that exists on one instanceId, and send it to another user-specified instanceId. (Multi Canvas only): When using Designer, the instanceID of an AWE command is determined by which instance is selected in the dropdown window of Designer.
Utilizing multi instance AWE Core requires these steps:
  1. Allocate a shared heap memory space in a memory region accessible to all AWE Core instances. If this shared memory region is cached, see the cbCacheInvalidate callback function in the AWECore Instance structure. Attach this shared memory space, along with its size, to each AWE Core instance using the following AWECore Instance struct members:
    /** The shared heap. */
    volatile UINT32 *pSharedHeap;
    /** The shared heap size. */
    UINT32 sharedHeapSize;
  2. Allocate the tuning packet buffer in a shared memory region accessible to all AWE Core instances. Initialize the reply buffer pointer to the same memory region as the packet buffer. (See the Single Instance Tuning Interface Section for more details)
  3. Provide a unique instanceId to each AWE Core instance, with instanceId 0 reserved for the AWE Core instance that is the primary audio processing instance. The primary audio processing instance is the one that interacts with the audio input and output devices, and is the only instance that should call awe_initPin(). The instanceId numbering scheme follows a linearly incrementing digit starting from 0 (e.g. 0, 1, 2, 3...). Note that if there is a tuning only instance that does no audio processing and only forwards packets to processing instances, then both the tuning only instance and the primary audio processing instance must have instanceId equal to 0. This tuning only instance must be initialized with awe_init for awe_loadAWB* API's to function correctly.
  4. Set the numProcessingInstances member of each AWE Core instance to the total number of AWE Core instances on the target system. For example, if the target system has two AWE Core instances (instanceId: 0 and instanceId: 1), then the numProcessingInstances member of each AWE Core instance should be set to 2. Tuning only instances do not contribute to this number.
    /** The number of audio processing instances of AWECore configured on a single target */
    UINT32 numProcessingInstances;
  5. Using a global software interrupt accessible to all AWE Core instances, trigger each instance to check their pump mask and pump. This trigger is required to be synchronous to the audio peripheral data passed in/out of AWE Core instance 0. (See RealTime Audio Integration Steps for more details on mask reading and pumping audio)
  6. Process packet buffer data using the multi instance packet process API awe_packetProcessMulti(). For the tuning master instance, the API is called once a complete packet is received. For non-tuning instances, the API is polled in a low-priority task.
For more details on how to implement multi instance AWE Core, including pseudocode related to all necessary implementation details, read the Multi-Instance AWE Core Integration Guide found at (https://documentation.dspconcepts.com/awe-designer/latest-version/application-notes), or see the example file LinuxAppMulti.c.
Troubleshooting note: -> If trouble in connecting AudioWeaver server to the target, make sure packet buffer (reply buffer) on all instances pointing to the same address in shared memory. Similarly, make sure shared heap on all instances pointing to the same address in shared memory. -> For example, on a multi-instance system with one core as ARM with different compiler and another core as DSP with different compiler when shared buffers are allocated as
   section("shared_mem")
   UINT32 g_packetBuffer[MAX_COMMAND_LEN];
   UINT32 g_sharedBuffer[SHARED_HEAP_SIZE];
on the DSP, linker will allocate both g_packetBuffer and g_sharedBuffer in the same order as declared above in the "shared_mem" memory segment, whereas on ARM, linker may allocate g_sharedBuffer first and then g_packetBuffer in the same "shared_mem" memory segment.
In the multi-instance systems the signal flow for all instances is contained in a single AWD layout file. The AWE Core framework loads the entire AWB so that all instances load their respective layouts before calling PFID_StartAudio, which signals the system to start processing the layout. This strategy of loading all the layouts for every instance before starting processing guarantees initial synchronicity between all the AWE Instances. The diagram below shows the timing of normal loading an AWB for a Multi-Instance system.
Normal Loading of Multi-Instance Layout
If the system has different boot time requirements for each instance (for example a 3 core system can have 2 cores with short boot time whereas the third core may have significantly higher boot time requirements), it's not possible to achieve these early audio requirements with a single AWB. To overcome this limitation, AWECore supports progressive loading of multiple AWB's one per instance on boot time. The AWE Core will ensure that audio remains synchronous between instances, even when loaded separately. Assigning AWE Instances as standalone only changes the timing of loading AWB’s directly on the target. The behavior of instantiating and tuning layouts over the tuning interface (like from Designer) is not changed. Following diagram shows the timing of progressive loading of multi-instance AWB.
Progressive Loading of Multi-Instance Layout
Progressive loading can be applied to a multi-instance system with the following rules and constraints:
  1. A single multi-instance AWB must be split into a combination of standalone instance AWB's, where only a single instance has it's own AWB commands, and a single multi-instance AWB file with the AWB commands for the remaining non-standalone instances. All instances can be loaded standalone with individual AWB's, in which case there would be no remaining multi-instance AWB.
  2. If any instances are to be loaded in standalone mode, instance 0 must also be standalone.
  3. Standalone instances must all have a lower instanceId than the first instance included in a multi-instance AWB. That is, if instances 0 and 1 are loaded as standalone instances with individual AWB files, and instances 2 and 3 are loaded from a single multi-instance AWB, instance 4 can not also be standalone.
  4. To preserve synchronized and uninterrupted IPC, progressive loading of standalone instances must be done in sequential order of InstanceID's, beginning with instance 0, and continuing with instance 1 only when instance 0 is complete, and so on. Loading of a multi-instance AWB, if there is one, must only be done after loading all standalone instances.
  5. It is valid to not have any AWB's defined for any instances other than instance 0. That is, loading a standalone AWB on instance 0, and then a multi-instance AWB that targets only instances 2 and 3 is valid.
Splitting a multi-instance AWB into multiple AWB's to support progressive loading should never be done manually. In order to preserve synchronicity between instances, splitting a multi-instance AWB or AWS must be done using the MATLAB script split_multi_instance_layout, provided as part of Designer installs. Type help split_multi_instance_layout in MATLAB for usage information.
To enable progressive loading, call awe_setInstanceStandaloneAWBLoad() with the second argument as 1 (True) on instance 0 before loading AWB on instance 0 in standalone mode. On the remaining instances it depends on the split. If the split is into 2 AWB's, the remaining AWB can be loaded as normal from the tuning master instance. If the split is separate AWB per instance, then awe_setInstanceStandaloneAWBLoad() must be called in each instance before calling AWB loading API.
INT32 awe_setInstanceStandaloneAWBLoad(AWEInstance* pAWE, INT32 status);
NOTE:
**When progressive loading is enabled, awe_audioIsReadyToPumpMulti() must be called for all secondary instances, before calling awe_audioGetPumpMask() in instance 0.**
In progressive loading, the AWB loading APIs awe_loadAWBfromArray() and awe_loadAWBfromFile() and awe_loadAWBfromFlash() return error code E_MULTI_INSTANCE_SPLIT_AWB_NOT_STARTED (-119) when trying to load AWB in an instance but the previous instance is not yet started (see constraint 4 above). For example, when trying to load AWB on instance(s) > 0, but instance 0 has not finished loading its AWB, the awe_load* APIs will return E_MULTI_INSTANCE_SPLIT_AWB_NOT_STARTED. This error code is provided to help users synchronize sequential AWB loading across multiple instances. Users should check for this error code and try to load the AWB in a loop until success or different error code.
Following are some of the example use cases with 3 instances system where instance 0 is the audio master and instance 2 is a tuning master.
Case 1.
-> Split the 3 instances AWB into 3 parts, Inst0_AWB, Inst1_AWB and Inst2_AWB.
-> On instance 0,
awe_setInstanceStandaloneAWBLoad(&g_AWEInstance, 1); // Mandatory ret = awe_loadAWBfromArray(&g_AWEInstance, Inst0_AWB, Inst0_AWB_Len, &pos);
-> On instance 1,
while(1) { ret = awe_loadAWBfromArray(&g_AWEInstance, Inst1_AWB, Inst1_AWB_Len, &pos);
// If the previous instance not started, awe_loadAWBfromArray() returns E_MULTI_INSTANCE_SPLIT_AWB_NOT_STARTED error code. Call AWB loading function in a loop until error code is not E_MULTI_INSTANCE_SPLIT_AWB_NOT_STARTED. if (ret != E_MULTI_INSTANCE_SPLIT_AWB_NOT_STARTED) { break; } }
-> On instance 2 (tuning master), AWB can be loaded in standalone or regular AWB.
awe_setInstanceStandaloneAWBLoad(&g_AWEInstance, 1); // Optional
while(1) { ret = awe_loadAWBfromArray(&g_AWEInstance, Inst2_AWB, Inst2_AWB_Len, &pos);
Case 2.
-> Split the 3 instances AWB into 2 parts, Inst0_AWB and Inst1_2_AWB.
-> On instance 0,
-> On instance 1, no changes.
-> On instance 2 (tuning master), combined AWB for instance 1 and 2 must be loaded as regular AWB.
while(1) { ret = awe_loadAWBfromArray(&g_AWEInstance, Inst1_2_AWB, Inst1_2_AWB_Len, &pos);
Multi Canvas Guide
Multi Canvas Tuning Interface Setup
Basic Overview of Multi Canvas Integration Steps
Integrating a multi canvas AWE Core system can be broken into the following basic steps. This assumes that the integrator is able to implement a single instance tuning interface.
  1. Setup and initialize the multiple AWE Instances with appropriate instanceID’s.
  2. Setup a tuning interface and tell Server how many instances there are. Do this by generating a reply to the PFID_GetCores2 AWE command sent from AWE Server.
  3. Route the packets to the correct instance based on the packet’s instanceID prefix.
  4. Send the replies back to Server.
Detailed Multi-Canvas Integration Steps
  1. Allocate/initialize the multiple AWE Instances with their instanceIDs. The instanceID is stored in the high order 4 bits of an 8 bit word. Therefore the first instance must always be 0, and the following cores will increment by 16. IMPORTANT: InstanceID’s should always increment by 16. So the instanceID’s for a 2 instance system would be 0, 16. For a 3 instance system, 0, 16, 32. Etc...
  2. Declare an instance table array as a UINT32[numInstances], where the elements are the instanceID’s of the AWE instance’s that were just initialized.
    //the following instance table represents a two-instance system.
    UINT32 numInstances = 2;
    UINT32 instanceIDs[numInstances] = { 0, 16 };
  3. Implement a tuning interface to pass AWE commands between AWE Server and the target (See the Single Instance Tuning Interface Section).
  4. When multi canvas is to be supported, the BSP author will setup the tuning interface to listen for the AWE Command “PFID_GetCores2” (use the PACKET_OPCODE macro and the enum in ProxyIDs.h to determine this command). When this command is received, use the GenerateInstanceTableReply function in AWECoreUtils to generate a reply to the PFID_GetCores2 command. Send the instance table reply back to the Server over the tuning interface. Now AWE Server knows how many instances there are in the system, and can create a dropdown list of the instances in AWE Server and Designer.
if (opcode == PFID_GetCores2)
    GenerateInstanceTableReply(AWE_Packet_Buffer_Reply, numInstances, instanceIDs);
    writePacketToServer(AWE_Packet_Buffer_Reply);
  1. Implement a packet router. The tuning interface must be able to send/receive packets from all instances. The packet router will take a packet from the Server, strip off its instanceID (use the macro PACKET_INSTANCEID), and then route the command to the appropriate instance.
Multi Canvas Pseudocode Examples
The following pseudocode example is for a chip with two signal processing AWE Instances with the first AWE Instance providing the tuning interface.
TuningInterface()
    AWE_Packet_Buffer = receivePacketFromServer();
    if (PACKET_OPCODE(AWE_PACKET_BUFFER) == PFID_GetCores2)
        *AWE_Packet_Buffer = *GenerateInstanceTableReply(AWE_Packet_Buffer, numInstances, instanceIDs);
        writePacketToServer(AWE_Packet_Buffer);
    else if (PACKET_INSTANCEID(AWE_Packet_Buffer) == 0)
        awe_packetProcess(&AWEInstance0);
        writeReplyToServer();
    else if (PACKET_INSTANCEID(AWE_Packet_Buffer) == 16)
        sendToInstance16();
        //command is processed on instance 16
        readReplyFromInstance16();
Below is a pseudocode example of a multi-canvas tuning interface that is implemented on an MCU that has no knowledge of the AWE Core instances. The system has two AWE instances on separate processors, with IDs of 0 and 16.
TuningInterface()
    Tuning_PacketBuffer= receivePacketFromServer();
    if (PACKET_OPCODE(Tuning_PacketBuffer) == PFID_GetCores2)
        GenerateInstanceTableReply(Tuning_PacketBuffer, numInstances, instanceIDs);
        writePacketToServer(Tuning_PacketBuffer);
    else if (PACKET_INSTANCEID(Tuning_PacketBuffer) == 0)
        sendPacketToInstance0(Tuning_PacketBuffer);
        //Instance 1 gets packet and calls awe_packetProcess
        receiveReplyPacketFromInstance0();
        sendPacketToInstance16();
        //Instance 16 gets packet and calls awe_packetProcess
        receivePacketFromInstance16();
Latency
Overview of Latency in AWE Core
This section discusses only the latency caused by the AWE Core framework. The signal processing flow, the firmware, and the hardware can all introduce additional latency to the overall system. In this discussion, a "block" of latency refers to the layout block size and the systems sample rate. For example, with a layout block size of 256 and a sample rate of 48 kHz, the latency through the AWE Core system will be in multiples of blocks of (256 / 48000) = 5.33 ms. AWECore can introduce up to 2 block’s of latency, but can also be configured to achieve 0 blocks of latency under certain conditions.
There are 3 possible latency situations introduced by the AWECore library
  • 2 blocks of latency
  • 1 block of latency
  • 0 blocks of latency
Which of the three latency paths will be taken depends on some conditions in the implementation of the AWECore API, and the relationship between the system and the signal processing layout.
Note: The following abbreviations may be used for these AWECore API calls:
Conditions that Impact Latency
To achieve 0 blocks of AWE-induced latency, the following three conditions must be met:
  1. Equivalent Block Sizes: The loaded layout’s blocksize must be equivalent to the AWECore instance’s fundamental blocksize.
  2. Order of audio API calls: The order of AWECore audio processing API calls in the BSP’s audio callback must be import -> pump -> export, as in the following: awe_audioImportSamples() -> awe_audioGetPumpMask() && awe_audioPump() -> awe_audioExportSamples
  3. awe_audioPump() Inline with DMA callback: The awe_audioPump() API for layout index 0 must be called inline with the BSP’s audio callback, as opposed to signaling another thread or raising an interrupt.
latency-table
Equivalent Block Sizes – Double Buffering
AWE Core has an internal double buffering scheme on the input and output pins to handle situations where a layout’s blocksize is a multiple of the AWEInstance’s fundamental blocksize. For example, a system with a 64 BS layout running on a 32 fundamental BS AWEInstance must complete two, 32-sample audio callbacks before actually pumping audio through the layout (to satisfy the 64 samples). Double buffering is used in this situation in order to store the next frames of data in one buffer, while the processing occurs on the data in the other buffer. Two blocks of latency are introduced by this double buffering of the input and output pins.
However, in a situation where a layout BS is the same as a fundamental BS, the double buffering scheme is not required and two blocks of latency can be avoided. AWECore has an internal mechanism to check if the layout and fundamental blocksizes are equivalent at layout runtime, and will automatically bypass the double buffering to eliminate the introduced latency. Less memory is also consumed under this condition as only a single buffer can be used at the input and output pins.
Order of AWECore API Calls – Import Pump Export
At a very high level, 0 blocks of latency can only fundamentally be achieved if all of the audio processing occurs in a single callback. Based on this, the audio processing function must implement the following order of API calls to achieve the lowest possible latency: awe_audioImportSamples() awe_audioGetPumpMask() && awe_audioPump() (can be a signal to lower priority threads to do actual pumping) awe_audioExportSamples()
Different orders of API calls will still operate correctly from a processing standpoint, but may not achieve the lowest possible latency.
Pump Inline with Callback – Pump Context
Virtually all systems that integrate the AWE Core will use a thread signaling or interrupt raising scheme to trigger awe_audioPump in separate, lower priority contexts from the main DMA audio callback. While this scheme is required in order to allow for efficient, multi-rate operation of signal processing layouts, it does mean that the processing of the audio signal will not be complete by the end of the audio callback, As mentioned in the section above, a system with 0 blocks of AWECore induced latency must complete all audio processing within the context of the main DMA audio callback. So in order to achieve minimal latency, the first sublayout (layout index 0) must be executed in place during the audio callback, not in a lower priority context.
The first sublayout consumes the input pin and fills the output pin, so it is only this layout that needs to be processed in place. Other non low latency paths (clockdivided sublayouts, layout index > 0) should still be signaled by the callback and pumped in another context.
Troubleshooting and Common Pitfalls
There are a few common pitfalls when BSP authors are integrating AWE Core. The most common problems are scheduling issues, specifically when the audio thread is not at a high enough priority and is preempted by the packet or deferred processing. RT audio needs to be running at a very high priority, just below the Tuning Interface IO thread.
